First Ontario Snow 2025: What's the Outlook?
Every year, as winter approaches, forecasters and meteorologists work to update their weather predictions, giving you time to prepare for the season. Long-range forecasts are hard to provide far in advance. Still, a general idea about the snow, temperature, and average weather conditions can be predicted.
Keep reading to learn more about the approaching fall-to-winter transition, what meteorologists have predicted for winter in Ontario, and how you can prepare your home for the future cold temperatures as fall sets in.
Assessing Ontario's Seasonal Shift: Cooler Days Signal Summer's End
The “ber” months, September, October, and November, have begun, signalling the start of autumn and the transition to winter. You may have noticed an increase in cold snaps and the leaves changing colour. However, like most of the country, you might have missed the official season change.
Countdown to Autumn
While autumn officially began on September 21, 2025, many Canadians likely didn't realize the date. The country has experienced above-average temperatures at the start of fall, which have persisted into October. A warm jet stream from the south has kept cold snaps to a minimum this season, letting warmer temperatures prevail. However, once the warm jet stream transitions, the winter cold will begin.
Prepare for Weather Shifts: Energy Readiness as Fall Sets In
The transition seasons are a great time to prepare your home for the upcoming, more intense season: summer or winter. As you enjoy the mild temperatures, fall festivities, and beautiful colour changes across the province, take the opportunity to update your home’s energy readiness while keeping an eye on the upcoming winter season.
While predictions and forecasts are still being refined, here’s a list of ways to prepare your home for this season and the next:
Insulating your home: The best way to securely insulate the house is to upgrade the insulation. Reinsulating the entire home can be quite the undertaking. At a minimum, ensure the attic is well insulated to prevent heat loss through the roof. Insulate the windows and doors. Check that they close tightly; if not, seal them with foam or use another method to stop the leak.
Backup power preparedness: Canadians are no strangers to severe winter storms. It’s not surprising to lose power in the winter, either due to weather damage to the lines or strain on the grid from increased use. Outages during the coldest months will quickly turn deadly if you're unprepared. Whole-home backup power stations by EcoFlow keep your home safe and comfortable. Systems with solar panels stay charged and quickly recharge directly from the sun.
Prepare the plumbing: While insulating your home, don’t forget the pipes. An older system may require an insulation upgrade to prevent pipes from freezing or bursting. Plumping systems won't have a reprieve during blizzard conditions.
Heating Systems and Safety: Service your central heating system annually. If you haven't done it yet this year, do it during this season. Space heaters are a great addition, but be aware of what is placed on top of them to avoid fires. Allow the space heater 3 feet of clearance and avoid using extension cords to plug it in.
Stay alert: Check that you receive mobile weather updates. Weather radios and other alert systems should be installed and set up before severe weather begins. Weather alerts and updates are lifesaving. Use an EcoFlow RAPID Pro-X Power Bank to keep your phone and other electronics charged, allowing you to receive alerts.
Exploring Regional Variations Across Ontario
After the warm jet streams end during November, so will the warmer-than-average temperatures. When it does, Ontario is expected to experience colder-than-average temperatures. Here’s a regional breakdown of what to expect in Ontario this winter.
Northern Ontario
All of Northern Ontario will be impacted by the jet stream across Canada. The jet stream will bring colder and wetter-than-normal conditions. The western half of the region is expected to experience more extreme winter conditions than the eastern half. Still, both areas should take the time now to prepare. Build your energy readiness before the power goes out with an EcoFlow DELTA 3 Classic portable power station. Keep this station charged and ready so you can charge cellphones, laptops, tablets, and other devices in a power outage.
Southern Ontario
The far eastern areas of Southern Ontario will experience colder temperatures. Still, the further you move from the jet stream’s direct path, the warmer and milder the temperatures will be. Keep in mind that a mild winter prediction for Canada does not necessarily mean tropical conditions. Cold snaps, snow, and other typical winter weather conditions will still occur.
Where Is the Snowiest Place in Ontario?
The snowiest place in Ontario is Owen Sound. This city receives 330.4 cm of snow every year, beating the second snowiest place by about 10 cm. Owen Sound has the best snowmobile loops in the province. If you’re visiting this town, the hiking trails are a must-do activity.
Why Is Ontario Getting So Much Snow?
The snow in Ontario is often lake-effect snow. Cold air from the west passes over warm air from the Great Lakes. Excess moisture from the warm air mass, combined with the freezing temperatures from the other leads, leads to heavy snowfall. This winter, heavy snowfall will likely come from storm systems converging from the south.
Ontario’s Winter Brings Chilly Temperatures
The warmer temperatures through September and October have made fall festivities more enjoyable, but it will come to an end. Mild cold snaps have been a steady reminder of the approaching winter. As the jet stream transitions, a sudden shift to typical winter weather is expected in November.
With time still left before winter sets in, take the opportunity to prepare your home for the harsh conditions. Upgrade your energy readiness with EcoFlow. Portable power stations, such as the EcoFlow DELTA 3 Classic, will bring safety, comfort, and energy resilience to your home from one season to the next.
