Winter 2025: Will It Come Early This Year?
As we head into the winter season, long-range forecasts predict that some areas of the U.S. may see their first snow earlier than expected. No matter what part of the country you’re in, it’s a good idea to prepare for this winter season ahead of time.
Keep reading to learn what weather aspects are shaping the winter forecast, a breakdown of regional snow pattern predictions, and what you should do now to prepare for the upcoming season.
What Will Shape the Winter 2025 Forecast
Currently, a weak La Niña event is strongly expected to influence winter 2025, lasting until the peak winter months before returning to an ENSO-neutral phase. The La Niña phase is characterized by below-average temperatures in the Pacific Ocean, which influence the jet stream, causing it to shift further north. This La Niña cycle is expected to last until February 2025.
The Arctic Oscillation, the pressure pattern of the Arctic that influences the polar jet stream, is negative this season. This means that there is a weak polar vortex, allowing cold air masses from the Arctic to move south. Cold snaps will be frequent in the Central and Eastern U.S.
Regional Snow Patterns: Northwest, Northeast, Midwest, and West
The Northwest is expected to experience above-average precipitation and below-average temperatures. Overall, those in the Northwest should be prepared for a colder, wetter, and active storm track.
On the opposite side of the country, the Northeast has a high probability for intense winter storms and nor’easters, especially towards the end of winter. Above-average precipitation and average temperatures are forecasted.
States in the Southwest and Southern Rockies can expect precipitation to be below average, while temperatures are expected to be above average. A warmer and drier winter than normal is predicted, which could worsen already significant drought conditions.
From all the regions, the Midwest and Great Plains are expected to experience the most significant impacts from snow and frequent cold outbreaks. Above-average precipitation and below-average temperatures are expected to contribute to a harsh winter season with a high risk for power outages.
February-March Transitions: Thaws, Warmer West, and End of East Season
While the start of winter will be cold, many forecasters predict a brief thaw in January. Milder temperatures will briefly cover the interior U.S., melting some of the snow. For skiers in the East and Midwest, the snowpack could melt earlier than expected.
In February, warmer temperatures are expected to spread across the West as a result of the weakening La Niña. Expect a faster snow melt and reduced snowfall. Higher-elevation ski resorts might hold up better than mid- and lower-elevation ones.
Come March, the Eastern U.S. could see an early end to its ski season. Warmer temperatures in January, February, and into March will soften the snow pack. Resorts relying on natural snow will likely see an early wrap-up to the season.
How to Prepare for Winter 2025
Plan for Power Outages: Unexpected outages happen all the time. Everyone will have their home heat turned on at the start of winter, which could strain the power systems, leading to blackouts. Whole-home backup power solutions can keep heat flowing to your home even when the grid is down.
Winterize Your Home: Ensure your home’s insulation is in good condition. Check your windows and doors' sealant, service your heating system, and insulate your pipes.
Stay Weather Aware: Follow long-range forecasts and storm alerts to plan ahead for heavy snow, especially if you’re in the northern part of the country. Use a charged EcoFlow DELTA 3 Ultra Plus to power weather radios, recharge cell phones, and other small electronics in case of a power loss during the snowstorm.
Protect Your Outdoor Plans: If you’ve been waiting all year for snow-related activities, such as skiing, consider updating your vacation plans to account for the potential early end to the season. Don’t wait until the last minute; it might be too late to change dates or cancel.
Leverage Renewable Energy: Pair your portable power stations or other home electronics with solar panels. Recharge batteries during daylight hours sustainably and keep appliances running off renewable energy. This winter, you’ll see reduced utility bills as rates typically increase during harsher temperature conditions.
Will Winter 2025 Be Colder Than Average?
It depends on what area of the U.S. you’re in. The Midwest, Northeast, and Pacific Northwest are expected to experience below-average temperatures. States in the southern part of the country will see warmer temperatures. So, yes, for some regions, this winter season will be colder than average.
When Will the First Major Snowfall Happen in 2025?
The exact time of the first snowfall is difficult to predict, as it depends greatly on the region. The first snowfall could happen in the Northern Rockies by October. The Great Lakes and Northeast could see snow as early as November. Snowfall in the South will be delayed due to the warmer temperatures.
How Does El Niño Affect Winter Weather in 2025?
This winter, we are currently leaning towards a weak La Niña, which is a distinct phase in the ENSO cycle compared to El Niño. Winter conditions this year will be dominated by a La Niña, resulting in a colder and wetter winter for the north and a drier and warmer winter for the South.
What Are the Best Ways to Prepare for Winter Power Outages?
In the winter, backup power is life-saving. Generators and portable power stations are essential to staying safe during cold temperatures. For extended power outages, use these systems to power heat sources. Take time to prepare your home by checking insulation and emergency kits.
Get Ready for Winter 2025 with EcoFlow Portable Power Stations
The upcoming winter season is expected to bring heavy snow and cold temperatures to the northern half of the U.S.. At the same time, the South is forecasted to experience warmer and drier conditions. This is typical of a La Niña system, which is predicted to transition to an ESNO-neutral state in early spring.
Prepare for the upcoming season before the cold weather arrives. Check your home for proper insulation and ensure you have an updated emergency kit. Have an EcoFlow DELTA 3 Ultra Plus on hand, charged, and ready to keep you powered during any winter weather outage.
