What Can I Run With the EcoFlow DELTA Pro Ultra?
Until recently, owning a whole home backup or standby generator powerful enough to keep all your appliances and HVAC systems running during a blackout meant buying a massive fossil fuel-powered system and installing it a safe distance from your house.
Not anymore.
EcoFlow’s DELTA Pro Ultra provides more than enough electricity to run your entire home — even during extended power outages.
Whether you opt for clean, renewable solar energy to keep  EcoFlow DELTA Pro charged and ready — or any of the other five charging options — this hybrid generator can power every appliance and system in your home.
Just how much electricity can EcoFlow DELTA Pro Ultra provide?
And for how long?
Read on to find out.
What Is EcoFlow’s DELTA Pro Ultra?
EcoFlow DELTA Pro Ultra is a whole home backup generator and hybrid solar power solution that can operate a house full of appliances for extended periods, depending on your system configuration and energy usage.
It’s the latest and most powerful solar generator in EcoFlow’s award-winning DELTA series.
EcoFlow DELTA Pro Ultra’s modular design gives you the option of expanding from 6kWh of solar battery storage to 90kWh and from 7.2 kW of output to 21.6kW by connecting 3 x DELTA Pro Ultra inverters.
With the option to connect up to 42 x EcoFlow 400W rigid solar panels, you could dramatically cut your electricity bills.
And because it’s a hybrid solar system that provides solar + storage, it offers home energy security even during extended blackouts.
Traditional on-grid solar panel systems DO NOT WORK during power outages.
How Does the EcoFlow DELTA Pro Ultra Work?
Like all commercially available residential solar panel systems, EcoFlow DELTA Pro Ultra uses solar panels comprised of solar cells to harness sunlight and convert photons into direct current electricity using the photovoltaic effect.
DC electricity is transmitted to the DELTA Pro Ultra Inverter for immediate consumption or stored in the DELTA Pro Ultra Home Backup Battery (LFP) for later use.
Unlike off-grid systems like EcoFlow DELTA Pro, EcoFlow DELTA Pro Ultra connects to the utility grid through Smart Home Panel 2 or a transfer switch for seamless backup power.
With grid connectivity, EcoFlow DELTA Pro Ultra offers an uninterruptible power supply during a blackout.
Depending on how many solar panels and 6kWh LiFePO4 batteries you add to your setup, you could use grid power strategically during off-peak hours to reduce electricity costs.
What Are the Benefits of Using the EcoFlow DELTA Pro Ultra?
EcoFlow DELTA Pro Ultra is an affordable hybrid solar power solution that offers numerous benefits.
Here are the highlights.
Modular Storage Capacity
Starting at 6kWh of storage capacity, the EcoFlow DELTA Pro Ultra is expandable up to 90kWh with up to 15 x 6kWh LFP batteries.
Thanks to EcoFlow DELTA Pro Ultra’s unique modular design, you can keep adding batteries as your budget allows or your family’s needs grow.
For context, the average US home consumes about 10,500kWh of electricity per year or 29kWh a day.
5 x fully charged EcoFlow DELTA Pro Ultra 6kWh Home Backup Batteries will provide enough electricity to run the average home for 24 hours without any power generated by solar panels or drawn from the utility grid. This is based on average US home consumption; actual runtimes may vary.
Whole Home AC Output
Depending on your chosen configuration, EcoFlow DELTA Pro Ultra offers three levels of continuous AC output: 7.2kW, 14.4kW, or 21.6kW.
Each EcoFlow DELTA Pro Ultra Inverter also offers additional starting wattage (surge power) to get high-wattage motor-driven appliances like HVAC systems, refrigerators, washing machines, and dryers up and running.
For many single-family homes and apartments, one inverter with 7.2kW of AC output (10.8kW surge power) is all you’ll need.
No matter what type of generator or home backup system you purchase, it’s essential to determine how much simultaneous AC output you need.
Learn how to calculate your household electricity consumption here.
EcoFlow DELTA Pro Series
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
Long-lasting Lithium Iron Phosphate (LFP) Batteries
Off-grid and hybrid photovoltaic systems require solar batteries to function.
Solar power is intermittent by nature…
PV panels don’t work at night, and electricity production diminishes on cloudy days.
Unless you have a traditional grid-tied system, you need solar batteries to store electricity for times when your household consumption exceeds the amount of electricity your PV modules produce.
There are many different types of solar batteries.
The primary factor that sets them apart is battery chemistry.
Lead-acid solar batteries tend to be the cheapest, but they also have the shortest lifespan, the lowest depth of discharge, and require considerable upkeep.
Traditional lithium-ion solar batteries are a popular choice, but they offer less efficiency and shorter cycle life than newer technologies like lithium iron phosphate (LiFePO4/LFP) rechargeable battery chemistry.
Along with offering peak performance, EcoFlow DELTA Pro Ultra LFP batteries have significant ethical advantages over standard Li-ion chemistry.
No cobalt is required for EcoFlow’s industry-leading LFP solar batteries.
Over 70% of the world’s cobalt is mined under extremely inhuman conditions in the Democratic Republic of Congo — often by pregnant women and children.
The situation is so dire that this metal required for traditional Li-ion batteries is often called blood cobalt.
In addition to being free of conflict metals like cobalt, LFP batteries offer numerous performance advantages, including:
  • Greater depth of discharge
  • Extended cycle life (3000 Cycles to +/-80% Capacity)
  • Wide range of operating temperatures: -4℉ to 113℉
  • IP54 dustproof and splashproof
Energy Independence and Security
EcoFlow DELTA Pro Ultra is a true hybrid solar solution.
With the option to connect up to 42 x EcoFlow 400W rigid solar panels, you could potentially live entirely off-grid…
With the right configuration, solar panels can meaningfully supplement your home’s electricity needs during daylight hours.
Or you can combine utility power with solar to slash your electricity bills by only using grid power during off-peak billing hours.
EcoFlow DELTA Pro Ultra’s charging capabilities don’t stop with grid power and solar.
All in all, you’ve got five options to keep your home backup generator charged and ready for any emergency, including:
  • Fossil fuel generator
  • Electric Vehicle charging pile
  • Solar panels
  • On-grid electricity
  • MultiCharge (Combined grid and solar power)
Whether your goal is to never go without power in a blackout or to achieve true personal energy independence, there’s an EcoFlow DELTA Pro Ultra setup to meet your needs.
(Source: EPA)
Clean, Renewable Electricity
Many people don’t know this, but burning fossil fuels to produce electricity is second only to the transportation sector in spewing the most CO2, methane, and other harmful greenhouse gases, carbon emissions, and particulate pollution into our atmosphere.
As extreme weather events increase due to global warming and climate change, governments worldwide seek to incentivize individuals and small businesses to generate electricity with renewable resources like wind and solar power.
Whether you choose to switch all or part of your home electricity consumption from utility grid to renewable solar power, you’ll be taking a meaningful step towards reducing your family’s carbon footprint and helping to ensure a better future.
What Can You Power With the EcoFlow DELTA Pro Ultra?
A better question might be, what CAN’T you power with EcoFlow DELTA Pro Ultra?
The base model provides 7.2kW (10.8kW surge power) out of the box and is expandable to 14.4kW or 21.6kW of continuous AC output with 2 or 3 inverters.
EcoFlow DELTA Pro Ultra starts with 6kWh of storage and is expandable up to 90kWh in 6kWh increments — enough electricity to run the average home for a month off-grid.
1 x EcoFlow DELTA Pro Ultra + Smart Home Panel 2 (AC Output: 7,200W/30A)
Device or Appliance
Average Wattage
Light
10W
Television
110W
Washing Machine
1000W
Microwave Oven
1000W
Refrigerator
300W
Central AC
(3 Tons/3.6kW)
Total
7,200W
2 x EcoFlow DELTA Pro Ultra + Smart Home Panel 2 (AC Output: 14,400W/60A)
Device or Appliance
Average Wattage
Light
10W
Television
110W
Washing Machine
1000W
Refrigerator
300W
Central AC
(3 Tons/3.6kW)
Electric Oven
4kW
Dishwasher
1.3kW
Induction Cooker
3kW
Total
15,500W
3 x EcoFlow DELTA Pro Ultra + Smart Home Panel 2 (AC Output: 21,600W/90A)
Device or Appliance
Average Wattage
Light
10W
Television
110W
Washing Machine
1000W
Refrigerator
300W
Central AC
(3 Tons/3.6kW)
Electric Oven
4kW
Dishwasher
1.3kW
Induction Cooker
3kW
Electric Car
6kW
Coffee Maker
1.5kW
Total
20,820W
How Much Does the EcoFlow DELTA Pro Ultra Cost?
Thanks to its modular design, EcoFlow DELTA Pro Ultra is highly customizable, and the cost will vary significantly based on your chosen configuration.
The table below shows three popular configurations and their current direct-from-manufacturer retail cost.
EcoFlow DELTA Pro Ultra + Solar Panels Configuration 1
Component
Quantity
AC Output or Rated Power
Storage Capacity
Price Per Unit
Combined Cost
EcoFlow DELTA Pro Ultra (Inverter + Battery)
1
7.2kW (10.8kW Surge)
6kWh
$5,799
$5,799
4
1,600W
N/A
$999
$3,996
Total
6kWh
$9,795
EcoFlow DELTA Pro Ultra + Solar Panels Configuration 2
Component
Quantity
Storage Capacity
Price Per Unit
Combined Cost
2
14.4kW (21.6kW Surge)
12kWh
$5,799
$11,598
EcoFlow DELTA Pro Ultra Home Backup Battery
2
N/A
12kWh
$2,999
$5,998
EcoFlow 400W Rigid Solar Panel
12
4,800W
N/A
$499.50
$5,994
Total
24kWh
$23,590
EcoFlow DELTA Pro Ultra + EcoFlow Smart Home Panel 2 + Solar Panels Configuration 3
Configuration 2
Quantity
Storage Capacity
Price Per Unit
Combined Cost
3
21.6kW (32.4kW Surge)
18kWh
$5,799
$17,397
1
N/A
N/A
$1,899
$1,899
12
N/A
72kWh
$2,999
$35,988
42
16,800W
N/A
$499.50
$20,979
Total
90kWh
$76,263
Please note. All prices are current as of April 2024 directly from EcoFlow and are subject to change. Some items may be bundled together for additional savings. Check the website for details.
As you can see, the more electricity your residential solar power system produces, the higher the cost — but so are the potential savings.
The sooner you achieve solar payback, the faster your system pays for itself through energy savings.
After all, a dollar saved on electricity bills is a dollar earned.
Thanks in part to government incentives — like the 30% Federal Solar Tax credit — the potential return on investment from residential solar power has never been greater.
There’s no limit on how much you can save — or how many times you can apply!
For example, if you purchase or finance EcoFlow DELTA Pro Ultra configuration #3 from the table above, you could save over $25,000 in income tax liability against equipment and installation costs.
Even if you opt for low-to-no-interest financing directly from EcoFlow and pay off the system over time, it shouldn’t affect your eligibility for 30% off of your total costs from the Residential Clean Energy Credit.
Only new systems are eligible and must be financed or bought outright — not rented or leased.
On top of the 30% federal tax credit, there may be numerous state tax and power company, local, and state tax incentives for switching to solar, depending on where you live.
Undoubtedly, the initial investment in renewable energy for your home can be steep…
But it will more than pay off in the long run.
The days of relying on massive, noisy fossil fuel generators that produce toxic emissions to ensure your family’s energy security during a power outage are over.
Not only will EcoFlow DELTA Pro Ultra keep your appliances and HVAC systems running during extended blackouts, but it can also significantly reduce your reliance on the utility grid and lower your electricity bills.
No matter what your off-grid or hybrid power needs are, check out EcoFlow’s award-winning solutions today and take the first step toward energy independence.
Portable Power Stations
