EcoFlow Integrated Tech Architecture System
At the Industry Forefront of Proprietary Home Power Technology. Imbuing Your Home Power with Superior Safety Standards, Performance, and Intelligence.
In tune with the global trend towards smart, clean energy, and to accelerate its implementation into home energy, EcoFlow is breaking new ground with X-Core 3.0.
X-Core 3.0 ensures safety is the foundation of home energy, while continuously pushing the boundaries of performance to deliver an unparalleled experience and seamless control within the EcoFlow smart ecosystem. Futuristic home energy is right at your fingertips.
.png)
A Huge Leap in Power Performance
Experience unparalleled 50-minute charging speeds and effortlessly power high-demand appliances while you enjoy the peace and comfort of a fully-powered home.
Industry's Fastest Charging
Recharge quickly, so you're ready for the unexpected anytime
180%
*Based on EcoFlow DELTA Pro 3 data
Charging 0-80% Compared to the Industry Average
Average industry charge time to 80%
90 MinEcoFlow X-Stream charge time to 80%
50 Min
First Soft-Start Technology in the Industry
Run almost every appliance around the home
Up to
Supports
The First Parallel-Expanding System
Increase capacity and power output
21.6kW
Output Power90kWh
Energy Storage* Using DELTA Pro Ultra
21.6kW
Output Power90kWh
Energy StorageEcoFlow-Developed Volume Minimizing System
Industry's lowest running volume of only 30 dB*
*Under 2000W output
Quiet Performance Compared to Industry Standard and Gas Generators
Lowest Gas Generator Volume
70 dBIndustry Average
60 dBEcoFlow
30 dB
Groundbreaking Accelerated Charging and Performance
Powering high - wattage appliances beyond AC limits
4000W
DELTA Pro 37000W
DELTA Pro Ultra
Navigate Power with Intelligence
With our advanced algorithms, we've pioneered how we synchronize and manage data from multiple platforms, including third-party and EcoFlow systems, ensuring an effortless user experience right at your fingertips.
Oasis
Smart, Seamless, & Safe Home Power Management
.png)
Multiple Devices, Unified Control
All our EcoFlow products are connected across the ether, from energy generation and storage to distribution and usage. By using a smart algorithm to analyze your energy usage across all your appliances, your system will choose the best power cycle solution for your home.
Seamless Cross-Platform Management
View all your real-time data with a tap of a button from your smartphone, wall-mounted monitor, or from your web browser. Check on all your devices, and optimize your energy usage based on the stats.
.png)
Collaborative Connections
EcoFlow ecosystem links to and manages third-party protocols, such as Matter and Shelly, connecting to multiple smart devices across your home in order to improve whole-home smart living and streamline energy use.
.jpg)
Saves Money and Stress
Connecting with local power grid price data, the smart EcoFlow system intuitively calculates the best way to charge and use power in real time. With Storm Mode, the system automatically prepares in advance to ensure normal power during an outage.
Elevating Safety Standards
We develop every product, from the cell level, with protection inside and out, to achieve and maintain the highest battery and material safety standards. We've integrated CTC structure into our batteries, as well as offering a 24/7 protection algorithm. Both industry breakthroughs.
Industry-Leading Home Power Safety Integrated with Hardware & Software
A protective triad: Structure, Material & Algorithm
High-Temperature Resistant Materials
UL Certificated 5VA-Grade and Self-Extinguishing
Even in the unlikely chance of a fire, the battery is designed to automatically extinguish itself within 30 seconds. So, there's no risk of a fire spreading even in high temperatures.
Industry-First IP65 Battery pack
Generates Less Heat & Prevents Water Access
Experience a safer battery with automotive-grade LFP cells. Achieving the highest possible UL9540 and UL9540A standards, it's designed to keep out water, even from low-pressure water jets.
Industry's First CTC Design
Accelerated Strength, Security & Impact Resistance
With a Cell-to-Chassis structure, the battery and internal makeup are fully integrated, improving its strength, and making it more secure and resilient during an impact.
.jpg)
Industry-Leading Algorithm
On Guard 24/7
Using an intelligent formula, safety is monitored in real-time, as well as using cloud data to predict risks. If a fault is discovered, you'll be notified immediately.
.jpg)
On Guard 24/7
Explore Our Hero Products Featuring X-Core 3.0.
![[object Object], Use your gas generators to refuel EcoFlow DELTA Pro 3 with up to 4000W using
X-Stream. Harness 3.2kWh in only 50 min, ensuring you have access to reliable power whenever outages hit.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718951269229/2.jpg)
![[object Object], Utilize an EV charger using
X-Stream to achieve an impressive 4000W input, ensuring plenty of power when you're on the road.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718700911597/2-1.jpg)
![[object Object], Take advantage of the state-of-the-art Smart Home Panel 2 to charge up to 4000W with X-Stream and control 12 home electrical circuits at the same time.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718700979184/3.jpg)
![[object Object],
A single unit can run specific appliances with up to 6000W, including central A/C, clothes dryers, and EV car chargers. That's 2000W more than DELTA Pro 3's rated output.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1719219373186/4.jpg)
![[object Object], You can multiply capacity by connecting different EcoFlow product lines, such as pairing EcoFlow DELTA Pro 3 with EcoFlow DELTA Pro Ultra. Plus, your gas generators and EcoFlow smart generators work well with EcoFlow battery generators using X-Link tech.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718701262269/5.jpg)
![[object Object], Experience ultimate whole-home output effortlessly when you connect EcoFlow battery generator units with the EcoFlow Smart Home Panel series in seconds. Expand output flexibly as needed, reaching 7200W, 14.4KW, and 21.6KW with the EcoFlow DELTA Pro Ultra.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1719219237764/6.jpg)
![[object Object], Ensures a constant power supply at home without disturbing your family. Sleep peacefully while your power runs constantly in the background.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718701473342/2.jpg)
![[object Object], Even if you need to work through the night, you can power through undisturbed. Stay productive even during an outage.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718701487555/8.jpg)
![[object Object], Use without affecting neighbors or head outdoors without disturbing nature or leaving behind a heavy carbon footprint.](https://ecoflow-service-us-cdn.ecoflow.com/upload/image/1718701501894/9.jpg)
.png)
.png)
