Solar Panel Snow Removal: When to Clear Snow, How to Do It From the Ground, and How to Keep It Off
Snow-covered solar panels can look like a problem, but you usually don't need to clear them right away. Snow often slides off tilted panels or melts when the sun returns. The biggest concern is heavy snow that stays put and blocks sunlight for several days.
The impact also depends on where you live. A federal laboratory study estimated annual snow-related energy losses near zero in Phoenix and around 15% in International Falls, Minnesota. This guide explains when solar panel snow removal makes sense, how to clear panels safely from the ground, and which tools to avoid. You'll also learn how to prepare your array for winter and store daytime solar power for evening use.
Snow on Solar Panels: How Much Output You Lose and When It's Worth Clearing
A light dusting usually has little effect on solar production. Heavy snow is different because it can block sunlight almost completely until the snow melts or slides away. Your annual energy loss depends on local weather, panel tilt, and how long snow stays on the array.
What Federal Labs Say About Winter Solar Loss
The Department of Energy Office of Energy Efficiency and Renewable Energy analyzed winter solar performance in January 2017 (archived DOE page, captured December 1, 2025). Their report notes that wind easily clears light snow. However, heavy snow blocks sunlight completely. As DOE researchers noted:
"It's a different story when heavy snow accumulates, which prevents PV panels from generating power."
The good news is that arrays bounce back fast. Once snow slides off, power production resumes immediately. Furthermore, melting snow actually cleans dust and grime off the front glass.
In August 2017, the National Renewable Energy Laboratory published a landmark solar study (Ryberg and Freeman, NREL/TP-6A20-68705). NREL was renamed the National Laboratory of the Rockies in December 2025. The researchers modeled average annual energy lost to snow across 239 US locations. They found the highest losses "beginning in the Northeast, spanning the Great Lakes," and reaching into the Midwest and northern Rockies.
These numbers reflect modeled averages for two sample fixed-tilt setups, not a guarantee for your roof:
Location
Panels tilted 20°
Panels tilted at latitude
International Falls, MN
15.90%
15.50%
Duluth, MN
15.10%
13.90%
Minneapolis, MN
10.70%
9.50%
Chicago, IL
6.10%
5.20%
Boulder, CO
5.50%
3.90%
Boston, MA
2.80%
1.90%
Phoenix, AZ
0.00%
0.00%
Sandia National Laboratories confirms this pattern in its photovoltaic performance research. Sandia notes that published estimates of annual energy loss range from 1% to 12%. However, severe winter storms can cause monthly losses as high as 100%. A rough week can zero out production, but yearly losses remain modest across most states.
Deciding When to Wait and When to Clear
You do not need to head outside after every flurry. Use these rules of thumb:
  • Wait it out: The snow is light, powdery, or already sliding off steep panels. Clear days or above-freezing temperatures in the immediate forecast will finish the job.
  • Consider clearing: A heavy layer has buried the glass for days without moving. Your monitoring app shows zero watts, and you can reach the panels from the ground.
  • Never clear: The panels sit high on a roof or require standing on a ladder.
Arrays can still generate power on overcast winter afternoons. Learning how weather affects solar panel output explains why patchy snow lets light through while dense drifts block it entirely. If heavy snow lingers and your array is accessible from ground level, use safe methods that protect both you and the equipment.
How to Remove Snow From Solar Panels Safely From the Ground
Solar panel snow removal should be a ground-level job. The Occupational Safety and Health Administration (OSHA) recommends avoiding roofs whenever possible during snow removal. Panel manufacturers also advise using soft tools and avoiding excessive force.
How to remove snow from solar panelsHow to remove snow from solar panels
Clear only what you can reach comfortably from the ground. If you encounter ice, stop and let it melt.
What You'll Need
  • A roof rake or snow broom with a soft foam head or soft bristles.
  • A long, telescoping, nonmetallic pole.
  • Boots with good traction.
  • A clear standing area away from falling snow.
Qcells recommends removing snow and ice carefully with a very soft broom. Canadian Solar also recommends a soft brush.
Steps for Removing Snow From Solar Panels
  1. Check the weather and monitoring app. If sunshine is coming soon, waiting may be the easiest option.
  2. Look for overhead power lines. Keep the pole well away from electrical service lines and other overhead hazards.
  3. Stand to the side of the array. Never stand directly below the panel edge or roof eave, where snow could fall suddenly.
  4. Pull snow down gently. Work in small sections with light strokes. Let gravity do the work instead of pressing the tool against the glass.
  5. Leave a thin layer if necessary. Don't scrape the surface to remove every last bit of snow.
  6. Stop when you reach ice. Never chip, hammer, or pry frozen snow away from the panel frame.
  7. Use the same care with ground-mounted panels. Work from the front edge without leaning on or standing on the modules.
Don't use a snow rake or shovel while standing on a ladder. OSHA also warns that falling snow, hidden roof features, and overhead electrical lines can create serious hazards.
When to Call a Professional
Call a certified solar contractor if your array sits out of ground reach. You should also call a pro if thick ice dams form along the bottom rail. Professional crews use certified fall arrest harnesses and follow OSHA standards.
Snow management is just one part of routine seasonal care. Knowing how often to clean solar panels keeps dust, pollen, and debris from reducing your energy harvest during spring and summer.
Once panels are clear, winter days present another hurdle. Short daylight hours concentrate production into a brief midday window, while household electricity demands spike after dark.
Storing Winter Sun for the Evening: EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus
A home battery can't remove snow or replace the electricity your panels missed while covered. But it can store energy generated during sunny winter hours for use after sunset. The right system depends on your solar array's wiring, voltage, and current limits, not simply its advertised kilowatt rating.
Matching Battery Inputs to Your Solar Array
Solar strings operate within distinct electrical boundaries. The EcoFlow US TITAN specifications detail these differences clearly. EcoFlow TITAN 5000 features a single solar input supporting up to 4,000W with a 40V to 450V operating range at 16A via one MPPT controller. EcoFlow TITAN 5000 Plus provides 8kW of total solar capacity split across two independent 4kW MPPT inputs, each accepting 40V to 450V at 16A.
A single solar string that stays inside 450V and 16A pairs naturally with EcoFlow TITAN 5000. Larger arrays requiring two strings or up to 8kW total capacity require EcoFlow TITAN 5000 Plus. A generic label like "6kW system" does not provide enough technical detail.
Your electrician must calculate open-circuit voltage for extreme winter temperatures. Cold air causes solar module voltage to spike, which directly impacts equipment limits in freezing climates.
Understanding AC Coupling and Outage Performance
Pairing either battery with existing rooftop solar requires an AC-coupled setup. EcoFlow pairs these units with Smart Home Panel 10 (240V version) and dedicated CT sensors. A licensed electrician must verify system compatibility and complete the installation.
Note that the 4kW and 8kW limits apply only to direct DC solar inputs. They do not dictate AC-coupling capacity.
Grid-tied rooftop solar systems automatically shut down during utility blackouts to prevent backfeeding lines. Standard rooftop panels will not recharge an AC-coupled battery during an outage. Only solar strings wired straight into the unit's DC input, or a dedicated backup generator, can charge the battery during a blackout.
Both models feature IP20 enclosures designed exclusively for indoor installation. EcoFlow lists battery charging temperatures between 32°F and 113°F, with discharging down to 14°F. An unheated garage in a northern climate requires careful planning with your installer before mounting the unit.
Here is how these two systems compare for storing winter sunshine:
EcoFlow TITAN 5000
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
EcoFlow TITAN 5000 fits a setup where the panels wired to the battery form one DC input of up to 4kW. EcoFlow TITAN 5000 Plus fits a setup that needs two MPPT inputs and up to 8kW of total DC input. Both store clear-day production for the evening, both run in no-export mode through Smart Home Panel 10 (240V version) installed by an electrician, and neither one clears snow or makes up for hours the panels spent covered.
Estimating Usable Winter Battery Storage
Both battery models help balance the winter generation gap. EcoFlow TITAN 5000 manages single-string DC setups up to 4kW, while EcoFlow TITAN 5000 Plus handles dual-string arrays up to 8kW. Both operate in zero-export modes via Smart Home Panel 10 installed by a licensed pro.
Consider a practical evening consumption estimate. For planning purposes, this article assumes a base 5,000Wh battery delivers about 4,250Wh to your loads (5,000Wh × 0.85). The 0.85 factor is a hypothetical allowance for inverter losses and usable depth of discharge. It is not a measured or manufacturer-published specification for the TITAN, so check EcoFlow's spec sheet for official usable-output figures.
  • A standard refrigerator (630 kWh annual DOE EnergyGuide label) uses about 72W, consuming roughly 430Wh over 6 evening hours.
  • A home Wi-Fi mesh router consumes around 7W, drawing about 42Wh across that same 6-hour span.
Together, these baseline devices consume under 500Wh, leaving ample reserves for lighting, space heaters, and entertainment circuits. Keep in mind that heavy overcast or lingering snow cover may prevent complete recharging on cloudy winter days. Check your own appliance nameplates to calculate exact runtime needs.
Adding storage requires careful coordination with your existing electrical setup. Learning how to install a battery with solar panels helps you design a resilient system before winter storms arrive.
Energy storage only works if your rooftop equipment stays undamaged through freezing conditions. Using improper snow removal tools is the fastest way to crack glass or compromise factory seals.
Tools That Can Damage Solar Panels: What REC, Qcells, and Canadian Solar Say
Metal shovels, hot water, and chemical sprays might seem like convenient shortcuts. They can also damage panel surfaces or put unnecessary stress on the glass and frame. Always check your own panel's manual before attempting snow removal.
Tools that can damage solar panelsTools that can damage solar panels
Official Manufacturer Cleaning and Maintenance Guidelines
Topic
REC Alpha Pure (UL, Rev 18, 3.2026)
Qcells Q.TRON M-G2.X (North America, Rev 01, Aug 2023)
Canadian Solar Standard Modules (June 2017)
Snow Removal
Not addressed directly in text
"Remove snow and ice carefully without force (e.g. with a very soft broom)"
"Snow should be removed using a soft brush"
Water
Ambient-temperature deionized water preferred; rainwater or tap water may also be used as a secondary solution (routine cleaning only, not for melting snow or ice)
"Do not clean modules with water if there is a risk of frost"
Non-abrasive sponge, low-mineral water, cool part of day
Tools & Chemicals
"Take care not to scratch the surface"; no acidic or alkaline detergents
No abrasive materials; "Do not bring any chemical substance (e.g. oil, solvent etc.) into contact with any part of the panel"
"Do not use abrasive or electric cleaners"; avoid rotating brushes that "could create micro-cracks"
Standing on Panels
"Do not stand or walk on the panels"
"Never step on modules"
"Do not stand, step, walk and / or jump on modules under any circumstances"
Dangerous Shortcuts to Avoid
  • Hot water: Never pour warm or hot water over freezing panels. The extreme thermal shock can crack tempered glass instantly. Qcells prohibits any water use whenever freezing conditions exist.
  • Chemical de-icers: Chemical sprays, car windshield fluid, and salt damage aluminum frames and eat through silicone seals. Never apply chemical melting agents to solar hardware.
  • Chipping bottom-edge ice: Ice often bridges across the lower frame lip. Chipping, tapping, or prying puts sharp point loads on glass edges, leading to spiderweb fractures. Leave ice dams to melt naturally in the sun.
  • Warranty protection: Qcells warns that improper cleaning methods cause surface scratching and permanent physical damage. Review your warranty documents carefully to avoid costly mistakes.
Aggressive scraping leads to long-term efficiency losses. Understanding what causes solar panels to degrade highlights why physical stress and surface abrasions degrade power production over time.
Proper clearing techniques protect your glass this season. However, your racking style and panel tilt angle determine how much snow accumulates in the first place.
How to Keep Snow Off Solar Panels: Tilt, Mounting, and Snow Load
You cannot stop winter storms from dropping snow on your roof, but you can configure panels to shed accumulation rapidly. Array tilt angle and physical mounting choices dictate winter performance. For an existing array, the goal is monitoring weight ratings and tracking drift patterns.
Choose the Right Tilt and Clearance
NREL's 2017 study identified sliding as the dominant snow-removal process. Its modeled results generally showed lower snow losses for systems tilted at latitude than for systems tilted at 20°.
For a new installation or ground-mounted array, ask your installer how tilt affects winter production. Don't change an existing roof-mounted system without professional advice.
Ground-mounted systems also need enough clearance below the panels. Sliding snow needs somewhere to go rather than piling against the lowest edge.
Choose the right tilt and clearanceChoose the right tilt and clearance
Check Snow Load Ratings
Panel and mounting systems must handle local snow and wind loads. Manufacturer guidance highlights several considerations:
  • REC Alpha Pure: The cited manual lists up to 5,400 Pa of downward pressure under specified mounting conditions, with a 3,600 Pa design load. Snow buildup can create forces beyond stated limits.
  • Canadian Solar: For heavy snowfall above 2,400 Pa, the manual recommends considering measures such as additional support bars.
  • Qcells: Mounting must comply with local snow and wind loads. Snowdrifts and overhanging snow can create unbalanced loads.
These ratings aren't interchangeable, and actual capacity depends on mounting configuration. Ask your installer whether the racking and panels meet local requirements and whether the lowest row needs extra support.
If panels sit above a door, walkway, or driveway, ask whether snow guards or other measures could manage sliding snow safely.
Array orientation plays a major role in overall production. Evaluating how mounting systems affect solar output helps homeowners in snowy regions choose the best angle for seasonal energy harvesting.
Once storms pass and snow slides clear, inspect your system to ensure normal power generation resumes.
After the Storm: How to Restore Generation and Spot Damage
Rooftop solar generation should recover quickly on the first clear day following a winter storm. If your monitoring portal shows flatlined output while the sun is bright, investigate further. A simple visual inspection from the ground reveals whether you need professional repairs.
Post-Storm Solar Checklist
  • Compare output on the first sunny day with a typical clear day before the storm.
  • Check whether the entire array is producing or one section is lagging.
  • Look from the ground for cracked glass, shifted panels, or sagging racking.
  • Contact your installer if the panels appear clear but production remains near zero.
  • Leave ice along the lower panel edges alone.
Qcells recommends inspections after unusual events, including storms, hail, and heavy snow loads. Don't attempt close-up inspections that require climbing onto the roof.
If severe winter weather knocks out the local electrical grid, remember that grid-tied solar systems automatically disconnect for anti-islanding safety. Rooftop panels will not energize your household circuits during a blackout on their own.
For downed power lines or immediate hazards in your yard, call 911 immediately. Report general neighborhood power outages directly through your local electric utility's reporting portal.
Catching performance drops is simple when you keep an eye on your system metrics. Routine habits around monitoring a home solar system ensure you spot storm-related faults before they impact your utility bill.
Snow usually costs solar owners a modest share of yearly production, from near 0% in Phoenix to about 15% in northern Minnesota in NREL's model, and it often slides off on its own. Wait when you can, clear only from the ground with a soft rake or brush, skip hot water, scrapers, and chemicals, and check output after every big storm. If you would like clear-day solar to last into winter evenings, compare EcoFlow TITAN 5000 (one 4kW input) and EcoFlow TITAN 5000 Plus (two inputs, 8kW total) with your installer.
Should I remove snow from my solar panels?
Usually, no. Snow often melts or slides off within a few days. Consider removing heavy buildup only when it persists, production remains low, and panels are safely reachable from the ground.
Can I use hot water to get snow off of solar panels?
No. Hot water can create thermal stress and potentially damage panel glass. Qcells also advises against cleaning modules with water when frost is possible. Always follow your manufacturer's cleaning instructions.
How do you keep snow off solar panels?
A steeper tilt helps snow slide off faster under its own weight. Proper mounting design with enough ground clearance also prevents shedding snow from damming up and pressing against the bottom row of panels.
Can snow damage solar panels?
Yes. Heavy snow, drifting, and uneven buildup can place excessive pressure on panels and mounting systems. Check manufacturer load ratings, and ask your installer to inspect suspected damage after severe storms.
Does a home battery help when snow covers my panels?
Yes, as long as the battery already holds a charge. Snow stops new solar generation, but it doesn't lock the stored energy away. A charged battery keeps powering your connected circuits until it runs down, which can cover evenings and a stretch of low production. It can't make new electricity while the panels are buried, and it won't fully make up for days of lost generation. Recharging depends on the panels clearing, or on grid power when the grid is up. During a blackout, grid-tied rooftop solar shuts down, so only solar wired directly to the battery's DC input or a backup generator can recharge it.
Solar Panels
