When Is the Best Time to Install Solar Panels? Seasons, Roof Timing, Permits, and Rule Changes
Most solar guides tell you to pick a sunny spring or fall day. But the day the crew climbs on your roof is only a small part of the timeline. What really shapes your schedule includes the weeks needed for permits, local inspections, and utility interconnection approvals. Just as important are the incentive requirements and utility policies that apply to your project, which may depend on when you apply, purchase equipment, install the system, or receive permission to operate.
Figuring out when is the best time to install solar panels means looking at the whole picture. This guide breaks down each season, roof conditions, the 2026 federal residential clean energy tax credit expiration, changing utility export rates, and the permitting timeline so you can plan your installation strategically. Because eligibility rules and export tariffs vary by program and may include grandfathering provisions or future adjustments, verify the specific requirements and effective dates that apply to your project. If you want home battery backup, plan it into the same schedule.
The Best Time of Year to Install Solar Panels: A Season-by-Season Look
There is no single best month for every home in the country. Each season brings trade-offs between local roof conditions, crew availability, municipal permit office workloads, and initial solar production. You can use the comparison table below to align your personal priorities with the right season, then verify the exact schedule with your local installer.
Season
Roof and crew conditions
Scheduling to ask about
First months of production
Spring
Mild temperatures, but rain can push roof work back
Ask how far out the installer is booking and how long your permit office takes
Your system turns on just as daylight hours expand toward summer peaks
Summer
Long workdays, but heat makes roof work harder
Ask whether summer demand is stretching the schedule
Your system begins generating during the highest-output months of the year.
Fall
Cool, dry stretches suit roof work in many areas
Ask whether the job can finish and pass inspection before winter weather or holiday closures
Production naturally tapers down as sun angles lower toward winter.
Winter
Snow and ice can stop roof work in colder states; milder in the South and Southwest
Ask whether the installer works through winter in your area and how weather delays are handled
Starts during lower-output months, then ramps up significantly by spring.
How sun angles shape output
The U.S. Energy Information Administration (EIA) points out that monthly solar generation follows a clear seasonal pattern. Sunlight intensity is higher during the summer and drops in the winter. Because of this natural cycle, turning on a system in November or December yields lower energy production at first.
However, colder weather by itself does not stop your panels from producing electricity. The real hurdle in winter is simply safe physical access to steep roofs covered in ice or snow. In fact, how solar panels perform in winter depends far more on daylight hours, cloud cover, snow shedding, and tilt angles than on cold ambient temperatures.
Check your own address
Don't count on a one-size-fits-all number. Run your address through PVWatts instead. It's a free calculator from the National Laboratory of the Rockies, formerly NREL. It estimates monthly and annual production for a rooftop system at your location.
Keep in mind that PVWatts provides estimates for preliminary planning. Your certified installer's on-site shade analysis and engineering blueprint provide the final numbers. When you talk to contractors, do not assume winter installations automatically come with steep discounts. Seasonality affects scheduling more than base hardware pricing, so always ask installers directly whether their rates or lead times fluctuate throughout the year.
Season is only one piece of timing. For many homes, the condition of the roof decides the start date before the calendar does.
Roof Replacement Timing: When to Install Solar Panels on an Older Roof
Solar panels are built to generate clean power for decades, so the roof underneath must be capable of lasting just as long. If your roof is approaching the end of its lifespan, replacing it before or alongside your solar build prevents costly array removals later on. Taking the time to verify your roof's age before signing a solar contract protects your investment.
Roof replacementRoof replacement
The U.S. Department of Energy's (DOE) Solar Energy Technologies Office highlights an important point: solar panels typically last 25 to 30 years. A roof's lifespan varies by roofing material, generally ranging from 20 to 50 years. Because these timelines can overlap, assessing your roof's remaining life before installing solar panels makes good financial sense. If your roof needs replacement soon, completing both projects together can help you avoid the additional cost of removing and reinstalling the solar array later.
Key steps before you sign
To make sure your roof is ready for a solar installation, take these specific steps:
  • Verify the roof's official age: Check your homeowner records or look up local municipal building permits to see when the roof was last permitted, installed, or re-shingled.
  • Schedule a professional structural assessment: Have several licensed solar contractors assess your roof rafters and decking to confirm they can handle the dead weight and wind loads.
  • Coordinate the trades: If a roof tear-off is required, hire your roofer and solar contractor in sync, so flashing attachments and mounting penetrations integrate smoothly with the new roofing warranty.
Shingle type, age, and condition all factor into whether to replace your roof first, and an inspection before signing settles it.
Once the roof and season are sorted, the next timing choice is whether a battery goes in with the panels or later, which affects the wiring plan and the paperwork.
Planning Storage and Backup at Install Time: Where EcoFlow TITAN Plus Fits
A home battery stores some of that energy for later use and can provide backup for selected circuits when configured appropriately. If you want both solar and battery storage, plan them together whenever practical. Your installer can account for the electrical connections, equipment compatibility, permits, and utility requirements from the beginning.
The EcoFlow TITAN Plus provides a purpose-built option for home storage. Before choosing it, consider three important factors.
Solar compatibility
The EcoFlow TITAN Plus features an 8,000W dual-MPPT solar input across two dedicated ports. Each port supports up to 4,000 watts, with a listed voltage range of 40 to 450 volts and a 16-amp limit.
The product also supports compatible existing rooftop solar through AC coupling when paired with the Smart Home Panel 10. The installer must confirm the complete configuration, including string voltages, inverter compatibility, electrical requirements, and local code compliance.
EcoFlow lists grid integration through the Smart Home Panel 10 in no-export mode. That means the configuration is intended to use stored energy at home rather than export it to the utility grid. Confirm how the system will operate under your utility's rules.
Reviewing household electricity usage
Before sizing battery capacity, check your actual historical electric demand. Pull your utility statements from the past 12 months. Track your average daily kilowatt-hour (kWh) usage across both hot summer months and cold winter periods.
Be sure to account for planned home additions, such as an upcoming electric vehicle or a heat pump conversion. Having these numbers handy allows you to match your storage needs to your real consumption.
Reviewing electricity usageReviewing electricity usage
Permitting and installation scheduling
The Smart Home Panel 10 must be hardwired into your electrical service. A licensed, qualified electrician must do the work under local utility rules.
Planning solar panels and battery storage together can help streamline system design, electrical planning, and the application process. However, co-installing both systems does not automatically mean you need only one building permit or grid-connection application. The number and type of permits, inspections, and utility approvals required depend on your local authority having jurisdiction (AHJ), building type, electrical configuration, and utility provider's rules. Before installation, ask your solar contractor and local permitting office whether applications can be combined and confirm all required approvals with your utility.
You can still add batteries after the fact. However, many utilities treat retrofits as entirely new interconnection projects. For instance, the Concord Municipal Light Plant in Massachusetts uses a separate form. Their "Battery Addition to Existing Photovoltaic Array" form requires separate approvals to install and operate. Always ask your utility which forms are required for no-export residential storage.
Backup limits to state plainly: EcoFlow's page notes that rooftop solar connected through a standard grid inverter shuts down during an outage, so it can't charge TITAN through that connection. Backup covers selected circuits through Smart Home Panel 10, not the whole house.
Also understand the backup limitations. A standard grid-tied solar inverter generally shuts down during an outage unless the system has appropriate backup equipment. Solar connected through that standard arrangement won't necessarily recharge your battery during a blackout. The supported backup circuits depend on the installed equipment and configuration.
So what should you bring to your installer? Here are the specs to use when checking compatibility and building the battery into your solar schedule.
EcoFlow TITAN 5000 Plus
EcoFlow TITAN Plus fits a household that is installing compatible solar and wants to use more of its own production at home and back up selected circuits, with Smart Home Panel 10 installed by a qualified electrician. It isn't a way to earn export credits, since it runs in no-export mode, and it doesn't change when your panels should go up. The final fit depends on your installer's compatibility check, your usage, and your utility's rules.
Storage capacity planning example
A simple planning example helps put capacity into perspective.
A 5,000 Wh battery multiplied by an assumed 85% usable-energy factor gives approximately 4,250 Wh, or 4.25 kWh, of usable energy. Actual usable energy depends on the system's specifications, operating conditions, and settings.
For a home that uses 20 kWh daily, 4.25 kWh represents about 21% of one day's electricity consumption. That doesn't mean the battery will cover 21% of every day's needs under all conditions. Your actual backup duration depends on which circuits you run and how much power they consume.
The wiring plan changes depending on adding a home solar battery to a new array or an existing one, so settle it before the permit is filed.
Equipment specifications determine how your system runs. However, tax rules and utility export policies dictate the financial return on your investment.
Tax Credit Deadlines and Export Rate Changes That Affect When Solar Pays Off
Old buying guides often urge homeowners to rush an install before December 31 to beat the federal tax credit deadline. If you plan to buy and own your system outright in 2026, that advice no longer applies. Today, project timing depends on your state programs and the utility export tariffs active on the date your system receives final approval.
The federal residential solar credit ended after 2025
According to the IRS, the federal Residential Clean Energy Credit isn't available for qualifying property placed in service after December 31, 2025.
That means a homeowner-owned solar system placed in service in 2026 doesn't qualify for the Section 25D residential credit. Purchasing equipment or signing a contract alone doesn't establish eligibility under the previous rules.
State and local incentives may still be available, but their requirements differ. Some programs have application deadlines, eligibility restrictions, or limited funding.
Before signing a contract:
  • Check your state energy office's current incentive programs.
  • Review your utility's available rebates or solar programs.
  • Confirm eligibility and application deadlines in writing.
  • Consult a qualified tax professional about your specific circumstances.
Don't base a 2026 installation decision on outdated federal-credit claims.
Export credits can change after you install
How your utility credits surplus electricity sent back to the grid can significantly impact your return on investment. These policies are set by state public utility commissions and can shift over time.
A clear example of this regulatory evolution occurred with Idaho Power:
  • December 29, 2023: The Idaho Public Utilities Commission issued final Order No. 36048 (Case IPC-E-23-14). This order approved a transition to a real-time net billing export credit rate structure.
  • September 30, 2025: The Commission issued final Order No. 36785 (Case IPC-E-25-15, effective October 1, 2025). It updated the Export Credit Rate for non-legacy on-site generation customers on Schedules 6, 8, and 84. The order capped the decrease in the rate's avoided energy value at 40% for summer and non-summer months. It also suspended annual update filings until April 1, 2028.
This case illustrates an important point. Export credit values can change on a commission's docket after your system is already spinning the meter. Before starting your project, contact your local electric utility. Review their active solar tariff riders. Ask whether incoming applicants are placed under legacy net metering or modern net billing rules. Finally, verify whether utility commission dockets are currently reviewing export valuation.
When utilities reduce export credit rates, sending excess power back to the grid becomes far less profitable. This makes comparing traditional net metering with battery storage essential for evaluating whether retaining and consuming your own solar energy on-site makes the best financial sense.
While utility export structures dictate what your solar array earns, the paperwork process determines when your system can legally generate electricity.
Permits, Inspections, and Interconnection: The Time to Install Solar Panels Is Mostly Paperwork
The physical assembly of racks, panels, and inverters on your roof is remarkably fast. The administrative reviews that surround the work take the bulk of the calendar.
The DOE notes that rooftop solar installation usually takes only a few days. However, obtaining permits and passing local inspections often takes weeks or months. To avoid surprises, plan your start date around this administrative window. Do not focus solely on the day the work truck arrives.
Permits, inspection, and interconnectionPermits, inspection, and interconnection
The typical solar installation process
Most projects follow these steps, although local requirements vary.
  1. Compare installers: Get multiple quotes and request roof assessments.
  2. Finalize the design: Your installer calculates system size, equipment requirements, and electrical connections.
  3. Submit permit applications: The relevant city or county authority reviews the proposed work.
  4. Install the equipment: The crew mounts the panels and completes the approved electrical work.
  5. Pass the local inspection. An inspector checks the installation against applicable requirements.
  6. Receive utility approval: The utility reviews the interconnection and provides permission to operate when required.
Don't turn on a grid-connected system until the required approvals are complete.
Faster permitting where SolarAPP
Some local governments use SolarAPP+, a web-based platform that automates permitting checks for eligible residential solar and solar-plus-storage projects.
Eligible systems may receive automated approval, while more complex projects can require manual review. Availability depends on the local jurisdiction and the project's characteristics.
DOE's Solar Energy Technologies Office funded its development through an award to NREL. An August 2024 NREL fact sheet says the tool eliminated over 150,000 business days of permitting delays in 2023. Ask your installer whether your city or county uses it.
You can also consult the Department of Energy's SolarTRACE resource to explore permitting, inspection, and interconnection timelines for your jurisdiction.
Knowing how long a residential solar installation takes from the initial site visit to the final switch-on prevents unexpected delays.
Once you understand the required approvals, a practical readiness checklist can help you decide whether to move forward now or wait.
When to Install Solar Panels: A Readiness Checklist for Your Home
The right time to install solar is when your roof condition, household energy demand, local utility policies, and installer schedules align. If any item on this readiness checklist falls short, address it before signing a binding contract.
  • Your roof has enough remaining life, or replacement is scheduled first.
  • You've reviewed 12 months of electricity bills, including seasonal usage.
  • You've accounted for planned changes, such as an EV or heat pump.
  • You've estimated monthly production using PVWatts.
  • You've checked your utility's current net-metering or net-billing rules.
  • You've reviewed pending utility commission cases that could affect export credits.
  • You've checked state and local incentives and their deadlines.
  • You know your local permit requirements and whether SolarAPP+ is available.
  • You've decided whether to include a battery in the initial installation.
  • You've compared at least two or three installer quotes.
  • Your preferred season allows for safe roof access and realistic weather planning.
When waiting can make sense
  • The roof needs replacement soon.
  • Your utility has a pending case that could change export credits, and you want the outcome first.
  • You are planning major electrical changes in the coming months, such as adding a home extension, an electric car, or a central heat pump.
If you're on a time-varying plan, knowing how time-of-use rates work helps you decide how much solar to store for evening hours.
The best time to install solar panels depends less on the month than on your roof's condition, the permit and utility approval timeline, and the export and incentive rules in effect when your system turns on. Start by inspecting your roof, reviewing a year of electric bills, running PVWatts, and confirming your utility’s current solar tariffs. Always begin paperwork early to navigate the weeks or months needed for official approvals.
If you also want stored power and blackout protection for critical circuits, ask your installer whether the EcoFlow TITAN Plus fits your setup.
What month is best to install solar panels?
There's no universally best month. Spring and fall often provide favorable roof-working conditions, but your roof, local contractor schedules, permitting process, and utility approval timeline matter more than the month itself.
Can you install solar panels in winter?
Yes, in many locations. Snow and ice can delay roof work in colder states, but cold temperatures alone don't prevent panels from operating. In addition, systems turned on in winter begin generating power during the lowest-production months of the year before ramping up in the spring.
How long does it take to install solar panels?
Residential solar panel installation in the U.S. typically takes 1 to 3 days, while the complete process can take several weeks to a few months. Timelines vary depending on permitting, inspections, weather, system complexity, and utility approval requirements.
Should I replace my roof before installing solar?
If your roof is near the end of its lifespan, replacing it before or alongside your solar installation is the smartest move. The DOE notes that solar panels last 25 to 30 years. Replacing an old roof first avoids paying thousands of dollars to dismantle and reinstall the array later.
Can I add a battery after installing solar panels?
Often, yes. However, compatibility, electrical work, permits, and utility requirements need to be checked. Some utilities require a new application for a battery addition, so ask about the approval process before choosing your equipment.
Solar Panels
