How Hot Do Solar Panels Get? What Heat Does to Output and How to Set Panels Up for Hot Days
On a bright summer afternoon, you might expect your solar panels to produce their most electricity of the year. However, intense sunlight also heats the panels, and that extra heat can reduce their output. Solar panels routinely operate much hotter than the surrounding air, especially when airflow beneath them is limited. Knowing how hot solar panels become, how temperature impacts performance, and how mounting choices can affect heat can help you get more from your system. We'll discuss realistic temperature estimations, what the solar panel temperature coefficient is, and practical setup advice for portable panels at home or at a campsite.
How Hot Do Solar Panels Get in Full Sun? Modeled Temperatures by Mounting Type
Solar panels can run tens of degrees hotter than the air on a sunny day. Sunlight intensity, wind speed, panel construction, and airflow behind the module all affect its temperature. Sandia National Laboratories provides models for estimating module temperatures under different conditions. For example, consider a sunny day with an air temperature of 95°F (35°C) and solar irradiance of 1,000 watts per square meter. The following figures are illustrative model estimates, not guaranteed readings for every panel.
Mounting affect panel temperatureMounting affect panel temperature
Mounting setup
Illustrative panel back temperature
Open rack with good airflow and a light breeze
Around 148°F (64°C)
Roof-mounted with a ventilation gap
Often hotter than an open rack
Very limited airflow behind the panel
Potentially much hotter
Why does mounting affect panel temperature?
An elevated solar panel allows air to circulate underneath, helping carry away heat, while panels mounted close to a roof can retain more warmth. Wind also affects cooling, and the solar cells can run slightly hotter than the panel's back surface. Since the hottest hour isn't always the most productive, understanding what peak sunlight means for solar production helps you assess available sunlight rather than relying on air temperature alone.
Why Heat Lowers Output: The Solar Panel Temperature Coefficient Explained
Solar panels are rated under Standard Test Conditions (STC), which include a solar-cell temperature of 77°F (25°C). Outdoor cells can become much hotter than this, even when the weather feels comfortable. The U.S. Department of Energy says the rise in temperature causes a slight rise in electrical current but a bigger drop in voltage. Because the voltage drops, the overall power output usually drops, too.
STC, NOCT, and NMOT in plain words
Solar panel datasheets use different measurements to show how panels perform under laboratory and real-world conditions. Understanding STC, NOCT, and NMOT helps you compare panels and see how operating temperatures may affect their actual power output.
  • STC (Standard Test Conditions): A laboratory rating based on 1,000 W/m² of sunlight, a cell temperature of 77°F, and a specified solar spectrum. This is the basis for a panel's advertised wattage.
  • NOCT (Nominal Operating Cell Temperature): An estimate of cell temperature under defined outdoor-like test conditions.
  • NMOT (Nominal Module Operating Temperature): A similar operating-temperature measurement used by many newer datasheets, under specified sunlight, ambient temperature, and wind conditions.
What is a solar panel temperature coefficient?
The temperature coefficient of power tells you how much a panel's power output changes for each degree Celsius above or below its reference cell temperature. It is usually expressed as a negative percentage per °C.
Example coefficient
Approximate power change per 1°C rise
−0.47%/°C
Loses 0.47%
−0.35%/°C
Loses 0.35%
−0.24%/°C
Loses 0.24%
A practical 400W panel example
A 400W solar panel with a cell temperature of 149°F (65°C) may produce around 325W with a −0.47%/°C temperature coefficient, compared with approximately 362W at −0.24%/°C. These estimates show how heat affects output, but actual production also depends on sunlight, shading, and panel orientation. Understanding how temperature affects solar panel efficiency helps you compare rated wattage with real-world performance and set realistic expectations.
Setting Up a Portable Panel to Lose Less Power to Heat: EcoFlow 400W Portable Solar Panel
Portable panels give you more control over placement than fixed rooftop systems. Whether you are charging a power station in your backyard or setting up at a campsite, a few simple adjustments can help reduce unnecessary heat buildup and improve sunlight exposure.
Practical ways to keep a portable solar panel cooler
  • Leave space underneath: Open the panel's support stand so air can circulate behind it. Avoid placing it directly against the ground.
  • Avoid hot surfaces: Dark pavement, vehicle roofs, and sun-baked sand can add unwanted heat. Choose a stable location with room for airflow.
  • Keep the panel clear of shade: Trees, tent edges, railings, and other obstructions can reduce output, even when most of the panel is in direct sunlight.
  • Adjust the angle: Reposition the panel as the sun moves so its surface receives stronger, more direct sunlight. The best angle depends on your location, season, and time of day.
  • Check the actual input: Read the wattage displayed by your power station instead of assuming the panel is producing its rated maximum. The power station's solar-input limits can cap the amount it accepts.
  • Handle the panel carefully: After hours in direct sunlight, the surface may be hot enough to cause discomfort or a burn. Let it cool before handling it unnecessarily.
Choosing a portable panel for outdoor charging
When choosing a portable panel for outdoor charging, consider its rated output, adjustable stand, durability, weather resistance, and conversion efficiency, especially if space is limited. The EcoFlow 400W Portable Solar Panel offers up to 23% conversion efficiency, an adjustable self-supporting design, and an IP68 waterproof rating under specified test conditions. However, these features do not eliminate heat-related power losses or guarantee 400W output, which depends on sunlight, temperature, panel angle, shading, and the connected power station.
• 400W Solar Input: Charges faster with a high 400W solar input. •High Conversion Rate: Converts sunlight to power at up to 23%. • Built to Last: Made from durable, multi-layered materials, with an IP68 waterproof rating. •Easy Setup: A one-piece folding design that stands on its own, with an adjustable angle. •Cable Included: Comes with the solar to XT60 charging cable.
Rated wattage reflects performance under specific test conditions, not the charging rate you can expect in hot weather, and the power station's solar input limit also affects how much energy it can accept. At a campsite, choosing the best solar panel angle helps capture sunlight more effectively. Combine the right angle with good airflow and minimal shading to support better real-world performance.
Do Solar Panels Produce Heat or Make Your House Hotter?
Solar panels soak up the sunlight and turn some of it into electricity and throw or dissipate the remainder as heat. They do not produce heat as an electric heater does. In fact, a rooftop solar installation can shade the roof below it. That shade can affect the amount of solar energy incident on the roof surface, but the overall impact varies with the building, roof construction, and installation. There is no one cooling figure that fits every home.
Residential rooftop solar panels absorbing sunlight on a clear summer dayResidential rooftop solar panels absorbing sunlight on a clear summer day
Solar photovoltaic (PV) panels convert sunlight into electricity, while solar thermal systems primarily capture heat for tasks such as warming water. Understanding how solar photovoltaic and solar thermal systems differ helps you choose the right technology for your needs. PV panels generate usable power rather than directly heating your home, and your overall system design determines how effectively electricity meets household demand.
Mounting, Airflow, and Climate: Keeping Rooftop Panels Cooler
For a permanent rooftop system, mounting design is one of the most important factors affecting panel temperature. A suitable gap beneath the modules allows air to circulate and carry away some of the heat. The exact clearance should follow the panel manufacturer's instructions and the installer's design.
What can homeowners do to manage heat?
  • Ask about mounting clearance: Discuss ventilation gaps with your installer before the system is installed. Avoid changing mounting hardware yourself.
  • Keep panels free of heavy dirt and debris: Accumulations can interfere with performance. Follow the manufacturer's cleaning guidance and use a qualified professional when access is unsafe.
  • Compare temperature coefficients: If you live in a hot climate, consider this specification alongside panel efficiency, warranty, and price.
  • Avoid spraying hot panels with cold water: Sudden temperature changes can create thermal stress. Clean panels only as recommended by the manufacturer.
  • Consider the local climate: Heat, wind, humidity, and seasonal sunlight all influence performance and long-term degradation.
A Department of Energy summary of non-residential solar research reports a median performance decline of around 0.75% annually, although degradation varies with climate and system conditions. For residential planning, understanding how heat and shade affect solar panel efficiency can help you assess environmental factors that influence long-term output, but this fleet-level finding is not a guarantee of an individual system's performance.
Solar panels can run tens of degrees hotter than the surrounding air, reducing their output as temperatures rise. Check the panel's temperature coefficient, allow airflow behind it, and monitor the actual watts reaching your device to understand real-world performance. For camp or backyard charging, the EcoFlow 400W Portable Solar Panel features an adjustable stand that helps you angle the panel toward the sun while maintaining airflow for more effective solar charging.
How hot can solar panels get?
Solar panels can reach temperatures well above the air temperature in full sun. A modeled example on a 95°F day gives a back-surface temperature of about 148°F with an open rack and light breeze. Mounting and wind can change the result significantly.
Do solar panels work in hot weather?
Yes. Solar panels continue generating electricity in hot weather, but their output generally decreases as cell temperature rises. The size of the reduction depends on the panel's temperature coefficient and operating conditions.
What is a good solar panel temperature coefficient?
A smaller negative power coefficient is generally better for hot conditions. For example, a coefficient of −0.24%/°C indicates a smaller temperature-related power reduction than −0.47%/°C, all else being equal.
Do solar panels make your attic hotter?
Panels shade the roof area they cover, but the effect on attic temperature depends on roof construction, ventilation, insulation, and the installation. Avoid assuming a specific cooling amount applies to every home.
Are solar panels hot to touch?
They can become very hot after prolonged exposure to direct sunlight. Handle portable panels carefully, avoid touching electrical connections, and allow hot equipment to cool before packing it away.
Solar Panels
