Solar for Your Car: What On-Car Panels Can Do and How Home Solar Charges an EV
The phrase “solar for your car” can mean three different things: solar cells built into a vehicle, portable panels that maintain its 12V battery, or home solar panels that supply electricity to an EV charger. Each setup serves a different purpose, and the amount of driving you can get from solar varies widely. This guide explains how each option works, how to size a home solar system around your daily driving, and where a home battery like EcoFlow TITAN 5000 Plus fits. It also covers Level 1 and Level 2 charging, installation requirements, and the federal tax credit changes affecting solar EV charging in 2026.
Solar for your car: Panels on the vehicle vs. solar at home
Solar for your car: Panels on the vehicle vs. solar at homeSolar for your car: Panels on the vehicle vs. solar at home
Solar can help charge an electric vehicle, but the setup matters. A car roof has limited space for solar cells, while a home solar array can generate enough electricity to cover a meaningful share of your daily driving. Portable panels marketed for cars serve a different purpose, usually supporting the 12V battery or small devices.
Setup
What it powers
What to expect
Who it suits
Solar built into the vehicle
The car's own battery, while parked or driving in sun
Small array limited by roof area; adds some miles, not a full charge (Aptera example below)
Buyers of the few models that offer it
Portable panels "for cars"
The 12V auxiliary battery, accessories, or a portable power station
Small output for lights, fans, and small electronics; not meant to charge an EV's main battery in a practical time
Campers, road trippers, cars that sit unused
Home rooftop or ground solar plus a home EV charger
The EV through a Level 1 or Level 2 charger (and the rest of the house)
The practical way to cover daily EV miles with solar; sized in kilowatts, not watts
Homeowners who park at home and can install panels
Solar built into a vehicle can add some driving range in good sunlight, but results vary. Aptera claims its vehicle has about 700 watts of integrated solar cells and can provide up to 40 miles of solar-powered driving per day. The company also states that the vehicle is still in testing and validation, so its specifications may change. Portable panels, such as those in Anker SOLIX's car solar panel collection, are intended for auxiliary batteries and devices rather than practical everyday charging of an EV's main battery.
For home charging, solar panels generate DC electricity, which an inverter converts to AC power. A compatible EV charger then draws electricity from the home's electrical system to charge the car. That's why most drivers asking whether solar panels can charge electric cars are really looking at home solar. The next step is to calculate how much electricity your daily driving requires.
How much home solar it takes to charge an EV
The solar capacity you need depends on how far you drive, your EV's efficiency, and how much sunlight your panels receive. Start with your daily mileage, then use the PVWatts Calculator to estimate solar production at your address. Your charging schedule matters, too, especially if your car is away from home during the day.
Calculate your daily energy needs
Check your vehicle's electricity consumption on FuelEconomy.gov, which lists energy use in kWh per 100 miles. The US Department of Energy reports that model year 2024 midsize electric cars range from 2.17 to 4.17 miles per kWh, while two-wheel-drive standard SUVs range from 0.97 to 2.94 miles per kWh. For example, driving 30 miles a day in an EV that averages 3 miles per kWh uses about 10 kWh daily, or 3,650 kWh a year. Allow extra solar production for charging losses and changes in driving conditions.
Estimate solar production at your address
The PVWatts Calculator estimates how much electricity a grid-connected solar system can generate at your location. Enter your address and model a 1 kW system to see its estimated annual production. Use that result to estimate how much additional solar capacity you may need to cover your EV's yearly energy use.
Consider when you chargeConsider when you charge
If your car is home during sunny hours, you can charge it while your panels generate electricity. But if you're away all day, you'll need grid power or stored solar energy to charge after sunset, depending on your utility's rules. The same sizing approach applies when estimating how many panels a Tesla needs. That's where a home battery can help. EcoFlow TITAN 5000 Plus stores daytime solar energy for later use, helping you power compatible home circuits when your car comes home after dark.
Storing daytime solar for your EV: EcoFlow TITAN 5000 Plus
If your car comes home after sunset, a home battery can store solar energy generated during the day for later use. EcoFlow TITAN 5000 Plus can store that energy and supply compatible home circuits, including an EV charging circuit if the system is properly designed and installed. It works alongside your solar panels and charger, not as a direct connection to your car's battery.
What to check before choosing a home battery
  • Solar compatibility: Your panels must meet the system's solar input requirements. Have your installer confirm the array layout, string voltage, and no-export configuration.
  • Charger power: Most residential Level 2 chargers operate at up to 7.2 kW, matching EcoFlow TITAN 5000 Plus's rated battery output. That leaves no battery output for other loads at full draw. Check whether your charger's manual allows a lower current setting, and have an electrician confirm compatibility.
  • Daily driving needs: Use your estimated daily energy consumption to work out how much solar energy you want to store.
  • Other household loads: Air conditioning, dryers, and electric ranges also draw power. A licensed electrician must confirm the system can support the planned loads and install the required home circuits and Smart Home Panel 10. Local utility rules may also apply.
The following specifications show how much energy EcoFlow TITAN 5000 Plus can store and how much power it can supply to compatible home circuits.
EcoFlow TITAN 5000 Plus can store solar energy during the day for use when your EV comes home after sunset. Its 5 kWh base battery can cover some daily driving, but it won't fully charge every EV. It also doesn't replace your EV charger or connect directly to your car's battery.
How much driving can the stored energy cover?
Assuming 85% usable energy after conversion losses, the 5 kWh base battery provides about 4.25 kWh, enough for roughly 13 miles in an EV averaging 3 miles per kWh. At a continuous 7.2 kW draw, that energy lasts about 35 minutes. For comparison, Hyundai lists the 2027 IONIQ 5 SE RWD with an 84 kWh battery and an EPA-estimated range of 318 miles. The EcoFlow TITAN 5000 Plus base battery holds about 6% of that capacity before losses. Adding batteries increases storage to 30 kWh, but rated output remains 7.2 kW. Actual results depend on your vehicle and charging setup. If your roof lacks suitable space for panels, a solar carport with battery storage is another option. Next, consider which charging level best fits your driving routine and available power.
Level 1 vs. Level 2: Matching the charger to your solar output
Your charging level determines how quickly electricity moves from your home electrical system into your EV. Level 1 uses a standard 120V AC outlet and charges slowly, while Level 2 typically uses a 240V circuit and can deliver substantially more power. The right choice depends on your daily mileage, how long the car sits at home, and how much power your solar and battery system can supply.
Level
Voltage
Power
Range added
Fits solar when
Level 1
"120 volt (V) AC plug"
1.9 kW (AFDC footnote assumption)
"Approximately 5 miles of range per 1 hour of charging"; "8 hours of charging at 120 V can replenish about 40 miles" for a mid-size EV
The car is home during the day and daily miles are modest
Level 2
"240 V (typical in residential applications)"
"Most residential Level 2 chargers operate at up to 30 Amps, delivering 7.2 kW"; units range "from 2.9 to 19.2 kW"
"Approximately 25 miles of range per 1 hour of charging"
Longer commutes, or charging that has to finish overnight
When your EV charger draws more power than your solar panels produce, the difference comes from the grid or a home battery. The same applies to overnight charging, which the Department of Energy's Alternative Fuels Data Center notes many EV owners use to meet their daily driving needs with Level 1 equipment. Check your charger's app or manual for scheduling and current adjustment options, and compare EV charging times by charger level to see what suits your commute. Once you've chosen a charger, check your home's electrical capacity, permit requirements, and applicable 2026 tax credits.
Wiring, permits, and tax credits for solar EV charging in 2026
A home solar EV setup involves more than panels and a charger. Your home's electrical service must support the equipment, the wiring must be installed correctly, and permits may be required. Federal tax credits have also changed, so older advice about incentives may no longer apply to a new installation.
Wiring, permits, and tax credits for solar EV charging in 2026Wiring, permits, and tax credits for solar EV charging in 2026
Check your home's electrical capacity first
According to the Department of Energy's Alternative Fuels Data Center, Level 1 charging requires an outlet on a dedicated branch circuit. Level 2 charging may require a qualified electrician to add a circuit with enough capacity for the charger. Some homes don't have enough available electrical capacity for Level 2 equipment without upgrades. If you're adding a home battery and Smart Home Panel 10, the backed-up circuits also need to be designed for the equipment's ratings and your household loads. Have a licensed electrician review your breaker panel, available capacity, circuit layout, and local permitting requirements before work begins.
Federal tax credits:
The federal credits for home energy equipment and EV charging have changed. Based on the IRS Section 30C guidance, the relevant dates are:
Tax rules and eligibility depend on the property and the dates involved. Confirm the latest IRS guidance with a qualified tax professional before including a credit in your project budget. State incentives and utility programs may have separate rules, so check those with the relevant agencies and your utility.
Solar can support EV charging in several ways, but the setup determines what you can expect. Integrated vehicle panels add some range, portable panels support smaller auxiliary loads, and a home solar array paired with a suitable EV charger offers a more practical way to cover daily driving. Start with your mileage and your car's kWh-per-mile efficiency, then use PVWatts to estimate solar production at your address. Match the charger to your available power, account for when the car is home, and have a licensed electrician confirm the wiring and battery connections. If your car usually comes home after sunset, EcoFlow TITAN 5000 Plus may help store part of the day's solar production for compatible home circuits. Ask your installer to confirm that the system can support your planned charging load.
Can you put solar panels on a car to charge it?
Yes. Some vehicles have integrated solar cells, but roof space limits how much energy they can generate. Aptera, for example, claims up to 40 miles of solar-powered driving per day for a vehicle it says is still in testing and validation. Treat that as the company's claim, not a guaranteed daily result.
How many solar panels does it take to charge an EV?
It depends on your daily mileage, your vehicle's efficiency, and local solar production. Calculate your annual EV energy use, then use PVWatts to estimate how much electricity a solar system can generate at your address. That gives you a starting point for sizing the additional solar capacity you may need.
Can solar panels charge an electric car directly?
No, not through a typical home solar setup. Solar panels produce DC electricity, which an inverter converts to AC for the home's electrical system. A compatible EV charger then supplies power to the car.
Can a home battery charge an electric car?
A home battery can supply a compatible EV charger circuit if the system's output can support the charger's demand and any other loads running at the same time. A licensed electrician should confirm the design, compatibility, and installation requirements.
Is there still a federal tax credit for a home EV charger in 2026?
Under the IRS Section 30C guidance, the Section 30C credit covered qualifying property placed in service through June 30, 2026. A charger placed in service after that date falls outside the stated eligibility window. Check current IRS Section 30C guidance and consult a tax professional before making a purchase based on an expected credit.
Solar Energy
