How Much Can You Save With Solar Panels? Solar Savings Explained
Solar panels can reduce what a household buys from the electric utility, but no reliable national savings figure exists. Two homes with identical arrays may see different results because their rates, roofs, usage schedules, and export credits are different.
A useful estimate begins with a full year of electric bills and the rules for the home’s utility account. Expected production, installation cost, financing, maintenance, and confirmed incentives complete the calculation.
This guide explains how solar savings work in the United States in 2026, how to build a realistic estimate, and when battery storage or changes in household energy use may improve the result.
How Much Money Can Solar Panels Save You?
For anyone asking “how much money do I save with solar panels?”, the answer is usually the value of reduced electricity purchases, not the disappearance of the utility bill. Most customers continue to pay a connection charge and taxes, along with charges for grid power used when the panels are not producing. Minimum-bill amounts or other nonbypassable charges may also remain.
Electricity produced by solar panels and used immediately in the home may avoid a retail purchase. Exported electricity is credited under the utility’s tariff, which may be close to the retail rate, tied to avoided cost, or vary by time of day.
Average Monthly Electricity Bill Savings From Solar Panels in 2026
The U.S. Energy Information Administration reported an average residential electricity price of 18.31 cents per kilowatt-hour for July 2026. That figure provides context, but the rate on the homeowner’s bill is what matters. To estimate how much can you save with solar panels per month, use the actual tariff, monthly production, self-consumption, and export credits instead of a national average.
Consider a system expected to produce 10,000 kWh in its first year. If every kilowatt-hour offsets electricity that otherwise would have cost 18.31 cents, the gross first-year value would be about $1,831, or an average of roughly $153 per month. That is an illustration, not a forecast. Fixed charges remain, and exported power may receive less than the retail rate.
A better estimate separates production into electricity used at home and electricity exported. Suppose the same 10,000-kWh system supplies 4,000 kWh directly to the house and exports 6,000 kWh. At a retail rate of 18.31 cents and an export credit of 6 cents, the annual value would be:
On-site use: 4,000 kWh × $0.1831 = $732.40
Exports: 6,000 kWh × $0.06 = $360.00
Estimated first-year value of solar electricity: $1,092.40, assuming these rates apply and excluding additional tariff adjustments. Fixed utility charges may remain on the household’s bill.
This is why a proposal based only on annual production can overstate savings. The time of production and treatment of exports also matter.
Estimated Solar Savings by State, Based on Typical Residential Rates and Usage
The table below is a comparison, not a savings promise. It uses July 2026 statewide residential prices and assumes 10,000 kWh of solar generation receives full retail value. It excludes fixed charges, financing, system cost, shading, lower export rates, and local incentives.
State | July 2026 Avg. Residential Rate | Gross Annual Value of 10,000 kWh at Retail | Monthly Equivalent | What May Change the Result |
California | 33.61¢/kWh | $3,361 | $280 | Net Billing Tariff export values, time-of-use periods, and battery dispatch |
Texas | 15.88¢/kWh | $1,588 | $132 | Retail provider plan, buyback terms, transmission charges, and summer use |
Florida | 15.03¢/kWh | $1,503 | $125 | Utility territory, minimum bills, insurance requirements, and roof condition |
New York | 29.90¢/kWh | $2,990 | $249 | Utility tariff, state programs, system location, and seasonal production |
Arizona | 15.38¢/kWh | $1,538 | $128 | Time-of-use rates, demand charges where applicable, and utility export rules |
Ohio | 19.45¢/kWh | $1,945 | $162 | Supplier and delivery charges, net-metering terms, and winter production |
Washington | 14.71¢/kWh | $1,471 | $123 | Lower retail rates, utility policy, roof orientation, and local cloud cover |
California deserves special attention. Under the Net Billing Tariff used by the state’s large investor-owned utilities, export credits reflect the electricity’s value to the grid. They are usually below retail import prices, although hourly values vary. A battery may move midday production into a more valuable period, but its cost and efficiency losses still belong in the analysis.
When reviewing a contractor’s projection, ask whether it uses the actual tariff, retains fixed charges, accounts for panel degradation, and distinguishes on-site use from exports.
What Factors Affect Your Solar Panel Savings?
For homeowners asking “can you really save money with solar panels?”, the answer depends on whether a productive roof, meaningful electricity use, favorable rates, reasonable installation cost, and the utility tariff work together.
Local Electricity Rates Determine the Value of Solar Energy
Each kilowatt-hour the home does not buy has a dollar value. When the retail rate is high, avoiding that purchase is generally worth more. Yet the number at the bottom of the bill cannot always be divided by total usage and applied to every solar kilowatt-hour.
Utility bills may contain customer charges, tiered prices, time-of-use periods, riders, taxes, and delivery fees. Some fall when grid purchases decline; others do not. Use the tariff that will apply after interconnection, since some utilities move solar customers to another schedule.
Sunlight Hours and System Size Affect Solar Production
Nameplate size describes how much power an array can produce under rated test conditions. It does not state how many kilowatt-hours the system will deliver over a year. Local weather, roof direction, tilt, shading, inverter sizing, equipment losses, and temperature all influence annual output.
A south-facing roof with little shade is often productive, but east- and west-facing sections may also make sense. In a time-of-use territory, later afternoon production can have added value. Ask for a month-by-month estimate that models trees, chimneys, roof planes, and equipment losses. NREL’s PVWatts Calculator provides a useful independent check.
Household Electricity Use Determines Solar Self-Consumption
Solar is most valuable when production aligns with the home’s demand. Air conditioning, a pool pump, an electric water heater, daytime EV charging, or a home office can absorb a meaningful share of midday output. A house that is mostly empty during the day may export much more.
Self-consumption simply means that solar power serves a household load before it passes through the meter to the grid. It may happen immediately, when an appliance runs while the sun is up, or later, when a solar battery stores surplus production and releases it after the panels slow down.
Planned loads such as an electric vehicle or heat pump may justify additional capacity. Installing panels for energy that may never be used, however, can lengthen payback where export compensation is low.
Net Metering Policies Affect Export Credits
“Net metering” is often used as a general term, but the details differ sharply. One utility may credit exported electricity at or near the retail price. Another may use a lower avoided-cost rate. A third may assign hourly values or settle credits differently at the end of a billing period.
Read the current tariff or ask the utility for a written explanation. Confirm the export price, credit expiration, annual true-up, system-size limit, required rate plan, and fixed charges. If a salesperson says the utility will “buy back” power, ask for the actual cents-per-kilowatt-hour value.
Installation Costs and Incentives Influence Total Savings
Compare cash price with cash price. A financed proposal may include dealer fees that are not obvious from its advertised rate. Review the total of payments, term, prepayment rules, and any assumption that a tax refund will reduce the principal.
For a residential system completed in 2026, homeowners should not assume the former 30% federal Residential Clean Energy Credit is available. Federal law accelerated the end of the Section 25D credit, and IRS guidance states that an installation completed after December 31, 2025, does not qualify even if the homeowner paid before that date.
State tax provisions, utility rebates, renewable-energy certificates, local grants, and property-tax treatment may still apply. Verify each one for the address and installation year; some require approval before work begins. Include roof work in the budget, since removing and reinstalling panels later adds cost.
How Can You Calculate Your Potential Solar Savings?
A credible estimate can be built with a spreadsheet and a year of bills. The purpose is to make the important assumptions visible enough to test.
1. Calculate Your Current Annual Electricity Costs
Collect at least 12 consecutive utility bills. Record the kilowatt-hours used and the amount charged each month, keeping fixed customer charges separate where possible. One summer statement is not a reliable annual baseline.
Note time-of-use periods, seasonal rates, demand charges, and unusual events that distort the total. Estimate planned EV charging or a change in heating fuel separately.
2. Estimate Annual Solar Electricity Generation
Use a site-specific model based on the proposed array. Estimating how many solar panels to power a house should begin with annual electricity use, site conditions, and expected production—not floor area alone. A rough screening calculation multiplies system size by expected annual production per installed kilowatt:
Estimated annual production (kWh) = System size (kW) × Annual production factor (kWh per installed kW)
For example, if a 7.5 kW array is modeled at 1,350 kWh per installed kW:
7.5 kW × 1,350 kWh/kW = 10,125 kWh in the first year
The 1,350 figure is an assumption, not a national constant. Replace it with a site-specific PVWatts result or contractor model. Read any production guarantee carefully; some agreements cover operation or workmanship rather than a set number of kilowatt-hours.
3. Calculate Self-Consumption Savings and Export Credits
Divide projected output into two categories:
Solar used on-site: Multiply the kilowatt-hours consumed in the home by the retail purchases they avoid.
Solar exported to the grid: Multiply exported kilowatt-hours by the utility’s applicable export credit.
Then add the two values:
Gross annual bill reduction = Value of on-site solar + Value of exported solar
Smart-meter interval data is better than an assumed self-consumption percentage. If it is unavailable, ask which hourly load profile the installer used. A battery scenario must also include charging and discharging losses.
4. Subtract System Costs and Apply Incentives
Begin with the full installed price, including panels, inverter equipment, racking, permits, interconnection, monitoring, labor, and applicable tax. Add roof, trenching, service-panel, or structural work excluded from the base quote.
Subtract only incentives for which the project is actually eligible. Keep financing expense separate so that a cash purchase and a loan-financed purchase can be compared fairly.
For example, an $18,000 installation with a confirmed $2,000 local rebate has a $16,000 net cash cost before financing and maintenance. It should not be modeled at $10,600 by applying an expired 30% federal credit.
5. Calculate Solar Payback and Long-Term ROI
Simple payback is an easy first test:
Estimated simple payback = Net upfront system cost ÷ Estimated annual bill savings
If the net cost is $16,000 and the first-year reduction is $1,600, the simple payback is 10 years. That result does not account for financing interest, changing electric rates, panel degradation, inverter replacement, insurance, or the time value of money.
For a fuller solar panel ROI comparison, model annual cash flow over the expected ownership period. Include the remaining utility bill, loan payments, maintenance, possible replacement costs, and likely length of ownership. Run conservative, expected, and favorable cases instead of relying on one rate-escalation forecast.
For a lease or power purchase agreement, review payment escalators, transfer terms, buyout provisions, and roof-work responsibilities. The system owner generally receives the incentives.
How Can You Maximize Your Solar Savings?
Treat the array, household loads, tariff, and any battery as one system. More equipment is not automatically more economical.
Match Solar System Capacity to Your Household's Energy Needs
Size the array against annual use, the hours when electricity is consumed, roof production, and the utility’s export policy. A smaller array with a high rate of on-site use can outperform an oversized one that sells most of its production at a low credit.
Ask the installer to model at least two system sizes using the same household load data and utility rate assumptions. Compare their expected production, on-site solar use, exports, remaining grid purchases, installed cost, and payback period. Include realistic future loads, such as an EV or heat pump, but avoid adding panels solely because more roof space is available.
Shift Electricity Use to Peak Solar Production Hours
When export credits are lower than retail electricity rates, households may get more value from their solar panels by using flexible loads while the system is producing. Appliances such as dishwashers, washing machines, pool pumps, and EV chargers may be scheduled for daylight hours when practical, rather than drawing grid electricity later. The EcoFlow TITAN 5000 Plus, paired with a compatible 120V/240V EcoFlow Smart Home Panel 10, can add battery storage and circuit-level energy management to this approach Through the EcoFlow App, homeowners can monitor connected circuits and coordinate battery use around available solar generation and an applicable time-of-use rate plan. This can help reduce reliance on higher-priced grid electricity after solar production drops, although actual savings depend on the utility tariff, household usage, system losses, and installed configuration. Because the panel connects to household wiring, the compatible 120V/240V Smart Home Panel 10 must be installed by a qualified electrician in accordance with local electrical codes.
Store Excess Solar Energy for Later Use
A battery can capture production that otherwise would be exported and use it later to reduce grid purchases. This is most valuable where midday exports earn little and evening electricity is expensive. It may also provide outage protection, although backup power is a separate benefit from bill savings.
Storage does not create energy. Conversion and standby losses mean less electricity comes out than went in, and the added cost may extend payback. Compare solar-only and solar-plus-storage proposals using the same load data and rate assumptions.
For households that regularly produce more solar energy than they use during the day, the EcoFlow TITAN 5000 provides a modular way to store compatible solar generation for later household use. It starts with 5kWh of capacity, supports up to 4kW of compatible solar input, and can expand up to 30kWh as the household’s storage needs grow. Using that stored energy after solar production drops may reduce evening grid purchases, particularly where export credits are lower than retail electricity rates.
Choose a Utility Plan That Rewards Solar Energy Use
Review every rate plan available to solar customers. A time-of-use plan may reward a battery that discharges during an expensive evening period, yet the same plan can increase costs if the household regularly imports power at that time.
Model a year of expected imports and exports under each eligible plan. Check seasonal time periods and any demand charge based on the customer’s highest interval. Revisit the choice after adding an EV, heat pump, or battery.
Maintain Solar Panels to Preserve Energy Production
Most rooftop arrays need limited routine maintenance. Monitor production so an inverter fault, communication problem, or sudden decline does not go unnoticed. Compare performance with the same season in prior years.
Rain handles much ordinary dust. Where pollen, bird droppings, ash, or heavy soiling persists, follow the manufacturer’s instructions or use a qualified provider. Avoid pressure washers and unnecessary roof work. Contact the responsible company before repairs if the array is leased or under warranty.
Solar savings are determined at the meter, not by a national headline. A homeowner needs four figures to begin: annual electricity use, site-specific solar production, the value of power used in the home, and the utility’s export credit. The installed cash price and financing terms then show whether the project makes sense.
In 2026, that calculation also needs to reflect the end of the federal residential clean-energy credit for newly completed homeowner installations. State and utility programs may still improve the economics, but they should be verified before appearing in a proposal.
Use several scenarios and keep the assumptions visible. A well-sized array may deliver substantial long-term savings, while load shifting or a battery may improve the value of midday generation. The strongest proposal is the one whose production, rate, cost, and usage assumptions can be checked against the home that will use the power.
How Much Efficiency Do Solar Panels Lose on a Cloudy Day?
Solar panels generally produce less electricity on cloudy days because less sunlight reaches the cells. The reduction varies with cloud thickness, weather conditions, and time of day. Panels can still generate electricity from diffuse daylight, but their output may be substantially lower than under clear skies.
Do Leased Solar Panels Increase Home Value?
No, leased solar systems rarely add equity to your property and can occasionally complicate the selling process. Because third-party leasing companies own the equipment, prospective home buyers must either agree to assume the remaining lease terms and credit checks or request that the seller buy out the contract prior to closing.
What Is the Biggest Downside to Solar Electricity?
The primary drawback of solar electricity is its intermittent generation curve paired with high initial installation costs. Solar arrays cannot produce power at night, meaning homeowners without battery storage remain tethered to the utility grid and vulnerable to utility blackouts and peak evening tariffs.
Does Your Insurance Go Up if You Have Solar Panels?
Installing rooftop solar panels may affect homeowners insurance premiums if the system increases the property’s insured replacement value. Many insurers cover permanently attached rooftop panels under dwelling coverage, but terms, exclusions, and coverage limits vary. Contact your insurer before installation to confirm whether additional coverage or a policy adjustment is needed.
How Much Efficiency Do Solar Panels Lose After 30 Years?
Quality solar panels typically lose approximately 15% to 18% of their original production efficiency over a 30-year operational lifespan. With industry-standard annual degradation averaging around 0.5% per year (plus 1% to 2% first-year light-induced degradation), high-tier panels will still reliably produce 82% to 85% of their initial rated nameplate capacity well past their standard 25-year manufacturer warranties.
