Solar Panel Wattage Explained: What the Rating Means, What You Actually Get, and How to Estimate Daily Output
You set up a new 400W solar panel in the afternoon, connect it to your power station, and see 280W on the display. Is something wrong? Generally not. The wattage printed on a panel describes what it produces in standard test conditions, while the display shows what it’s producing in the current sunlight and temperature. Watt-hours tell you the energy produced over time. These three numbers will help you to guess what you will output every day and to choose a panel that works for your setup.
What Solar Panel Wattage Means: The STC Rating and the Rest of the Spec Sheet
Solar panel wattage measures the maximum power a panel can produce under standard test conditions (STC). Those conditions include 1,000 watts of sunlight per square meter, a cell temperature of 77°F (25°C), and an air mass of 1.5. A rooftop or campsite rarely matches all three conditions at once, so real-world output often falls below the rating.
What Solar Panel Wattage MeansWhat Solar Panel Wattage Means
How to read a solar panel spec sheet
The wattage rating is only one part of a panel's specifications. You'll also know how it will perform and if it will work with your power station, including the voltage, current, and efficiency.
Specification
What it tells you
Rated power (W)
The panel's maximum output under standard test conditions, such as 220W or 400W.
Open-circuit voltage (Voc)
The voltage measured when the panel isn't connected to a load. Check this against your power station's maximum solar input voltage.
Operating voltage (Vmp)
The voltage at which the panel produces its rated maximum power under test conditions.
Operating current (Imp)
The current the panel produces at its maximum power point under test conditions.
Conversion efficiency
The percentage of incoming sunlight the panel converts into electricity.
Maximum system voltage
The highest system voltage the panel is designed to support under its stated specifications.
Voc deserves special consideration when matching a solar panel with a portable power station or charge controller. If the open-circuit voltage of the panel is above the limit of the device, they might not be compatible. Check voltage and current ratings before connecting your equipment. Once the label of the panel is known, it is easier to estimate its energy production. You'll need its rated wattage, peak sun hours for your location, and a margin for energy losses. This makes calculating solar panel output more straightforward. The difference between rated watts, live output, and daily energy is best illustrated by comparing two portable solar panels.
Rated watts, live output, and watt-hours: EcoFlow NextGen 220W Bifacial vs. EcoFlow 400W Portable Solar Panel
A 220W panel and a 400W panel differ in more than just size. The rated wattage is the amount of power that a panel can produce under standard test conditions. The live output is what the panel is producing given the current sunlight and temperature. Watt-hours are a measure of energy over time. They allow you to compare what each panel might add to your system.
Three numbers to know
  • Rated watts (W): The panel's rated power under standard test conditions, such as 220W or 400W.
  • Live output (W): The power produced at that moment. Heat, cloud cover, shade, and low sunlight can reduce output.
  • Watt-hours (Wh): The energy generated over time. For example, a panel averaging 150W for four hours produces 600Wh.
How the two panels compare
The EcoFlow NextGen 220W Bifacial Portable Solar Panel is a practical option when portability and storage matter. It weighs 15.4 lb and folds to 24.2 × 23.2 × 1.3 inches. Its rear side has a separate 175W rating, but actual rear-side output depends on reflected sunlight. The front and rear ratings should not be added together to promise 395W of output. The EcoFlow 400W Portable Solar Panel suits setups with more room to unfold a larger panel and a power station that supports its output. Although its rated wattage is higher, actual output depends on sunlight and the power station's maximum solar input and supported voltage range.
What could each panel generate in a day?
With five peak sun hours, an illustrative estimate using a 14% loss allowance puts the 220W panel at around 950Wh per day and the 400W panel at around 1,720Wh per day. The loss allowance comes from NREL's PVWatts default for rooftop systems, so these figures are estimates rather than guaranteed results for portable panels. Peak sun hours vary by location and season, and actual production depends on weather, positioning, and system losses. Use NREL's PVWatts calculator to estimate solar production for your location. Both panels have their strengths, depending on how much power you need and how much space you have. Compare their specifications below to find the better fit for your setup.
• Bifacial Design: The two-in-one bifacial design collects up to 25% more energy. •High Efficiency: Up to 25% conversion efficiency rate. • Adjustable Angle: 30 to 60° adjustable angle bracket with an integrated solar angle guide. • Durable Build: Tempered glass and ETFE coating, with an IP68 rating against water and dust. • Ready to Charge: Lightweight, compact, and portable, with the solar-to-XT60 charging cable included.
If portability matters less and you need more power for your setup, the EcoFlow 400W Portable Solar Panel offers a higher rated output, with up to 23% conversion efficiency and an adjustable stand for positioning it toward the sun.
•400W Solar Input: Charges faster with a high 400W solar input. • High Conversion Rate: Converts sunlight to power at up to 23%. •Built to Last: Made from durable, multi-layered materials, with an IP68 waterproof rating. •Easy Setup: A one-piece folding design that stands on its own, with an adjustable angle. • Cable Included: Comes with the solar to XT60 charging cable.
Light-colored surfaces can reflect more sunlight onto a bifacial panel's rear side, potentially increasing its output. This comparison of bifacial and monofacial 220W panels explains when the extra rear-side generation can make a difference. Actual daily output also depends on peak sun hours, which vary by location, season, and weather.
How Much Power Does a Solar Panel Produce Per Day?
Even if you have a 100-watt panel, the amount of solar power produced each day is based on how much sunlight is hitting your panel. Peak sun hours are the number of hours of equivalent full sun (1,000 watts per square meter) that a location gets. Five peak sun hours doesn't mean the sun shines for only five hours. It means the day's total solar energy is equivalent to five hours at that intensity.
Estimate your daily solar output
Use these steps to estimate how much energy your panel might generate.
  1. Find your peak sun hours. Use the NREL PVWatts calculator to estimate solar production for a location and time of year.
  2. Multiply the panel rating by peak sun hours. A 400W panel with five peak sun hours has a starting estimate of 2,000Wh.
  3. Allow for losses. For a basic estimate, multiply by 0.86 to account for a 14% loss assumption.
  4. Adjust for real conditions. Heat, shade, dust, and poor positioning can lower output further.
Using that method, the 400W example produces an estimated 1,720Wh per day. A cloudy day or a hot panel could deliver less. A different location or season could produce more.
Peak sun hours
220W panel, after 14% assumed losses
400W panel, after 14% assumed losses
3
568Wh
1,032Wh
4
757Wh
1,376Wh
5
946Wh
1,720Wh
6
1,135Wh
2,064Wh
These estimates aren't guaranteed. NREL's PVWatts calculator accounts for system losses and uncertainty, and its default 14% loss assumption is based on rooftop systems, so portable panels may perform differently. Weather matters too: as explained in this guide to how solar panels work, sunlight levels change with the season, and thick clouds can reduce output.
Solar Panel Sizes and Wattage: From One Cell to a Rooftop System
A solar panel contains many connected solar cells. The U.S. Energy Information Administration says a single solar cell typically produces only 1 or 2 watts, so manufacturers connect many cells to produce useful amounts of power. Rooftop modules commonly reach around 400W or more, while portable panels often trade some output for easier transport and storage.
How panel size affects wattage
Solar setup
Typical rating or scale
What to know
Individual solar cell
About 1W to 2W
A single cell produces little power on its own.
Portable solar panel
Examples include 220W and 400W
Designed for movable setups, camping, and portable power stations.
Rooftop solar module
Often around 400W or more
Built for fixed installation and connected into a larger system.
Residential solar system
Depends on the home's needs and available roof space
Uses multiple modules to meet a household's electricity needs.
The wattage of a solar panel is based on the number of cells, the technology, and the efficiency. The median U.S. residential solar system size in 2025 was 7.7 kW, or about 19 panels rated at 400W each, according to Lawrence Berkeley National Lab. Panels of the same size can still produce different amounts of power because their types and efficiency influence how effectively they convert sunlight into electricity. Depending on technology, some high-efficiency modules are reaching upwards of 25 % conversion efficiency. Don't select panels on wattage alone. Consider roof space, shading, orientation, and household electricity usage when planning a home installation.
What lowers solar panel output: heat, angle, shade, and bifacial expectations
A panel's real output often falls short of its rated wattage because sunlight and operating conditions change throughout the day. Four factors are especially useful to check: temperature, angle, shade, and the surface beneath a bifacial panel.
What lowers solar panel outputWhat lowers solar panel output
Heat reduces output
Solar panels are tested at 77°F, but summer heat can push cell temperatures much higher and reduce power output. NREL's PVWatts model uses a temperature coefficient of −0.37% per °C for standard panels in current versions (V7/V8). For example, a 400W panel operating at a cell temperature of 65°C (149°F)—assuming a standard 25°C baseline—would experience a 40°C temperature rise ($$40 \times -0.37\% = -14.8\$$), resulting in an output of about 341W under otherwise similar sunlight conditions. Actual output varies by panel and weather, so keep portable panels well ventilated to help limit heat buildup.
Angle changes how much sunlight reaches the panel
Panels produce more power when sunlight hits them closer to perpendicular. For a portable panel, adjusting the angle as the sun moves can help maintain output. Fixed rooftop panels use an orientation and tilt suited to their location and installation.
Shade and dirt cut production
Even partial shade can reduce output, depending on the panel's design and where the shade falls. Dust, pollen, leaves, and bird droppings can also block sunlight. Clear the panel surface as needed, and move it away from trees, buildings, or other objects that cast shadows.
Bifacial panels need reflected light
A bifacial panel can collect sunlight on both sides. The rear side works best when light can reach it and reflect back from the surface below. Pale concrete or sand may reflect more light than dark soil or grass, but the gain depends on the environment. Treat rear-side production as a possible bonus, not a guaranteed percentage.
Quick checks for better solar output
If your panel is producing less power than expected, check these basics before assuming something is wrong:
  • Check live output: Read the power station's display to see how much power the panel is generating.
  • Confirm compatibility: Make sure the panel's voltage and current fall within the power station's supported range and maximum solar input.
  • Adjust the angle: Position the panel toward the sun and readjust it as the sun moves.
  • Check for shade and dirt: Even partial shade can reduce output. Clear dust and debris from the panel surface.
  • Allow airflow: Keep the panel ventilated and avoid trapping heat beneath or around it.
  • Consider the weather: Cloud cover, hazy skies, and low morning or evening sun can reduce output even when the panel is working properly.
  • Check the cables and connections: Ensure the charging cable is connected securely and is compatible with your equipment.
  • Compare under similar conditions: Check output at similar times and in similar sunlight before deciding whether the panel is underperforming.
The sun's angle changes with location and season, so the best tilt varies too. If you want to set up a fixed system, this guide to solar panel angle explains what to consider.
Solar panel wattage tells you what a panel can produce under standard test conditions. Live output changes with sunlight, temperature, shade, and the limits of the device receiving the power. Daily energy depends on how those conditions add up over time. For a starting estimate, multiply rated watts by your peak sun hours and then by about 0.86 to allow for assumed system losses. Use NREL's PVWatts calculator for a location-based estimate, and check your power station's solar input limits before connecting a panel. If portability matters most, consider the EcoFlow NextGen 220W Bifacial Portable Solar Panel. If you have more room and your power station supports input, the EcoFlow 400W Portable Solar Panel offers a higher rated output.
What is the wattage of a typical solar panel?
Many current rooftop modules are rated around 400W or higher, while portable panels cover a wider range. EcoFlow's portable options include a 220W bifacial panel and a 400W panel. The right rating depends on your available space, energy needs, and receiving device.
How much power does a 400W solar panel produce per day?
Assuming a 14% loss factor and 5 peak sun hours, a 400W panel could generate around 1720Wh or 1.72kWh in a day. The actual output will vary by location, season, heat, shade, and angle of the panels.
Why is my solar panel producing less than its rated watts?
Rated wattage is based on standard test conditions of 77°F cell temperature and 1,000 watts of sunlight per square meter. Live output can be reduced by heat, clouds, low sun angle, shade, dirt, and the power station’s input limit.
How many watts does one solar cell produce?
The U.S. Energy Information Administration says a single solar cell typically produces about 1 or 2 watts. Manufacturers connect many cells to create panels with higher output ratings.
Can you add a bifacial panel's front and rear ratings?
No. The rear-side rating describes its potential under specified test conditions, and actual rear output depends on reflected light reaching the panel. Treat it as variable extra production rather than adding the front and rear ratings together.
Solar Panels
