Kitchen Renovation: What It Really Costs, How Long It Takes, and How to Plan One
A kitchen renovation touches almost every system in a house at once: plumbing, electrical, flooring, and cabinetry, all on the same tight schedule. That overlap is exactly why timelines slip and budgets grow past the original estimate. A straightforward kitchen renovation can take around 60 days, while material and fixture costs for a mid-size kitchen can start at roughly $18,000, depending on the scope, materials, and location. This guide breaks down the real timeline phase by phase, what different kitchen sizes actually cost, current design directions, and how to vet a contractor before signing anything.
How Long Does a Kitchen Renovation Actually Take?
Most homeowners underestimate how long a kitchen renovation takes because they only picture the visible work. The full timeline includes several phases most people never see.
Phase
What happens
Typical duration
Prep
Demo, plumbing and electrical updates, wall repair, painting, most flooring, finalizing design and ordering materials
Varies by project
Install the essentials
Cabinet installation, custom countertop fabrication and installation
Cabinets: about 1 day once on site. Countertops: often 3 to 4 weeks for fabrication and scheduling after measurements
Finishing touches
Backsplash, final plumbing and electrical hookups, appliance connections, paint and cleaning
About 2 weeks
Added together, a straightforward kitchen renovation often lands around 60 days start to finish. Custom orders, permitting, and contractor scheduling can extend that well beyond two months. Planning around that reality, rather than a shorter estimate, saves a lot of frustration partway through the project. It also helps to look at how DIY home improvement projects typically get sequenced. The same scheduling logic applies well beyond just the kitchen.
With a two-month project as the realistic baseline, most households immediately face a practical question: how to function without a kitchen for weeks. It starts with power.
Staying Powered When Your Kitchen Circuit Goes Down
A kitchen renovation does not just remove counters and cabinets. It frequently removes power too, for stretches that can last days at a time.
Kitchen circuits are frequently de-energized during electrical rough-in, appliance disconnection, and final hookups. That means the refrigerator, coffee maker, and other essentials may need to run from somewhere else in the house temporarily. Contractors doing electrical or plumbing work near the kitchen panel may also need to work on other circuits, extending outages beyond just the kitchen itself.
A portable power hub also solves a second renovation problem. Grinders, sanders, and saws often draw more than a standard household outlet can reliably deliver. Running them safely usually means finding another power source, not a full rewire just to get through the job. It's worth reading through a full breakdown of powering tools and appliances through a renovation without relying on overloaded circuits before the demo work starts.
EcoFlow DELTA Pro Ultra X
1. 100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity. 2. Plug & play design, installed in 7 days. Save up to 80% on time and cost. 3. Smart & reliable when it matters most, 20ms auto switchover. 4. Save up to $6000/year, 3-year ROI. 5. End-to-end system protection, the highest safety standards.
EcoFlow DELTA Pro 3
1. Powerful and Versatile: Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed. 2. Continuous Output While Charging: Provides stable, uninterrupted power at 120/240V with a maximum continuous output of 4000W, even during pass-through charging. Endless energy: Compatible with portable generators, auto recharging when connecting with EcoFlow Smart Generator 4000. 3. Longer Life Cycle: Retains 80% capacity even after 4000 cycles, thanks to advanced EV-grade LFP battery technology.
EcoFlow DELTA 2 Max
1. Expandable capacity - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use. 2. Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles. 3. Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
With power planning covered, here's what a renovation this size typically costs, broken down by kitchen size.
Kitchen Renovation Costs by Size
 Kitchen Renovation Costs by Size Kitchen Renovation Costs by Size
Kitchen renovation costs scale with square footage, but not in a perfectly straight line. Fixed costs like appliances and plumbing fixtures stay similar across sizes.
Kitchen size
Approximate area
Starting cost (materials and fixtures only)
Medium
Roughly 100 to 200 sq ft
About $17,800
Large
Roughly 200 to 300 sq ft
About $25,500
Both figures cover cabinets, appliances, custom countertop, lighting, and a sink and faucet, with cabinets and appliances typically representing the largest individual costs. These figures cover materials and fixtures only. Labor, installation, demolition, permitting, and any plumbing or electrical work add to the total, often substantially, depending on the project's scope. Nationally, the U.S. Census Bureau reports that new homeowners spend a median of about $3,900 a year on home improvement projects overall. That is well below what a single kitchen renovation alone commonly costs.
Costs vary significantly by region, material choices, and labor rates. Treat these figures as a starting-point benchmark rather than a firm quote for any specific project. Getting a realistic number usually means comparing them against home renovation costs across different project types, not just a kitchen alone.
With a budget range in mind, the next planning step is usually figuring out what direction to actually take the design.
Kitchen Renovation Ideas and Layout Styles
Layout and style decisions shape both the budget and the daily experience of the finished kitchen. Most homeowners land on one of a few well-established directions.
Layout options worth considering:
  • Galley kitchens maximize efficiency in a narrow footprint.
  • U-shaped and L-shaped layouts add counter and storage space.
  • Open-concept designs with a central island remain a popular choice for households that entertain or want the kitchen connected to the living space.
Style directions currently popular:
  • Modern and minimalist kitchens lean on clean lines and integrated appliances.
  • Farmhouse and coastal styles favor warmer wood tones, open shelving, and lighter palettes.
  • Industrial and mid-century looks bring in exposed materials, bold color, and statement lighting.
A bold backsplash, updated hardware, or a waterfall-edge countertop can meaningfully change a kitchen's look. None of that requires the cost or disruption of a full layout change. That kind of targeted upgrade follows the same logic as return on investment for home improvement generally. It means spending less to change more of what people actually notice day to day.
Once the design direction and budget are set, the last major planning step is finding the right person to actually build it.
Finding and Vetting a Kitchen Renovation Contractor
kitchen renovation contractorkitchen renovation contractor
Design and budget decisions only matter if the person building the kitchen executes them correctly. Vetting a contractor properly takes real time, and it is worth every minute of it.
Confirm licensing and insurance before signing anything. The Federal Trade Commission recommends verifying a contractor's license through the local building department. It also recommends requesting proof of liability, worker's compensation, and property damage coverage before work begins. A legitimate contractor should provide both without hesitation, and doing this protects the homeowner if something goes wrong mid-project.
Get at least three detailed quotes for the same scope of work. Ask each contractor for recent references or photos of comparable kitchen projects, not just a general portfolio. When searching for a kitchen renovation contractor nearby, cross-reference online reviews with the contractor's standing with the local licensing board. A high star rating does not always reflect a clean compliance history.
For anyone whose renovation involves updating outlets, circuits, or the panel itself, home rewiring adds its own timeline and cost. It helps to understand the costs and safety basics of rewiring a home before that work starts.
A typical kitchen renovation runs about 60 days across prep, installation, and finishing phases. Material costs commonly start around $18,000 for a medium kitchen and $25,000 or more for a larger one. Plan for the kitchen circuit going down during electrical work, budget beyond materials alone, and vet any contractor's licensing and references before signing. EcoFlow's DELTA Pro Ultra X, DELTA Pro 3, and DELTA 2 Max cover whole-home and temporary-kitchen backup power for the length of the project.
How long does it take to renovate a kitchen?
A straightforward kitchen renovation typically takes about 60 days from prep through finishing touches. Custom cabinet or countertop orders, permitting delays, and contractor scheduling can extend that well beyond two months.
How much does a kitchen renovation cost?
As a starting benchmark, materials and fixtures are estimated at about $17,800 for a medium kitchen and $25,500 for a larger one. Actual costs can vary significantly based on location, materials, appliances, labor, and project scope.
How do I find a reliable kitchen renovation contractor near me?
Confirm licensing and insurance, get at least three detailed quotes for the same scope of work, and check references from recent, comparable projects. Cross-reference online reviews with the contractor's actual standing on the local licensing board.
What are the most popular kitchen renovation ideas right now?
Open-concept layouts with a central island are currently the most requested design. Modern and minimalist styles, farmhouse and coastal palettes, and industrial or mid-century looks are all common style directions within that layout.
How do I keep my refrigerator running if my kitchen power gets shut off during renovation?
A portable power station like the EcoFlow DELTA Pro Ultra X or DELTA Pro 3 can keep a refrigerator running. It can also keep other essential circuits powered during electrical work. Smaller options like the DELTA 2 Max work well for a temporary countertop kitchen setup elsewhere in the house.
Home Solutions
