How to Keep a Greenhouse Warm in the Winter
An unheated greenhouse can still get cold enough to damage plants, even after a sunny afternoon. Clear winter nights are especially tough because the heat stored during the day can disappear quickly after sunset. Learning how to keep a greenhouse warm in the winter starts with the basics. Keep as much daytime heat as you can, slow down overnight heat loss, and have a backup heat source ready for the coldest nights. A few changes to the greenhouse itself can make a noticeable difference before you ever turn on a heater.
Passive Ways to Trap Daytime Heat
Sunlight is your cheapest source of heat, so make the most of it before reaching for an electric heater. A few simple changes can help your greenhouse collect more warmth during the day and hold onto it after sunset.
Get the most from available sunlight
If you have a choice in how the greenhouse sits, orienting it toward true south can help it capture more sunlight during the day. Clean glazing matters, too. Dirt, algae, and grime can block some of the light you want coming through the panels. The goal is to give the greenhouse as much direct winter sun as your property allows. Keep nearby branches trimmed if they're blocking the glazing, and check the panels before winter settles in.
Close the greenhouse before sunset
Once the sun starts going down, close the doors and vents. Leaving them open can let the warm air you've built up during the afternoon escape before the coldest part of the night arrives. Make this part of your evening routine during cold weather. If you have automatic vents, check their settings so they aren't opening when you need the greenhouse sealed.
Add an inner layer of bubble wrap
Bubble wrap can add another layer between the plants and the cold outside air. Hung along the inside of the greenhouse, it creates a rough double-glazing effect that helps slow heat loss. You don't need to cover every surface blindly. Focus on the areas where heat escapes most easily while leaving enough access for ventilation and plant care. If you're also using solar power for your greenhouse, solar-powered greenhousescovers ways to combine solar energy with greenhouse growing. Keeping daytime heat is a good start. The next challenge is holding onto that heat after the sun goes down.
Using Thermal Mass to Even Out Temperature Swings
A greenhouse can heat up quickly during a sunny winter day and cool down just as quickly at night. Thermal mass helps slow that swing by storing some of the daytime heat and releasing it after dark.
Put water barrels where the sun reaches them
Dark-colored water barrels are one of the easiest ways to add thermal mass. Place them near the south-facing wall where they can absorb sunlight during the day. As the greenhouse cools at night, the stored heat is released gradually. The barrels don't need to be fancy. What matters is having enough water exposed to the daytime warmth and enough space to keep them from getting in the way of your plants.
Use stone and other heavy materials
Stone, cinder blocks, and gravel can also absorb heat during the day and give some of it back after sunset. A gravel path or masonry surface inside the greenhouse can do double duty as a walkway and thermal mass. These materials won't replace a heater during a severe cold snap. They can, however, help reduce the size of the temperature swing between afternoon and overnight.
Consider the heat from compost
A well-managed compost pile can produce heat as organic material breaks down. If you have enough space, placing one inside the greenhouse can add another source of warmth. Keep it managed properly and away from plants that could be affected by excess moisture or pests. For growers starting plants ahead of spring, starting seeds indoors can also take some pressure off the greenhouse during the coldest part of winter. Passive heat sources can help smooth out temperature swings, but they may not be enough during a hard freeze. That's when supplemental heat and a reliable backup power source can help protect plants from a sudden temperature drop.
Backing Up Heat When Passive Methods Aren’t Enough
On a very cold night, even a well-insulated greenhouse may need supplemental heat. A small electric heater can warm the growing area, while seedling heat mats let you put heat where tender plants need it most. A power outage can make the situation harder. If the greenhouse depends on electric heat, losing grid power during a cold snap can leave plants exposed to falling temperatures. Having stored battery power available gives you another option if the electricity goes out.
If you're planning for longer outages or need to run heating equipment for several hours, you'll want more battery capacity. The EcoFlow DELTA 3 Max gives you 2,048Wh of stored energy and supports heavier loads with X-Boost.
Backup power gives you another option during a cold snap or outage. But you don't always need to heat the entire greenhouse, especially when only a few plants need extra protection.
When Electric Heat Still Makes Sense
Electric heat works best when you use it where it's needed. You don't necessarily need to heat every square foot of the greenhouse to protect a few sensitive plants.
Use seedling heat mats for tender plants
Seedling heat mats put warmth directly under trays and containers. That makes them useful when your main concern is protecting young plants rather than raising the temperature of the entire greenhouse. They're also a smaller electrical load than heating the whole structure. If only a few trays need extra warmth, targeted heat can make more sense than running a space heater all night.
Let a thermostat control the heater
A thermostat-controlled space heater can turn on when the temperature drops below your set point and shut off as the greenhouse warms. That keeps the heater from running continuously when the sun comes back out. Use a heater that's appropriate for the greenhouse environment and follow its safety instructions. Keep cords and electrical equipment protected from water and condensation.
Heat the plants that need it most
Group cold-sensitive plants together instead of spreading them across the greenhouse. You can then focus your supplemental heat on one area rather than trying to warm the entire structure. This approach can also reduce the amount of stored power you need during an outage. For a more tailored setup, greenhouse battery heating covers how to size battery-based heating around your greenhouse and heating needs.
Sealing Drafts and Insulating the Structure
A heater has to work harder when warm air is leaking through gaps around doors, vents, and other openings. Before adding more heat, check the greenhouse itself for places where cold air gets in.
Seal gaps around doors and vents
Weatherstripping can close small gaps around doors and vents. Check the seals before winter and replace sections that have become cracked, loose, or worn. Pay attention to the bottom of doors and corners. Small gaps may not look like much during the day, but they can let warm air escape for hours overnight.
Add a windbreak
Strong winds can increase heat loss from the greenhouse. Shrubs, fencing, or another suitable windbreak on the side facing prevailing winter winds can reduce that exposure. Keep the windbreak far enough away that it doesn't block useful winter sunlight. You want protection from the wind without putting the greenhouse in permanent shade.
Insulate the north-facing wall
The north-facing side gets little or no direct winter sunlight, so it's a logical place to focus additional insulation. A reflective barrier or added insulation on that wall can help reduce heat loss. Don't block glazing that could collect winter sun. If you're working on insulation around the house at the same time, understanding R-value can help you compare insulation performance and choose where an upgrade makes the most sense.
Knowing how to keep a greenhouse warm in the winter comes down to managing heat before and after sunset. Start by capturing as much winter sunlight as possible, then use bubble wrap, thermal mass, draft sealing, and insulation to slow the heat from escaping. For colder nights, targeted electric heat can protect seedlings and other sensitive plants without heating the entire greenhouse. A battery backup such as the EcoFlow DELTA 3 Plus or EcoFlow DELTA 3 Max can also keep compatible heating equipment running during a power outage.
How can I heat my greenhouse without electricity?
You can rely on passive methods to keep your greenhouse warmer. Maximize winter sunlight and close the vents and doors before sunset. Adding bubble wrap and thermal mass can also help. Water barrels, stone, gravel, and a well-managed compost pile can store heat during the day. They slowly release that heat overnight.
What temperature should a greenhouse stay above in winter?
The right temperature depends on what you're growing and how much cold those plants can handle. Some plants can tolerate cooler nights, while tender seedlings may need more protection. Check the temperature range for your specific plants before deciding whether you need supplemental heat.
Does bubble wrap really help insulate a greenhouse?
Yes. Hanging bubble wrap along the inside of the greenhouse adds an extra air layer that slows heat loss through the glazing. It can help the greenhouse hold onto more of the warmth it collects during the day, especially after the sun goes down.
Is it worth running an electric heater in a greenhouse all winter?
That depends on the plants you're growing and how cold your greenhouse gets. A thermostat-controlled heater can make sense for sensitive plants during cold nights, while seedling heat mats can provide targeted warmth without heating the entire structure.
What plants can survive a greenhouse without heating?
Some cold-hardy plants can tolerate winter conditions without supplemental heat, but the answer depends on the plant and your local temperatures. Check each plant's temperature tolerance before leaving it in an unheated greenhouse.
