Small Generator for Home: 5 Top Picks and How to Size One Right
The power goes out at 9 p.m. The house turns dark and quiet. What matters most now is a cold fridge and a working sump pump, not the whole house.
A small generator for home use can cover those needs. Whether it does depends on one number that many shoppers skip: starting watts. Motors in fridges and pumps pull far more power for a moment when they kick on.
This article sets out a simple sizing method with sourced wattages. It compares gas, inverter, and battery options fairly. It also covers the safety limits that decide where each type can run.
Best Small Generators for Home: 5 Top Picks
Top-ranking reviews keep landing on the same handful of small inverter generators. Most add one battery option for indoor use. The table below puts them side by side. Every figure comes from each maker's own site. Makers measure noise and run time at different loads, so the numbers work as rough guides, not a head-to-head test.
Pick
Best for
Type
Starting / running watts
Run time (maker's load)
Noise (maker's rating)
Weight
CO safety feature
Honda EU2200i
Quiet, proven all-rounder
Gas inverter
2,200 / 1,800W
3.2 hr at rated load; 8.1 hr at 1/4 load
57 dB(A) at rated load; 48 dB(A) at 1/4 load
47.4 lb dry
CO-MINDER auto shutdown
3 years residential
Yamaha EF2200iS
A 2,200W alternative with a bigger tank
Gas inverter
2,200 / 1,800W
10.5 hr at 1/4 rated load
57 to 65 dBA (1/4 to rated load)
55.2 lb dry
CO sensor with automatic shutdown
3-year limited
Champion 4000-Watt Dual Fuel Inverter (201050)
More power and a propane option
Dual fuel inverter
4,000 / 3,000W gas; 4,000 / 2,700W propane
Up to 10 hr gas, 25 hr propane (20-lb tank), at 1/4 load
64 dBA from 23 ft
51.8 lb
CO Shield auto shutoff
3-year limited
WEN 56235i
Budget buyers who want the lightest unit
Gas inverter
2,350 / 1,900W
Over 5.7 hr at half load
51 dB at quarter load
39 lb
Not listed on this model
2 years
EcoFlow DELTA 3 Max (2048Wh)
Indoor use, apartments, no fuel
Battery power station
4,800W surge / 2,400W rated
It depends on load (estimates in H2 #3)
25dB or less at 600W
About 45 lb (EcoFlow lists 20.3 kg)
No engine exhaust
Up to 5 years (3 standard + 2 with app registration)
Each row lists both numbers because the gap between starting and running watts decides whether a unit can start a pump or a fridge compressor. A short note on each pick follows.
  • Honda EU2200i. This unit covers a fridge plus a few small loads. Honda lists it as "Not for sale in California," so shoppers in that state need a compliant alternative.
  • Yamaha EF2200iS. It sits in the same output class as the Honda, with a larger 1.24-gal tank. Yamaha's US page still shows the 2021 model year, so the current listing is worth a check.
  • Champion 201050. This is the only dual fuel pick. Its 4,000W starting rating leaves the most headroom of the gas picks when a 1/2 HP sump pump (2,150W start) kicks on while the fridge runs. That combined start is 2,150 + 192 = 2,342W, based on the Honda wattage table in the next section. The 2,200W Honda and Yamaha fall short of it. The WEN's 2,350W clears it by only 8W. Champion states that the unit is EPA certified.
  • WEN 56235i. It is the lightest and lowest priced of the gas picks, with WEN listing $509.99. No CO shutoff is listed on this model, so CO alarms matter here. WEN sells a separate CO-sensor version, the 56235iX, which was not verified for this article.
  • EcoFlow DELTA 3 Max. This is the only pick that can run indoors. Its limit is stored energy, not fuel.
Every gas pick still runs outdoors only, at least 20 feet from the house, per the Consumer Product Safety Commission (CPSC). That rule applies no matter how quiet the engine sounds.
The picks show what is available. The right one depends on the appliances that must keep running, so sizing comes next.
Sizing Small Household Generators, One Appliance at a Time
Sizing starts with a simple sum. Add the running watts for everything that runs together. Then, for the appliance with the biggest jump at startup, swap its running watts for its starting watts. The starting figures in the table are the total draw at startup, not an extra amount, so adding one on top of the running total would count that appliance twice. Honda advises against simply totaling every wattage, so staggering big loads helps.
The table below uses the Honda Power Equipment wattage estimation guide, checked 2026-09-28.
Appliance
Running watts
Starting watts
Refrigerator/freezer (ENERGY STAR)
132 to 192
1,200
Sump pump (1/3 HP)
800
1,300
Sump pump (1/2 HP)
1,050
2,150
Furnace fan (1/4 HP)
600
1,000
Window AC (10,000 BTU)
1,500
2,200
Microwave (650W)
1,000
1,000
Coffee maker
600
600
Garage door opener
720
1,420
Laptop
200 to 250
200 to 250
Honda lists the 1/2 HP sump pump as a 240V load. Check your pump's nameplate, since a 240V appliance needs a 240V power source.
A Worked Example
This is an example, not a rule for every home. A refrigerator (192W), a 1/2 HP sump pump (1,050W), and a 46" TV (190W) total 1,432W running.
Now the pump starts while the others run. The math becomes 192 + 190 + 2,150 = 2,532W, needed for a moment.
The takeaway is plain. For a home with a sump pump, a unit's surge rating matters as much as its running rating.
Matching Size to Three Common Needs
  • Apartment or condo essentials. A fridge, laptop, phones, and lights make up this list. No motor beyond the fridge compressor is involved, so the load stays modest.
  • Basement home. A fridge plus a sump pump is surge-heavy. The plan has to cover the pump's start, not only its running draw.
  • Summer outage. A fridge plus a window AC brings a running draw of about 1,630 to 1,690W. The AC, at 1,500W, dominates runtime.
Knowing what a 2,000-watt generator can realistically handle gives a useful reference point for the smallest of these setups.
With a target wattage set, the choice shifts to fuel. The options are gas, a quieter inverter generator, or a battery that runs indoors.
Gas, Inverter, or Battery: The Best Small Home Generator for Your Needs
All three types can hit the same wattage. They differ on where they can run, noise, fuel, and upkeep. The best pick depends on how a household lives, not on a ranking.
Conventional gas portable
Gas inverter generator
Where it runs
Outdoors only, 20+ feet from the house (CPSC)
Indoors; no exhaust
Fuel
Stored gasoline, kept out of living areas (CPSC)
Recharges from wall, solar, or a generator
Runtime
As long as fuel lasts
Limited by stored capacity (Wh)
Noise
Engine noise (no figure cited)
Generally quieter than conventional (no figure cited)
EcoFlow DELTA 3 Max: 25dB or less at 600W
Battery Runtime Examples
These are estimates. The formula is capacity × 0.85 ÷ load.
  • EcoFlow DELTA 3 Max with a fridge, TV, and laptop. The math is 2,048 × 0.85 ÷ 632W, or about 2.8 hours of continuous draw. Real runtime runs longer because the fridge cycles on and off.
  • EcoFlow DELTA 3 Max with the worked example above. Its 2,400W rated output covers the 1,432W running load, and its 4,800W surge covers the 2,532W pump start, provided the pump is a 120V model. Check the pump's nameplate first: the EcoFlow DELTA 3 Max outputs 120V, and the Honda table lists a 1/2 HP sump pump as a 240V load, which needs a 240V power source instead.
  • EcoFlow DELTA Pro Ultra X (standard 12kWh bundle) with a fridge, a 1/4 HP furnace fan, and a 1/2 HP sump pump. The load totals 1,842W, so 12,000 × 0.85 ÷ 1,842W gives about 5.5 hours of continuous draw. Motors cycle, so real runtime varies.
A Long Outage Plan
The EcoFlow DELTA 3 Max recharges from 0 to 80% in 68 minutes from a wall outlet or a generator. That opens a middle path. A battery indoors and a small gas unit outdoors can work together.
Picking between inverter generators or power stations often depends on whether the unit has to sit outside or can stay in the living room.
A battery fits best when the power source has to stay close to living space. Two EcoFlow models show the range. One handles essentials for renters and small households. The other suits homes where the load list has grown past what any small unit can carry.
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. • Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
Outages also hit when nobody is home, and a gas unit needs someone there to fuel and start it. A home battery system can switch over on its own. The EcoFlow DELTA Pro Ultra X switches over in about 20ms with Smart Home Panel 3, installed by a licensed electrician. Coverage depends on the home's loads, and stored energy is still limited.
•Whole-Home Backup (with the right setup): 12kW output and 12kWh capacity in the standard bundle (1 inverter + 2 Smart Extra Batteries), expandable up to 36kW and 180kWh with added inverters and batteries. Whole-home backup requires Smart Home Panel 3 installed by a licensed electrician, and coverage depends on your home's loads. •Fast Switchover: Automatic switchover in about 20ms with Smart Home Panel 3, so selected circuits stay on when the grid drops. •Installation: Plug-and-play design that EcoFlow says can be installed in 7 days. Permitting, your electrical panel, and installer schedules can change that timeline. • Comprehensive Safety: End-to-end system protection built to high safety standards.
The EcoFlow DELTA 3 Max is the small plug-in pick for essentials and renters. The EcoFlow DELTA Pro Ultra X is for owners whose load list has outgrown any small unit and who can have it installed by a licensed electrician.
Every type on that list can be sized correctly and still cause harm in the wrong spot. Gas units need the most care on that point.
Safety Rules for Small Portable Home Generators
Small gas generators are the kind most often tied to carbon monoxide deaths. They are easy to set up too close to the house. A quick placement choice in a storm can turn deadly.
What the Data Shows
A May 2026 CPSC report on non-fire CO deaths (2022 annual estimates) puts numbers on the problem. Generators averaged an estimated 98 non-fire CO deaths per year from 2020 to 2022, out of 238 total. Since 2012, the estimate reaches 892 deaths.
Placement and Setup Rules
CPSC guidance from Feb. 19, 2026 sets the core rules:
Measuring correct generator safety distance from homeMeasuring correct generator safety distance from home
  • Outside only. Run the unit at least 20 feet from the house. Never place it on a porch or in a carport.
  • Exhaust direction. Point exhaust away from the home and neighbors.
  • CO shut-off feature. Look for one when shopping for a unit.
  • CO alarms. Use battery or battery-backup alarms inside the home.
The EPA adds that CO is odorless and colorless. It can also linger for hours after a generator shuts off. CDC guidance backs the distance rule by advising 20 feet from windows.
CPSC Pub. 5123 adds more setup points. Never backfeed power through a wall outlet. Use heavy-duty, outdoor-rated extension cords. Run the unit on a dry surface under an open, canopy-like cover.
Where Standards Stand
CPSC has proposed a mandatory Safety Standard for Portable Generators (RIN 3041-AC36). The rule is not final.
Concerns over CO are a big reason apartment dwellers and renters look at gas generator alternatives.
Safe placement covers the outage itself. The other half is making sure the unit starts, or holds a charge, when the next one hits.
Keeping a Small Generator Ready Between Outages
Most small units sit unused for months. That is when they tend to fail. Upkeep differs by type.
Checking generator safety and fuel readinessChecking generator safety and fuel readiness
  • Gas units. Store fuel outside living areas in labeled, non-glass safety containers, per CPSC Pub. 5123. The maker's manual explains how often to start the engine and how to store fuel.
  • Battery units. Top off the charge periodically and check it before storm season. The EcoFlow DELTA 3 Max app offers Storm Guard Mode, which, per EcoFlow, starts charging ahead of severe weather alerts.
A short checklist keeps the routine simple:
  • Test run the engine or check the battery charge
  • Inspect extension cords for damage
  • Test CO alarms
  • Tape the load list near the unit
A short routine of generator and battery maintenance keeps either type ready for hurricane season or a winter storm.
The right small generator for home use is sized by running watts plus the biggest starting surge. It is then chosen by where it has to run and how it will be refueled or recharged.
The next step is simple. List 3 to 5 must-run appliances, total them with the table above, and check both the running and surge ratings before buying.
For fume-free essentials indoors, the EcoFlow DELTA 3 Max fits the need. For a larger, electrician-installed setup, the EcoFlow DELTA Pro Ultra X is the one to explore.
What size small generator do I need to run a refrigerator?
A fridge runs on about 132 to 192W but needs about 1,200W to start, per Honda. A unit with at least that starting rating can handle it. Add other loads on top of the running number.
Can a small generator run a sump pump?
Yes, if its surge rating covers the pump's start. Honda lists 1,300W for a 1/3 HP pump and 2,150W for a 1/2 HP pump. Running watts alone do not tell the full story.
Is an inverter generator safe to use indoors?
No. It still burns fuel and makes CO. The CPSC says to run it outside only, at least 20 feet from the house.
Is a battery power station better than a small gas generator?
That depends on the need. A battery suits indoor use and quiet operation. A gas unit offers longer runtime as long as fuel lasts. Many households pair the two.
What is the best small generator for apartments?
A battery unit is the usual choice, since gas generators cannot run on balconies or porches. Building rules are worth checking first.
Home Solutions
