Induction vs Electric Cooktops: How They Heat, What They Cost, and Which to Choose
Choosing between induction and traditional electric cooking isn't just about appearance. Both use electricity, but they heat your cookware differently. A standard electric cooktop heats a coil or glass element, which then transfers heat to the pan. Induction uses a magnetic field to heat compatible cookware directly. ENERGY STAR estimates induction transfers about 85% of heating energy to cookware, compared with 75% to 80% for electric resistance. Induction also boils water faster in testing. Here's how the two compare in everyday kitchens, including cookware, costs, efficiency, and cooking during short power outages.
Induction vs Electric: How Each One Heats
The biggest difference comes down to where the heat starts. Traditional electric cooktops heat an element first, which then warms your pan. Induction creates heat inside compatible cookware through electromagnetic energy. That difference affects cooking speed, efficiency, and how hot the cooking surface gets.
How Induction Cooktops Work
An induction cooktop uses electromagnetic energy to heat compatible pots and pans. Beneath its glass surface sits a copper coil. When electricity flows through the coil, it creates a magnetic field.
Place compatible cookware on the burner, and the magnetic field generates heat inside the pan itself. The cooktop doesn't need to heat a separate element first.
How induction cooktop worksHow induction cooktop works
This design offers several practical benefits:
  • Faster heating: Water boils faster because heat develops directly inside the cookware.
  • Better temperature control: Adjustments respond quickly when you raise or lower the setting.
  • Less residual heat: The glass surface receives heat from the hot pan rather than generating it.
  • Easier cleanup: Flat glass surfaces make spills easier to wipe away.
The U.S. Department of Energy explains that induction heating stops when you remove the cookware. That also reduces the risk of accidentally leaving an active burner heating an empty surface.
How Traditional Electric Cooktops Work
Traditional electric cooktops use resistance heating. Electricity passes through a metal heating element, producing heat that transfers to the cookware.
How electric cooktops workHow electric cooktops work
There are two common designs:
  • Coil electric: Exposed metal coils heat pots and pans directly through contact.
  • Smooth-top electric: Radiant heating elements sit beneath a ceramic-glass surface.
Both designs work with a wide range of flat-bottom cookware. However, they take longer to heat up and cool down. The cooking surface also stays hot after you remove the pan.
Induction vs Electric: Side-by-Side Comparison
Feature
Induction Cooktop
Electric Resistance Cooktop
What It Heats
The pan directly via a magnetic field
The coil or radiant element, then the pan
Energy Efficiency (ENERGY STAR)
About 85%
About 75% to 80%
Cookware Compatibility
Magnetic bottoms only (cast iron, magnetic stainless steel)
Many flat-bottomed pans. Check the cooktop manual for approved materials and finishes.
Temperature Response
Near-instant adjustments up and down
Slower to heat up and slow to cool down
Surface Temp After Use
Warm from the pan, cools quickly
Stays hot much longer after shutoff
Kitchen Heat Output
Very little wasted ambient heat
Warms up the surrounding kitchen air
According to ENERGY STAR, induction is approximately 5% to 10% more efficient than conventional electric resistance cooking. That difference comes from transferring more heating energy directly into the cookware.
One more thing to consider: Upgrading to induction isn't always a simple appliance swap. Older homes may need electrical work before installing a new range. Plan for induction retrofits and panel upgrades if your electrical service is tight. Have an electrician check your existing panel and circuit capacity before purchasing.
During short outages, a countertop burner can offer another way to prepare simple meals without running your entire kitchen range.
Cooking During a Short Outage
Neither of the two 120V EcoFlow models discussed here can supply a 240V range. They can run compatible 120V countertop burners within the equipment limits. Check its input watts against the outlet and total limits.
When a summer thunderstorm knocks out the neighborhood grid or a winter ice storm takes down a line, a hardwired kitchen stove sits useless. You don't need to fire up a charcoal grill in freezing rain just to make soup or boil water for coffee. A single plug-in portable induction burner or electric hot plate plugged into a backup battery handles basic meals indoors safely.
EcoFlow power stations can run a compatible 120V countertop burner when the range is down. Full 240V ranges are a separate electrician project.
Matching a Portable Burner to Backup Power
Before plugging any heating appliance into a battery station, check the sticker on the bottom of the burner. Most 120V countertop induction burners draw between 1,000W and 1,800W at full blast. That's a heavy continuous load, so you need a power station built to handle high-wattage kitchen gear without tripping its overload protection.
You also need to keep a few safety checks in mind:
  • Check input watts: Verify the burner's maximum wattage rating before turning it to high.
  • Verify allowed connections: Plug the burner directly into the power station's AC outlet rather than daisy-chaining thin extension cords.
  • Watch outlet and total limits: Make sure no other high-draw appliances share the same circuit limit at the same time.
  • Leave 240V ranges to pros: Hardwired 240V stoves require dedicated circuit design and electrical panel calculations by a licensed electrician.
For one compatible low-power 120V induction or electric burner, EcoFlow DELTA 3 Classic's 1,800W output covers short meals.
EcoFlow DELTA 3 Classic (1024Wh) + Bag
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For a higher-input countertop burner, or a burner plus a compatible fridge, EcoFlow DELTA 3000 Gen4 has 3,600W output and 3,072Wh.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How the products divide the job
Choosing between these two setups depends on what else you want running while you cook:
  • EcoFlow DELTA 3 Classic: Best suited for running one matching low-power 120V countertop burner for quick meals when you don't need heavy simultaneous loads.
  • EcoFlow DELTA 3000 Gen4: Built for a higher-input 120V countertop burner, or running a burner while keeping a compatible refrigerator cold at the same time. Just check your per-outlet and total output limits.
  • Full 240V Fixed Ranges: Require separate electrical circuit design, breaker sizing, and professional installation rather than a portable plug-in unit.
How Long Can These Power Stations Run a Countertop Burner?
Runtime depends on the burner's actual average power draw. Cooking at full power continuously uses more energy than intermittent heating.
The following figures are estimates, not guaranteed runtimes. They use 870Wh and 2,611Wh of estimated usable capacity, respectively.
Load Scenario
Average Watts Used
EcoFlow DELTA 3 Classic (870Wh Usable Est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh Usable Est.)
Countertop burner at medium for 30 min/day, averaged (example: 1,200W × 0.5h ÷ 24h)
About 25W
About 35 hours
About 104 hours
Burner average + fridge average (ENERGY STAR fridge example, ~38W)
About 63W
About 14 hours
About 41 hours
Calculation method:
Estimated runtime = Usable battery capacity (Wh) ÷ Average load (W).
The first example assumes a 1,200W burner running for 30 minutes daily. That's 600Wh of daily energy use, averaged across 24 hours.
The second adds an illustrative 38W refrigerator average. Actual refrigerator consumption depends on its model, temperature, and operating conditions.
These estimates simplify daily energy use into an average load. They aren't predictions of continuous cooking time. Actual results vary with conversion losses, operating conditions, and battery reserve.
Check the appliance label and measure its actual consumption before relying on these figures. The same checks apply to running an electric kettle on battery.
Next, cost and installation.
Cost to Buy, Install, and Run
Induction usually costs more to buy. Both often need a 240V circuit for a full range. Running cost difference is small per meal.
Cost to buy, install and runCost to buy, install and run
Upfront Purchase Price
When you shop appliance stores, standard electric coil and smooth-top radiant ranges fill the entry-level and mid-range aisles. Induction models still carry a higher upfront price tag because the internal copper coils and power electronics cost more to manufacture.
Prices swing widely depending on brand, oven features, and slide-in versus freestanding designs. Compare current models across retailers and check for local utility rebates or federal electrification incentives, which can narrow the price gap at checkout.
Electrical and Installation Requirements
An existing 240V connection may be reusable if it meets the new range’s installation instructions. One GE freestanding range example specifies an individual branch circuit of at least 40A. Other models call for a different rating or connection. Have a licensed electrician verify the circuit and wiring for the exact range.
Switching from a gas stove takes more prep work. Gas ranges usually plug into a standard 120V wall outlet just to power the clock and igniter. Moving to either electric resistance or induction means hiring an electrician to run a dedicated 240V line from your main breaker panel to the kitchen. Check electric stove wattage before sizing a circuit so your wire gauge and breaker match the new unit's peak demand.
Daily Operating Costs and Speed
Because induction transfers about 85% of its energy straight into the pot compared to 75% to 80% for resistance elements, it wastes less electricity every time you cook. On a single pot of pasta, that 5% to 10% efficiency edge translates to pennies saved on your electric bill. Over ten years of daily family dinners, those pennies add up, though energy savings alone rarely pay back a big upfront price difference.
Where you really notice the difference is speed. According to the DOE, Consumer Reports testing found that induction cooktops can boil water 20% to 40% faster than tested gas and electric cooktops. Dinner hits the table sooner, and your kitchen stays cooler in July so your central AC doesn't have to work as hard.
Finally, which one fits your kitchen?
Which Should You Choose?
Induction is a strong choice if you want faster cooking, better temperature control, and improved efficiency. Traditional electric resistance is still worth considering if you want a lower upfront price and broader cookware compatibility.
The right choice depends on your kitchen, cooking habits, and budget.
Choose Induction If...
Induction makes sense for households that cook regularly and value responsive temperature control.
Consider induction if you:
  • Want water to boil faster and meals to cook more quickly.
  • Prefer precise temperature adjustments.
  • Want a cooking surface that doesn't retain as much heat.
  • Already own magnetic cookware or plan to replace your pans.
  • Want better energy efficiency than traditional resistance cooking.
Induction is also worth considering in homes where summer heat is a concern. Because less heat escapes into the kitchen, it can reduce the extra heat your air conditioner needs to remove.
Choose Traditional Electric If...
Resistance cooktops remain practical for homeowners who want straightforward electric cooking without replacing their cookware.
Consider traditional electric if you:
  • Want a lower initial purchase price.
  • Already own nonmagnetic cookware.
  • Prefer familiar coil or smooth-top cooking.
  • Don't want to spend extra on compatible pots and pans.
  • Don't need the faster temperature response of induction.
Traditional electric is also a reasonable replacement when your existing cooktop works well and installation costs are a priority.
Check Your Cookware Before Buying
You don't necessarily need an entirely new cookware collection for induction.
Try this simple magnet test:
  1. Find a refrigerator magnet.
  2. Place it against the bottom of each pot or pan.
  3. If it sticks firmly, the cookware should work with induction.
  4. Repeat the test for every pan you regularly use.
Cast iron, many stainless steel pans, and enameled cast iron cookware generally work with induction.
Aluminum, copper, and glass cookware usually won't work unless they have a compatible magnetic base.
Quick Decision Guide
Your priority
Better choice
Faster cooking
Induction
Higher efficiency
Induction
Precise temperature control
Induction
Lower purchase price
Resistance
Works with most cookware
Resistance
Less residual surface heat
Induction
Minimal cookware replacement
Resistance
Whichever option you choose, cooktops are one of several energy-saving appliances worth buying. Compare the long-term benefits rather than focusing only on the purchase price.
Induction vs electric comes down to how heat is made: ENERGY STAR puts induction at about 85% efficient versus 75% to 80% for resistance, and it boils water faster, but it needs magnetic cookware. Standard electric resistance models cost less upfront and accommodate a wider range of flat-bottomed cookware, subject to the cooktop manual, though they heat slower and hold residual heat longer.
Before buying, grab a magnet to test your pots, ask a licensed electrician to compare the new range’s electrical requirements with your existing branch circuit, and compare current models side by side. If you want a simple backup plan for short grid outages without rewiring your kitchen, pairing a 120V countertop burner with an EcoFlow DELTA 3 Classic or EcoFlow DELTA 3000 Gen4 keeps hot meals on the table when the power goes out.
Is induction better than electric?
Induction is more efficient, heats pans faster, and offers instant temperature control with a cooler cooktop surface. Standard electric resistance is better if you want a lower purchase price and compatibility with a wider range of flat-bottomed non-magnetic cookware. For a smooth glass cooktop, check the manual before using materials such as glass or unfinished cast iron.
Does induction use less electricity?
Yes. ENERGY STAR estimates induction is about 5% to 10% more efficient than conventional electric resistance cooktops. Induction transfers approximately 85% of heating energy into cookware, compared with 75% to 80% for resistance models.
Do I need special pans for induction?
Yes, induction requires cookware with a magnetic base, such as cast iron, enameled iron, or magnetic stainless steel. You can check your existing pots at home by seeing if a standard magnet sticks firmly to the bottom.
Can induction run on a 120V outlet?
Portable induction burners are available for standard 120V household outlets. However, full-size induction ranges typically require a dedicated 240V circuit. Always check the manufacturer's electrical requirements before installation.
Can I cook on induction in an outage?
Yes, as long as you use a compatible 120V portable countertop burner paired with a properly sized portable power station that can handle the burner's input wattage. The two 120V stations described here cannot power a fixed 240V range. A licensed electrician must evaluate that appliance and a compatible 240V backup circuit.
Save Bills
