Do Tankless Water Heaters Save Money? How to Compare Cost, Use, and Payback
Tankless water heaters can save money by reducing energy waste, but actual savings depend on household hot water usage and installation costs. According to the U.S. Department of Energy (DOE), gas tankless water heaters can be 24% to 34% more energy efficient than conventional storage water heaters for households using 41 gallons of hot water daily or less. For households using around 86 gallons daily, gas tankless models can be 8% to 14% more energy efficient than conventional storage water heaters. However, higher upfront costs can offset these benefits. Comparing energy prices, maintenance expenses, and installation quotes helps determine whether switching to a tankless system is a worthwhile investment.
Yes, tankless water heaters can reduce energy consumption because they heat water when you need it instead of maintaining a tank of hot water all day. However, lower energy use does not automatically mean lower overall costs. Your household's hot water habits, fuel prices, and installation expenses determine whether the upgrade makes financial sense. According to the U.S. Department of Energy's (DOE) Energy Saver Guide, gas tankless water heaters can be 24% to 34% more energy efficient than conventional storage water heaters for households using 41 gallons of hot water daily or less. For households using around 86 gallons daily, gas tankless water heaters can be 8% to 14% more energy efficient than conventional storage water heaters.
Storage tank and tankless water heaters side by sideStorage tank and tankless water heaters side by side
Why Tankless Water Heaters Can Reduce Energy Costs
Traditional storage water heaters keep a reservoir of water heated throughout the day. Even when nobody is showering or washing dishes, the heater periodically uses energy to maintain the temperature. This is called standby heat loss. Tankless systems work differently. When someone opens a hot water tap, cold water travels through the unit and gets heated as it passes through a heat exchanger. This on-demand approach avoids the standby losses associated with conventional storage tanks.
  • Tankless water heaters reduce energy waste by heating water only when there is a demand for hot water.
  • They do not require a large storage tank to maintain water temperature throughout the day, helping avoid standby heat loss.
  • They provide hot water on demand without requiring you to wait for a storage tank to refill after use.
  • They can be more energy-efficient for households with relatively low daily hot water consumption because they avoid continuously heating stored water.
Tankless vs. Tank: Which Costs Less?
The biggest difference is usually the initial investment. A conventional tank heater generally costs less to purchase and install, while a tankless model may require additional plumbing, venting, gas-line, or electrical work.
Cost factor
Storage tank
Tankless
Purchase price
Generally lower
Generally higher
Installation
Often simpler
May require modifications
Standby heat loss
Yes
No storage-related standby loss
Hot water supply
Limited by tank capacity
Depends on flow rate and heating capacity
Maintenance
Periodic inspection and flushing
May require regular descaling
Energy efficiency
Generally lower
Generally higher for comparable gas models
A tankless system may offer better long-term efficiency, but a simple tank replacement can be much cheaper upfront. Before requesting installation quotes, compare the tankless pros and cons for your household rather than assuming that newer technology always means a better financial decision.
The Backup Power Line Item
A gas tankless water heater burns natural gas or propane to heat water, but it still needs electricity for its electronic controls, ignition system, and, depending on the model, a fan. If the electricity goes out, the heater may stop working even when the gas supply remains available. If you want hot water during an outage, include backup power as a separate purchase in your budget. It is not part of the tankless heater's energy-efficiency savings.
What Should You Check Before Choosing Backup Power?
Not every gas tankless water heater works with every portable power station. Before purchasing backup equipment, check the manufacturer's requirements for:
  • Power connection: Confirm whether the heater supports the proposed 120V plug-in connection or requires another electrical arrangement.
  • Running and startup watts: Check the electrical label and manual for continuous consumption and any startup demand.
  • Grounding and electrical compatibility: Follow the heater manufacturer's grounding and connection requirements.
  • Water and gas supply: Electricity cannot replace the water pressure or fuel supply needed for operation.
A Separate Backup Option: EcoFlow DELTA 3 Classic
For a compatible gas tankless heater that the manufacturer allows to operate from a standard 120V plug, the EcoFlow DELTA 3 Classic offers an optional backup-power solution. It has a 1,024Wh battery capacity and 1,800W AC output. When properly connected to a compatible heater, it can supply electricity to the controls, fan, and ignition components while the gas burner provides heat. If you are preparing for outages, plan your essential backup loads before choosing a battery capacity.
EcoFlow DELTA 3 Classic (1024Wh) + Bag
• Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. •1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Supports standby UPS operation when the EcoFlow DELTA 3 Classic's AC input is connected to a wall outlet and supported devices are plugged into its AC output ports. When grid power is interrupted, it automatically switches to battery power within 10ms to keep connected devices running, such as a Wi-Fi router or NAS.
Estimated Runtime for a Small Electrical Load
Here is a simple illustration of how long an EcoFlow DELTA 3 Classic might support a gas tankless heater's electrical components.
Example load
Estimated power
Estimated runtime
Gas tankless controls and fan while firing
About 100W
About 8.7 hours
Calculation: (1,024Wh × 0.85) ÷ 100W = approximately 8.7 hours.
This runtime estimate uses an 85% usable-energy allowance and a placeholder 100W average load, so replace the placeholder with the manufacturer's actual electrical specifications before using the calculation for equipment planning. Actual runtime will vary depending on operating conditions and power consumption. Before connecting a battery power station, check the water heater manufacturer's instructions for voltage requirements, startup and running loads, grounding, and approved electrical connection methods. Never use extension cords or adapter plugs if the manufacturer's instructions prohibit them.
How to Calculate Tankless Payback
The simplest way to decide whether a tankless system makes financial sense is to calculate how long its annual operating savings would take to cover the additional installation cost.
Payback period = Extra upfront cost ÷ Annual net savings
You will need information from your plumber, water heater specifications, utility bills, and maintenance schedule.
Comparing Tankless and Traditional Water Heater CostsComparing Tankless and Traditional Water Heater Costs
Step 1: Compare Installation Quotes
Installation costs can vary significantly between storage tanks and tankless water heaters, depending on your home's existing plumbing, gas supply, venting, and electrical setup. Ask a licensed plumber for itemized quotes so you can compare the full installation cost rather than just the equipment price. Use the following table to identify the main cost items to check in each estimate.
Cost item
Storage tank
Tankless
Equipment
Tank unit
Tankless unit
Installation
Standard connections
Unit-specific installation
Venting
Existing or required venting
Compatible venting
Gas line
Existing or required work
Possible upgrade
Drainage
Depending on installation
Depending on model and installation
Electrical work
Depends on model
Depends on model
The difference between the two complete quotes is your additional upfront investment. For example, if the storage-tank installation costs $1,500 less than the tankless installation, your extra upfront cost is $1,500.
Step 2: Estimate Annual Fuel Costs
Look at the yellow EnergyGuide label or manufacturer specifications for each model. Use the estimated annual energy consumption and your actual utility price to compare operating expenses. For a gas heater, consider your natural gas or propane price. For an electric model, use your electricity rate. Keep the comparison consistent. Both systems should be evaluated using the same household hot water demand and local fuel prices.
Step 3: Include Maintenance Differences
Tankless heaters may require periodic descaling, particularly in areas with hard water. Some models also need filter cleaning and professional inspection. Storage heaters have their own maintenance requirements, including checking the anode rod and flushing sediment when recommended. Check both manuals and estimate the annual maintenance cost for each system.
Step 4: Calculate Your Payback Period
Subtract the additional annual maintenance expense from your annual fuel savings. Then divide the additional installation cost by the remaining annual savings.
Example (illustrative placeholders):
  • Additional tankless installation cost: $1,500
  • Annual fuel savings: $150
  • Additional annual maintenance: $50
  • Annual net savings: $100
Payback = $1,500 ÷ $100 = 15 years.
This example shows why a more efficient water heater is not necessarily the cheaper option over its useful life. If annual net savings are zero or negative, there is no financial payback under those assumptions. You can also explore ways to manage time-of-use electricity costs when comparing your household's wider energy expenses. However, do not count unrelated battery savings as tankless water heater savings.
What Makes Tankless Worth It (or Not)
The financial value of a tankless water heater changes from one household to another. A smaller household with moderate hot water demand may benefit more from efficiency improvements than a large family with frequent simultaneous showers and appliance use.
1. Local Fuel Prices
The cost of electricity, natural gas, and propane directly affects operating expenses. Gas tankless models may be economical in areas where natural gas is relatively affordable. However, electric tankless models can become expensive to operate where electricity rates are high. Check what you pay per kWh before comparing electric water heating costs. For gas, review your utility bill and applicable delivery charges.
2. Household Size and Hot Water Demand
A smaller household with moderate hot water consumption may benefit from the efficiency advantages of a tankless system. Larger households often need higher flow rates to support multiple showers and appliances operating simultaneously. Choosing an undersized system can create performance problems, while purchasing an oversized unit can increase upfront expenses.
3. Installation Complexity
Replacing an existing tank with another tank may require fewer modifications than installing a completely different system. Tankless installations may require upgraded gas piping, new venting, electrical work, or additional drainage. Electric tankless systems can also require dedicated high-capacity electrical circuits. Get an electrician's assessment before choosing a model.
4. Maintenance and Equipment Lifespan
Mineral buildup can affect performance, especially in areas with hard water. Regular descaling and servicing help maintain the equipment according to manufacturer recommendations. Compare warranty coverage, replacement parts, and expected maintenance expenses when evaluating long-term value.
5. Other Ways to Reduce Household Energy Costs
A new water heater is not the only way to lower utility expenses. Reducing unnecessary hot water use, repairing leaks, and installing efficient fixtures can also help control monthly bills. Understanding what you pay per kWh can help you identify how electricity rates affect your household energy costs and where simple efficiency improvements may make a difference. If your home uses time-of-use electricity pricing, shifting energy use to lower-rate periods can provide another opportunity to manage expenses.
Tankless water heaters can lower energy costs, with the U.S. Department of Energy reporting that gas tankless water heaters are 24% to 34% more energy efficient than conventional storage water heaters for households using 41 gallons of hot water daily or less. For households using around 86 gallons daily, they are 8% to 14% more energy efficient than conventional storage water heaters. However, higher equipment and installation costs can affect the payback period. Before choosing a system, compare itemized installation quotes, calculate operating costs using your local fuel prices, and divide the extra upfront cost by estimated annual savings. If outage protection is also important, consider pricing an EcoFlow DELTA 3 Classic separately for essential backup power.
Do tankless water heaters save money?
They can reduce energy consumption by avoiding standby losses. However, actual financial savings depend on installation costs, household hot water usage, fuel prices, and maintenance expenses.
How much more efficient is tankless?
According to the DOE, gas tankless water heaters can be 24% to 34% more energy efficient than conventional storage water heaters for households using 41 gallons of hot water daily or less. For households using around 86 gallons daily, they can be 8% to 14% more energy efficient than conventional storage water heaters.
How long is the payback?
There is no universal payback period. Divide the additional installation cost by your annual net savings to estimate how many years it may take to recover the extra investment.
Is gas or electric tankless cheaper to run?
It depends on local energy prices and equipment efficiency. Compare the cost of natural gas or propane with electricity rates before choosing a system.
Do tankless heaters work in a power outage?
Gas tankless water heaters generally require electricity for their controls, ignition, and fan. A compatible backup power source may keep these components running, provided the heater's manufacturer allows the connection.
Save Bills
