How Much Does It Cost to Run a Space Heater?
At the U.S. residential benchmark of $0.1816 per kWh reported by the U.S. Energy Information Administration for August 2026, a standard 1,500-watt space heater costs about $0.27 per hour to operate. If it runs continuously for eight hours a day, that comes to approximately $2.18 per day or $65.38 over 30 days. The total on your bill may be lower if the thermostat regularly switches the heating element off, or higher if your utility charges more for electricity.
Those figures provide a useful starting point, but they do not describe every household. Wattage, runtime, room conditions, thermostat settings, and local rates all affect the final cost. The calculations below show how those pieces fit together and where small changes can make a noticeable difference.
What Is the Average Cost to Run a Space Heater?
Electric utilities bill customers by the kilowatt-hour, so how much do space heaters cost to run? The answer depends on how much power a heater draws and how long it stays on. A compact personal heater on a low setting costs far less per hour than a hardwired garage heater. The same appliance can also cost substantially more in a high-rate state than it does in an area with inexpensive electricity.
For consistency, the tables in this article use $0.1816 per kWh, the U.S. residential average for August 2026 reported by the U.S. Energy Information Administration. A second column shows the same calculation at $0.32 per kWh, illustrating how strongly the local rate can affect the result.
Hourly Cost of Running a Space Heater at Different Wattages
Most plug-in room heaters sold in the U.S. draw up to 1,500 watts on their highest setting, although many models also offer lower-power modes. Personal heaters may use only a few hundred watts, while a hardwired 240V unit intended for a garage, workshop, or basement can draw considerably more.
Heater Wattage
Typical Heater Type / Setting
Cost per Hour (at $0.1816/kWh)
Cost per Hour (High-Rate State, $0.32/kWh)
500W
Compact desk or under-table personal heater
$0.09
$0.16
750W
Low setting on a standard portable heater
$0.14
$0.24
1,000W
Medium setting or small room panel heater
$0.18
$0.32
1,500W
Standard ceramic, oil-filled, or infrared heater (High)
$0.27
$0.48
3,000W
Hardwired 240V garage, workshop, or basement heater
$0.54
$0.96
The hourly figure represents continuous operation at the listed wattage. In everyday use, a thermostat-controlled heater may cycle between heating and standby after the room reaches the selected temperature. The cost then depends on how often the heating element has to switch back on.
Daily and Monthly Space Heater Operating Costs
Runtime is where a modest hourly expense begins to add up. Using a 1,500W heater for two hours in the morning is a very different commitment from leaving one on throughout an eight-hour workday. Overnight use costs more again, particularly when a cold or poorly insulated room keeps the heater operating near full power.
Usage Scenario (1,500W Heater)
Hours per Day
Daily Cost ($0.1816/kWh)
Monthly Cost (30 Days)
Taking the morning chill off a bathroom/bedroom
2 hours
$0.54
$16.34
Heating a home office during a workday
8 hours
$2.18
$65.38
Running overnight in a bedroom
10 hours
$2.72
$81.72
Continuous operation (uninsulated space)
24 hours
$6.54
$196.13
Note: Daily and monthly totals use the unrounded hourly rate of $0.2735 before the final result is rounded to the nearest cent. If the heater has a thermostat that switches the element off after the room reaches its set temperature, actual costs may be 30% to 50% lower than the continuous full-wattage estimates.
These totals also assume the heater operates at 1,500W whenever the element is active. A model running on a 750W setting would use half as much electricity during those heating periods.
How Do You Calculate the Cost of Running a Space Heater?
If you are wondering how much it costs to run a space heater, you do not need a specialized calculator to estimate the expense. Start with the wattage printed on the heater, find the per-kWh rate on your electric bill, and decide how many hours the appliance is likely to run each day. The result will be more useful when those inputs reflect your actual routine instead of a general national estimate.
Find Your Space Heater's Wattage
Check the rating label on the back, bottom, or side of the heater. The same information may also appear in the owner’s manual. Look for a number followed by a “W”, such as 1500W or 750W/1500W. A heater with two listed wattages has more than one power setting, so use the number that corresponds to the setting you expect to run.
If the label lists amps and volts rather than watts, multiply the two values. A heater rated at 12.5A and 120V has a maximum draw of 1,500W:
12.5A × 120V = 1,500W
Use the label rather than assuming that every portable heater draws 1,500W. Compact personal models and lower settings may consume considerably less.
Check Your Electricity Rate per Kilowatt-Hour (kWh)
Your most recent utility bill should show the number of kilowatt-hours used during the billing period and the charges associated with that electricity. Rates differ by state, utility, season, and rate plan, so the national benchmark may not resemble what you actually pay.
Look for the effective rate, not only the advertised supply charge. One practical method is to divide the total electric portion of the bill by the total kWh used. This includes the delivery, transmission, and local charges on that bill and gives a more realistic estimate of what an additional kilowatt-hour costs your household.
If your utility uses Time-of-Use pricing, check which rate applies during the hours when the heater normally runs. An evening rate and an overnight rate can produce different daily costs even when the heater’s wattage and runtime do not change.
Use the Formula to Calculate Your Space Heater's Running Costs
Once you have the wattage, daily runtime, and electricity rate, apply this electrical power formula:
Daily cost = (Wattage ÷ 1,000) × Hours used per day × Electricity rate per kWh
Suppose you live in Chicago, pay $0.16 per kWh, and operate a 1,500W oil-filled radiator for six hours each evening:
  1. Convert watts to kilowatts: 1,500 ÷ 1,000 = 1.5 kW.
  2. Calculate daily energy use: 1.5 kW × 6 hours = 9 kWh.
  3. Calculate the cost: 9 kWh × $0.16 = $1.44 per day, or $43.20 per month.
This example assumes the heater draws its full rated wattage for all six hours. If the thermostat switches the element off for part of the evening, multiply the wattage by the number of hours the element is actually energized for a closer estimate. The same watt-hour calculation can estimate how quickly a portable power station would be depleted by a heater, although conversion losses and other connected loads also affect runtime.
EcoFlow DELTA 3800 Gen4 Portable Power StationEcoFlow DELTA 3800 Gen4 Portable Power Station
What Factors Affect the Cost of Running a Space Heater?
Two households can use the same heater for the same number of clock hours and still see different costs. One room may hold heat well enough for the thermostat to cycle off regularly. Another may lose warmth through windows, walls, or an open doorway, forcing the heater to run almost continuously.
The utility rate matters just as much. A heater cannot tell whether electricity costs $0.1816 or $0.32 per kWh, but the difference will be obvious on the monthly bill.
Heater Wattage and Energy Consumption
Electric resistance heaters convert nearly all the electricity they use into heat at the point of use. When a 1,500W ceramic heater and a 1,500W infrared heater operate continuously, both consume 1.5 kWh each hour and therefore cost the same to run at a given electricity rate. They may not feel identical, however. A fan heater moves warm air through the room, while an infrared model directs radiant warmth toward people and nearby objects.
The way the heat is delivered can influence how the appliance is used, even though the electrical cost at the same wattage remains unchanged.
Controls can make a larger difference than the heating style. A model with an Eco mode may reduce its draw from 1,500W to 750W after the room warms. A basic heater left on its high setting continues using the full rated power whenever its element is active. A battery-powered heater setup must also account for usable battery capacity, conversion losses, and other connected loads.
Daily Usage Time and Thermostat Settings
Every additional hour of active heating adds to the total. Thermostat settings also affect how long the element remains energized. A bedroom heater set to 68°F may reach its target and cycle off, while the same unit set to 76°F during a January cold spell may operate for much longer stretches.
The setting shown on a portable heater is not always the same as the temperature throughout the room. The thermostat reads conditions near the appliance, so placement, airflow, and cold spots may affect when it cycles. What ultimately matters for the electric bill is the number of hours the heating element draws power.
Room Size, Insulation, and Outdoor Temperature
A 1,500W heater may be marketed for a bedroom or home office, but the suitable room size depends on the model and the room’s heat loss. Manufacturer coverage estimates assume particular test conditions. A high ceiling, uninsulated basement wall, large window, or persistent draft increases the amount of heat the room loses.
In a smaller, well-contained space, the heater may reach the selected temperature and rest between cycles. Put the same unit in a broad living room or drafty basement, and it may remain on high without bringing the entire area to the desired temperature. The electricity use rises because the appliance spends more time operating, not because its maximum wattage has changed.
Outdoor temperature affects the result for the same reason. A room loses heat faster when the temperature difference between indoors and outdoors is greater, so a heater often runs longer during the coldest weather.
Local Electricity Rates and Time-of-Use Pricing
Electricity prices vary widely across the United States. At the benchmark rate of $0.1816 per kWh, a 1,500W heater costs about $0.27 an hour. At $0.32 per kWh, the same hour costs $0.48. Nothing about the heater changes; only the electricity price does.
Households on Time-of-Use (TOU) plans may pay different rates throughout the day. Peak periods often fall between 4:00 PM and 9:00 PM, when people return home and household demand rises. Running a space heater during that window may cost considerably more than using it during an off-peak period.
Review the actual schedule on your utility plan rather than assuming every TOU program uses the same hours. The heater’s cost should be calculated with the rate that applies when it is normally used.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Can You Reduce the Cost of Running a Space Heater?
Lowering the cost does not necessarily require replacing the heater. The most effective changes usually involve reducing runtime, keeping warm air in the occupied room, and avoiding expensive rate periods when the household has that flexibility.
A space heater is most economical when it replaces some whole-house heating for a limited area. If the central thermostat stays at the same temperature and the portable heater is added on top, the household is simply paying for another electrical load.
Use Zone Heating to Avoid Heating Unoccupied Rooms
Zone heating directs warmth to the room being used rather than keeping every part of a large house at the same temperature. During the workday, for example, you might lower the central thermostat to 62°F–65°F and use a space heater in a closed home office.
Closing the interior door helps keep that warmth from drifting into hallways and unused rooms. The approach can also work in a bedroom at night, provided the heater is operated according to its instructions. The savings come from allowing the central system to do less work, not simply from adding a portable heater.
The room still needs to hold the heat. Addressing a draft around a window or door may shorten the heater’s operating cycles and improve comfort without increasing the temperature setting.
Use Stored Solar Energy to Power Your Space Heater
Rooftop solar panels often produce the most electricity during sunny winter afternoons, while demand for space heating may rise after sunset. A portable power station can store some of that daytime surplus and make it available later, allowing the household to use more of its own solar production instead of drawing as much electricity from the grid in the evening. Homeowners comparing solar-powered storage options can explore solar generators to find systems that store excess solar energy for later use.
Systems like the EcoFlow DELTA 3800 Gen4 Portable Power Station allow homeowners to store excess solar energy harvested during the day and discharge it to power evening space heating. This can increase solar self-consumption while reducing grid reliance and monthly heating expenses.
1. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output.
The financial effect depends on the amount of surplus solar available, the heater’s energy use, and the utility’s rate and export-credit structure. The basic calculation remains the same: compare the energy required by the heater with the stored electricity available for evening use.
Charge Your Home Battery During Off-Peak Hours
240V heaters used in garages, workshops, or basement living areas can create substantial winter demand, particularly when they run during high-rate evening periods. Under a Time-of-Use plan, a home battery may charge from the grid during lower-cost overnight or midday hours and then supply stored electricity when peak prices take effect.
When paired with the Smart Home Panel 10, the EcoFlow TITAN 5000 Plus can supply power to 240V household circuits. Through the EcoFlow app, OASIS 3.0 can help homeowners schedule battery charging during off-peak Time-of-Use (TOU) rate periods and discharge stored energy during peak-rate periods. This time-of-use load shifting allows households to reduce their reliance on grid electricity when rates are highest, potentially lowering winter heating costs.
1. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
Space heater expenses are easier to control once you know the appliance’s wattage, your electricity rate, and the number of hours it actively heats. Calculate a realistic baseline first, then adjust the thermostat, schedule, or room setup where doing so makes sense.
A 1,500W space heater costs about $0.27 per hour at the $0.1816-per-kWh benchmark used in this article. Eight hours of daily operation comes to approximately $65.38 over 30 days, although thermostat cycling can lower the actual amount.
For a household-specific estimate, use the wattage printed on the heater and the effective rate from the electric bill. Zone heating, shorter operating periods, stored solar energy, and off-peak charging may help manage the expense. Homeowners who want to use more of their solar production after sunset can also explore EcoFlow’s home battery solutions and choose a setup that fits their energy use.
Is It Cheaper to Use a Space Heater or Central Heat?
A space heater may cost less when it warms one occupied room and allows the main thermostat to be set lower. Central heating may be more economical when several rooms need heat, but the comparison depends on the central system’s efficiency, fuel price, local electricity rate, and how long each system runs.
What Is the Cheapest Type of Heater to Run per Hour?
Electric resistance space heaters with the same wattage have essentially the same hourly electricity cost while their heating elements run continuously. While oil-filled radiators feel like they keep warming a room after shutting off, that residual heat simply comes from the extra electricity used to warm up the oil initially. Over a full day, the real money-savers are models with accurate digital thermostats and Eco modes, which prevent overheating and cycle the heating element off automatically instead of running at full power nonstop.
Is It Safe to Leave a Space Heater on Overnight?
No. The U.S. Consumer Product Safety Commission advises turning a space heater off before going to bed and whenever you leave the room. Place it on a stable, level surface, plug it directly into a wall outlet, and keep it at least three feet from bedding, curtains, furniture, and other combustible materials. Safety shutoffs are backups, not permission to leave the heater operating unattended.
Do Space Heaters Save Money on Heating Bills?
They may reduce total heating costs when they warm one occupied room while the main system is set lower, but the result depends on the home’s heating system, fuel prices, room conditions, and operating time. If the central system remains at its usual setting and a space heater is added, total energy use generally increases.
Home Backup
