Energy Saving Devices for Home: How to Compare Them by Measured Use
Plenty of gadgets claim to cut a bill, but energy saving devices only help when they reduce energy a household actually uses. A smart thermostat trims heating and cooling. LEDs cut lighting. Power strips stop standby draw. Each one works on a different slice of the bill, so the right pick depends on where the kilowatt-hours go. This article compares common devices using ENERGY STAR and DOE figures. It shows how to measure before buying. It also explains why storing solar power is a separate kind of saving from efficiency.
Which Energy Saving Devices Actually Work?
Energy-saving devices are most useful when they address loads your home actually uses. Heating, cooling, and water heating can all be substantial, as EIA's Residential Energy Consumption Survey shows. The best place to start depends on your home. Check your bills and measure the loads you can before selecting a device.
Device
What it cuts
Source figure
ENERGY STAR smart thermostat
Heating and cooling
About 8% of HVAC bills, or $50 a year on average (ENERGY STAR)
ENERGY STAR LED bulbs
Lighting
Up to 90% less energy than incandescent lighting at comparable light output (ENERGY STAR residential lighting guide)
Smart power strip
Standby power
Electronics left drawing power when switched off could add 5%–10% to a monthly utility bill (DOE Energy Saver, page 35)
ENERGY STAR TV
Standby
Standby-passive at most 0.5W (ENERGY STAR)
Read the Averages Carefully
Most of these gadgets report results as averages, and averages hide a lot. The $50 thermostat figure is a national number. A home in Phoenix and a home in Minneapolis use heating and cooling very differently. Actual results vary with climate, schedule, and house size.
Thermostats tend to help most where schedules change often and the system runs long hours. Setback schedules and occupancy sensing cut run time while nobody is home. A household that already keeps one steady setting may see less change.
LEDs use less electricity to provide comparable light and give off less heat. Compare lumens rather than wattage when choosing a replacement. See the ENERGY STAR residential lighting guide.
Televisions are a quieter example. A certified set may draw no more than 0.5W in its standby-passive mode. Models that stay connected to a network can draw more in other standby modes, so settings matter.
Where Smart Systems Fit
Smart home energy saving devices often work as a set. The ENERGY STAR smart home energy management systems program recognizes packages built around a few core pieces. At a minimum, that means a certified smart thermostat, lighting, and a way to monitor or control plug loads. The pieces share one app, which makes the data easier to read.
Appliances deserve a separate look as well. Big-ticket energy saving appliances like fridges and washers run for years, so small efficiency gaps add up over time.
Home batteries often land on the same shopping lists as these products. They deserve their own section, because storing solar power saves money through a different mechanism.
Is a Home Battery an Energy Saving Device?
Not in the efficiency sense. A battery does not make any appliance use less. It changes when and where the energy comes from, and under the right rules that can lower costs.
Efficiency Cuts Use, Storage Moves It
Efficiency lowers the kilowatt-hours a home consumes. Storage shifts them in time. A household with solar panels often makes the most power at midday, when few people are home. A battery can hold some of that output for the evening, when the household would otherwise buy from the utility.
Three factors shape the result:
  • Conversion losses. Some energy is lost as it goes into the battery and comes back out. The estimate below assumes a 10% loss.
  • Lost export credit: Solar kept in a battery is not sent to the grid, so any credit for exported power is given up.
  • Fixed monthly charges: Service fees stay the same with or without storage.
Shifted energy should never be counted as appliance efficiency. The refrigerator uses the same power either way. Only the source and the timing change.
EcoFlow TITAN 5000 is a whole-home battery system for 120 V/240 V split-phase homes. It can shift compatible solar generation from midday to evening. A new compatible DC array connects to the unit's PV inputs within the manufacturer's limits. For AC coupling to compatible existing rooftop solar and its inverter, EcoFlow's U.S. product page specifies the 240 V Smart Home Panel 10 and a CT sensor. Ask a licensed installer to check compatibility and include the appropriate equipment and labor in the quote. The battery shifts the energy supply; appliance efficiency stays the same.
Storing solar shifts energy in time. The value depends on the rate plan, export credit, and losses, so the numbers below work as an illustration, not a predicted saving.
EcoFlow TITAN 5000
An Example With Assumed Numbers
The table below is an estimate. It assumes a 10% round-trip loss. Real losses vary by system, and the household's actual tariff should replace the rate inputs.
Illustrative calculation
Value
Solar stored at midday
4kWh
Round-trip losses (assumed 10%)
About 0.4kWh
Delivered in the evening
About 3.6kWh
Value
3.6 kWh × evening purchase rate − 4 kWh × daytime export rate
Tariff to use
Use the home's applicable per-kWh rates for the two time periods
Unchanged
A fair check follows three steps:
  1. Multiply the 3.6 kWh delivered in the evening by the per-kWh purchase charges you avoid at that time.
  2. Multiply the 4 kWh diverted at midday by the export credit per kWh you would otherwise have received. Subtract that amount from the evening savings.
  3. Add the net value across days using the energy delivered, energy diverted, and rates that apply each day. Track fixed charges separately.
The EcoFlow Smart Home Panel 10 (SHP10) must be installed by a qualified, licensed electrician. A grid connection through it is No Export, which means the system does not send power back to the grid.
Export rules still decide the value of stored solar. How much it is worth depends on net metering in a given state.
Not every saving needs a battery or a large purchase. Some of the smallest devices go after waste that rarely gets noticed.
How Much Do Smart Plugs and Power Strips Save?
They stop standby draw from electronics that never fully turn off. The savings are real but small per device. Across a TV setup or a home office, they add up.
Smart power strip behind television standSmart power strip behind television stand
What DOE Reports
  • Standby cost: DOE's Energy Saver guide, page 35 says electronics that keep drawing power when switched off could add 5%–10% to a monthly utility bill. The effect varies. Use a meter and the applicable per-kWh rate for your own devices.
  • What controls do: DOE describes advanced power strips that can cut power to devices in standby, using timers, activity monitors, or remotes.
  • The plug's own draw: A smart plug itself uses a little power to stay connected. That draw counts against what it saves.
Most of this waste is phantom power from idle electronics like game consoles and cable boxes. One device draws little. A full entertainment center draws more. Smart plugs also add schedules and remote control, which helps with devices that are easy to forget.
Where Plug Controls Make Sense
Controls fit best where several devices idle together. A TV, soundbar, game console, and streaming box can all sit in standby at once. One controlled outlet group can cut all four.
A home office works the same way. A monitor, printer, and charger often stay powered all day. A timer or a master-and-peripheral setup can switch them off together.
Some devices need steady power. A cable box with a recording schedule is one example. Those are better left on a normal outlet.
Savings claims only mean something when matched to real use. That makes measurement the last step before buying anything.
How to Measure What Your Devices Use
Measure first, then pick the device. A plug-in meter or a whole-home monitor shows real use. The utility bill shows the price per kWh.
Plug-in meters only read devices that use a standard outlet. Hardwired loads, such as a furnace or a water heater, need a whole-home monitor or an electrician's help.
Plug-in meter measuring appliance power usePlug-in meter measuring appliance power use
A Simple Measuring Method
  1. Find the avoidable rate: Use the per-kWh energy and delivery charges that apply when the device runs. Keep fixed monthly fees separate. The EIA national residential average of 18.16 cents per kWh for August 2026 is an illustration, so use your tariff for a household estimate.
  2. Plug in a meter: Read the watts a device draws while idle and while running. Note how many hours each mode lasts per day.
  3. Convert to kWh: Multiply watts by hours, then divide by 1,000. Repeat for a full year.
  4. Apply the per-kWh charges you can avoid: Multiply the energy saved in each rate period by the applicable variable charges and add the results.
A Worked Example
This one is an example, not a measurement. A 10W standby load running all day uses 87.6 kWh a year. At 18.16 cents per kWh, that comes to about $15.91.
One device at that level looks minor. Ten of them in a home tell a different story. That is why a meter pays off before any purchase.
A whole-home energy monitor shows total household use. A system with circuit-level sensors or supported end-use monitoring can also show how much particular circuits or loads consume. Use the available detail to choose what to measure next.
Energy-saving devices work when they reduce electricity your home actually uses. ENERGY STAR reports average HVAC bill savings of about 8% for certified smart thermostats. Its residential lighting guide says certified LED lighting can use up to 90% less energy than incandescent lighting. Measure your electronics' standby draw to see what you could save.
The takeaway is simple. Measure the loads first, then pick devices for the biggest ones.
Households with solar can treat storage as a separate question, apart from efficiency. EcoFlow TITAN 5000 shows how a battery moves midday solar into the evening instead of reducing use. The result still depends on the rate plan, export credit, round-trip losses, and a licensed electrician installing the Smart Home Panel 10. Measuring first keeps any comparison honest. It also keeps the focus on real numbers instead of marketing claims.
What are the best devices for saving energy at home?
Smart thermostats, LEDs, power strips with standby control, and energy monitors work best when matched to actual use. Check heating, cooling, water heating, and other substantial loads in your own home, then measure the devices you are considering changing.
Do plug-in "energy saver" boxes work?
No government data cited in this article supports them. A plug-in meter shows real watts. A household can measure use before and after adding one, then judge the claim on its own numbers, not on the box's label or its marketing.
How much does a smart thermostat save?
ENERGY STAR reports average savings of about 8% of heating and cooling bills, or $50 a year. Results vary with climate, schedule, and home size, so actual numbers can run higher or lower in any one household, and a bill comparison helps.
Do smart plugs save electricity?
They can reduce energy use when their schedules or controls cut a device’s standby draw. The smart plug uses a little power to stay connected. Measure the load before and after to estimate the net savings.
Is a home battery an energy saving device?
No. It shifts when a home uses energy rather than reducing how much appliances use. Value depends on the rate plan, export credit, round-trip losses, and fixed charges, so check those numbers before judging any battery on cost.
Save Bills
