Fan vs AC: How They Cool, What They Cost, and When Fans Aren't Enough
Fan vs AC comes down to what each one cools. A fan moves air over skin, so a person feels cooler, but the room does not get any colder. An air conditioner removes heat and humidity from the room. That is why fans use far less power, and why they cannot protect anyone in extreme heat.
This article shows how to measure watts and compare run time using example loads, shows how to estimate cost, and explains the DOE tip for raising the thermostat about 4°F with a ceiling fan. It also covers what to run during a summer outage.
Fan vs AC: How Each One Cools
A fan cools people, not rooms. An AC cools and dries the air. Using both helps a household set the AC a little higher.
Moving air speeds up sweat evaporation, which carries heat away from skin. That is why a breeze feels cool even when the thermometer has not moved. An AC works on the air itself. It pulls heat out through a refrigerant cycle and drains moisture as it runs.
What federal agencies say
DOE on ceiling fans: The U.S. Department of Energy says a ceiling fan allows the thermostat to rise about 4°F without reducing comfort. In moderate climates, fans can sometimes replace AC.
CDC on extreme heat: The CDC recommends using fans only below 90°F indoors. In hotter conditions, a fan can increase body temperature. Move to an air-conditioned place or a cooling center, and use a cool shower or damp cloth to help cool down.
Fan and AC side by side
Fan | AC | |
Lowers room temperature | No | Yes |
Removes humidity | No | Yes |
Typical draw | Low (example: about 40W) | Much higher (example: about 600W while running) |
Safe in extreme heat alone | Not enough alone, per CDC | Stronger protection, per CDC |
Does a fan use less electricity than AC?
Yes, in nearly every home. A fan only moves air. An AC compressor moves heat out of a room, and that takes far more power.
Speed matters too, since higher settings draw more watts. The electricity a fan uses at each speed is easy to measure with a plug-in meter.
During a summer outage, fans and AC need very different backup power.
What to Run During a Summer Outage
Fans and phone charging are small loads. A window or portable AC needs much more, plus a startup surge. Each one should be sized by measured watts and hours.
Fan or AC during power outage: what changes
A fan can run on a small battery for many hours. An AC compressor pulls a large burst of power when it starts, then cycles on and off. That startup peak can overload a battery that looks big enough on paper.
Four checks help keep the plan realistic:
Outlets and startup peak: Confirm the outlet type and the AC's startup draw in the manual. A unit that starts above the battery's surge rating will not run.
Devices running together: Add up the watts of everything on at once. A fan, a router, and a phone charger can reach a total faster than expected.
Runtime by actual use: Estimate hours from real draw, not label numbers alone. Duty cycle shifts with heat, sun, and room size.
Dangerous heat: In very hot weather, follow local guidance and go somewhere cool, such as a cooling center, instead of waiting out the outage at home.
EcoFlow power stations run indoors without fumes, which makes them handy during summer outages. A fuel generator has to stay outside, but a battery can sit in the room where the load is. The right model depends on whether the plan is to run fans or an air conditioner, since watts set what can start and watt-hours set how long it runs.
For fans and phone charging, the EcoFlow DELTA 3 Classic fits the job on paper. Its 1,024Wh capacity lasts a long time, since fans draw little power, and a quiet battery in the bedroom keeps the setup simple.
Air conditioners are a bigger job. For short runs of a verified 120V window or portable AC, the EcoFlow DELTA 3000 Gen4's 7,200W surge rating is built for compressor starts, and its 3,072Wh capacity sets the hours. EcoFlow's US page lists shipping in early January 2027, so it suits planning ahead, not an outage already underway.
How the two products divide the job
EcoFlow DELTA 3 Classic: Fans, lights, routers, and phone charging. Loads this small can stretch a battery over many hours.
EcoFlow DELTA 3000 Gen4: Short runs of a verified 120V window or portable AC. Hours depend on the AC's duty cycle and startup draw.
Dangerous heat: A battery does not change the health risk. When indoor heat turns dangerous, a cooling center is the safer place to be.
Runtime estimates
The figures below are estimates, not label ratings.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) |
Box fan + phone charging | about 50W | about 17 hours | about 52 hours |
Window AC at 60% duty (600W running) | about 360W | about 2.4 hours | about 7.3 hours |
The method is usable capacity (Wh × 0.85) ÷ load (W). The 0.85 factor is a rough allowance for conversion losses. The 50W and 600W loads are example figures, so real draw should come from a meter or the product label.
Window AC wattage varies by size, age, and efficiency. Reading the window AC watts on the nameplate, then confirming with a meter, keeps an outage plan honest.
Backup power aside, most households first want to know what each option costs on a normal day.
How to Compare Fan and AC Running Cost
To estimate cost, multiply power in watts by the hours of use, divide by 1,000 to get kWh, and multiply by the local rate per kWh. If you start with the compressor’s running watts, account for how much of that time it runs and any other power the unit draws. A suitable plug-in energy meter can measure total kWh directly.
The fan vs air conditioner cost gap shows up fast once the math is on paper.
Three steps to the math
Find the watts: Read the label or plug the device into a meter. For AC, use running watts, not only the startup peak.
Convert to kilowatt-hours: Multiply watts by hours of use, then divide by 1,000. For AC, multiply by the duty cycle first. That is the share of time the compressor runs.
Multiply by the rate: The U.S. Energy Information Administration reported an average U.S. residential price of 18.16 cents per kWh in August 2026 (preliminary). Local rates differ, so the utility bill is the better source.
Duty cycle explains why AC cost swings so much. On a mild day, the compressor may run less than half the time. In a heat wave, it may run almost nonstop. A meter reading over a full day gives a better average than a single spot check.
Example: eight hours of use
These labeled examples use the 18.16 cent rate and placeholder loads, not measured results.
Fan: 40W × 8 hours = 0.32kWh, which is about $0.06.
Window AC: 600W × 60% duty × 8 hours = 2.88kWh, which is about $0.52.
Ceiling fan electricity use is small next to AC, even when the fan runs most of the day.
Sizing the AC first
An oversized unit is less effective and wastes energy, according to ENERGY STAR. ENERGY STAR sizing works from square footage, with small adjustments:
Room size: A room of 150 up to 250 square feet maps to about 6,000 BTU per hour on the ENERGY STAR chart.
Sun and shade: Capacity drops 10 percent for a heavily shaded room and rises 10 percent for a very sunny one.
Occupants: If more than two people regularly use the room, add 600 Btu/h of cooling capacity for each additional person.
The lowest bill usually comes from using both tools together.
Using Fans and AC Together
Run the AC at a higher setpoint and add a fan. Turn fans off in empty rooms. Time AC use around the rate plan, if one applies.
Ceiling fan vs AC: a team, not a rivalry
DOE says fans let the thermostat rise about 4°F with no loss in comfort. The fan handles how the body feels, and the AC handles the heat and humidity in the air. Each does a different job.
Raise the setpoint: Move the thermostat up about 4°F and turn on the fan, as DOE suggests. The AC then runs less often.
Switch fans off in empty rooms: A fan cools skin, not air. With nobody in the room, it only adds to the bill.
Know the limit: The CDC recommends using fans only when the indoor temperature is below 90°F. If your home is too hot, go to an air-conditioned place or a cooling center.
Watch the clock: Some plans charge more in the late afternoon. Knowing the cheapest time to use electricity on a plan helps shift AC use when it is practical.
Fan vs AC comes down to what they cool. Fans cool people for little power, while AC cools the room, and the CDC recommends using fans only below 90°F indoors. The practical move is to pair a fan with a higher AC setpoint, as DOE suggests. For outages, an EcoFlow DELTA 3 Classic or an EcoFlow DELTA 3000 Gen4 can match the loads covered above, once watts and hours are checked.
Is a fan cheaper to run than AC?
Yes, usually by a wide margin. A fan often draws tens of watts, while a window AC can draw hundreds when running. Measuring both and multiplying by the local rate shows the real gap for any home, since hours of use and duty cycle change the result.
Does a fan lower room temperature?
No. A fan cools people by moving air across skin, which helps sweat evaporate. The room stays the same temperature, so a fan in an empty room only uses power. An AC is what removes heat from the air, along with some humidity.
Can I use a fan instead of AC in a heat wave?
The CDC says to use a fan only when it is below 90°F indoors. When your home is too hot, go to an air-conditioned place or cooling center. A cool shower or a damp cloth can also help cool your body.
How much can a ceiling fan save?
DOE says a ceiling fan lets the thermostat rise about 4°F with no loss in comfort. Actual savings depend on the AC, the climate, and the local rate, so the utility bill is the best way to confirm the result after a few weeks.
What can I run in a summer outage?
Fans and phone charging need only a small battery. An AC needs more capacity plus enough surge power for the compressor start. Add up the watts and hours first, and verify the startup draw of any AC before connecting it to a battery.
