Houston Electricity Bill Increase: Causes and How to Lower Your Costs
If you noticed your Houston electric bill has gone up recently, it could be due to your usage or a change in utility rates. CenterPoint’s delivery charges, your contract terms and the continuing need for air conditioning can all affect the total bill. Even though your day-to-day habits haven’t changed, your bill may still change. Knowing which part of the bill has changed will help you know if there’s something you can do.
Why Are Electricity Bills Increasing in Houston?
Unfortunately, a higher bill doesn’t always mean you’ve used more electricity. In Houston, delivery charges, retail residential plan changes and long stretches of hot, humid weather can all play a part.
Higher Transmission and Distribution Charges
After you lock in an electricity supply rate with your Retail Electric Provider (REP), CenterPoint Energy Houston Electric adds regulated delivery charges to your bill. CenterPoint maintains the utility poles, wires, and meters that deliver electricity to Houston-area homes. As of November 19, 2026, its residential delivery rate is 6.5611¢/kWh, plus a $4.90 monthly customer and metering charge. For a household using 1,000 kWh per month, these delivery fees total approximately $70.51, before electricity supply charges and taxes.
Rising Grid Maintenance and Infrastructure Costs
Houston’s weather puts a lot of stress on local infrastructure due to hurricane damage and aging substations. The utility will request additional funds for replacement and repair projects. If these projects are approved, part of these costs can show up on your bill through the Distribution Cost Recovery Factor (DCRF) and Transmission Cost Recovery Factor (TCRF).
Higher Electricity Supply Rates in Texas
Your REP provider’s rate can change too, particularly when a contract ends. Texas retail plans reflect conditions in the ERCOT market. When a fixed-rate plan ends and rolls over into a variable rate plan, your supply rate may rise even if your usage stays the same.
Increased Household Electricity Consumption
Of course, electricity bills can also increase because of higher household electricity consumption, even when rates remain unchanged. Houston’s long, hot summers and warm fall weather can keep air conditioners running well into October. Working from home, using an older HVAC system, running a pool pump, and charging an EV can all increase your monthly electricity consumption.
EcoFlow TITAN 5000EcoFlow TITAN 5000
What Makes Up an Average Houston Electricity Bill?
When comparing your costs with the average electric bill in Houston, separate electricity supply charges, delivery charges, and other applicable fees. Comparing these line items with earlier statements can show whether an increase came from your retail plan, TDU charges, or higher usage.
Bill Component
Who Sets the Rate?
How It Is Calculated
Typical Share of Bill
Electricity Supply Charges
Price per kWh multiplied by monthly usage (may vary by tier or time of day)
~55% – 65%
CenterPoint TDU Delivery Charges
CenterPoint Energy (PUCT-regulated)
$4.90/month base fee + 6.5611¢ per kWh delivered
~30% – 40%
Base Charges, Taxes & Fees
REP, State & Local Authorities
Monthly REP customer fee (if applicable), PUC assessment, gross receipts reimbursement, local sales tax
~3% – 8%
Note: Actual electricity bills and the proportion of each charge may vary depending on your monthly electricity consumption, REP pricing plan, applicable CenterPoint delivery rates, and local taxes and fees.
The energy charge is the part of your bill associated with electricity supplied under your retail plan. Depending on your plan’s Electricity Facts Label (EFL), the supply charges can be based on different structures. The supply charge might be a straightforward flat rate per kilowatt-hour, a tiered rate that penalizes or rewards crossing 1,000 kWh, or a time-of-use schedule with cheaper nighttime power.
CenterPoint’s TDU delivery charges apply regardless of which REP you choose and appear on Houston-area electricity bills. The delivery charges combine a flat $4.90 monthly meter and customer fee with a per-kilowatt-hour delivery fee. Therefore, using more electricity will always increase both your supply costs and your CenterPoint delivery total.
Base Charges, Taxes, and Other Fees
Your utility statement may also include several smaller line items. Some REPs charge a monthly base fee of around $4.95 to $9.95, depending on the plan and its usage requirements. State and local authorities may also impose additional charges, such as the Public Utility Commission Assessment, Miscellaneous Gross Receipts Tax Reimbursement, and applicable local sales taxes, which may add around 1% to 2% in certain areas within Houston city limits.
How Can You Track Changes in Houston Electricity Rates?
A month-to-month comparison of just the total cost on your statement can be misleading, especially when the weather changes. Check your plan’s terms and compare both your kilowatt-hour use and the average price you paid per kilowatt-hour.
For homes with rooftop solar, tracking grid purchases and export credits also helps assess whether a solar battery could make better use of daytime generation.
Monitor TDU Rate Updates
CenterPoint typically updates its TDU delivery tariffs twice a year, usually around March 1 and September 1. Occasionally, there will also be interim adjustments if approved by the PUCT. To better understand your utility bill charges, check the PUCT’s monthly TDU rate summary for changes. Then look at your REP’s bill breakdown every spring and fall for changes. This will show you whether a higher bill came from CenterPoint’s regulated delivery tariff rather than your provider overcharging you.
Review Your Electricity Plan Renewal Terms
For fixed-rate electricity contracts lasting at least three months, Texas retail electric providers (REPs) must send residential customers at least three written contract expiration notices during the final third of the contract term. For contracts lasting more than four months, the final notice must arrive at least 30 days before the contract expires; shorter contracts have different notice requirements. If you don’t choose another plan before your contract ends, your REP will automatically move you to a default month-to-month variable-rate plan, which may have a different price each billing cycle. Because this rate can change, set a reminder to compare plans before your contract expires rather than waiting until the default plan takes effect.
Compare Your Monthly Electricity Bills
Houston weather can vary dramatically from week to week and month to month, so utility costs will also vary. Beyond the total cost, look closely at two metrics on your electricity statements: total kWh used and the average price paid per kWh. Average price is your total bill divided by total kWh. Compare those numbers against the same month last year to find out if costs are higher due to more AC usage or higher rates.
Checking billing-period length and estimated meter readings can also help explain why your electricity bill is so high.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Can You Lower Your Electricity Bill in Houston?
Your local TDU’s delivery charges are out of your control, but there are things you can control to reduce costs. Check whether your electricity plan is still the best fit for your household, and reduce your power usage where you can. In Houston, cooling efficiency matters, and shifting some electricity use can help if your plan offers lower rates at certain times.
For households considering a home battery, potential savings depend on the rate schedule, usable solar surplus, and installation costs.
Compare Electricity Plans and Fixed-Rate Options
Power to Choose, the PUCT’s official comparison site, is a useful place to start. Check each plan’s Electricity Facts Label (EFL) at 500, 1,000 and 2,000 kWh. Note that bill credits can make a plan look cheap at one usage level and costly at another. A fixed-rate plan can help stabilize the energy rate in your contract; the total bill still depends on electricity use, applicable delivery charges, and other plan terms.
Improve Home Insulation and Energy Efficiency
Air conditioning can account for more than half of summer electricity use in Houston, so reducing how much heat your home lets in will make a noticeable difference. Check and seal HVAC duct leaks, add weatherstripping around doors and windows, and improve attic insulation. Also, use a smart thermostat that can raise the temperature by a few degrees while you’re out.
Sealing drafts and adjusting thermostat settings are among the easy ways to save electricity at home.
Shift High-Energy Activities to Lower-Cost Hours
Dryers, ovens and dishwashers give off a lot of heat as well as use electricity. Using these on a hot afternoon will make your AC work harder. Try running them later in the day. If your plan has time-of-use or free-night rates, moving EV charging and other large loads to those lower-cost hours may also reduce what you pay per kWh.
Store Excess Solar Energy for Later Use
For households considering power storage, the EcoFlow TITAN 5000 and TITAN 5000 Plus start at 5 kWh and can be expanded to 30 kWh. The TITAN 5000 provides 7.2 kW of battery output and the TITAN 5000 Plus can deliver up to 10 kW of combined output with compatible solar panel input. That extra capacity may be ideal for homes with higher energy demands or multiple large appliances running at the same time.
Both systems include EcoFlow OASIS 3.0, which can learn household usage patterns and schedule battery stored energy use. If you’re on a time-of-use plan, it can charge the battery during lower-rate periods and prioritize stored battery power when TOU rates rise. Actual savings depend on your plan, solar buyback terms, household usage and system setup.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $2,900/year, with ROI in 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, including upfront purchase, installation, and long-term use.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
A higher Houston electricity bill may be due to a rate change, higher air-conditioning use, or both. Reviewing your plan, tracking usage against the same month last year and making practical efficiency changes can help you find where to save. If you have rooftop solar, storing some of your daytime generation for evening use may also reduce the amount of high peak rate grid power you buy.
What Time of Year Are Electricity Rates Lowest in Texas?
Spring (March through May) and fall (October through November) traditionally offer the lowest electricity rates in Texas. Mild temperatures across Houston and the rest of the ERCOT grid ease statewide air conditioning and heating demand, which generally lowers wholesale power prices and prompts retail providers to roll out more competitive fixed-rate plans—even though scheduled power plant maintenance during shoulder months can occasionally cause brief wholesale price spikes.
What Is the Average Monthly Electric Bill in Houston?
The average monthly electric bill in Texas was approximately $171 in 2025, with residential customers using around 1,110 kWh per month, according to the U.S. Energy Information Administration (EIA). Houston-area bills can vary depending on home size, electricity plan, and seasonal usage. Smaller apartments generally use less electricity, while larger single-family homes may have higher bills during peak summer months when air conditioning runs frequently. Actual costs vary by household and location.
What Runs up Your Electric Bill the Most?
Central air conditioning and heating systems are among the largest contributors to household energy use in Houston. According to the U.S. Energy Information Administration (EIA), space heating and air conditioning together accounted for 52% of total annual household energy consumption nationwide in 2020. Electric water heaters, clothes dryers, pool pumps, and Level 2 EV chargers can also contribute significantly to a home’s electricity use, depending on the equipment installed and how frequently it is used.
How to Get the Best Electricity Rates in Texas?
Shop for a straightforward fixed-rate plan during spring or fall shoulder seasons and verify the total price at your actual monthly usage level on the Electricity Facts Label (EFL). Avoid variable-rate plans, watch out for tricky bill-credit tiers that spike your rate if you miss a usage threshold, and set a calendar reminder 30 days before your contract expires so you never roll onto an expensive default renewal rate.
Will Electricity Rates Go down in Texas?
Retail electricity supply rates in Texas dip seasonally during mild spring and fall months, though long-term grid maintenance and CenterPoint delivery fees tend to trend upward over time. Because ERCOT wholesale prices remain sensitive to extreme summer heat, winter freezes, and growing statewide power demand, locking in a competitive fixed-rate contract and reducing grid usage remain the most reliable ways to keep your costs down.
Save Bills
