Texas Solar Buyback Plans: How Credits Work and How to Compare Them
If you have rooftop solar in a competitive Texas market, your retail electric provider decides what you earn for extra power. There's no single statewide buyback rate. Two neighbors with similar solar systems can receive different bill credits because their plans have different export rates, rollover rules, and monthly fees. This guide explains how Texas solar buyback plans work under state law, what to look for in an Electricity Facts Label (EFL), and how to compare plans against your actual usage. You'll also see when storing midday solar for evening use may make more sense than exporting it.
How Do Texas Solar Buyback Plans Work?
In Texas's competitive electricity market, your retail electric provider (REP) sets the terms for buying your excess solar power. The credit you receive depends on your plan, so choosing a provider matters alongside the size of your solar array.
How Do Texas Solar Buyback Plans Work?How Do Texas Solar Buyback Plans Work?
Who pays for the solar power you export?
Texas Utilities Code §39.916(j) says that in areas with customer choice, a distributed renewable generation owner must sell surplus electricity to the retail electric provider serving the property. The price is a value agreed upon by the owner and provider. That value may reflect the electricity market's clearing price at the time of export or take the form of an account credit.
Some plans let unused credits carry over to later billing periods until they're redeemed. Others may apply different limits or conditions. Read the plan's EFL and Terms of Service to see how your provider handles those credits. The rules differ outside competitive retail markets. Municipal utilities, such as Austin Energy and CPS Energy, and electric cooperatives set their own solar programs. Check the utility's current rate documents and board-approved policies before estimating what your exports are worth.
What's the difference between your REP and your utility?
Your retail provider and your transmission and distribution utility (TDU) have different jobs.
  • Retail electric provider: Sets your electricity plan, including the price you pay for power and the credit you receive for exported solar.
  • TDU: Maintains the poles and wires, handles meter-related work, and responds to power outages in its service area.
For example, Oncor and CenterPoint are TDUs, while companies such as TXU Energy and Green Mountain Energy offer retail electricity plans. Your TDU doesn't set the buyback credit on your retail plan. Your plan choice also affects solar's value in Texas. A higher export credit may improve the value of excess production, while a plan with lower credits can make using more of your own solar power attractive. When your plan pays less for exported electricity than you pay to buy power in the evening, storing some of that midday production may be worth considering.
Exporting vs Storing: Where a Home Battery Fits
A home battery lets you store excess solar power during the day and use it after sunset instead of sending it to the grid. Whether that saves money depends on your plan's export credit and the price you pay for electricity in the evening. Compare both values in your Electricity Facts Label (EFL) before choosing a battery.
Compare your buyback plan with battery storage
Start by checking the electricity plans available for your ZIP code. Use each plan's EFL to compare the energy rate, solar export credit, credit rollover rules, and fixed fees. Then look at your hourly solar surplus and evening electricity use to estimate how much energy you could store and use later. A battery's value also depends on your existing solar setup. If your system already uses a grid-tied inverter, an installer must check AC-coupling compatibility, metering, and utility interconnection requirements. Include battery losses, installation costs, and any export credits you would give up. Don't assume storage will pay for itself.
Choosing an EcoFlow TITAN system
If your plan pays less for exported solar than you pay for evening electricity, storing some of that surplus may be worth considering. EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus accept direct solar input and can connect to selected home circuits through a Smart Home Panel 10 (SHP10). A qualified, licensed electrician must install the SHP10. Its grid connection is configured as No Export. For a new or redesigned solar array that fits within one 4,000W input, the EcoFlow TITAN 5000 can store excess solar for use later in the day.
EcoFlow TITAN 5000
For homes with two compatible solar arrays and higher midday production, the EcoFlow TITAN 5000 Plus offers up to 8,000W of total DC solar input across two ports. It provides more solar input capacity than the standard model, making it an option to consider when planning a larger battery setup.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
How the two systems differ
The main difference is how much DC solar input each system can accept:
  • EcoFlow TITAN 5000: Accepts up to 4,000W through one solar input. It suits a new or redesigned array that fits within that limit.
  • EcoFlow TITAN 5000 Plus: Accepts up to 8,000W across two 4,000W inputs. It's an option for two compatible arrays with more midday solar surplus.
Both models have a 7,200W rated output.
Example: Estimate the value of storing solar
The example below shows how to compare storing excess solar with exporting it. The prices are placeholders. Replace them with the rates from your electricity plan's EFL.
EFL Figures
Value
kWh stored instead of exported per day
8 kWh
Usable after round-trip losses (assume 85%)
about 6.8 kWh
Avoidable import cost: energy + variable TDU delivery + applicable usage-based taxes and fees
X ¢/kWh
Plan export credit (placeholder from EFL)
Y ¢/kWh
Daily value of storing
(6.8 × X) − (8 × Y) ¢/day
Calculation: (stored kWh × 85% × avoidable import cost X) − (stored kWh × export credit Y). X and Y are in cents per kWh, so the result is cents per day. X includes the energy rate, any separately billed per-kWh TDU delivery charges, and applicable usage-based taxes or fees that fall when imports fall. Oncor distinguishes fixed monthly charges from variable delivery charges. Do not add delivery twice if it is already included in your rate, and exclude fixed charges that do not change with battery use. This simplified example assumes constant marginal rates and that all export credits forgone would otherwise be usable. TXU Energy, for example, limits buyback credits to eligible energy charges; they do not offset its base charge, TDU charges, taxes, or fees. If credit caps, minimum-use fees, tiered rates, or rollover restrictions affect your plan, compare the actual bill with and without storage instead. Record the plan name and EFL version date. This daily operating-value estimate excludes battery purchase, installation, and degradation costs and does not establish a payback period.
How to Read an Electricity Facts Label for Solar
Every retail electricity plan has an Electricity Facts Label. It lists average electricity prices at specific usage levels and explains key plan terms. For a solar home, pay close attention to the export credit, how the provider applies it, and any fixed monthly charges.
Check these details before choosing a plan
Under 16 TAC §25.475(g), residential EFLs must identify whether a plan has a fixed rate or variable price. They also show average prices at 500, 1,000, and 2,000kWh of monthly usage. Those figures help compare plans, but they may not reflect what a solar household pays after exporting electricity. Review the EFL and Terms of Service for these details:
What to check
Why it matters
Export credit per kWh
Sets the value of each kWh you send out
Credit rollover or cap
Unused credits may expire or be capped
Base or minimum usage fee
Can wipe out savings when solar cuts your net use
Price at your real net usage
Advertised averages may not match a solar home
Contract term and fees
Switching may cost money
Don't compare plans using the advertised average price alone. A home that exports a lot of solar during the day may have a different bill from a home that uses the same amount of electricity but draws most of it from the grid at night. Check how the provider calculates export credits, too. A plan may apply credits to the account differently from another plan, even if the headline rates look similar. Review the full terms before switching. You can also compare your household's usage with Texas electricity bill averages, but your own meter data will give you a more useful starting point.
How to Choose the Best Solar Buyback Plan for Your Home
The best plan depends on how much electricity your panels export, how much power your home draws from the grid, and when you use it. Gather a year of electricity bills and solar production data before comparing providers. That gives you a more realistic picture than a rate advertised for a typical household.
How to Choose the Best Solar Buyback Plan for Your HomeHow to Choose the Best Solar Buyback Plan for Your Home
Use your own solar and electricity data
Look for monthly exported kWh in your utility account, smart meter data, or solar monitoring app. You'll also need the amount of electricity you bought from the grid during each billing period. For each plan, estimate the bill using: Estimated bill = [grid electricity used × (plan energy rate + variable TDU delivery rate)] + fixed monthly charges + applicable taxes and fees − export credits. If the energy rate already includes delivery charges, do not add them twice. Use only export credits that can actually be applied under the plan's rules, including whether credits offset only energy charges or the full bill, along with any rollover limits, caps, or expiration dates. Repeat the calculation for each month if the plan's pricing or credit treatment changes with usage.
Compare plans in your TDU area
Your address determines which TDU serves your home and which retail plans are available. For example, Houston homes may fall under CenterPoint, while many Dallas–Fort Worth homes are served by Oncor. Compare plans available in your area, using the current EFL and version date for each offer. Before switching, confirm meter and interconnection requirements with your TDU and solar installer. Also check Texas solar incentives for programs that may apply to your project.
Texas solar buyback plans vary by retail provider, and the EFL is where you'll find the terms that determine what your exported electricity earns. Compare export credits, rollover rules, fixed fees, and the price you pay for grid power using your own usage data. If your evening electricity price is higher than your export credit, compare the cost of storing solar with the value of selling it. EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus are options to discuss with a qualified installer when planning a compatible home battery setup.
Does Texas have net metering?
Texas doesn't require retail electric providers in competitive areas to offer a statewide net metering program. Each provider sets its own terms for crediting excess solar power, including the rate and how credits are applied to your bill. Compare the EFL and Terms of Service before choosing a plan.
Who pays me for exported solar in Texas?
In areas with customer choice, the retail electric provider (REP) serving your home pays for the surplus electricity your solar panels send to the grid. The value depends on the agreement in your electricity plan. Your transmission and distribution utility (TDU), such as Oncor or CenterPoint, handles the poles, wires, and meter services, not your buyback rate.
Where do I find a plan's solar buyback rate?
Start with the plan's Electricity Facts Label (EFL), then read the Terms of Service for the full conditions. Look for the export credit per kWh, how credits are applied, and whether the provider sets limits or expiration dates. Check the EFL's version date to make sure you're reviewing the current offer.
Do solar credits roll over in Texas?
Some Texas solar buyback plans let unused credits carry into future billing periods, but this isn't guaranteed across all providers. Texas law allows credits to roll over when the agreement includes that arrangement. Check your plan for rollover limits, expiration rules, and any conditions for redeeming the balance.
Is a home battery better than a solar buyback plan?
That depends on how much your provider pays for exported solar compared with what you pay for electricity in the evening. A battery lets you store some midday production for later use, but you also need to account for energy losses and installation costs. Compare the value of using stored power with the export credits you'd give up before deciding.
Save Bills
