EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
Choose the DELTA Gen4 That Fits Your HomeChoose the DELTA Gen4 That Fits Your Home
DELTA 3000 Gen4
DELTA 3000 Gen4
Portable Backup, Easy to Move
Free Gift
$1,299$1,699
Shop Now
  • 3072Wh
    Rated Capacity
  • 3600W
    Rated Output
  • 26 kg
  • Non-expandable
    Expandability
  • 1000W
    PV Input
  • <10 ms9
    UPS
DELTA 3800 Gen4
DELTA 3800 Gen4
Expandable Backup for Longer Outages
Free Gift
$1,699$2,199
Shop Now
  • 3763Wh
    Rated Capacity
  • 3600W
    Rated Output
  • 30.6 kg
  • Expandable
    Expandability
  • 2000W
    PV Input
  • <10 ms9
    UPS
* Limited to the first 500 qualifying orders in total across both models (DELTA 3000 Gen4 and DELTA 3800 Gen4), while supplies last.
DELTA 3000 Gen4
DELTA 3000 Gen4
Free Gift
$1,299$1,699
Shop Now
  • 3072Wh
    Rated Capacity
  • 3600W
    Rated Output
  • 26 kg
  • Non-expandable
    Expandability
  • 1000W
    PV Input
  • <10 ms9
    UPS
* Limited to the first 500 qualifying orders in total across both models(DELTA 3000 Gen4 and DELTA 3800 Gen4), while supplies last.
Estimate Your Runtime
Subscribe
I agree to the Terms of Use and Privacy Policy.
Please agree to the Terms of Use and Privacy Policy.
EcoFlow Image
Industry-First3 Fridge Runtime Boost™ Mode. Helps Protect $200+ in Food Per Outage11Industry-First3 Fridge Runtime Boost™ Mode. Helps Protect $200+ in Food Per Outage11
Turn it on using the unit or the EcoFlow app to extend refrigerator runtime through on-demand power matching and smart power consumption management.
Industry-First³ Fridge Runtime Boost™ Mode.
Helps Protect $200+ in Food Per Outage¹¹
Retains Up to 99% of Its Charge After One Year in Storage¹⁴
Retains Up to 99% of Its Charge After One Year in Storage14
Automotive-grade LFP cells and smart power management minimize energy loss during storage, helping preserve battery charge and reduce the need for frequent recharging.
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Image
EcoFlow Ecosystem Compatibility26
Pair DELTA Gen4 with EcoFlow ecosystem products to build the setup that fits your needs. Compatible with more products beyond those shown.
EcoFlow Ecosystem Compatibility²⁶
Why Choose EcoFlow?
Why Choose EcoFlow?
Comparison
DELTA
3800 Gen4
DELTA 3800 Gen4
Other Power Station
Other Power Station
3763Wh
3584Wh
Fridge Runtime
70 hours
53 hours
No-Load Power Consumption
14W
23W
USB-C Ports
3
2
Weight
30.6kg/67.5lb
34.47kg/76.0lb
Volume
37.73L
57.4L
2*1000W
1000W
Exclusive Mode
Fridge Runtime Boost Emergency Power Mode
NO
EcoFlow Image
EcoFlow Image
EcoFlow Image
$1,599
$1,599
EcoFlow Image
$1,299
$1,299
EcoFlow Image
1.“70+ Hours. The Longest Runtime in Its Class” claim is based on EcoFlow internal testing and a review of selected comparable 3.5–4kWh portable power stations available in the target market as of August 14, 2026 under comparable refrigerator test conditions. Testing was conducted with a Samsung 654L AI refrigerator (model RS62DG50H8CWSC) under no-load conditions, with the refrigerator and freezer temperatures set to 3°C and −18°C, respectively. Actual runtime varies by refrigerator model, food load, ambient temperature, door openings, settings, and usage conditions.
2.The 3W standby power consumption and 14W no-load power consumption figures are based on EcoFlow internal testing under specified conditions. The standby time of 52 days and 6 hours is based on theoretical calculations. Actual power consumption and standby time may vary depending on settings, connected loads, firmware, battery level, and operating environment.
3.Based on EcoFlow internal review of comparable portable power stations available in the target market and their publicly available product features as of August 14, 2026.
4.Performance at 3600W rated output and 7200W surge output is based on EcoFlow internal testing under specified conditions. Actual performance may vary depending on connected loads, ambient temperature, battery health and state of charge, and input voltage conditions.
5.The “smallest and lightest,” “41% smaller,” and “22% lighter” claims are based on EcoFlow internal testing and comparisons with selected comparable 3.5–4kWh portable power stations available in the target market as of August 14, 2026. Product volume is calculated without handles unless stated otherwise. Actual weight may vary by up to ±0.5 kg. Product volume may vary slightly depending on the measurement method.
6.Charging data is based on EcoFlow internal testing under specified conditions, with results compared against EcoFlow DELTA Pro under comparable charging conditions. Actual charging time varies depending on input source, product settings, battery level, ambient temperature, and operating environment.
7.EcoFlow DELTA 3800 Gen4 supports six charging methods, while EcoFlow DELTA 3000 Gen4 supports wall, solar, alternator, and generator charging. Availability varies by model, accessories, region, grid conditions, vehicle compatibility, solar conditions, and product configuration. Certain charging methods require compatible accessories, which may be sold separately and are not included with the product.
8.Based on laboratory testing under specified charge and discharge conditions, the battery cell retains 70% of its initial capacity after 6,000 cycles. The theoretical service life of over 15 years is calculated assuming one charge cycle per day. Actual results may vary depending on usage and operating conditions.
9.UPS <10 ms is based on internal testing. This product does not support 0 ms professional UPS applications and is not intended to be used as the sole backup power source for life-support medical equipment or other systems that require an uninterrupted power supply. Please verify equipment compatibility before use.
10.Promotional savings, offer value, eligibility, availability, and campaign terms are subject to the final campaign terms and conditions.
11.Estimated food value is based on household food-at-home spending and internal assumptions regarding refrigerator/freezer food inventory and the share of perishable food. Actual food value protected varies by refrigerator model, food load, ambient temperature, door openings, household food inventory, and outage duration. EcoFlow is not responsible for food spoilage or secondary losses resulting from power outages or improper device operation.
12.Runtime data is based on EcoFlow internal testing with a Samsung 654L AI refrigerator (model RS62DG50H8CWSC) under no-load conditions, with the refrigerator and freezer temperatures set to 3°C and −18°C, respectively. Actual runtime varies by refrigerator model, food load, ambient temperature, door openings, settings, and usage conditions.
13.The industry average is based on EcoFlow internal testing of selected comparable 3–4kWh portable power stations under comparable refrigerator test conditions. Actual runtime varies by product, appliance, usage, and operating conditions.
14.Calculated based on EcoFlow internal estimates of device hardware standby power consumption and cell self-discharge under standard ambient conditions. Actual battery retention may vary by storage temperature, battery age, storage duration, product condition, and usage conditions. Actual results may vary.
15.Calculator results are estimates only and may vary by appliance model, rated power, startup power, usage settings, battery condition, ambient temperature, and operating conditions.
16.“Power 99% of Home Appliances” is based on EcoFlow internal review of rated power requirements for selected common household appliances. Actual appliance support depends on appliance rated power, startup power, usage conditions, and whether multiple loads are used at the same time.
17.The industry-leading protection claim is based on EcoFlow internal review of selected comparable portable power stations available in the U.S. and their publicly available safety, monitoring, and protection features as of August 14, 2026.
18.This refers to EcoFlow's internal testing process, which includes cell-level tests and whole-unit safety tests. The 120+ tests figure is based on EcoFlow laboratory data and is for reference only.
19.The 50+ BMS protection claim is based on EcoFlow internal product specifications. Protection availability and performance may vary by operating conditions, firmware version, battery status, load, and product settings.
20.Thermal runaway protection claims are based on EcoFlow internal product specifications and applicable UL 9540A cell thermal runaway testing. Actual safety performance may vary by use environment, product condition, installation, and operating conditions.
21.Warranty coverage includes a 3-year basic warranty. An additional 2-year warranty extension is available upon product registration through the app or official website.
22.The industry-first Emergency Power Mode™ claim is based on EcoFlow's internal review of comparable portable power stations available in the U.S. and their publicly available product features as of August 14, 2026.
23.Emergency Power Mode™ performance is based on EcoFlow internal testing under specified conditions. Actual charging results vary by phone model, battery health, cable, ambient temperature, product settings, and device usage during charging.
24.Compared with the previous generation, Storm Guard Mode 2.0 integrates U.S. National Weather Service data to provide more accurate severe-weather forecasts, helping the system prepare and recharge automatically before storms for more reliable backup readiness.
25.Weather alerts, Storm Guard availability, automatic charging, and supported weather data sources vary by region, software version, network connection, and user settings. Weather information is provided by third-party weather data services. EcoFlow does not warrant or guarantee the completeness or accuracy of third-party weather data. Automatic charging and alerts may fail or be delayed due to network outages, service interruptions, incorrect settings, or unexpected weather changes. EcoFlow is not liable for power loss, property damage, spoiled goods, or other losses resulting from failed, delayed, or inaccurate alerts. Dashboard data and savings estimates are for reference only and may vary by device setup, electricity rates, usage patterns, and software version.
26.Accessory compatibility, feature availability, and bundle configurations vary by model, region, firmware, accessory version, and product setup. Check compatibility before purchase.
27.All product images, specifications, and performance data shown are for illustrative purposes only. Actual product performance may vary due to environmental conditions, software versions, and usage practices.
