What Is a Smart Thermostat? How It Controls Your HVAC and What It Saves
What is a smart thermostat? It is a connected thermostat that lets you schedule HVAC operation and can allow remote control. Some models learn routines or respond to occupancy. ENERGY STAR says certified models save about 8% on heating and cooling bills, or roughly $50 a year on average. This article covers how a thermostat signals a furnace, heat pump, or AC, how to check wiring compatibility, what shapes the savings, and what still needs power during an outage.
What Is a Smart Thermostat and How Does It Work?
A thermostat tells the HVAC equipment when to run. A smart model adds network connectivity and software so you can set a schedule or control the temperature remotely when the connection is available. Wi-Fi is common. Others, such as the Resideo T6 Pro Z-Wave, connect through a compatible gateway or controller. Learning and occupancy features depend on the model.
Not every model earns the ENERGY STAR label. An ENERGY STAR smart thermostat is independently certified by EPA-recognized certification bodies, and its savings must be shown in real homes across the United States.
How Does a Smart Thermostat Work Day to Day?
The cycle is short. Sensors read the room, the software compares that reading with the target, and a relay signals the equipment.
  • Sensing: Built-in sensors track indoor temperature. Many models add humidity or motion sensing, and some pair with remote room sensors.
  • Deciding: The software uses the temperature target and any schedule you set. Some models also respond to occupancy or learn a schedule. Check the model instructions for how learning works and when changes take effect.
  • Signaling: In a compatible low-voltage central HVAC system, control wires signal the furnace, heat pump, or AC to heat, cool, or run the fan.
  • Reporting: Some models log run time and display usage trends.
Smart vs. Manual vs. Programmable
The U.S. Department of Energy notes that smart models can adjust based on occupancy or activity, while programmable ones follow a fixed schedule. The table shows the gap.
Feature
Manual
Programmable
Smart
Schedule
None
Set by hand
App-set schedules; some models learn routines
Remote control
No
No
Yes, through the supported connection
Occupancy sensing
No
No
Many models
Usage reports
No
No
Available on some models
Power and Wiring Basics
Many smart thermostats for low-voltage central HVAC use 24 V control power. A common wire, often labeled C, can provide a steady power path. A 120 V or 240 V line-voltage heater requires a thermostat designed for that heater and voltage. Follow the model's own wiring instructions and use an electrician where needed.
Check the maker's compatibility tool for the thermostat and HVAC system together. Google's Nest compatibility guide shows that some setups work without a C wire and others need a C wire or compatible power connector.
Location features add to the picture. Some models use geofencing for HVAC savings, easing the setpoint when a phone leaves home and restoring it on the way back.
A thermostat only sends orders. The equipment on the other end still needs power to follow them, and that matters most when the grid goes down.
Does a Smart Thermostat Work in a Power Outage?
Not on its own. The thermostat, the furnace control board, and the blower motor all need power. Keeping only the thermostat on does nothing for heat.
A gas furnace relies on electricity for several parts:
  • Igniter: Most modern gas furnaces light with an electric igniter, so there is no flame without power.
  • Inducer fan and pressure switch: The inducer establishes draft. The pressure switch confirms draft to the control board before ignition, as illustrated in the Lennox heating sequence.
  • Control board: It runs the startup sequence and the safety checks.
  • Blower: It pushes warm air through the ducts. Without it, the heat stays inside the furnace.
That is why a gas furnace without electricity usually sits idle. A thermostat with backup batteries may keep its screen lit, but the furnace still waits for power.
The Outage Heat Chain
In an outage, heat depends on three links working in order:
  1. The thermostat calls for heat.
  2. The control board starts the sequence.
  3. The blower moves the warm air.
A break at any link stops the chain. A backup plan has to cover all three. That is why powering the thermostat alone, with a small battery or plug-in supply, does not restore heat.
Backing Up the Furnace Circuit
EcoFlow TITAN 5000 is a home battery. Paired with the EcoFlow Smart Home Panel 10 and installed by a licensed electrician, it can back up selected circuits. For outage heat, the furnace circuit is the one that counts. It feeds the control board, igniter, and blower, along with the thermostat.
A gas furnace draws modest power next to many large appliances. The battery may carry that circuit for many hours, once an electrician confirms the furnace and its controls suit the setup.
EcoFlow TITAN 5000
The panel must be installed by a qualified, licensed electrician. Grid connection with the Smart Home Panel 10 is No Export, per EcoFlow.
Runtime Estimates
Estimate runtime by dividing usable watt-hours by the measured average load in watts. For backup sizing, have an electrician check the furnace model's electrical requirements and motor startup demand. For runtime, measure representative power or energy over a full cycle, including standby. The examples assume about 4,265 Wh usable, or 85% of the TITAN 5000's rated 5,017.6 Wh capacity.
Load (example)
Watts used
EcoFlow TITAN 5000 (4,265Wh usable est.)
Hypothetical furnace load while running
about 500W
about 8.5 hours
Hypothetical average at 50% duty, excluding standby
about 250W
about 17 hours
Other loads on the same circuit, cold weather, and battery condition would change these numbers.
Outages are rare, though. On most days, the thermostat's job is cutting waste, and a few factors decide how much it cuts.
How Much Can a Smart Thermostat Save?
ENERGY STAR's average is a fair starting point. Results still depend on climate, habits, and equipment. A home that already follows a tight schedule has less left to gain.
ENERGY STAR reports that, on average, savings are about 8% of heating and cooling bills, or $50 per year. It adds that savings may run higher depending on climate, comfort preferences, occupancy, and HVAC equipment.
The target is large. According to ENERGY STAR, almost half of a household's annual energy bill goes to heating and cooling, more than $900 a year.
Homeowner checking energy usage on phoneHomeowner checking energy usage on phone
What Changes the Savings
  • Climate: Homes in harsh climates run equipment longer, so setbacks have more hours to work with. Mild regions leave less room.
  • Habits: Irregular schedules gain more from occupancy sensing and geofencing than a household that is home all day.
  • Equipment: Heat pumps, multi-stage furnaces, and older systems respond differently. ENERGY STAR notes that variable-capacity systems generally perform best with the manufacturer-recommended thermostat.
  • Starting point: A home with a well-used programmable thermostat sees a smaller change than one run by hand.
Smart Thermostat Benefits Beyond the Bill
Comfort and convenience count too. Remote control fixes a forgotten setback from anywhere. Usage reports show how long equipment runs, which helps catch a system that cycles too often. Some models also send alerts when indoor temperature passes a set limit, which can help with a vacant home.
A thermostat is one piece of smart home energy savings, alongside smart plugs and energy monitors. Each piece is small, and the gains add up slowly.
Savings only show up when the unit fits the system. That makes setup the last step to get right.
How to Choose and Set Up a Smart Thermostat
Check compatibility before choosing features. Identify the HVAC type, stages, and thermostat voltage. The setup steps below apply to compatible low-voltage central HVAC only. For line-voltage electric heat, choose a compatible thermostat and follow the manufacturer's line-voltage installation guidance.
Hands wiring a new wall thermostatHands wiring a new wall thermostat
Pre-Purchase Checklist
  1. System type: Identify a gas furnace, heat pump, or dual fuel setup, and note the number of stages. Dual fuel needs a model that can manage the switch between heat sources.
  2. Wiring: Use the thermostat maker's compatibility tool to check whether your HVAC setup needs a C wire, a compatible adapter, or neither. See Nest's model-by-model guide for examples.
  3. ENERGY STAR certification: Certified models have verified savings data behind them.
  4. Rebates and demand response terms: Programs differ by utility. ENERGY STAR notes that most rebate programs do not require demand response participation, but each program's terms are worth reading.
Basic Setup Steps
  1. Turn off power to the HVAC system at the breaker.
  2. Photograph the old wiring and label each wire.
  3. Mount the new base plate and connect the wires as the maker directs.
  4. Restore power and connect the thermostat as its manual directs, using its supported Wi-Fi network or gateway.
  5. Build a schedule and review it after a week.
An HVAC technician can help when the wiring looks unfamiliar or the system is a heat pump with auxiliary heat.
Match the Schedule to the Rate Plan
Rate structure changes the best schedule. If the home is on time-of-use rate plans, shifting heating and cooling away from peak hours can lower costs. Peak hours vary by region and season, so the utility's own schedule is the one to follow. Pre-cooling or pre-heating should finish before the utility's peak window opens.
A smart thermostat is a connected control for scheduling and adjusting HVAC equipment. Network and automation features depend on the model. ENERGY STAR estimates that certified models save about 8% on heating and cooling bills, or $50 a year, on average. Check system compatibility, wiring, and utility rebates before choosing one.
Outage heat is a separate question. A thermostat cannot run a furnace by itself, so homes with gas heat may want a plan for the furnace circuit. The EcoFlow TITAN 5000 can back up a furnace circuit once an electrician has evaluated the furnace and its controls and installed the EcoFlow Smart Home Panel 10. It is one option worth weighing against the furnace's rating plate and the home's backup needs.
A smart thermostat is a connected HVAC control that lets you set schedules and, when supported, adjust settings remotely. Some models learn schedules or detect occupancy. The thermostat signals the equipment, which supplies the heating or cooling.
Do smart thermostats really save money?
ENERGY STAR says certified models save about 8% of heating and cooling bills, or $50 a year, on average. Climate, habits, and equipment change the result, and a home that already runs a tight schedule may save less than that average.
Do I need a C-wire?
It depends on the thermostat and HVAC system. A C wire provides steady power for many low-voltage models. Check the manufacturer's compatibility guide to see whether your setup needs a C wire or an approved adapter, or can work without either.
Does a smart thermostat work without Wi-Fi?
Many Wi-Fi models can still control heating or cooling locally as long as the thermostat and HVAC equipment have power. Whether a stored schedule keeps running depends on the model. Remote app access and cloud alerts may pause while the connection is down. Models that use a hub or gateway have their own offline behavior.
Will my heat work in an outage with a smart thermostat?
Only if the furnace and blower also have power. The thermostat only sends the call for heat. A gas furnace still needs electricity for the igniter, inducer, control board, and blower, so any backup plan has to cover each of them.
Save Bills
