How Many Watts Does an Electric Stove Use?
Electric stoves are common in many kitchens and offer a popular cooking option. If you're looking for ways to cut your electricity bill, understanding electric stove wattage is essential. This is a breakdown guide to the power consumed by different electric stoves - coil, smooth top, and induction models. We delve into the amount of electricity individual burners use, factors affecting power use, and how the oven element comes into the equation.
Electric Stove Wattage: How Different Types Compare
Coil Electric Stoves
Coil stoves are the traditional option with visible heating elements. They're usually more affordable than other types. These stoves work by sending electricity through metal coils that heat up to cook your food.
Most coil stoves use between 1,000 and 3,000 watts in total, though larger models can use up to 12,000 watts. The individual burners use different amounts of power depending on their size:
  • Small burners: 1,200-1,500 watts
  • Large burners: 2,000-2,700 watts
When looking at energy usage, pay attention to both the model and burner size since they can vary quite a bit.
Smooth Top Electric Stoves
Smooth top stoves have a flat cooking surface made of ceramic glass with heating elements hidden underneath. They look more modern and are easier to clean than coil stoves.
Like coil stoves, they typically use 1,000-3,000 watts overall. Standard home models with multiple burners and an oven might use 6,000-8,000 watts total. The individual burners generally use:
  • Small to medium burners: 1,200-2,200 watts
  • Larger burners: up to 3,500 watts (especially for rapid-boil elements)
While they use similar power to coil stoves, smooth tops often offer more variety in burner power options.
Induction Electric Stoves
Induction stoves use electromagnets to heat your cookware directly, making them faster and more energy-efficient than traditional electric stoves. The cooktop creates a magnetic field that interacts with your pots and pans to produce heat.
Small or single-burner units typically use 1,000-3,000 watts, while high-end models can reach 12,000 watts. Induction burners tend to have higher wattage than other types:
  • Single burners: 1,200-2,000 watts
  • Medium burners for everyday cooking: 2,000-2,500 watts
  • Large burners: 2,500-3,700 watts (some premium models go up to 4,600 watts)
For most home cooking, 2,000-2,500 watts per cooking zone works well, balancing speed and efficiency.
Electric Stove Wattage Comparison Chart
Stove TypeEntire Unit (W)Small Burner (W)Medium Burner (W)Large Burner (W)
Coil1,000-3,0001,200-1,500~2,0002,000-2,700
Smooth Top1,000-3,000~1,200~2,0002,500-3,500
Induction1,000-3,000 (up to 12,000)1,000-2,0002,000-2,5002,500-3,700+
Electric Stove Power Usage: The Cooktop Burners
Small Burners
Small burners use the least power on any electric stove. They're perfect for simmering sauces or keeping your food warm without wasting electricity.
Stove TypeWattage Range
Coil1,200-1,500 watts
Smooth TopAround 1,200 watts
Induction1,000-2,000 watts
Portable Induction1,000-1,800 watts
Medium Burners
Medium burners are your everyday workhorses. They hit a sweet spot between power and versatility for regular cooking tasks like boiling pasta water or cooking vegetables.
CoilAround 2,000 watts
Smooth TopAround 2,000 watts
Induction2,000-2,500 watts
It's interesting that medium burners use pretty much the same power across all stove types - seems like 2,000 watts is the magic number for general cooking.
Large Burners
Large burners bring the heat when you need it most - for searing steaks, stir-frying, or heating big pots of soup. They use the most power but get the job done faster.
Coil2,000-2,700 watts
Smooth Top2,500-3,500 watts
Induction2,500-3,700+ watts
Induction burners typically have the highest wattage because they're designed to heat up quickly and efficiently.
Electric Stove Power Usage: The Oven Section
Preheating Phase
When you first turn on your oven, it uses a lot of power to heat up quickly. This is the preheating phase that most recipes ask for.
AspectDetails
Typical Power Usage2,000-5,000 watts
Average Duration10-20 minutes
Factors Affecting Duration• Oven size • Target temperature • Oven efficiency/age
Preheating uses a good chunk of energy even though it's brief. If you're trying to save electricity, avoid preheating longer than needed.
Baking Phase
Once your oven reaches the right temperature, it switches to maintenance mode - just keeping the heat steady while your food cooks.
AspectPower Usage
General Range2,000-5,000 watts
Standard OvensAround 3,000 watts
Modern Ovens (medium-high heat)Around 2,400 watts
The actual power used during baking depends on your temperature setting. Higher temperatures mean the heating elements turn on more frequently, using more electricity. For example, baking cookies at 350°F uses less power than roasting a chicken at 425°F.
Beyond Specifications: Practical Factors Affecting Electric Stove Energy Usage
Wattage numbers on appliance labels do not tell you everything you would like to know. Here's what really affects how much electricity your stove uses daily:
EcoFlow DELTA Pro 3 Portable Power Station 3EcoFlow DELTA Pro 3 Portable Power Station 3
1. Dial Position: Low vs. High Settings Power Difference
Turning your burner low doesn't utilize it at maximum power all the time. Rather, it is constantly turned on and off in an attempt to regulate temperature. With a 2,000-watt low-set burner, however, sits idle much of the time, it will likely draw a true average of only 500 watts. Smaller ratings mean more electricity being consumed by an element over longer periods. Therefore, for long cooking sessions, simmer phases are significantly less expensive than running high heat.
2. Pot and Pan Types: Flat-Bottom Cookware Efficiency
Pans you use to cook are far from equally efficient. Compelling a larger flame into service flat-bottomed pots maximize contact and conduction. Thinned or bent pans waste energy; heavy stainless steel, cast iron pans are good conductors. By a few minutes, a good pan shortens the cooking time and thus saves actual energy over time. In eight minutes, rather than twelve, a good pan can warm your food up—that's thirty-three percent less energy used.
3. Cooking Time: Direct Impact on Energy Consumption
Your stove consumes more electricity the longer it's on. The relationship is direct - double the cooking time means double the energy used. Cooking at high heat for a short amount of time can sometimes be more efficient than cooking at low heat for long periods of time. For instance, despite elevated power level, rapidly boiling vegetables may use less total energy compared to slowly simmering them over an extended period.
4. Stove Age: Efficiency Decline in Older Models
For the same cooking purpose, older stoves consume more electricity. Older ovens are poorly insulated, exhausted heating elements take longer to heat, and broken seals allow heat to escape. For the same jobs, a 15-year-old stove can consume 20–30% more electricity than a new one. Although regular cleaning makes it better, sooner or later the efficiency difference may be enough to make a replacement necessary.
How to Calculate Your Electric Stove's Energy Cost
Step 1: Find Your Stove's Wattage Rating
Your electric bill is calculated in kilowatt-hours (kWh). Think of a kWh as the amount of electricity needed to keep a 1,000-watt appliance running for one hour. This is how utility companies measure and charge for the electricity you use.
First, check your stove's label or manual to find the wattage of each burner and the oven. This information is usually listed on a sticker on the back or bottom of your stove, or in your user manual.
Step 2: Calculate kWh From Usage Time
To figure out how much electricity your stove uses:
  • Take your stove's wattage and divide by 1,000 to get kilowatts (kW)
  • Multiply by the number of hours you use it
Energy (kWh) = Power (kW) × Time (hours)
For example:
Using a 2,000-watt burner for 1 hour = (2,000 ÷ 1,000) × 1 = 2 kWhUsing a 2,400-watt oven for 30 minutes = (2,400 ÷ 1,000) × 0.5 = 1.2 kWh
Step 3: Convert to Dollars on Your Bill
To calculate your actual cost:
  • Find your electricity rate on your utility bill (typically around $0.13 per kWh)
  • Multiply your kWh by this rate
For example:
2 kWh × $0.13 = $0.26 to run a large burner for an hour
1.2 kWh × $0.13 = $0.16 to use your oven for 30 minutes
Your stove doesn't always use its maximum wattage. On medium heat, burners typically use roughly half to three-quarters of their maximum rating.
Lower Your Electric Stove Power Bills!
Every type—from coil to induction models—has varied energy requirements. The most important factors are your stove's age, the pots you use, the heat settings you set, and how long you cook. Using the correct burner size, quality cookware, and suitable heat levels will help you to save electricity while still producing fantastic food. Little adjustments in your cooking techniques can result in clear monthly savings on your expenses.
