Tornado Emergency Kit: What Goes in Your Shelter Space and What You Grab on the Way
A tornado warning isn't the time to look for a flashlight or figure out where to shelter. A warning means a tornado has been sighted or indicated by radar, and dangerous weather may be close. That is why a good tornado emergency kit should be ready before severe weather arrives. More importantly, it should be organised around how a tornado emergency actually unfolds. Think of your supplies as two connected kits: one in your shelter and another you can quickly grab on your way. Once the storm passes, the next worry is backup power. This is crucial if damaged lines leave your neighbourhood without electricity.
Why a Tornado Kit Isn't the Same as a Standard Emergency Kit
Hurricane and winter storm preparations may give you hours or days to organize supplies, but tornadoes can develop much faster. A tornado watch is the time to review your plan, charge devices, and check supplies, while a warning means you should take shelter immediately. During the watch stage, knowing what a tornado watch really means can help you prepare before conditions worsen. Keep shared supplies in your shelter space and personal essentials in a grab-and-go bag.
The Tornado Emergency Kit Checklist, Split in Two
A shelter kit should remain in or immediately beside your designated safe area. A grab-and-go bag should contain items that household members may need personally or may need to take if they must leave the home afterward.
Item | Where It Lives | Where It Matters |
Water | Shelter space | Plan for at least 1 gallon per person per day |
Nonperishable food | Shelter space | Provides food when cooking or refrigeration is unavailable |
Manual can opener | Shelter space | Open canned food without electricity |
NOAA Weather Radio | Shelter space | Provides weather warnings without relying on cellular service |
Flashlight + batteries | Shelter space | Provides safer lighting during an outage |
First-aid kit | Shelter space | Handles minor injuries and basic medical needs |
Whistle | Shelter space | Can help attract rescuers if trapped |
Blankets or sleeping bags | Shelter space | Adds warmth and body protection |
Helmets | Shelter space | Provides an additional layer of head protection |
Sturdy shoes | Shelter space | Helps protect feet from broken glass and debris |
Phone + charger/power bank | Grab-and-go | Keep communication available |
Medications and glasses | Grab-and-go | Covers individual daily needs |
ID, keys, cash, documents | Grab-and-go | Useful after evacuation or property damage |
Pet supplies | Grab-and-go | Supports pets during evacuation or displacement |
Head protection and footwear
Helmets and sturdy footwear deserve special attention in a tornado kit. NWS offices recommend having helmets available when possible, while CDC notes that research on helmet effectiveness during tornadoes is limited. CDC does emphasize that head injuries are a common cause of tornado deaths and says helmets should never replace getting into proper shelter. Sturdy shoes are equally practical. Broken glass, nails, damaged flooring, and other debris can make walking through a damaged home hazardous after the storm.
Staying informed without cell service
A NOAA Weather Radio with battery backup gives you another way to receive warnings when the power or cellular network is unavailable. CDC identifies NOAA Weather Radio as an important source for continuous weather information. Keep spare batteries with your radio and flashlight, and test them regularly. A well-stocked supply bin still depends on the room around it, so choosing one of the safest rooms in your house helps determine where the shelter portion of your kit should live.
Backup Power for the Outage After the Tornado Passes
A tornado can damage power lines and other electrical infrastructure, so safety should come first after the storm. Stay away from damaged buildings and downed power lines, while a closed refrigerator can generally keep food cold for up to four hours. Fuel generators must be used outdoors and more than 20 feet from windows, doors, and vents, while battery power stations can provide indoor power without producing exhaust. For longer outages, the EcoFlow DELTA 3 Max can provide portable backup for essential appliances, while the EcoFlow DELTA Pro Ultra X offers an installed solution with 12kWh of storage and 12kW of output, expandable up to 180kWh and 36kW depending on configuration.
For homeowners who want an installed backup system rather than a portable kit item, EcoFlow DELTA Pro Ultra X provides 12kW of output and 12.288kWh standard capacity, with larger configurations available. It can integrate with Smart Home Panel 3, but installation requires professional electrical work.
For a portable option, EcoFlow DELTA 3 Max (2048Wh) provides 2,400W of AC output, 4,800W surge output, and can recharge from 0% to 80% in about 68 minutes under specified charging conditions.
The difference is practical: the EcoFlow DELTA Pro Ultra X is designed as an installed home backup system, while the EcoFlow DELTA 3 Max can be moved where power is needed. Planning for power loss after a tornado can therefore be treated as the second half of tornado preparation rather than an unrelated backup-power project.
Where to Store Your Kit Based on Your Home
The best emergency tornado kit is one you can reach quickly when a warning is issued. Store it based on where your household will actually shelter, keeping essential supplies within easy reach. This helps you move to safety without wasting time searching for important items.
Homes with a basement
Place the shelter portion in the interior part of the basement, away from windows. Keep shoes and helmets somewhere everyone can reach, even if the lights are out. Water, food, blankets, flashlights, radios, and first aid supplies can stay in a clearly marked container nearby.
Homes without a basement
Choose a small interior room without windows on the lowest floor. A closet, bathroom, or interior hallway may work, depending on your home's layout. The route to this space should remain clear. Avoid storing heavy boxes or furniture where they could slow everyone down.
Mobile and manufactured homes
A mobile home is not a safe place to remain during a tornado. The CDC and National Weather Service recommend moving to a sturdy building or storm shelter. Plan your destination before severe weather arrives. Keep the grab-and-go bag near the door and make sure everyone knows where to go.
Safe rooms and storm shelters
A reinforced safe room can provide a more permanent shelter option, but structural work should be properly planned rather than treated as a casual DIY project. If your household is considering building a tornado shelter at home, make the emergency kit part of that planning from the beginning.
Keeping Your Tornado Kit Ready Year-Round
A tornado kit should be maintained regularly so its supplies remain usable when severe weather strikes. A simple twice-a-year check can help you replace expired items, test equipment, and keep your household prepared.
Test the NOAA Weather Radio and flashlight: Turn on both devices to confirm they work properly and provide clear alerts or lights when needed.
Replace or recharge batteries as needed: Check battery levels in radios, flashlights, and other devices, replacing expired batteries or fully recharging rechargeable ones.
Rotate stored food and water: Check expiration dates and use older supplies first, then replace them with fresh food and water to keep your emergency stock ready.
Update medications and important documents: Replace expired medications and review copies of identification, insurance information, emergency contacts, and other important documents.
Check shoes and helmets for children: Make sure children still have properly fitting sturdy shoes and helmets, especially if they have grown since your last inspection.
Recharge and test your backup power equipment: Fully recharge portable power stations and test them with essential devices to confirm they are ready for an outage.
Review the shelter location with everyone in the household: Make sure everyone knows where to go during a tornado warning and understands the safest route to the designated shelter area.
Practice moving to the shelter quickly: Run a short tornado drill so everyone can practice reaching the shelter safely and knows what to do when an alert is issued.
CDC also recommends creating and practicing a tornado emergency plan, including identifying the shelter location and making sure household members understand warning procedures. Tornado risk varies by region, so checking tornado season timing by region can also help you decide when to perform your more thorough seasonal inspection.
A tornado emergency kit works best as two connected parts: shelter supplies that stay in your safe location and a grab-and-go bag containing personal essentials. Water, food, a NOAA Weather Radio, a flashlight, a first-aid kit, a whistle, blankets, sturdy shoes, and head protection cover the immediate needs. Choose your shelter room, stock it, and check the kit twice a year. For the outage afterward, a portable EcoFlow DELTA 3 Max can support essential devices and appliances, while the installed EcoFlow DELTA Pro Ultra X is designed for larger home backup needs.
What should be in a tornado emergency kit?
A basic kit should include water, nonperishable food, a manual can opener, a weather radio, flashlight, extra batteries, first aid supplies, whistle, blankets, sturdy shoes, and head protection. Keep phones, chargers, medications, important documents, and personal necessities in a grab-and-go bag.
Where should I keep my tornado shelter survival kit?
Keep your tornado shelter survival kit in the interior part of your basement if you have one. If not, store it in a small, windowless interior room on the lowest floor where your household plans to take shelter.
Do I really need a helmet in my tornado kit?
National Weather Service offices recommend helmets when available. The CDC notes that research on helmet effectiveness during tornadoes is limited, but head injuries are a significant concern. A helmet can be part of a broader protection strategy.
What's the difference between a tornado watch and a warning?
A watch means conditions are favorable for tornadoes, so it's time to prepare. A warning means a tornado has been sighted or indicated by radar, so you should take shelter immediately.
What should mobile home residents do?
Plan to leave for a sturdy building or storm shelter before a tornado arrives. Do not rely on a mobile home as a shelter location. Keep your grab-and-go bag ready and know your destination ahead of time.
