Texas Winter Storm: How to Track Grid Alerts, Handle Outages, and Prepare
A Texas winter storm can cause two kinds of outages. One is local. Ice snaps a line on your street, and your utility fixes it. The other is grid-wide. In February 2021, FERC says more than 4.5 million Texans lost power, some for four days. In January 2026, ERCOT reported no systemwide outages during Winter Storm Fern. This guide shows where to check forecasts and grid status. It explains ERCOT alert levels. It helps you tell local outages from grid ones. It also covers how to keep essentials running until power returns.
Is a Texas winter storm coming?
Check your local NWS office first. Forecasts change as cold air gets closer. In the ERCOT service area, also check ERCOT grid alerts. Elsewhere, check your local utility and grid operator.
On Nov. 20, 2026, NWS Fort Worth said temperatures should run below normal for much of next week. It also expected a mostly dry pattern. A dry pattern lowers the chance of ice, but forecasts can shift. Check again before you plan.
Here are the NWS offices that cover the major metro areas:
ERCOT manages the grid serving about 90% of Texas electric load. Some areas are outside its footprint. It sends alerts through TXANS. Those alerts include a Weather Watch, a Voluntary Conservation Notice, a Conservation Appeal, and Energy Emergency Alert (EEA) Levels 1 to 3. You can sign up at ercot.com/txans by email or text.
Past outages shaped how Texans plan today. Read the FERC and NERC report on the February 2021 outages.
Whatever the forecast says, plan your power for the gap before restoration.
Keeping essentials running through a winter outage
Plan for short local outages and longer ones. Start with lights, phones, and a radio. Add a fridge if outages may last more than a few hours.
FoodSafety.gov says a fridge keeps food safe for up to 4 hours without power. A full freezer holds for about 48 hours. Both need the door shut.
Check your utility for local outages. For systemwide updates, use ERCOT if you are in its footprint, or your own grid operator if you are outside it. Then size your backup for the gap you expect before power comes back.
Before you buy anything, check four things:
  • Compressor startup: A fridge draws more power for a moment when its compressor starts.
  • Outlets: Make sure the unit has the outlets your devices need.
  • Simultaneous loads: Add up what runs at the same time.
  • Measured use: Use real watt readings, not guesses.
Charge and use a power station in a dry place. Keep it within its listed temperature range. Fixed heating and medical equipment need separate plans.
EcoFlow power stations run indoors with no fumes. That matters in cold weather, when windows stay shut. Gas generators need to sit outside, far from the house. A power station can stay inside. Pick one by two things. How long might you go without power? And what has to stay on? Answer those first, then choose.
For short outages, the EcoFlow DELTA 3 Classic keeps lights, phones, and a radio going. Store it and charge it indoors. It holds 1,024Wh, enough for basic needs when the line on your street goes down. It recharges fast.
EcoFlow DELTA 3 Classic (1024Wh)
EcoFlow DELTA 3 Classic (1024Wh) + Bag
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For longer gaps, DELTA 3000 Gen4 can run a compatible 120V fridge, plus communications and lights, until you can recharge. Check delivery timing first. EcoFlow's US page says it ships in early January 2027, so it is a plan for later, not for a storm now.
EcoFlow DELTA 3000 Gen4
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How do the products divide the job?
  • EcoFlow DELTA 3 Classic: short outages.
  • EcoFlow DELTA 3000 Gen4: a fridge plus essentials until your next recharge.
The table below shows estimated run times. These are estimates. Real run time depends on your devices, the cold, and how often a fridge compressor starts. The method is simple: usable capacity (Wh × 0.85) ÷ load (W).
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
Lights + phones + radio
about 30W
about 29 hours
about 87 hours
Fridge average (ENERGY STAR example, about 38W) + router + lamp
about 63W
about 14 hours
about 41 hours
Size battery backup for a refrigerator by startup and daily kWh.
Next, local outages versus grid emergencies.
Local outages vs grid emergencies
Ice on lines or falling trees can cause local outages. Within the ERCOT service area, ERCOT can direct controlled outages during an Energy Emergency Alert Level 3. Utilities and grid operators outside ERCOT use their own procedures.
During Winter Storm Fern in January 2026, ERCOT issued no Energy Emergency Alert. It reported no systemwide power outages. Local utilities handled the outages that ice caused.
February 2021 was different. FERC says more than 4.5 million Texans lost power, some for as long as four days. At the worst point, ERCOT ordered 20,000 MW of firm load shed.
Outage type
Cause
Where to check
Local
Ice, trees, equipment
Your wires company (Oncor, CenterPoint, AEP Texas, TNMP) or co-op/muni outage map
Grid emergency
Supply short of demand
ERCOT TXANS and dashboard within the ERCOT footprint. Outside it, check the local utility and its regional grid operator.
Maps show local status. In North Texas, start by using the Oncor outage map.
Finally, safety in the cold.
Illustration of icy road conditions that can occur during a central Texas winter storm.Illustration of icy road conditions that can occur during a central Texas winter storm.
Winter storm safety in Texas
Heat safely and avoid carbon monoxide. Insulate exposed pipes to reduce freezing risk. Locate your main shutoff in advance so you can turn the water off safely if a pipe bursts. Have a plan for medical devices and fixed heating.
The CDC says to never run a generator inside a home or garage. Keep it more than 20 feet from windows, doors, and vents. The CDC also says to keep refrigerator and freezer doors closed during an outage.
Medical equipment and fixed heating need their own plans. Ask your doctor or equipment supplier what backup you need.
Recent storms are useful guides. Look back at the polar vortex and Winter Storm Fern.
A Texas winter storm can cause local outages from ice. Severe events can also strain the bulk power grid and trigger an emergency like February 2021, when FERC says more than 4.5 million Texans lost power. Follow NWS forecasts. Sign up for ERCOT TXANS if it covers your area, or use alerts from your own utility and grid operator. Check your utility's outage map. Those three steps tell you what is coming and what is happening.
If you want a backup plan, start small. An EcoFlow DELTA 3 Classic can keep lights, phones, and a radio on during a short outage. An EcoFlow DELTA 3000 Gen4 can keep a compatible 120V fridge and essentials on until you recharge. EcoFlow DELTA 3000 Gen4 ships in early January 2027, so confirm delivery timing for your address. Check the specs, add up your loads, and pick the unit that fits the gap you expect.
1. Is a winter storm coming to Texas?
Check your local NWS office. As of Nov. 20, 2026, NWS Fort Worth expected below-normal temperatures and a mostly dry pattern for much of next week. Recheck often.
2. How do I get ERCOT alerts?
In the ERCOT service area, sign up for TXANS at ercot.com/txans by email or text. Alerts range from a Weather Watch and conservation notices to Energy Emergency Alert Levels 1 to 3.
3. Will ERCOT do rolling blackouts?
In ERCOT’s footprint, the operator can direct controlled outages during Energy Emergency Alert Level 3. Local damage can cause an outage without an ERCOT emergency. Check your utility for service at your address and your grid operator for regional alerts.
4. How many people lost power in the 2021 freeze?
FERC says more than 4.5 million Texans lost power in February 2021, some for as long as four days. ERCOT ordered 20,000 MW of firm load shed.
5. Who do I call about a local outage?
Call your wires company, co-op, or city utility, such as Oncor, CenterPoint, AEP Texas, or TNMP. Call 911 for downed power lines and stay back from them.
Power Outages
