Rime Ice: What It Is, How It Forms, and Can It Cause Power Outages?
Some winter mornings leave trees and fences covered with white ice that looks more like feathers than a frozen coating. The same ice may collect on road signs, communication towers, and power lines, usually on the side facing the wind. This is rime ice, a product of supercooled fog or low clouds meeting surfaces that are already below freezing.
Light deposits may disappear once the weather changes. A prolonged event can create thick, stubborn growth, especially across exposed ridges and mountain passes. When enough hard rime gathers on utility equipment or tree limbs, the added weight and wind resistance can contribute to power outages. Understanding what rime is—and how it differs from frost or freezing rain—makes it easier to judge the risk and prepare for an interruption in electrical service.
What Is Rime Ice?
Rime ice forms when tiny, supercooled water droplets strike a cold object and freeze almost immediately. Because the droplets solidify before spreading into a smooth film, they trap air between layers of ice. The result is generally white, opaque, and rough rather than clear and glassy.
Rime is commonly associated with freezing fog, low clouds, and exposed terrain. It can form on vegetation and buildings at ground level, but it is especially noticeable on mountain summits, towers, antennas, and other objects that remain in clouds for long periods.
What Does Rime Ice Look Like?
Fresh rime is usually milky white or chalky, with a granular or feathery surface. A light coating may resemble packed snow. With continued exposure, it can grow into ridges, cones, or flag-like shapes rather than covering an object evenly.
The direction of that growth is one of its most recognizable features. Moving fog carries droplets toward the windward side of a branch, wire, or railing, so the deposit builds outward into the breeze. In exposed locations such as New Hampshire’s Mount Washington or windy Midwestern ridgelines, these formations are sometimes described as rime flags.
The white color comes from the small air pockets trapped as each droplet freezes. Glaze ice from freezing rain contains fewer of those pockets, which is why it tends to look smooth and transparent instead.
Types of Rime Ice
Rime does not always have the same texture or density. Meteorologists generally describe two forms, based on the conditions in which the droplets freeze:
  • Soft Rime: Formed in colder conditions with small supercooled droplets and relatively gentle airflow, soft rime has a light, feathery structure. Its open texture makes it relatively fragile, and a thin coating may brush away from a car mirror or porch railing with a gloved hand.
  • Hard Rime: Stronger winds and larger droplets, often at temperatures closer to freezing, create a more compact deposit. Hard rime is denser, heavier, and more firmly attached to surfaces such as towers, tree limbs, and utility wires.
The two forms are ends of a range rather than completely separate events. A change in wind, temperature, fog density, or droplet size can alter the character of the ice while it is still accumulating.
Rime Ice vs. Frost and Glaze Ice
Rime, hoarfrost, and glaze can all leave a white or icy landscape, but they do not form through the same process. Although rime frost is sometimes used informally, rime and hoarfrost refer to different formation processes. Their weight and potential effect on property also differ.
Feature
Rime Ice
Frost (Hoarfrost)
Glaze Ice (Freezing Rain)
How It Forms
Supercooled fog or cloud droplets freeze on contact in windy conditions.
Water vapor turns directly into ice crystals on cold surfaces during calm, clear nights.
Liquid raindrops freeze upon hitting sub-freezing ground and objects.
Appearance
Milky white, opaque, rough, and feathered into the wind.
Delicate, lacy, feathery white crystals evenly covering surfaces.
Smooth, clear, glossy, and glass-like coating.
Density & Weight
Light (soft rime) to moderately dense and heavy (hard rime).
Very light and fragile; easily melts or blows away.
Extremely heavy, dense, and hard to remove.
Grid & Property Risk
Moderate to high; adds wind drag and weight on elevated lines and trees.
Usually limited structural loading; it may still obscure surfaces and require removal.
Severe; notorious for snapping power lines and toppling mature trees.
Hoarfrost grows when water vapor changes directly into ice on a cold surface. It often appears during calm, clear weather and does not require suspended liquid droplets. Freezing rain arrives as liquid precipitation and turns to glaze after striking a surface below 32°F. Rime falls between those familiar examples: it begins with liquid fog or cloud droplets but produces a rough, opaque deposit because they freeze so rapidly.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
How Does Rime Ice Form?
Rime icing develops when below-freezing surfaces encounter supercooled liquid water. Fog or cloud supplies the moisture, and air movement repeatedly carries droplets against exposed objects. If those conditions continue, a barely visible coating can become a substantial mass of ice.
Fog and Clouds Contain Supercooled Water Droplets
Liquid cloud and fog droplets can remain unfrozen even when the surrounding air is colder than 32°F. In that state, the water is described as supercooled. It has not turned to ice, but contact with a suitable cold surface can trigger rapid freezing.
Freezing fog creates this setup near the ground. On higher terrain, a mountain summit or ridgeline may sit inside a cloud even while lower elevations have good visibility. Trees, towers, and signs in that cloud continuously encounter suspended water droplets and may develop rime long before nearby valleys do.
Wind Carries Droplets Toward Exposed Surfaces
Air movement determines where the droplets strike. As wind pushes fog across a landscape, exposed objects interrupt the flow and collect some of the suspended moisture. Thin features such as pine needles, wires, antenna elements, and fence strands can accumulate ice quickly because their leading edges meet the incoming droplets directly.
Sheltered sides collect less, so the coating may look lopsided. Even two branches on the same tree can develop very different deposits if one faces the wind and the other sits behind the trunk. Stronger, sustained airflow generally brings more droplets into contact with a surface and encourages the distinctive upwind growth.
Droplets Freeze on Contact and Build Up Over Time
When a supercooled droplet strikes an object below freezing, it solidifies before it can flow far across the surface. That quick change traps air and creates the cloudy, porous appearance associated with rime. The next droplets freeze onto the first layer, gradually extending the formation outward.
Duration matters as much as the initial coating. A short period of freezing fog may leave a delicate layer that disappears later in the day. Hours of continued wind and moisture can produce thick, hard rime on the same object. As the shape becomes larger and more irregular, it adds both weight and a broader profile for the wind to push against.
Can Rime Ice Cause Power Outages?
Rime ice can contribute to outages, although freezing rain is responsible for many of the most widespread and destructive ice events. The greatest rime-related risk occurs where hard deposits persist on elevated lines, exposed utility structures, or trees close to electrical equipment. Where winter outages recur, a home battery can form part of a broader plan for keeping selected essential loads available.
Power outages from winter storms may result from ice loading, wind acting on the enlarged surface, or a branch failing under the combined load. In some situations, several of those stresses occur at the same time.
Ice Accumulation Increases Stress on Power Lines
Hard rime adds weight to an overhead conductor. It also changes the line from a relatively narrow, smooth wire into a wider and rougher shape. That greater profile catches more wind, increasing the sideways force on the conductor and its supporting hardware.
The combined load can raise line tension, cause conductors to sag, and place additional stress on crossarms, poles, and attachment points. Uneven ice can also contribute to conductor movement in the wind. Utilities account for ice and wind loading when designing exposed infrastructure, but unusually persistent conditions can still damage equipment or produce faults.
Ice-Laden Tree Branches Can Fall on Power Lines
Trees often create a more immediate neighborhood hazard than the rime on a line itself. Conifers offer many needles and small branches for droplets to collect on, while bare hardwood limbs can develop thick deposits along their windward sides. The load may not be distributed evenly, which can pull a branch away from its usual balance point.
Cold wood is less flexible, and gusty weather adds movement to a limb that is already carrying ice. A branch that breaks across a distribution line can trip protective equipment, damage a pole, or pull down the service line to one home. The tree may remain standing, making the problem difficult to identify until crews inspect the area.
Ice Buildup Can Disrupt Power Distribution Equipment
Rime can collect on utility poles, transformers, switches, and the insulators that separate energized conductors from grounded structures. The rough accumulation may interfere with moving parts, reduce clearances, or create conditions in which conductors move too close together.
Electrical problems become more likely when an ice-covered insulator is wet or contaminated as temperatures approach freezing. Under the wrong conditions, current can travel across the surface and produce a flashover or short circuit. Protective devices may then isolate the affected section of the system, leaving a smaller area without power until the equipment is inspected and service is restored.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
How Can You Prepare for Power Outages During Icy Winter Weather?
Rime is often localized, so conditions at a nearby airport or city center may not describe what is happening on an exposed hill or wooded road. When freezing fog, low clouds, and wind appear together in the forecast, prepare for the same basic problems associated with other winter outages: loss of heat controls, lighting, refrigeration, and communication.
Complete outdoor tasks while surfaces are still safe. Once ice has formed on steps, branches, and utility lines, the better choice is usually to stay clear and wait for conditions to improve. A portable power station may support compatible communication, lighting, or refrigeration loads when its output and usable capacity match the household plan.
Monitor Winter Weather Alerts and Outage Updates
Keep weather notifications enabled and follow the forecast for your immediate area. Temperature alone does not describe the rime risk; fog, cloud level, wind direction, and duration also matter. Mountain communities and elevated rural properties may see icing even when a broader regional forecast emphasizes only fog or cold.
Save the electric utility’s outage information before a storm rather than searching for it after the lights go out. If service fails, report the address and check restoration updates periodically. Stay away from any downed wire, even if it is coated with ice and does not appear to be energized.
Prepare an Emergency Kit for Winter Power Outages
Use a winter storm emergency kit to keep essential supplies together in a place that remains easy to reach in the dark. A practical kit includes:
  • Lighting: High-lumen LED flashlights, headlamps, and spare batteries instead of relying on open-flame candles.
  • Warmth: Wool blankets, thermal base layers, insulated socks, and hand warmers.
  • Food & Water: At least three days of non-perishable food, a manual can opener, and one gallon of drinking water per person per day.
  • Connectivity: Fully charged phone power banks and a battery-powered or hand-crank NOAA weather radio.
Add household-specific items such as prescription medicine, infant supplies, or pet food. Test flashlights and radios before winter, since equipment left in a drawer may have weak or damaged batteries when it is finally needed.
Choose Backup Power Based on Heating Needs
Backup power should be selected based on the equipment that must remain available and the likely duration of the outage. Lighting, phone charging, and low-draw warming devices require far less energy than a portable electric heater. Decide which loads take priority before connecting several appliances at once.
  • Short Outages (A Few Hours): A three- or four-hour outage can still leave a room uncomfortable when outdoor temperatures are below freezing. For an electric blanket or heated throw, as well as phone charging and a few lights, the EcoFlow DELTA 3 Max Plus Portable Power Station offers 2,048Wh of capacity. It provides quiet indoor electrical power for low-draw heating gear and other listed essentials while utility service is unavailable.
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
  • Overnight or Multi-Day Outages: A longer interruption places greater demands on stored energy, particularly when a household plans to operate a portable electric space heater, a refrigerator, a Wi-Fi router, and household lighting. The EcoFlow DELTA Pro Ultra Whole-Home Backup Power scales up to 90kWh of storage capacity, providing expandable reserves for high-wattage electric heating equipment as well as critical kitchen and communication appliances until grid power returns.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home even with a central AC 3. 6kWh-90kWh capacity, whole house backup for weeks with comfort
Heating equipment can consume stored energy quickly, so the devices with the highest wattage should be considered first when deciding what to run. A backup system is most useful when everyone in the household understands which appliances have priority.
Prevent Carbon Monoxide Risks
An outage during cold weather can make unsafe heating methods seem tempting. Never operate a gas generator in a garage, basement, sunroom, or any other enclosed or partially enclosed area. Place it outdoors, at least 20 feet from windows and vents. An open garage door does not make generator operation inside the garage safe.
Outdoor camp stoves, charcoal grills, and gas ovens should not be used to heat a home. They can release carbon monoxide, a gas that cannot be detected by smell or sight. Install and test battery-operated carbon monoxide detectors on every level of the house before winter weather arrives.
Rime ice forms when supercooled fog or cloud droplets freeze rapidly on cold, exposed surfaces. Its white, rough appearance distinguishes it from the clear glaze left by freezing rain and the delicate crystals of hoarfrost. Soft rime is often fragile, but persistent hard rime can increase the weight and wind resistance of power lines, utility equipment, and tree limbs.
When freezing fog and wind are expected, monitor local conditions and prepare for the possibility of a winter outage. Keep food, water, warm clothing, lighting, and communication equipment within reach. A backup power source chosen for the household’s essential loads can help keep necessary devices operating until electrical service is restored.
Where Is Rime Ice Most Commonly Found?
Rime ice is most commonly found in elevated mountain regions, exposed coastal ridges, and cold, fog-prone valleys where sub-freezing temperatures overlap with persistent wind and moisture. In the United States, hotspots include the White Mountains of New Hampshire, the Cascades and Rockies, the upper Great Plains, and parts of the Appalachian ridge.
How Long Does Rime Ice Last?
Rime ice may last from a few hours to several days, depending on air temperature, wind, sunlight, and whether supercooled fog persists. In shaded high-altitude locations or prolonged cold, hard rime can remain on branches and towers until temperatures rise or sunlight and wind help break it down.
Can Rime Ice Affect Solar Panels?
Yes. Rime ice can block sunlight from reaching solar cells and sharply reduce a solar array’s output while the modules remain covered. The actual reduction depends on how much of the array is coated, the deposit’s thickness, available sunlight, and system design. Output can recover as the buildup sheds or melts; do not climb onto an icy roof to remove it.
What Happens to Rime Ice When Temperatures Rise?
When temperatures climb above 32°F (0°C) or bright winter sun heats the surfaces underneath, rime ice softens, breaks loose in chunks, and melts away. During rapid warm-ups, large pieces of hard rime falling from tall trees, rooflines, and utility towers can create overhead hazards for parked cars and pedestrians below.
Power Outages
