How Do You Know If Your Pipes Are Frozen? Signs, Safe Thawing, and Prevention
How do you know if your pipes are frozen? The first clue is usually a faucet that gives a trickle or nothing at all on a cold morning. Frost on exposed pipes, a bulging section, or odd noises can point to the spot. The biggest worry is a pipe that has already split and will leak once it thaws. This guide covers the signs to check, how to tell a frozen pipe from a burst one, NWS-recommended ways to thaw safely without open flame, and how keeping your heating running during outages helps prevent a repeat.
Check the faucets first. Then look at pipes in cold spots: crawl spaces, exterior walls, garages, and under sinks. Frost or bulges narrow it down.
According to the National Weather Service (NWS), after a stretch of freezing temperatures, you should check your plumbing right away because your pipes may be frozen. Catching a blockage early saves you from major water damage.
Sign | What it suggests |
No water or a trickle at one faucet | Possible frozen branch or a fixture problem; check nearby taps and the local shutoff |
No water anywhere | Possible main supply, shutoff, or utility issue; check for a service outage |
Frost or bulge on a visible pipe | Possible location of freezing or pipe damage |
Water on floors, walls, or ceilings | Possible burst; act now |
Faucet Flow and Temperature Tests
Start at the sink and turn the tap on slowly. A trickle or no flow during a freeze can indicate ice, but check other fixtures, your shutoff valves, and your water provider’s outage notices first.
Next, compare the hot and cold lines at the exact same faucet. The comparison only narrows down where the problem may be.
Cold water works, hot water stops: Check other hot taps. The problem could be with the affected fixture, a hot-water valve, the water heater, or a cold-exposed hot-water branch.
Hot water works, cold water stops: Check whether other cold taps are affected. The fixture, a local valve, or a cold-water branch may be involved.
Neither hot nor cold works: At one fixture, check for a fixture or supply problem. If several fixtures are affected, look for a shared supply issue and check whether your utility has an outage.
Walk through the rest of the house and test other sinks, tubs, and toilets. If one room is affected, start there. If every tap is dry, contact your water provider to check service before assuming the main or meter is frozen. If you find a leak, follow the burst-pipe steps below.
Visual Clues in Cold Spots
Grab a flashlight and inspect the areas of your home that lose heat the fastest. Unheated spaces and exterior walls are the usual culprits during a deep freeze.
Check these high-risk spots first:
Under kitchen and bathroom sinks: Open the cabinet doors, especially on sinks built against outside walls.
Basements and crawl spaces: Look up along the floor joists where copper or PEX lines run near foundation vents.
Garages and utility rooms: Inspect any exposed plumbing near garage doors or uninsulated exterior walls.
Outdoor hose bibs: Check the interior shutoff valves that feed your exterior spigots.
Look closely at the pipe surface for a layer of white frost or heavy condensation. You should also run your hand along the pipe to feel for any unusual swelling or bulges. Water expands as it freezes, so a swollen pipe means the ice is pushing hard against the metal or plastic walls.
Flow and Drain Clues
Check for changes in flow, and keep drain problems separate from the water supply.
Turn on an affected tap. If flow is weak, compare it with nearby hot and cold taps. Unusual sounds alone do not identify an ice blockage.
A sewer odor at the drain may point to a dry or damaged P-trap. The P-trap is part of the drainage system, so check the odor separately from any suspected cold- or hot-water supply blockage.
Stopping a freeze before it starts is always easier than dealing with the aftermath. Start with frozen pipe prevention for winter before the next cold snap hits your area.
Keeping the house heated is the best defense, including during an outage.
Keeping Heat On During Outages to Prevent a Refreeze
Most furnaces and boilers need electricity to run. If the power goes out in a cold snap, the house cools and pipes can freeze again. Backing up heating circuits helps.
Why Heating Systems Stop in a Power Outage
Fuel-fired systems vary. A furnace with electronic controls, ignition, or a blower needs electricity for those parts. Some direct-vent wall furnaces operate without external power. Check the exact model before planning backup.
Hot water boilers face the exact same issue. Without power, the circulator pumps stop moving heated water through your baseboards or radiators. Once the heat shuts off in sub-freezing weather, indoor temperatures drop fast, putting vulnerable pipes right back in the danger zone.
Planning Backup Power for Heating Circuits
If you want to keep your heating system running during a winter blackout, you have to plan ahead. Pipe diagnosis and plumbing repairs are completely separate tasks from backup power setup. Backup power is strictly meant to run normal, undamaged heating equipment.
Before an outage hits, have a licensed electrician evaluate your electrical panel and heating setup. They will check the system voltage, measure actual heating power draw, and calculate expected runtime. They can then wire your furnace controls, boiler controls, or circulator circuits into a dedicated backup panel.
EcoFlow TITAN 5000 is a 5kWh home battery that backs up selected circuits through a Smart Home Panel 10 installed by a licensed electrician. Powering compatible heating controls can reduce refreezing risk while the battery lasts, but exposed lines, exterior walls, and unheated rooms can still freeze. Monitor temperatures and insulate vulnerable pipes.
Furnace and boiler controls are modest loads, so the base 5kWh covers many hours of cycling. An electrician confirms the circuit and startup.
Estimate How Long Heating Backup Could Last
The battery capacity alone doesn't determine runtime. Your heating equipment's actual electricity consumption matters just as much.
For a basic estimate, use this formula:
Runtime (hours) = Usable battery capacity (Wh) ÷ Average load (W)
For illustration, consider a 5kWh battery with an estimated 4,265Wh usable capacity. This assumes 85% usable energy after conversion and system losses.
The following examples use placeholder loads, not measured equipment specifications.
Load | Watts used | EcoFlow TITAN 5000 (4,265Wh usable est.) |
Gas furnace cycling | About 250W | About 17 hours |
Boiler controls + circulator | About 150W | About 28 hours |
These figures are estimates, not guaranteed operating times. Actual runtime depends on equipment cycling, startup demand, battery condition, temperature, and other connected loads.
These are examples based on assumed average loads. Use a measured or duty-cycle-adjusted average for runtime. Have an electrician verify equipment ratings, startup requirements, and circuit compatibility separately.
Heating belongs on your list of essential circuits for backup so your home stays warm when the grid goes down.
Next, what to do if a pipe has burst.
Frozen or Burst? What to Do First
A frozen pipe and a burst pipe aren't the same problem. A frozen pipe may have a temporary blockage. A burst pipe has a crack or opening that allows water to escape.
If you notice water leaking from a pipe, don't wait to investigate. Take action immediately to limit water damage.
Warning Signs of a Burst Pipe
Watch for these common burst pipe signs:
Water pooling beneath sinks or around plumbing fixtures.
Wet patches appearing on walls or ceilings.
Sudden drops in water pressure.
Water stains or bubbling paint on drywall.
Unusual dripping sounds behind walls.
Visible cracks, splits, or leaking joints.
Unexpected increases in your water bill.
Sometimes, a burst pipe isn't immediately visible. Water can travel through wall cavities and appear far from the damaged section.
What to Do If You Suspect a Burst Pipe
Follow these steps if you find a leak or suspect a pipe has cracked.
Shut off the main water supply. Find your home's main shutoff valve and close it. Follow local emergency guidance if you can't reach it safely.
Open nearby faucets. This can help release remaining pressure and drain water from the plumbing.
Protect your belongings. Move furniture, electronics, and valuables away from leaking water when safe.
Stay away from wet electrical equipment. Never touch wet outlets, switches, wiring, or electrical panels.
Call a licensed plumber. Have the damaged pipe inspected and repaired before restoring normal water service.
If water reaches an electrical panel or nearby outlets, don't approach or touch them. Contact your utility or a qualified electrician for help.
Never assume that shutting off the water makes a wet electrical area safe.
Prepare Before a Freeze Warning
Monitoring local weather alerts gives you a head start before temperatures plunge. Use NWS alerts for getting ready for freeze warnings so you can insulate vulnerable lines and prepare your home ahead of time.
Before temperatures drop:
Check exposed pipes for existing damage.
Insulate vulnerable plumbing.
Disconnect outdoor hoses.
Confirm everyone knows where the main water shutoff is.
Check your heating system.
Charge your home backup battery, if available.
A little preparation can make a significant difference during a prolonged cold spell.
How to Thaw Frozen Pipes Safely
Open the faucet first. Warm the pipe slowly from the faucet end. Never use a flame.
If the pipe has not split or leaked, you can carefully warm the frozen section yourself. Always keep safety front and center during this process.
Step-by-Step Safe Thawing Guide
Follow these NWS-recommended steps to melt the ice blockage without damaging your plumbing:
Keep the faucet open: Leave both the hot and cold handles open on the affected tap. As you warm the pipes, water will start to drip and eventually flow, which helps melt the remaining ice faster.
Start near the faucet: Apply heat starting at the section of pipe closest to the open tap, then work your way back toward the frozen blockage. Keep the tap open so melting water has a path out. If you suspect that a pipe has split, stop thawing and shut off the water if you can reach the valve safely.
Use gentle heat: Follow NWS thawing guidance. Use an electric heating pad, hair dryer, or portable heater only if the floor, equipment, and outlet are dry and safe. Warm towels are a non-electric option. Stop if you find a leak, standing water, or wet electrical equipment. Follow the burst-pipe steps and call a plumber.
Follow space heater safety rules: According to the U.S. Consumer Product Safety Commission (CPSC), always keep portable space heaters at least three feet away from anything that can burn, and plug them directly into a wall outlet. Never use an extension cord or power strip.
Continue until full pressure returns: Keep applying gentle heat until normal water flow is restored. If you cannot reach the frozen spot, or if the water does not come back, call a licensed plumber.
What Never to Do When Thawing Pipes
Never try to rush the thawing process with high heat. Using the wrong tool can melt plastic pipes, damage solder joints, or start a house fire.
Never use an open flame: Do not use a blowtorch, propane heater, kerosene heater, or charcoal stove anywhere near your pipes or walls.
Do not pour boiling water directly on cold pipes: Extreme temperature swings can cause rigid pipes to crack from thermal shock.
Do not leave heating devices unattended: Stay in the room the entire time you are running a hair dryer or space heater so you can spot a leak the second the ice melts.
Winter storms often knock out power right when temperatures hit rock bottom. Fold pipe checks into a winter storm outage plan so your family knows how to protect your plumbing when the lights go out.
A faucet that produces a trickle or no water during freezing weather is a common sign of frozen pipes. Frost and bulging sections can help identify the affected area. But water on floors, walls, or ceilings may indicate a burst pipe. Shut off your main water supply if you suspect a burst. Keep away from wet electrical equipment and call a plumber. For frozen pipes without visible damage, use gentle heat as the NWS recommends. Never use an open flame.
Preparing your heating system before winter can also help reduce refreezing risks. EcoFlow TITAN 5000 offers 5kWh of battery capacity and can back up selected heating circuits through a professionally installed Smart Home Panel 10. Have an electrician verify your equipment's startup requirements and expected runtime before relying on backup power.
A trickle or no water at a faucet in cold weather is the most common sign, often paired with frost or bulging on exposed pipes. Compare flow at other fixtures, check valves and utility notices, and look for leaks.
How do I find the frozen spot?
Start by checking exposed pipes in garages, crawl spaces, basements, and under sinks. Pay particular attention to plumbing along exterior walls. Look for frost, ice buildup, or visible swelling. If the frozen section is inaccessible, contact a plumber.
Can frozen pipes thaw on their own?
Yes, frozen pipes can sometimes thaw as indoor temperatures rise. However, waiting isn't always the safest approach. Ice expansion can damage plumbing, and cracks may leak once the ice melts. Use gentle heat or contact a plumber.
What should I do if a pipe bursts?
Shut off the main water valve immediately, open faucets to drain the lines, and call a plumber. If water reaches electrical outlets or your breaker panel, stay back and contact an electrician or your utility.
How do I keep pipes from freezing in an outage?
Keep heat running with backup power wired to your furnace or boiler circuits, and insulate exposed pipes in unheated spaces. Letting faucets drip slightly during extreme cold also helps keep water moving.
