Best Way to Heat a Garage: 7 Effective Heating Options and How to Choose
A cold garage can turn a simple oil change into a chore and make woodworking or a morning workout much less inviting. The best way to heat a garage depends on how you use the space: warming one workbench occasionally is a different job from heating a busy workshop, home gym, or parking area through the winter. This guide explains how to choose among seven practical options, use your heater safely, and improve efficiency without driving up energy bills.
What Are the 7 Best Ways to Heat a Garage?
The choices range from a portable heater to a gas unit mounted permanently on the ceiling. The best way to heat a garage in winter depends on heat output, upfront cost, installation work, garage size, and how often you use the space.
Portable Electric Space Heaters
For an occasional project or a single workbench, a portable ceramic or fan-forced heater is an affordable place to start. Most models plug into a standard 120V outlet and provide 1,500 watts (about 5,120 BTUs) of heat. That works well for a small area, but not for an entire uninsulated two-car garage. Choose a model with tip-over and overheat protection, and plug it straight into a wall outlet rather than an extension cord.
Electric Infrared Heaters for Targeted Heating
Instead of warming the air first, an infrared heater delivers radiant heat directly to people and nearby surfaces. That difference matters in a drafty garage or one where the main door opens often: moving air has less effect on the warmth you feel. Wall- and ceiling-mounted units run quietly and produce no combustion fumes. You can choose a 120V plug-in model or a 240V hardwired version.
Hardwired Electric Forced-Air Heaters
A ceiling-mounted 240V forced-air heater is a step up from a plug-in unit for a larger two- or three-car garage. Typical ratings run from 5,000 to 10,000 watts (17,000–34,000 BTUs). A fan pushes air across the heating coils and circulates warmth through the space. When selecting an electric heater for a garage, confirm its voltage, circuit requirements, and required clearances. The tradeoff is the installation: you need a dedicated circuit and proper wiring, usually handled by a licensed electrician. Once that work is done, the heater requires relatively little maintenance.
Natural Gas Garage Unit Heaters
Already have natural gas service? A ceiling-mounted gas heater can bring a large garage up to temperature quickly and economically. Models rated from 30,000 to 75,000+ BTUs can quickly replace the heat lost when the garage door opens, and in many U.S. regions they cost less to operate than electric resistance heaters. Venting to the outdoors is essential. Where sawdust, paint fumes, or fuel vapors may be present, a sealed-combustion model is preferable.
Propane Garage Heaters
Where natural gas is unavailable, propane heaters can run off an outdoor storage tank or a portable cylinder. A permanently vented unit suits regular winter use, while a portable radiant model is handy for short jobs. When using one, follow the manufacturer’s directions, ensure adequate ventilation, maintain proper clearances, and take precautions against carbon monoxide exposure.
Wood-Burning Stoves
If you have a detached workshop and access to affordable firewood, a wood-burning stove can supply strong radiant heat without grid electricity. Installation, however, must meet applicable building codes, equipment listings, clearance rules, and insurance requirements. Rules for solid-fuel appliances in garages vary by adopted code and jurisdiction, and gasoline or solvent vapors create serious fire and explosion hazards. Check with the local building department and insurer before installing a stove, even in a detached workshop.
Ductless Mini-Split Heat Pumps
A ductless mini-split moves heat rather than generating it directly. According to ENERGY STAR, an air-source heat pump can deliver up to three times more heat energy than the electricity it consumes. Actual performance varies by model and outdoor temperature. Cold-climate models can operate below 0°F (-18°C), although output and efficiency vary by model and temperature. The higher upfront cost is the main drawback. A mini-split makes the most sense for an insulated garage used daily as a year-round workshop, gym, or office.
Heating Option
Typical Output
Upfront Cost
Installation Effort
Best For
Portable Electric
~5,120 BTU (1,500W)
$30–$120
None
Small areas, occasional use
Electric Infrared
5,000–17,000 BTU
$80–$400
Low–moderate
Drafty garages, workbenches
Hardwired Electric
17,000–34,000 BTU
$200–$600 + wiring
Moderate
Insulated two-car garages
Natural Gas
30,000–75,000+ BTU
$500–$1,200 + venting
High
Frequent winter use
Propane
9,000–60,000+ BTU
$100–$1,000
Low–high
Garages without natural gas
Wood Stove
25,000–60,000+ BTU
$800–$2,500+
High
Suitable detached workshops
Ductless Mini-Split
9,000–24,000+ BTU
$1,500–$4,000+
High
Year-round heating and cooling
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
How Do You Choose the Right Garage Heating System?
Before comparing heater prices, decide how to heat a garage based on the space itself. Its size and insulation determine how much heat you need, while local energy prices shape what that heat will cost through the winter. If outage operation matters, compare the heater’s running demand and expected runtime with the continuous output and usable capacity of a power station.
Calculate Your Garage's Heating Requirements
Start with two measurements: floor area and ceiling height. As a rough guide, garages in North American climates may require 20–40 BTUs per square foot, depending on insulation and outdoor temperatures:
  • One-car garage (240–300 sq. ft.): 5,000–12,000 BTUs
  • Two-car garage (400–576 sq. ft.): 15,000–25,000 BTUs
  • Three-car garage or workshop (650–900+ sq. ft.): 30,000–45,000+ BTUs
A garage with a 10- or 12-foot ceiling can require more heating capacity than one with a standard 8-foot ceiling. For a permanent installation, a professional heat-loss calculation is more reliable than a rough percentage estimate.
Evaluate Your Garage's Insulation
Before paying for a more powerful heater, check the walls, ceiling, and garage door. Uninsulated exterior walls and a thin metal door can let so much heat escape that even a powerful heater may struggle to keep the garage comfortable through a Minnesota or New York winter. Adding insulation first reduces the amount of heat the garage needs. For a drafty garage used only occasionally, an infrared heater offers a practical alternative.
Compare Fuel Availability and Operating Costs
Take a 5,000W electric resistance heater running at full power. At the August 2026 U.S. residential average of $0.1816/kWh, it costs about $0.91 per hour to operate. The cheapest way to heat a garage depends on local electricity and fuel prices, installation costs, insulation, and runtime. Compare electric garage heater costs with the full installed and operating cost of each alternative rather than relying on fuel price alone.
How Can You Heat a Garage Safely?
Garages often hold gasoline, paint, sawdust, and other combustible materials. That makes heater placement and ventilation especially important. Electrical capacity and any portable power station used during a power outage deserve the same attention; confirm the heater’s continuous demand and expected runtime before connecting it.
Ensure Proper Ventilation and Install CO Detectors
Anything that burns fuel produces combustion gases, including potentially dangerous carbon monoxide. Permanent gas and wood heaters must vent outdoors according to local codes. Never operate an unvented kerosene or construction-style propane heater inside a closed residential garage. Install carbon monoxide detectors where required, follow the manufacturer’s placement instructions, and keep smoke alarms properly maintained.
Choose Safe Heating Alternatives During Power Outages
When a winter storm knocks out power, standard electric garage heaters stop working. A portable fuel-burning heater may look like a convenient substitute, but using the wrong heater in an enclosed garage poses serious carbon monoxide and fire risks.
For a short outage, low-wattage personal heating accessories may require far less stored energy than a space heater. The EcoFlow DELTA 3 Max Portable Power Station (2048Wh) can support compatible heated seat cushions or desk mats when their combined demand remains within the unit’s output limits. Actual runtime depends on the connected load, battery state, temperature, and conversion losses.
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
During a longer outage, you may need more stored energy, particularly if lights and heating equipment run together. The EcoFlow DELTA 3800 Gen4 Portable Power Station has 3,763Wh of capacity and 3,600W of output for compatible loads. Electric resistance heating consumes substantial energy, so confirm the heater’s rated wattage and allow for conversion losses and other connected devices when estimating runtime.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output.
Follow Electrical and Installation Safety Requirements
Electric heaters put a sustained load on household circuits. The safety check starts where you plug in and extends to the space around the unit:
  • Avoid extension cords: Plug a portable 1,500W heater directly into a suitable wall outlet. Do not use a power strip or extension cord.
  • Check circuit capacity: A 1,500W heater draws about 12.5A at 120V and places a heavy sustained load on a 15A branch circuit. Follow the heater’s listing and instructions, plug it directly into a suitable wall outlet, and avoid operating power tools, compressors, or other high-draw equipment on the same circuit.
  • Maintain safe clearances: Keep cardboard, rags, wood scraps, and other combustibles at least three feet from a portable heater, or farther away if the manufacturer requires it.
How Can You Heat a Garage More Efficiently?
Heat loss and warmth trapped near the ceiling can both undercut a heater’s performance. Insulate the door and seal any leaks first. Then use a fan to bring that warmth back down so the garage feels more comfortable without using as much energy.
Insulate the Garage Walls, Ceiling, and Door
A thin metal garage door is often a major source of heat loss. A compatible rigid foam or reflective insulation kit can improve the door’s thermal performance. If the ceiling joists are exposed, fiberglass insulation rated R-30 or higher may help reduce heat loss into an unheated attic, but the right rating depends on local climate requirements. Whatever you add must not interfere with garage door operation or required fire protection.
Seal Air Leaks Around Windows and Doors
Check for drafts around the overhead garage door, side entrance, windows, and utility openings. If the bottom seal or perimeter weatherstripping is worn, replacing it will help keep cold air out. Smaller gaps around window frames and wall penetrations call for exterior-grade silicone or polyurethane caulk.
Use Ceiling Fans to Circulate Warm Air
Warm air naturally collects near the ceiling, especially in a garage with high rafters. A ceiling fan can bring it back down. Use the manufacturer’s winter setting or the low-speed direction that gently moves warm air downward without creating an uncomfortable draft; rotation direction varies by fan design. This works particularly well with forced-air heating systems.
Occasional projects are the simplest case: a portable electric or infrared heater is a practical fit. A larger garage used regularly needs more warmth, so a hardwired electric unit or vented gas heater is often the better option. If you need efficient heating and cooling throughout the year, consider a ductless mini-split. With any of these systems, better insulation and fewer air leaks help keep the garage warm and winter energy costs down.
Should You Keep Your Garage Heated All Winter?
Most garages do not need continuous heating unless they contain temperature-sensitive materials, vulnerable plumbing, or are used daily. Heat the space when needed, or use a suitable thermostat-controlled system at a setting consistent with the plumbing layout, equipment manuals, local conditions, and insurer requirements.
How Long Does It Take to Heat a Garage?
Heating time varies with garage volume, outdoor temperature, insulation, air leakage, heater output, and the target temperature. A properly sized high-output system may warm the air relatively quickly, while an infrared heater can provide direct warmth before the surrounding air reaches the same temperature.
Can You Leave a Garage Heater Running When You're Not in the Garage?
Only permanently installed, thermostat-controlled heaters specifically approved for unattended operation should be left running, and only according to manufacturer instructions. Portable electric heaters, portable propane heaters, and wood-burning stoves should not be left unattended because of fire and combustion hazards.
Does a Heated Garage Help Protect Your Car in Winter?
Yes, moderate garage heating can make cold starts easier and help protect the battery from extreme temperatures. However, in regions where roads are heavily salted, keeping the garage excessively warm may accelerate corrosion on salt-covered vehicles. A modest temperature around 45°F–50°F, combined with proper drainage and ventilation, is generally more practical.
Home Solutions
