Cold Weather Advisory: How NWS Cold Alerts Work and How to Prepare
A cold weather advisory means your local National Weather Service office expects cold that can be hazardous, especially for older adults, kids, and anyone outside. In October 2024, it replaced the old Wind Chill Advisory, and it can be issued for cold temperatures with or without wind. Each office sets local thresholds. One Bay Area advisory covered 33–36°F; another region may use a different threshold. This guide explains the alert levels, how to read one, what to do, and how to keep your heating running if the power goes out.
What is a cold weather advisory?
A cold weather advisory is a National Weather Service (NWS) alert for cold weather that is dangerous but below warning level. It replaced the Wind Chill Advisory in 2024. The criteria vary by local office.
On October 1, 2024, the NWS changed its winter alert names. The Wind Chill Advisory became the Cold Weather Advisory. The Wind Chill Warning became the Extreme Cold Warning, and the Wind Chill Watch merged into the Extreme Cold Watch. NWS Amarillo notes that these products now rely on the temperature or the wind chill, with no wind threshold.
Alert
Meaning
Action
Hazardous cold expected
Dress in layers, check heaters, protect pets and pipes
Extreme Cold Watch
Dangerous cold possible
Prepare heat and supplies
Dangerous cold expected
Limit time outside, act now
Freeze Warning
Freezing temps for crops/plants
Protect plants and exposed pipes
Winter alerts come at different levels, so compare winter storm watches, warnings, and advisories to see where cold alerts fit.
Cold alerts matter most when the power fails and heat stops.
Keeping heat on if the power goes out
Most furnaces and boilers need electricity even when they burn gas, oil, or propane. Plan backup for the heating circuits before cold nights arrive. Also, know where you can get warm if heat fails.
Start with the alert itself. Your local NWS office decides what counts as a Cold Weather Advisory, an Extreme Cold Warning, or a road icing alert, so note the office’s thresholds and the issue time. An advisory signals hazardous cold, a warning signals dangerous cold, and road icing is a travel hazard rather than a heating one. Outage prep should center on the heating circuits that must run during the actual cold hours.
Before the cold arrives, check each part of your heating plan:
  • How the furnace or boiler starts after an outage
  • Whether aux heat is in use
  • How much fuel you have
  • The wiring plan
  • The ambient temperature the equipment allows
Make sure everyone in the home has warm clothing and a place to go.
EcoFlow TITAN 5000 is a 5kWh home battery that backs up selected circuits through a Smart Home Panel 10 installed by a licensed electrician. On cold nights, those circuits can be furnace blowers, controls, and circulator pumps that keep heat moving. Grid connection with the panel is "No Export", so it does not send power to the grid.
For an advisory overnight, the plan is simple: hours of cold × heating load. A licensed electrician confirms which circuits to back up, how the equipment starts, and whether aux heat, fuel, and wiring match the cold hours you expect.
EcoFlow TITAN 5000
Here are estimated runtimes, for two example heating loads. Real loads vary, so treat these as estimates.
Load (example)
Watts used
EcoFlow TITAN 5000 (4,265Wh usable est.)
Gas furnace cycling overnight (placeholder average)
about 250W
about 17 hours (estimate)
Boiler controls + circulator (placeholder)
about 150W
about 28 hours (estimate)
Estimate runtime by multiplying rated capacity in Wh by the assumed usable share (0.85 here), then dividing by measured or duty-cycle-adjusted average load in watts. Verify peak demand, auxiliary electric heat, and circuit compatibility separately with an electrician.
Forced-air gas furnaces with electronic controls or a blower need electricity for those parts. Some direct-vent wall furnaces need no external electrical supply, so check your exact unit.
Next, a real example of an advisory.
How to read a cold weather advisory: a Bay Area example
Each alert lists what, where, when, and impacts. Check the issue time and expiration. This example shows an advisory in a mild climate.
Example only, not a current alert. The NWS Bay Area advisory update at 6:06 AM PST on Thursday, November 19, 2026 listed these conditions:
  • What: Temperatures of 33–36°F.
  • Where: Interior North Bay, Eastern Santa Clara Hills, and interior Monterey and San Benito.
  • When: 1–8 AM PST Friday, November 20, and again 1–8 AM PST Saturday, November 21, for the areas listed above. The East Bay Interior Valleys and Hills were covered by the Saturday window only.
  • Impacts: NWS warns that “prolonged exposure will lead to hypothermia for people and animals.”
The issue time tells you how fresh the alert is, and the expiration tells you how long to stay careful. A gap between two windows, like the Friday and Saturday periods above, means the cold returns. Don’t assume the danger is over.
Because people reach for heaters and generators when temperatures dip, know the carbon monoxide dangers in winter before using any heater.
Finally, what to do during an advisory.
Cold weather means warmthCold weather means warmth
What to do during a cold weather advisory?
Dress in layers and limit time outdoors. Check approved indoor heaters and keep outdoor-only combustion equipment outside. Protect pets, plants, and pipes.
  • Check your heaters. NWS Bay Area advises making sure space heaters work properly before you need them.
  • Never use portable fuel-burning generators or outdoor grills indoors. Run a portable generator outside, at least 20 feet from doors, windows, and vents. Install, vent, and maintain fixed indoor fuel-burning heaters according to the manufacturer’s instructions.
  • Follow CPSC heater rules. Keep heaters three feet from anything that can burn, and plug electric space heaters directly into a wall outlet.
  • Refuel early. NWS winter prep includes refilling heating fuel before it runs out.
  • Find warmth. Check with local officials for warming centers if your home loses heat.
  • Protect animals. Make sure pets and livestock have food, unfrozen water, and warmth.
Long cold weather can freeze pipes, so pair the advisory with frozen pipe prevention steps.
A cold weather advisory is an NWS alert for hazardous cold. It replaced the Wind Chill Advisory in October 2024 and uses local thresholds. Read the issue time and area, dress in layers, check heaters, and protect pets and pipes.
If your heat depends on electricity, an EcoFlow TITAN 5000 can back up evaluated heating circuits such as the furnace blower, controls, and circulators during an outage. A licensed electrician installs the Smart Home Panel 10 and confirms what the system can carry. Pair that plan with local NWS alerts, warm clothing, and a place to go if heat fails, and you will be better prepared before the next cold night.
1. What does a cold weather advisory mean?
The National Weather Service expects hazardous cold. Take precautions, especially for older adults, young children, pets, and anyone outdoors, since prolonged exposure can lead to hypothermia.
2. Is a cold weather advisory the same as a wind chill advisory?
It replaced the wind chill advisory on October 1, 2024. The new alert covers cold temperatures or wind chill, and offices such as NWS Amarillo use no wind threshold.
3. What temperature triggers a cold weather advisory?
It varies by National Weather Service office. A Bay Area advisory covered temperatures of 33–36°F, while colder regions use lower thresholds, so check your local office’s criteria.
4. What is the difference between an advisory and a warning?
A warning means dangerous cold is expected and calls for immediate action. An advisory is less severe but still hazardous. Dress in layers, limit time outside, and check heating.
5. How do I keep heat on in an outage?
Back up heating circuits before cold nights. Most furnaces and boilers need electricity even with fuel, so have an electrician evaluate loads and plan a warm place to go.
Power Outages
