PG&E Electricity Cost per kWh by Tier: Rates and Pricing Explained
After a hot week in Fresno or a Bay Area cold snap, the total on your PG&E bill’s summary page rarely tells the whole story. Your energy charges come down to how much power you use and, on some plans, your baseline allowance or the time of day you use electricity. This guide explains how the tiers work, how to estimate your charges, and how to keep them in check.
What Are PG&E Electricity Rate Tiers?
Many residential customers use Time-of-Use plans, while eligible households may choose E-1 tiered pricing. In each billing cycle, E-1 charges a lower rate for the first block of electricity and a higher rate for any usage above it. If you are on E-1 and your bill jumps in a hot or cold month, checking how much fell into each tier can help explain the change. Understanding PG&E rates starts with identifying the plan shown on your bill.
How Tier 1 and Tier 2 Electricity Rates Work
Your monthly electricity use is split between two pricing brackets. The lower Tier 1 rate applies to the first block, up to your baseline allowance. Once you pass that allowance, only the additional kWh are billed at the higher Tier 2 rate for the rest of the cycle. When comparing PG&E rates, the key question is how much of your usage falls above that baseline.
What Is the PG&E Baseline Allowance?
Your Baseline Allowance is the amount of electricity available at the lower Tier 1 rate. Local weather and home heating needs vary across Northern and Central California, so the allowance does too.
  • Climate zone: A home in hot Bakersfield may need more summer cooling than one on the San Francisco coast, so hotter inland areas generally receive a higher summer allowance.
  • Season: PG&E sets separate allowances for summer (June through September) and winter (October through May).
  • Heating source: Homes with permanently installed electric space heating as their primary heat source qualify for all-electric baseline quantities. The applicable allowance depends on territory, season, and eligibility; it is not necessarily larger in every case.
How Tiered Pricing Differs From Time-of-Use Rates
With E-1, what matters is how much electricity you use over the billing period. On Time-of-Use plans such as E-TOU-C and E-TOU-D, the rate depends on the time of day, so running the dishwasher at 2 p.m. can cost less than running it during the evening peak. The best fit depends on both your monthly usage and when your home tends to use the most power.
Feature
Tiered Rate Plan (E-1)
Time-of-Use Plans (E-TOU-C / E-TOU-D)
Primary pricing driver
Total monthly kWh consumed
Time of day and day of the week
Peak-hour rates
No time-based penalty; the rate is the same at 10 a.m. or 7 p.m.
Higher during peak hours, typically 4 p.m.–9 p.m.
Baseline allowance
Sets the Tier 1 cutoff
Included as a baseline credit in E-TOU-C; not used in E-TOU-D
May suit
Lower-use households or those home during peak hours
Households that can shift laundry, EV charging or AC use to off-peak hours
A solar battery can store daytime solar generation for later use; on a TOU plan, that may reduce purchases during higher-priced hours, while E-1 has no time-based price difference.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Much Does PG&E Charge per kWh for Each Tier?
PG&E electricity rates depend on your tariff and whether you receive bundled service or generation from a Community Choice Aggregator (CCA). PG&E’s 2026 rollout of the flat Base Services Charge reduced per-kWh rates across residential plans, but Tier 2 remains more expensive than Tier 1.
PG&E Tier 1 Electricity Rates per kWh
Bundled residential customers on E-1 typically pay around $0.35 to $0.37 per kWh for Tier 1 electricity, which covers usage up to 100% of the baseline allowance. Before the 2026 fixed-charge adjustment, the rate for this bracket was roughly $0.40–$0.43/kWh. Adjusting your thermostat can help keep your usage in this lower-priced bracket.
PG&E Tier 2 Electricity Rates per kWh
Once you pass 100% of your baseline allowance, the additional electricity is billed at roughly $0.44 to $0.47 per kWh, down from $0.50–$0.54/kWh before the rate restructuring. That extra 9 to 10 cents per kWh adds up fast in July and August, when a few extra hours of afternoon AC can push a household deep into Tier 2.
How to Calculate Your PG&E Electricity Bill by Tier
Use two figures from your bill to see how much falls into each tier: your baseline allowance and your total electricity use. Apply the corresponding rates to estimate your energy charges before fees and credits.
Find Your Baseline Allowance and Monthly Electricity Usage
Grab a recent PG&E bill and open the “Details of Electric Charges” section. Near the top, look for your Baseline Territory (a letter such as P, R, S, or X), your daily baseline allowance in kWh, and the number of days in the billing cycle. Multiply the daily allowance by the number of days shown to find your Tier 1 threshold for that bill, then compare it with your total metered kWh.
Knowing how to calculate kWh usage can help you identify which appliances contribute most to that total.
Calculate Electricity Costs for Each Tier
Suppose a Stockton household in Territory S has a monthly baseline allowance of 350 kWh and uses 520 kWh in July. For the math, we’ll use $0.36/kWh for Tier 1 and $0.45/kWh for Tier 2.
  1. Tier 1 cost: 350 kWh × $0.36 = $126.00
  2. Tier 2 usage: 520 kWh − 350 kWh = 170 kWh
  3. Tier 2 cost: 170 kWh × $0.45 = $76.50
  4. Total volumetric energy charges: $126.00 + $76.50 = $202.50 (before adding your monthly Base Services Charge and local taxes)
Other Charges on Your PG&E Electricity Bill
Most of your bill comes from the electricity you use, but these charges and credits also affect what you owe:
  • Base Services Charge: For standard residential customers, the flat grid-infrastructure fee is approximately $24.15/month under California’s 2026 fixed-charge structure, and income-qualified households pay a lower fee. This charge replaces the former Minimum Delivery Charge and offsets the reduction in per-kWh rates.
  • California Climate Credit: This bill credit comes from California’s Cap-and-Trade program and returns a share of the proceeds from carbon pollution allowance auctions to eligible customers. In 2026, PG&E residential electric customers will receive the credit in August and September.
  • Taxes and Surcharges: Local utility users’ taxes, state energy commission surcharges, and California-mandated wildfire fund charges fall into this category.
How to Reduce Your PG&E Electricity Costs
To manage PG&E electric rates effectively, match the fix to what is pushing your bill up. On a Time-of-Use plan, that might mean running some appliances outside the most expensive hours.
Solar panels paired with a home battery can store daytime generation for evening use and reduce electricity purchased from the grid.
Shift Energy-Intensive Activities to More Cost-Effective Hours
On a Time-of-Use plan, shifting appliance use can lower your bill and reduce strain on the grid. If your plan charges its highest rates from 4 p.m. to 9 p.m., run electric clothes dryers, dishwashers, pool pumps, and other high-draw appliances outside those hours. Another classic California trick is to pre-cool your house to 72°F in the early afternoon, then raise the thermostat to 78°F at 4 p.m. so you can run the AC less during those expensive evening hours without sweating indoors.
Use Solar Panels to Reduce Electricity Purchased From the Grid
Each kilowatt-hour of rooftop solar you use directly at home is one less you need to buy from the grid. On a tiered plan, daytime solar can power your AC and home office, helping keep what you draw from the grid below your Tier 1 baseline threshold.
Those avoided grid purchases are the starting point for estimating how much solar panels save on an electricity bill. When solar production exceeds your daytime needs, storing the surplus can help reduce grid purchases after sunset as well.
Store Excess Solar Energy for Evening Household Use
A home battery stores the extra electricity your rooftop panels generate around midday so you can use it in the evening. Once solar output drops in the late afternoon, you can power lights, kitchen appliances, and electronics with stored energy instead of buying expensive power from PG&E. The modular EcoFlow TITAN 5000 and TITAN 5000 Plus each start at 5 kWh and can expand to 30 kWh, letting homeowners add capacity in stages as household energy needs grow.
  • For standard residential setups, the TITAN 5000 supports up to 4 kW of solar input and 7.2 kW of battery output, giving you plenty of capacity to bank extra daytime solar power and run high-draw household appliances after dark.
  • For homes with larger rooftop arrays, the TITAN 5000 Plus supports up to 8 kW of solar input and combines solar and battery power for a total output of up to 10 kW. That output helps your home handle heavy daytime demand.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $2,900/year, with ROI in 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, including upfront purchase, installation, and long-term use.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
Using stored solar power in the evening can help you manage your PG&E bill. Actual savings will vary depending on your solar generation, household load profile, battery configuration, and applicable utility rate plan.
Next time you open your PG&E statement, check where your Tier 1 baseline allowance ends and how much electricity was billed at the higher Tier 2 rate. Those numbers make it easier to choose a next move that fits your rate plan and daily routine, whether that means changing when you run high-draw appliances or pairing solar with a home battery to keep your grid usage in check.
How Does PG&E Determine Baseline Allowance?
PG&E uses your climate zone—known as your Baseline Territory—and whether you heat your home with electricity or gas to set your summer and winter allowances. These allowances are intended to cover roughly 50% to 60% of average residential electricity consumption in the local area.
Why Is My PG&E Bill So High?
A high bill usually means you used more electricity, ran more appliances during expensive hours, or both. On a tiered plan, summer air conditioning or winter electric heating can push you into Tier 2. On a Time-of-Use plan with a 4 p.m. to 9 p.m. peak window, running appliances during those hours can raise your costs. If the bill jumps even though the weather and your routine have been fairly steady, an aging refrigerator, a malfunctioning pool pump, or a faulty water heater element could be to blame.
What Is the Cheapest PG&E Rate Plan?
No single PG&E plan is the cheapest for everyone—the best fit depends on how much power you use and when you use it. In general, low-usage households that draw most of their electricity in the evening come out ahead on the E-1 Tiered Plan, while drivers with EVs, homeowners with solar panels, or anyone with a flexible schedule pay less on E-TOU-C, E-TOU-D, or EV2-A.
What Time Is PG&E Most Expensive?
On standard PG&E Time-of-Use plans, peak rates hit in the evening. On E-TOU-C and EV2-A, the most expensive hours run from 4 p.m. to 9 p.m. every day, including weekends and holidays. E-TOU-D has a shorter peak window, running only from 5 p.m. to 8 p.m. on non-holiday weekdays. If you’re on the E-1 tiered plan, there is no peak period—your rate for a given tier stays the same all day.
Did PG&E Cut Its Electricity Rates in 2026?
Yes, although the decrease was small. In early 2026, regulatory changes and California’s new flat Base Services Charge brought down per-kWh rates for PG&E’s bundled residential customers. Even with that shift, though, overall bills remain among the highest in the country. Because ongoing wildfire mitigation and grid upgrades keep driving new CPUC rate filings, improving your home’s efficiency and generating your own power are still much safer bets than waiting around for major rate cuts.
Save Bills
