Energy Cost Calculator: How to Estimate Your Electricity Costs
Your electric bill jumps in summer, and the air conditioner is the obvious suspect. Come winter, electric heat can play the same role. The bill doesn’t always make it clear which appliances drove the increase. An energy cost calculator fills in that missing detail by combining wattage, operating time, and your electricity rate to estimate what a device costs to run each month. Here’s how to run the numbers, compare appliances, and see where you can save.
How Can You Estimate Your Electricity Costs with an Energy Cost Calculator?
A few details are enough for a useful estimate. The appliance label or manual gives you the power rating, and your utility bill lists the rate. Factor in the daily runtime, and you have everything you need to understand how to calculate energy cost for that appliance.
What Information Do You Need to Use the Calculator?
Three figures go into the math:
Appliance Wattage (W): The appliance label, power adapter, or user manual should list the wattage. For simple resistive loads such as heaters or toasters, volts multiplied by amps gives real power: 120 V × 10 A = 1,200 W. For AC motors and electronic equipment, volts × amps gives apparent power unless power factor is included. Use the device’s listed input watts or a suitable power meter when available rather than assuming a fixed 15% to 30% adjustment. The electrical power formula depends on the load and the information shown on its label.
Daily Usage Hours: Figure out how many hours a day the appliance actually runs. Being plugged in isn’t the same as drawing full power: refrigerators, air conditioners, and space heaters cycle on and off.
Electricity Rate ($/kWh): Your utility bill lists the rate per kilowatt-hour. The U.S. residential average was $0.1816/kWh in August 2026, according to the U.S. Energy Information Administration, but actual rates vary by state, utility, season, plan, and bill components. Use the effective rate from your own bill for a household estimate.
How to Calculate Electricity Costs Using kWh
To understand how to calculate electrical energy cost, an energy cost calculator uses a three-step formula that you can also work through by hand:
Convert watts to kilowatts: A 1,500 W appliance draws 1.5 kW; for any other rating, divide the listed wattage by 1,000.
Find daily kilowatt-hours (kWh): Multiply that kW figure by the appliance’s actual daily runtime. This is the energy it uses in a day.
Multiply by your utility rate: Multiply the day’s kWh by the rate per kWh on your bill. That’s the daily cost; 30 times that amount gives a rough monthly estimate.
Daily Cost = (Wattage × Hours Used per Day ÷ 1,000) × Electricity Rate ($/kWh)
Take a 1,500-watt hair dryer for example: 15 minutes of use each morning (0.25 hours) adds up to 0.375 kWh per day. At $0.1816 per kWh, that’s about $0.07 a day—roughly $2.04 over 30 days.
The same watt-hour calculation can estimate stored-energy demand when comparing a power station, although usable capacity and conversion losses also affect runtime.
How Much Does It Cost to Run Common Household Appliances?
Power rating alone doesn’t tell you what an appliance costs to run. A space heater that’s on for a few hours can cost more than a refrigerator plugged in all day. To keep the comparisons consistent, all three tables below use the August 2026 U.S. residential average of $0.1816 per kWh; replace it with the effective rate from your own bill for a household-specific estimate.
Heating and Cooling Appliances
Space heating and air conditioning accounted for 52% of average U.S. household energy consumption in the 2020 Residential Energy Consumption Survey. Their share of electricity use and cost varies by home, climate, equipment, and fuel.
Appliance | Typical Wattage | Est. Daily Active Runtime | Daily Cost (@ $0.1816/kWh) | Monthly Cost (30 Days) |
Central Air Conditioner (3-Ton) | 3,500 W | 8 hours | $5.08 | $152.54 |
Portable Space Heater (High) | 1,500 W | 6 hours | $1.63 | $49.03 |
Window AC Unit (10,000 BTU) | 1,000 W | 8 hours | $1.45 | $43.58 |
Electric Water Heater | 4,500 W | 3 hours | $2.45 | $73.55 |
Ceiling Fan | 65 W | 12 hours | $0.14 | $4.25 |
Kitchen and Laundry Appliances
Kitchen and laundry appliances often pull a lot of power in short bursts. A refrigerator cycles on and off all day, while a clothes dryer or electric oven draws more power for a much shorter time.
Electric Clothes Dryer | 3,000 W | 1 hour | $0.54 | $16.34 |
Electric Oven / Range | 2,400 W | 1 hour | $0.44 | $13.08 |
Refrigerator (Modern ENERGY STAR) | 150 W (running) / ~50 W (avg.) | 8 hours active (24h plugged in) | $0.22 | $6.54 |
Dishwasher (with Heated Dry) | 1,800 W | 1 hour | $0.33 | $9.81 |
Microwave Oven | 1,100 W | 0.25 hours (15 min) | $0.05 | $1.50 |
Drip Coffee Maker | 900 W | 0.5 hours (30 min) | $0.08 | $2.45 |
Note: Monthly estimates are calculated from exact unrounded daily costs multiplied by 30 days.
Electronics and Everyday Devices
A home office setup or entertainment center may cost only pennies per hour to run, and phone chargers even less. Over a 30-day billing cycle, though, the cost of running always-on devices and high-end gaming rigs can add up.
Device | Typical Wattage | Est. Daily Active Runtime | Daily Cost (@ $0.1816/kWh) | Monthly Cost (30 Days) |
Gaming PC + Monitor | 450 W | 4 hours | $0.33 | $9.81 |
65-Inch LED/OLED TV | 120 W | 5 hours | $0.11 | $3.27 |
Wi-Fi Router & Modem | 20 W | 24 hours | $0.09 | $2.62 |
Laptop (Working from Home) | 60 W | 8 hours | $0.09 | $2.62 |
Smartphone Charger | 15 W | 2 hours | $0.005 | $0.16 |
What Factors Affect Your Household Energy Costs?
Appliance efficiency is only one factor in what you pay. To understand how to estimate power consumption, start with measured or listed wattage and actual runtime; then account for your local rate, daily habits, and the time of year.
Local Electricity Rates and Utility Plans
Rates vary across states for practical reasons: energy sources, grid costs, and state regulations all play a role. The utility plan matters too. Many U.S. utilities, particularly in California and Arizona, offer Time-of-Use (TOU) plans. These plans charge more during peak hours (often 4:00 PM to 9:00 PM) and less during off-peak periods.
Appliance Wattage and Daily Usage
Both wattage and runtime affect what you pay. A 1,200-watt toaster uses very little energy when it runs for five minutes. Leave a 400-watt dehumidifier running continuously, though, and it uses 9.6 kWh per day—about $52.30 over 30 days at $0.1816/kWh. Calculating power needs from actual runtime produces a more useful estimate than relying on nameplate wattage alone. Older or poorly maintained appliances may also operate for longer cycles.
Seasonal Changes in Energy Consumption
Extreme heat and cold push electricity bills up. During a heat wave, the air conditioner runs longer. In winter, you rely more on electric heat and lighting, and the water heater works harder because the incoming water is colder.
How Can You Reduce Your Household Energy Costs?
Once you know which appliances use the most electricity, you can stop guessing about where to cut back. Sometimes the answer is as simple as adjusting the thermostat or running an appliance later. Homes with solar panels may also use a solar battery to store some excess daytime production for later use, subject to system compatibility, losses, rates, and operating settings.
Improve Energy Efficiency and Adjust Usage Habits
You can make these changes today without buying new equipment:
Optimize thermostat schedules: Try 78°F in summer and 68°F in winter. While you’re asleep or away, set the temperature back 7°F to 10°F; that one habit can trim heating and cooling costs by up to 10% a year.
Eliminate phantom loads: Game consoles, soundbars, desktop monitors, and cable boxes still sip electricity in standby mode. Plug your entertainment and office equipment into smart power strips so you can shut it all off overnight.
Wash clothes in cold water: Nearly 90% of a washing machine’s energy goes toward heating water. Cold cycles clean everyday laundry just as effectively, and they’re easier on fabrics.
Maintain HVAC airflow: Replace dirty air filters every one to three months; a clean filter prevents unnecessary strain on the blower motor and improves heat transfer.
Shift Electricity Use to Lower-Cost Hours
With a Time-of-Use plan, timing can matter almost as much as total consumption. Schedule flexible loads such as dishwashing, laundry, or EV charging during the off-peak periods shown on your utility plan. Many modern appliances have delay-start timers, but use them only in accordance with the manufacturer’s safety instructions.
Store Excess Solar Energy for Later Use
For a home that already has rooftop solar panels, cutting usage isn’t the only way to lower the bill. You can also use more of what you generate. A home battery can store excess solar power produced during sunny midday hours. You can then use it at night or during the evening peak instead of paying higher grid rates.
If you want storage that can grow, the EcoFlow TITAN 5000 starts at 5 kWh and expands to 30 kWh, allowing capacity to keep pace with daily household demand and solar production. For homes that need to capture more daytime power from larger rooftop arrays, the EcoFlow TITAN 5000 Plus supports up to 8 kW of solar input. That makes it easier to store more of your own electricity for high-demand periods throughout the day and night.
Both systems support OASIS 3.0 and pair with the compatible 240 V Smart Home Panel 10. Solar output, the battery’s state of charge, and local utility rate schedules all feed into the systems’ intelligent energy management. When grid rates peak, stored solar automatically takes priority. That way, you buy less grid power at those prices and have more control over your monthly bill. The Smart Home Panel 10 must be installed by a licensed electrician in accordance with local electrical codes.
An energy cost calculator shows you where the money goes. Start with the wattage and hours, then apply your local electricity rate to get a cost estimate you can compare with your bill. From there, you can save money over time by cutting unnecessary use or shifting some tasks to off-peak hours. If you already have solar panels, the right battery storage helps you use more of what you generate instead of buying from the grid when rates are high. The next time a summer or winter bill jumps, you’ll have a way to figure out which appliances are behind it.
How Much Does It Cost to Run a 1000-Watt Heater per Hour?
Running a 1,000-watt heater at full power uses 1 kWh per hour. At the August 2026 U.S. residential average electricity price of $0.1816 per kWh, that costs about $0.18 per hour. Your actual hourly cost equals the effective per-kWh rate on your utility bill.
How Much Does It Cost to Run an Electric Heater 24 Hours a Day?
Running a 1,500-watt electric space heater continuously for 24 hours uses 36 kWh. At $0.1816 per kWh, that costs about $6.54 per day, or $196.13 over 30 days. Actual use may be lower when the thermostat cycles the heating element off, but the result depends on runtime, insulation, room size, heater setting, and outdoor temperature.
Why Is My Electric Bill Higher Than I Expected?
A sudden jump in your electric bill is most often caused by seasonal weather swings forcing your HVAC system to run longer, utility rate hikes, or a shift into a higher pricing tier. Hidden culprits also include failing refrigerator door gaskets, sediment buildup inside an electric water heater, a dehumidifier running continuously, or forgotten space heaters.
What Runs up Your Electric Bill the Most?
Heating and cooling are major household energy uses. EIA’s 2020 Residential Energy Consumption Survey estimates that space heating and air conditioning together accounted for about 52% of average household site energy consumption. That figure is an energy-use share, not necessarily an electricity-bill share: the largest contributor to a particular electric bill depends on the home’s heating fuel, climate, equipment, and usage patterns.
