Electric Fireplace Cost: Unit, Installation, Circuit, and Running Cost
Electric fireplace cost depends on more than the price on the box. You'll also need to account for the surround or mantel, installation, and possible electrical work. Once it's installed, your electricity bill depends on the heat setting and how long you run it. One example plug-in model draws 1,500 watts on its highest heat setting, while flame-only mode uses much less. This guide breaks down the upfront expenses, shows how to calculate running costs, and explains what to consider if you want to use the fireplace during a power outage.
What Does an Electric Fireplace Cost?
Start by pricing each part of the project separately. A freestanding unit may need little installation work, while a wall-mounted fireplace or built-in insert can involve framing, finishing, and electrical changes. The total depends on the model and the condition of the room where you plan to install it.
What Does an Electric Fireplace Cost?What Does an Electric Fireplace Cost?
Break down the upfront costs
Use this list when collecting estimates from retailers, installers, and electricians.
Cost item
What drives it
How to price
Unit
Size, insert vs wall-mount vs freestanding
Retailer
Surround or mantel
Material, custom vs stock
Retailer or carpenter
Installation
Wall recess, mounting, finishing
Installer quote
New circuit (if needed)
Panel space, wire run
Licensed electrician quote
The fireplace itself is only one part of the budget. A wall-mounted model may need secure mounting and access to a suitable outlet. A built-in electric fireplace insert may require a framed opening, trim, and finishing work. Custom stone or wood surrounds can add to the project, too. Ask for separate quotes for the unit, installation, and electrical work. That makes it easier to compare models and see whether a lower purchase price still makes sense once installation is included. Don't assume an existing outlet or circuit will meet the fireplace manufacturer's requirements.
Compare the main fireplace styles
The right style depends on the room and how much installation work you're willing to take on.
  • Freestanding electric fireplace: Usually the simplest option to place in a room, provided the model has a suitable outlet and enough clearance.
  • Wall-mounted electric fireplace: Attaches to a wall and may need additional work to route or conceal wiring, depending on the design.
  • Electric fireplace insert: Fits into an existing fireplace opening or a newly built surround. Check the required dimensions and installation instructions before buying.
Running costs also deserve a place in your budget. The electricity calculation is similar to how much electricity space heaters use, especially when the fireplace's heating element is running.
Should Your Electric Fireplace Be on Backup Power?
An electric fireplace can draw a lot of power in heat mode, which can drain battery storage quickly. If you include it in your outage plan, treat it as a short-term heating option for one room and keep essential circuits, such as your refrigerator and lights, in the plan.
Using EcoFlow TITAN 5000 for fireplace backup
EcoFlow TITAN 5000 has a 5kWh base capacity and can back up selected home circuits through the Smart Home Panel 10 (SHP10). A compatible fireplace circuit may be included, but a qualified, licensed electrician must install the panel and check the fireplace's wiring and electrical load. At 1,500W in heat mode, the fireplace can use stored energy quickly. The electrician can assess the existing fireplace circuit alongside your refrigerator and lighting circuits. Check the fireplace manual for its wattage, voltage, and outlet or hardwiring requirements before planning backup. The estimates below show how quickly heat mode can use available battery capacity.
EcoFlow TITAN 5000
Estimate fireplace runtime during an outage
The following calculation examples assume a constant steady load and use an estimated 4,265Wh of usable capacity calculated from the EcoFlow TITAN 5000's 5,017.6Wh nominal capacity at an assumed 85% usable ratio (5,017.6Wh × 0.85 ≈ 4,265Wh) to account for conversion losses.
Load (example)
Watts used
EcoFlow TITAN 5000 (4,265Wh usable est.)
Electric fireplace on heat (Dimplex 1,500W model)
about 1,500W
about 2.8 hours
Fireplace heat (1,500W) + refrigerator (39.6W annualized) + three LEDs (26.4W)
about 1,566W
about 2.7 hours
These are estimates based on steady heating and lighting plus the stated refrigerator average. Each figure divides the estimated usable battery capacity by the combined load in watts. Actual runtime depends on the fireplace thermostat cycling, the refrigerator compressor turning on and off, and what else is drawing power on connected circuits. Heat mode can use most of the available capacity in a few hours. Rank the fireplace against other essential backup circuits and measure representative average use for runtime and verify equipment ratings and startup demand before deciding whether to include it. You may get more value from keeping the refrigerator, lights, and communications equipment running first.
Do You Need a Dedicated Circuit?
Many plug-in electric fireplaces specify a 15-amp, 120-volt circuit. A dedicated circuit is often preferred, although the exact requirement depends on the model. Hardwired fireplaces have their own installation instructions, which must also meet local electrical code.
Follow the manufacturer's wiring instructions
The Dimplex Revillusion RLG25 Owner's Manual (7214560100R04) specifies a 15-amp, 120-volt circuit. It notes that a dedicated circuit is preferred, though not essential in every installation; however, if the breaker trips regularly, a dedicated circuit is required. Check these details before plugging in or installing a fireplace:
  • Voltage and amperage: Confirm that the outlet and circuit match the model's requirements.
  • Other appliances: Avoid overloading a circuit with several high-draw devices.
  • Breaker trips: If the breaker trips repeatedly, stop using the fireplace until the circuit has been checked.
  • Hardwired installation: Follow the manufacturer's instructions and local electrical requirements.
The Dimplex Revillusion RLG25 Owner's Manual also instructs users to plug the fireplace directly into a wall outlet and never use an extension cord. The Consumer Product Safety Commission gives similar guidance for electric space heaters, advising consumers to plug them directly into a wall outlet rather than an extension cord or power strip. If you're unsure whether your existing circuit is suitable, have an electrician inspect it. Understanding 15-amp and 20-amp circuits can help you follow the discussion, but don't use the breaker rating alone to decide whether a fireplace is safe to connect.
How Much Does an Electric Fireplace Cost to Run?
The cost to run an electric fireplace depends on its wattage, how many hours you use it, and your electricity rate. Heat mode usually accounts for most of the electricity use. Flame-only mode uses much less, but the exact draw depends on the model.
How Much Does an Electric Fireplace Cost to Run?How Much Does an Electric Fireplace Cost to Run?
Calculate the cost by wattage and hours
Use this formula: Electricity cost = (Watts ÷ 1,000) × Hours used × Electricity rate. For example, the Dimplex Revillusion RLG25 (Manual 7214560100R04) plug-in model is rated at 120 volts, 12.5 amps, and 1,500 watts. Running it on heat for four hours uses 6kWh:
  • 1,500 watts ÷ 1,000 = 1.5kW
  • 1.5kW × 4 hours = 6kWh
  • 6kWh × $0.1816 = approximately $1.09
The $0.1816 rate reflects the U.S. national average residential electricity price of 18.16 cents per kWh reported in the EIA Electric Power Monthly (Table ES1.A) for August 2026. Your local utility rate may be higher or lower.
Use example
Electricity consumed
Estimated cost at 18.16¢/kWh
1,500W heat for 1 hour
1.5kWh
About $0.27
1,500W heat for 4 hours
6kWh
About $1.09
1,500W heat for 8 hours
12kWh
About $2.18
These figures assume the fireplace draws 1,500W continuously while heating. A thermostat may cycle the heating element, so actual use can be lower depending on the room temperature and settings.
Heat mode and flame-only mode use different amounts of power
The heater is usually the main source of electricity use. If you switch the fireplace to flame-only mode, the heating element turns off while the flame effect continues. Check the manual for the model's exact flame-only wattage before calculating that cost. Your usage habits matter, too. Running the heater for an hour or two while you're in the room will cost less than leaving it on for most of the day. If you're comparing heating options, include local fuel prices in the calculation. Propane and electric heater costs can vary considerably by location and equipment.
Electric fireplace cost includes the unit, any surround or mantel, installation, and possible electrical work. The running cost depends on wattage, hours of use, and your utility rate. For a 1,500W model, four hours of heat use about 6kWh. Check the manual's circuit requirements and get separate installation and electrical quotes before buying. If you want to include a fireplace in your outage plan, EcoFlow TITAN 5000 can support selected compatible circuits through a professionally installed SHP10. Have an electrician check the fireplace load alongside your refrigerator and lighting circuits. Since heat mode draws power quickly, plan for limited use rather than relying on it for extended heating.
How much does an electric fireplace cost?
Divide the fireplace’s wattage by 1,000 to get kilowatts. Multiply by the hours it runs and by your electricity rate in dollars per kWh. A 1,500W model such as the Dimplex Revillusion RLG25 running for four hours uses 6kWh. At the August 2026 U.S. residential average of 18.16 cents per kWh from the EIA Electric Power Monthly, that costs about $1.09.
How much does an electric fireplace cost to run?
Divide the fireplace’s wattage by 1,000 to get kilowatts. Multiply by the hours it runs and by your electricity rate in dollars per kWh. A 1,500W model such as the Dimplex Revillusion RLG25 running for four hours uses 6kWh. At the August 2026 U.S. national average residential rate of 18.16 cents per kWh from the EIA Electric Power Monthly (Table ES1.A), that costs about $1.09.
Do electric fireplaces need a dedicated circuit?
Some manufacturers prefer a dedicated circuit, while others allow a suitable shared circuit under certain conditions. Check the manual for the required voltage and amperage. If the breaker trips repeatedly, have an electrician inspect the circuit.
Can I plug an electric fireplace into an extension cord?
No. Manufacturer installation instructions, such as the Dimplex Revillusion RLG25 Owner's Manual (7214560100R04), specify plugging the fireplace directly into a wall outlet. The CPSC also advises against using extension cords or power strips with electric space heaters.
Can backup batteries run an electric fireplace?
A compatible backup system may support an electric fireplace for a limited time, provided the circuit and load meet its requirements. Heat mode can use stored energy quickly. Have a licensed electrician check the fireplace circuit and prioritize essential household loads.
Save Bills
