How to Calculate kWh: The Simple Formula
Every electric bill comes down to kilowatt-hours (kWh). Most appliance labels only list watts, not kWh. That gap confuses a lot of people. Learning how to calculate kWh bridges that gap. Once you know the math, you can track your energy habits. You can also lower your monthly utility bills and size backup power systems with ease.
This guide breaks down the core formula step-by-step. We will explore real-world examples, connect numbers to dollars, and look at common math traps to avoid.
The kWh Formula
Understanding how to calculate kilowatt hours comes down to one basic relationship. Watts measure how fast a device pulls power right now. Kilowatt-hours measure total energy consumed over time.
Think of watts like the speedometer in your car. It tells you your speed at any given second. Kilowatt-hours are like your trip odometer. They show the total distance you have traveled.
The Basic Math
To find your energy consumption, use this simple formula:
kWh = (Watts × Hours) ÷ 1,000
Here is what each part of that equation means:
  • Watts: The power rating on your appliance label.
  • Hours: The total time you run the device.
  • 1,000: The conversion factor, since 1 kilowatt equals 1,000 watts.
Example
Let's test this with an everyday fixture. Suppose you have a standard 60-watt incandescent light bulb in your living room. You leave it on for 5 hours in the evening.
  1. Multiply the wattage by the hours: 60 × 5 = 300 watt-hours.
  2. Divide that result by 1,000: 300 ÷ 1,000 = 0.3 kWh.
That single bulb adds 0.3 kWh to your daily usage. Learning how to calculate kWh usage gives you full control over your home energy budget.
Applying that formula to a few everyday appliances makes the math click faster.
Worked Examples for Common Appliances
Real appliances do not all pull power the same way. Some run continuously at full blast. Others, like your kitchen fridge, cycle on and off throughout the day.
Applying the formula to everyday household goods shows how these patterns play out.
Appliance
Rated Wattage
Daily Run Time
Daily kWh Consumed
Refrigerator
150W (cycling)
~8 hours active
~1.2 kWh
Living Room TV
150W
4 hours
0.6 kWh
Ceiling Fan
75W
8 hours
0.6 kWh
Space Heater
1,500W
3 hours
4.5 kWh
Breaking Down the Appliance Numbers
Notice how run time completely changes the total impact on your bill. A 75W ceiling fan running all workday uses the exact same energy as a 150W TV on for half that time.
Meanwhile, high-draw thermal appliances like portable space heaters pull massive loads. Just three hours with a space heater running chews through 4.5 kWh. That is nearly four times what your refrigerator consumes all day.
If you ever wonder how to calculate kilowatts per hour across different devices, remember it always hinges on hours used. Always multiply running watts by actual runtime, not just the hours the unit sits plugged in.
Once daily kWh is known for an appliance, connecting it to an actual dollar cost is one more short step.
Sizing Battery Runtime With the Same Math
The same kWh formula that explains a bill also predicts exactly how long a portable power station will run something. Dividing a station's rated Wh capacity by an appliance's wattage gives a straightforward runtime estimate before heading out the door or into an outage.
Most stations list capacity in watt-hours. A 2,000 Wh unit holds about 2 kWh. Runtime equals usable capacity divided by the load in watts. Factor in a bit of inverter loss, usually 5 to 15 percent, and you get a realistic number.
Example: A 2,000 Wh station running a 100-watt fridge averages around 18 to 20 hours. The same station powering a 1,500-watt heater lasts closer to an hour. The math stays the same whether you're prepping for a weekend camping trip or a multi-day outage during hurricane season.
Once you know your appliance's wattage and estimated runtime, the next step is matching those needs to a power station's capacity and output. These EcoFlow models provide practical options for calculating and managing backup runtime.
The EcoFlow DELTA 3 Plus delivers expandable capacity from 1 kWh up to 5 kWh, continuous 1,800 W output with surge support, and multiple fast-charge options so you can size runtime for fridges, lights, or medical devices with confidence during extended grid failures.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
For heavier loads or longer runtimes, a higher-capacity unit gives more headroom while still using the identical kWh math. The EcoFlow DELTA 3 Max offers 2,048 Wh of storage, 2,400 W continuous output with strong surge capability, and rapid recharging, so you can keep essential appliances running longer without constantly recalculating remaining energy.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Whether estimating a bill or battery runtime, connecting kWh to an actual cost is the final piece.
Connecting kWh to Your Electric Bill
Once you've calculated an appliance's kWh usage, you can estimate what it costs to operate.
Connecting kWh to electric billConnecting kWh to electric bill
The basic formula is:
Electricity cost = kWh used × Electricity rate
Suppose an appliance uses 4.5 kWh per day, and your electricity rate is $0.16 per kWh.
The daily cost would be:
4.5 × $0.16 = $0.72 per day
Over 30 days:
$0.72 × 30 = $21.60
So, that appliance would cost about $21.60 per month under those assumptions.
Your actual electricity bill may include additional charges, so this calculation estimates the energy portion of the cost. Electricity rates also vary by utility, location, plan, and time of use. Understanding your electricity cost per kWh makes the calculation more practical.
A few common mistakes throw this otherwise simple calculation off.
Common Mistakes When Calculating kWh
The math looks simple, but small oversights can skew your estimates. Keep an eye out for these frequent mistakes when sizing circuits or calculating monthly budgets.
Common mistakes to avoidCommon mistakes to avoid
1. Forgetting to Divide by 1,000
This is the most common blunder people make. If you multiply 1,500 watts by 5 hours, you get 7,500. Forgetting to divide by 1,000 makes your power draw look 1,000 times higher than reality. Always convert watt-hours to kilowatt-hours before doing cost math.
2. Using Nameplate Wattage as Constant Draw
Look at the back of your refrigerator, blender, or microwave. That label shows maximum nameplate wattage. It represents the absolute peak draw the internal motor can pull under heavy stress.
Most appliances rarely run at peak capacity continuously. A refrigerator might be rated for 600W surge, but it averages around 100W to 150W when running. Its compressor only runs about one-third of the day. Using nameplate wattage directly will wildly inflate your calculations.
3. Ignoring Phantom and Standby Loads
Many modern gadgets never truly shut down. TVs, game consoles, microwave clocks, and laptop chargers continuously draw trickles of electricity.
These vampire draws typically range between 2W and 15W per device. Left unchecked around the clock, they add up across a dozen household items.
Comparing your total against how much kWh an average house uses offers a quick reality check for your numbers.
At the end of the day, understanding your power use comes down to multiplying wattage by running hours and dividing by one thousand. That simple calculation explains the total on your monthly electric bill and tells you exactly how long a backup battery will keep your gear running. Just remember to use actual running wattage rather than peak nameplate numbers, and never skip the step that converts your watts into kilowatts.
If you want to take the guesswork out of sizing your backup power, EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max make it easy. Both units list capacity in watt-hours and show real-time wattage draw right on the screen, letting you manage your runtime with total confidence.
What is the formula to calculate kWh from watts?
The formula is kWh equals watts times hours divided by 1,000. Multiply the appliance wattage by the hours it runs. Then divide by 1,000 to convert the total into kilowatt-hours. This gives the energy used over that time.
How do I calculate kWh for an appliance that runs on and off?
Estimate the average running watts while the motor or compressor is active. Multiply by the total hours it actually runs each day, then divide by 1,000. For appliances that cycle frequently, actual measurements can improve accuracy.
What is the difference between kW and kWh?
Kilowatts measure power, or how fast energy is used at any moment. Kilowatt-hours measure total energy used over time. Your utility bills you for kWh, not kW. Think of kW as speed and kWh as distance traveled.
How do I find the wattage of an appliance if it's not listed?
Check the specification label for voltage and amperage ratings. Multiply the volts by the amps to determine total wattage. In standard American homes, normal wall outlets supply 120 volts, making this calculation quick and straightforward.
How does kWh relate to what I actually pay on my electric bill?
Electric companies bill you directly for the total kilowatt-hours used over a monthly cycle. Multiplying your cumulative kWh by the utility's local rate per kilowatt-hour determines the base energy charges listed on your bill.
Tips
