Smart Power Strip Guide: How They Cut Standby Power and How Much You Can Save
A smart power strip does one job a regular strip can’t: it cuts power to devices that sit in standby, like the soundbar, game console, and streaming box behind a TV, without you flipping a switch. DOE says standby power can be 5 to 10 percent of home electricity use. But savings depend on what you actually plug in. This guide explains the types of smart power strips, how to measure your own standby load, how to estimate savings with EIA’s current price, how to set one up around a TV, and what should stay always on.
What is a smart power strip?
A smart power strip is a power strip that switches outlets off automatically. Some follow a control device, some use timers, and some sense motion. App-controlled strips add scheduling.
DOE explains that smart strips can detect when a device is in standby and cut its power, which a regular strip can’t do. It also puts standby power at 5 to 10 percent of residential energy use, which it says could cost the average U.S. household as much as $100 per year.
Type
How it switches
Good for
Control (master) outlet
Turns peripherals off when the TV turns off
TV and media centers
Timer
On a schedule
Office gear, holiday lights
Occupancy sensor
Turns off when no one’s around
Home offices
App or Wi-Fi strip
Remote control and schedules
Anything you can switch off
Phantom power adds up. Learn what phantom power is first.
Some devices on that TV stand should never be cut, like the modem and router. If you also want internet during outages, power them separately.
Keep the router always on (and online during outages)
Put the modem and router on an always-on outlet, not a switched one. If you also want Wi-Fi in an outage, a small power station can run them directly. That’s a separate budget from the strip’s savings, and your internet provider’s network still has to be up.
Using a TV stand as the example, measure the standby use of the peripherals you can cut, then list the devices that must stay on, like the router. If the household also wants internet during outages, the EcoFlow DELTA 3 Classic can power a compatible modem and router directly. That keeps switchable loads and always-on loads apart. Because continuous communication is the only extra task here, more storage can’t increase the strip’s standby savings.
A smart strip saves by switching things off; your router needs the opposite. If you want Wi-Fi during outages, an EcoFlow portable power station can run the modem and router directly while the grid is down. Treat it as its own purchase, separate from anything the strip saves. Your provider’s network still has to be up for the connection to work.
A modem and router draw little power, so a 1kWh station can keep them running for many hours. That only helps if your provider’s network is up, so treat the hours below as an estimate, not a promise.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimate (illustrative)
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Modem + router (example 25W)
about 25W
about 35 hours
Method: usable capacity (Wh × 0.85) ÷ load (W). This is an estimate; your equipment’s draw will differ.
Unplugging saves less than you think. Check whether unplugging appliances saves money.
Back to savings: measure before you buy.
How much can a smart power strip save?
Measure standby watts with a plug-in meter. Multiply the measured standby watts by the number of hours those devices are switched off, then divide by 1,000 to get kilowatt-hours. Multiply by your utility rate per kWh to estimate the savings.
EIA reports the U.S. average residential price at 18.16 cents per kWh in August 2026 (preliminary). As an example, cutting a 10W standby load for 18 hours a day is 0.18 kWh per day. Over a year that’s about 66 kWh, or roughly $12 at 18.16 cents. That’s an estimate; your loads and rate will differ.
ENERGY STAR TVs use at most 0.5W in standby-passive mode, so newer TVs save little. Consoles and older gear save more, so measure them.
TV power usage varies a lot. See how much electricity a TV uses.
Finally, setup.
A smart power strip powering both laptop and smartphoneA smart power strip powering both laptop and smartphone
How to set up a smart power strip?
Plug the TV into the control outlet. Put peripherals on switched outlets. Put the router and DVR on always-on outlets.
If the strip doesn’t detect the TV turning off, adjust the sensing threshold. Don’t daisy-chain strips, and don’t use one for space heaters. Also, a surge protector and a smart strip aren’t the same thing, so check the label.
Strips and surge protectors differ. Know the difference between power strips versus surge protectors.
A smart power strip cuts standby power, which DOE says makes up 5 to 10 percent of home electricity use. Your savings depend on measured standby watts and the hours they’re cut. Measure first, keep routers on always-on outlets, and use EIA’s rate to estimate. If you also want Wi-Fi during outages, an EcoFlow DELTA 3 Classic can run your modem and router separately from the strip, so the two budgets stay clear and simple.
A smart power strip automatically cuts power to devices in standby, using a control outlet, timer, motion sensor, or app, so you don’t have to flip switches yourself.
Do smart power strips really save money?
Yes, by the standby watts it actually cuts. Measure each device with a plug-in meter, multiply by hours switched off, and apply your utility rate to estimate savings.
What should not go on a smart power strip?
Keep routers, modems, and DVRs that need continuous power on always-on outlets rather than switched outlets. Electric space heaters should not be connected to any outlet on a power strip, including an always-on outlet. CPSC recommends plugging electric space heaters directly into a wall outlet.
How much standby power do TVs use?
ENERGY STAR TVs use at most 0.5 watts in standby-passive mode, so newer TVs save little on their own. Consoles, soundbars, and older gear often use more, so measure.
Is a smart strip a surge protector?
Only if the label says so. A smart strip switches power off; a surge protector absorbs voltage spikes. Some do both, so check the packaging for a joules rating.
Save Bills
