Automated Demand Response: What Happens During a Utility Peak Event
On a hot summer afternoon, electricity use can climb as homes run air conditioners, refrigerators, and other appliances. When demand puts pressure on the grid, utilities may ask participating customers to reduce their electricity use. Automated demand response handles that request through signals sent to connected devices. A smart thermostat might adjust its temperature setting, while an eligible home battery may change how it supplies power. Here's how the process works, which devices can take part, and what to consider before allowing a utility event to draw from your backup battery.
What Is Automated Demand Response?
Demand response is changing when and how much electricity you use in response to utility prices or incentives. Automated demand response goes one step further and sends signals to enrolled devices (smart thermostats, home batteries, etc.) to allow them to respond automatically. FERC defines demand response as changes in electricity use in response to prices or incentives, while the EIA notes that some programs let grid operators control load and others leave customers in charge.
What Is Automated Demand Response?What Is Automated Demand Response?
How does auto-DR work?
Auto-DR is automated demand response, which connects a program’s signal to compatible equipment. An instruction is sent by the utility, grid operator, or another authorised organisation. An enrolled device receives it and follows the settings you agreed to when joining the program.
The OpenADR Alliance describes automated demand response as automated signaling from a utility, grid operator, or other authorized entity. In the U.S., that can include an independent system operator (ISO) or a regional transmission organization (RTO). OpenADR is a communication standard that supports the exchange of demand response signals between organizations and energy devices. A typical setup involves three parts:
  • The program operator: A utility, grid operator, or approved aggregator schedules or sends the event.
  • The communication system: A compatible control system or connected device receives the event signal.
  • The participating equipment: A thermostat, battery system, EV charger, or other eligible device adjusts its operation according to the program settings.
Customers may receive a bill credit, an event payment, or another incentive, depending on the program. Some demand response programs offer payments, but the amount and payment rules vary. Check the terms before assuming you'll receive a particular benefit.
Can a Home Battery Take Part in Demand Response?
If the home battery model and configuration are approved by the utility or program provider, the battery may be eligible for demand response. In its August 17, 2026 ADER Pilot update, slide 2, ERCOT reported 249 MW of qualified capacity under the 500 MW pilot cap, with residential batteries driving much of the growth. The figure measures qualified capacity. It does not report how much power was being dispatched. The EcoFlow TITAN 5000 provides a capacity example for planning an outage reserve.
It has a 5kWh base capacity, expandable to 30kWh with additional batteries, and can back up selected circuits through the Smart Home Panel 10 (SHP10), which requires installation by a qualified, licensed electrician. Its grid connection with SHP10 is configured for No Export. Before joining a program, confirm its eligible device list, dispatch rules, and payment terms with your provider. The EcoFlow TITAN 5000 is included here as a capacity example, not as a confirmed participant in a demand response program.
EcoFlow TITAN 5000
How Much Battery Capacity Can You Keep Above Your Outage Reserve?
Before a demand response event, estimate how much battery capacity your home needs during an outage. The following example uses the EcoFlow TITAN 5000 and assumed appliance loads.
Illustrative reserve calculation
Value
EcoFlow TITAN 5000 usable (5,017.6Wh × 0.85)
about 4,265Wh
Outage reserve (assumes a 150 W fridge and a 15 W router for 12 hours)
about 2,000Wh
Left above reserve
about 2,265Wh
Program eligibility
Must be confirmed by the provider
These figures are estimates, not guaranteed runtimes. To calculate your reserve, multiply each essential appliance's wattage by the number of hours you want to run it, then add the results. Check the appliance labels and use your actual power requirements. Utilities are also testing virtual power plants and home batteries to reduce demand across groups of homes. However, your battery's eligibility depends on the program and must be confirmed with the provider. Here's what a typical event looks like from the household side.
What Happens During a Demand Response Event?
Typically, a demand response event is called when a utility or grid operator expects an increase in electricity demand or needs to balance available supply. The programme sends a notice or signal to the devices that are involved. Those devices then adjust their operation for the scheduled period. The exact process depends on the utility and the agreement you signed. A typical event has three stages:
Step
Who acts
What changes
Notice
Utility, ISO, or aggregator
Event time sent to devices or app
Event
Thermostat, battery, EV charger
Pre-cool, raise setpoint, discharge, or pause charging
Settlement
Program
Reduction measured against a baseline
Which devices respond during an event?
Depending on the program, smart thermostats can adjust cooling settings, EV chargers can pause charging, and compatible home batteries can change their output or supply selected circuits. These adjustments help reduce demand during peak periods, often on hot summer afternoons. Check when peak electricity hours occur and review your program's terms for event notices, duration, and opt-out options.
How Much Battery Reserve Should You Keep?
Set aside enough battery capacity to cover the household essentials you may need during an outage. Then decide whether any energy above that reserve can be made available for a demand response event. Start by listing the appliances and devices you want to keep running. Check their actual power requirements and estimate how many hours you may need them. A refrigerator and Wi-Fi router, for example, may be more important during an outage than nonessential appliances.
How Much Battery Reserve Should You Keep?How Much Battery Reserve Should You Keep?
Example: Calculate a 12-hour outage reserve
The following figures illustrate the calculation. Use your own measured appliance consumption and planned outage duration to size the reserve.
Essential load
Example power draw
Runtime
Energy needed
Refrigerator
150W average
12 hours
1,800Wh
Wi-Fi router
15W
12 hours
180Wh
Total
165W
12 hours
1,980Wh
That's roughly 2kWh for the two loads over 12 hours. The calculation is straightforward: Reserve capacity (Wh) = Appliance power (W) × Operating time (hours). For multiple appliances, calculate each load separately and add the results. Actual refrigerator consumption can vary because its compressor cycles on and off, so use measured consumption where possible.
What could remain available above the reserve?
EcoFlow TITAN 5000 is rated at 5,017.6Wh. That's about 4,265Wh based on an estimated 85% usable capacity. Subtracting the example 1,980Wh outage reserve, there is about 2,285Wh left. Actual capacity is dependent upon system settings and connected loads. Your battery configuration must be approved by the programme before you can use it for an event. Demand response payments and peak shaving savings are separate benefits unless the programme says otherwise. Remember your reserve when considering programme terms.
Automated demand response lets utilities or grid operators ask compatible devices to reduce or shift electricity use during periods of high demand. Before joining, check your provider's device list, event rules, payment terms, and opt-out options. If you have a home battery, decide how much capacity your household needs during an outage before making any available energy part of a program. The EcoFlow TITAN 5000 offers a 5kWh starting capacity and can illustrate how to plan that reserve. Its eligibility for any demand response program must be confirmed with the provider.
What is automated demand response?
Automated demand response uses signals from a utility, grid operator, or approved organization to tell enrolled devices when to reduce or shift electricity use. Compatible equipment follows the settings agreed upon when the customer joins the program.
Who sends the demand response signal?
The signal may come from your electric utility, an independent system operator (ISO), a regional transmission organization (RTO), or an approved aggregator. The organization responsible depends on the program.
Can I override a demand response event?
Some programs allow customers to opt out of individual events, while others set specific limits. Check your agreement for the opt-out process, notice requirements, and any effect on incentives.
Do home batteries qualify for demand response?
Some home batteries qualify, but eligibility depends on the program's approved device list, control system, and electrical setup. Ask your utility or program provider to confirm your exact configuration before enrolling.
Will demand response drain my backup battery?
It can reduce the energy available during an outage if the program dispatches the battery. Set an appropriate reserve and confirm that the program supports your required backup settings before participating.
Save Bills
