Why Does Power Go Out During Storms? What Breaks and How Long It Lasts
Why does power go out during storms, even when the wind doesn't seem that bad? Often, the problem starts on a local power line. A falling tree limb, lightning strike, ice buildup, or floodwater can damage equipment or trigger a safety shutdown. The outage may last a few minutes or stretch into hours, depending on the damage and how quickly utility crews can reach it. EIA annual totals show how much major events added to the time customers spent without power over the year. For the restoration estimate in a particular outage, check your utility. Here's what causes storm outages and how to prepare your home.
Storms can damage the equipment that carries electricity from substations to homes and businesses. Strong winds push trees and branches into power lines, lightning can damage transformers, and flooding can reach electrical equipment near the ground. Sometimes, protective devices also shut off power to prevent a fault from spreading. Here are the main causes:
Cause | What happens | Typical sign |
Wind and trees | Limbs or whole trees hit lines and poles | Flicker, then outage |
Lightning | Surges trip breakers or damage transformers | Bang, then outage |
Ice and snow | Weight snaps lines and branches | Outage during or after the storm |
Flooding | Water reaches underground or substation gear | Outage in low areas |
Why does the power sometimes flicker first?
A brief flicker can happen when a protective device detects a problem on the line and tries to restore service. For example, a tree branch might touch a power line during a gust of wind. A breaker or recloser can interrupt the current, then try to close the circuit again. If the fault has cleared, power returns. If the branch is still touching the line or the equipment has been damaged, the device may shut the circuit off again. That can leave a home without power until utility crews inspect and repair the problem.
The timing and frequency of outages also vary throughout the year. Looking at outage causes by season can help explain why some areas face more trouble during hurricane season, winter storms, or periods of heavy vegetation growth. Knowing what caused the outage won't bring the power back sooner, but it can help you plan for the wait.
Keeping the Essentials Running Until Power Returns
Your local utility provides the best estimate of when power will return. Plan for both short and extended interruptions. Start with essentials such as lights, phones, and your Wi-Fi router, then consider the refrigerator. According to FoodSafety.gov, a closed refrigerator keeps food cold for up to four hours and a full freezer for about 48 hours. The EcoFlow DELTA 3 Classic is an option for smaller loads, and the larger EcoFlow DELTA 3000 Gen4 can support a compatible refrigerator and other appliances. Keep the battery unit and all connections in a dry place where floodwater cannot reach them. Check current delivery availability before buying.
For longer storm outages, you may need more than backup for lights and communication. The 3,072Wh EcoFlow DELTA 3000 Gen4 offers greater capacity and 3,600W of continuous output, giving you more room to run a compatible refrigerator alongside essential devices. Check the refrigerator's startup surge and daily energy use to make sure the unit can handle the load.
How the products divide the job
The EcoFlow DELTA 3 Classic is suited to shorter outages when you mainly need to keep phones, lights, and your Wi-Fi router running. For longer outages, the EcoFlow DELTA 3000 Gen4 offers more capacity for a compatible refrigerator and other essentials. Check the refrigerator's startup wattage and daily energy use before choosing.
Estimated runtime for common household loads
The table below gives a rough comparison using estimated usable capacity and example power draws. These are calculations, not guaranteed runtimes. Actual results depend on the devices connected, their power use, conversion losses, and how often an appliance cycles on and off.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) |
Example: router, modem, and LED lamp | about 40W | about 22 hours | about 65 hours |
Example: refrigerator (38 W annual average) and router (15 W assumed) | about 53W | about 16 hours | about 49 hours |
The estimates divide usable battery energy (Wh) by load (W) and assume usable energy equal to 85% of rated capacity. The ENERGY STAR listing for the Insignia NS-RTM14WH5-C gives 333 kWh per year, equivalent to about 38 W averaged over a year. The router is an assumed 15 W. A refrigerator can draw substantially more when the compressor starts. Check its startup demand and measure daily energy use before sizing battery backup for a refrigerator.
How Long Do Storm Outages Last?
According to the U.S. Energy Information Administration, U.S. electricity customers experienced about 11 hours of interruptions on average across 2024. Major events accounted for nearly nine of those hours, about 80% of the total. Hurricanes Beryl, Helene, and Milton were examples of those events. Excluding major events, the annual average has been about two hours since 2013. These figures add up interruptions over a year. Check your utility's outage map for the expected restoration time at your address.
Why does restoration take time?
Utilities restore power in segments beginning with the larger equipment and lines that serve the most customers and then work down to smaller local faults. If fallen trees, damaged poles, or blocked roads prevent access to the location, or if weather conditions are not safe, repairs may take longer. Ice storms can make the damage worse by adding weight to branches and power lines, which can sometimes break after the storm has passed. Check your utility's outage map or text alerts for updates specific to your address, and review these winter power line risks before the cold-weather season.
How to Stay Safe During a Storm Outage
A power outage can leave hazards around your home that aren't always easy to spot. Downed lines, damaged electrical equipment, and improperly used generators can put your household in danger. Keep your distance from damaged equipment and follow instructions from emergency services and your utility.
Stay away from downed power lines
Treat any downed line as energized, even if it is quiet and not sparking. Keep people and pets away. Do not touch, move, or drive over the line. From a safe place, call 911 and report it to the local utility. If a line falls on your car while you are inside, stay there and call 911. Leave only if there is fire or smoke. If you must leave, jump clear without touching the vehicle and the ground together, then shuffle away with your feet close together.
Use generators outdoors
Never run a fuel-powered generator inside a home, garage, or other enclosed space. It can produce dangerous levels of carbon monoxide. CPSC recommends operating generators outdoors, at least 20 feet from homes and buildings, with exhaust pointed away from windows, doors, and vents. Follow the generator manual's instructions for dry placement. For an indoor battery power station, keep the unit, plugs, and outlets dry and where water cannot reach them. Never operate or plug in equipment while standing in water. Have a qualified professional inspect any equipment or circuits that got wet before using them.
Keep refrigerator and freezer doors closed
Each time you open the refrigerator or freezer, cold air escapes. Keep the doors shut as much as possible. FoodSafety.gov's outage guidance gives roughly four hours for an unopened refrigerator and 48 hours for a full freezer with its door shut. Keep phones charged, save your utility's outage number, and decide where family members should meet if travel is difficult. Writing down a severe weather family plan can make those steps easier to follow.
Storm damage can knock out power for minutes or leave a neighborhood without electricity for hours. Before the next storm, check your utility's outage alerts, keep clear of downed lines, and decide which appliances you need to run. A battery power station can help cover those essentials while crews work on repairs. The EcoFlow DELTA 3 Classic suits smaller loads such as phones, lights, and a Wi-Fi router, while the EcoFlow DELTA 3000 Gen4 offers more capacity for a compatible refrigerator and other devices. Check startup wattage, daily energy use, and product availability before choosing a setup.
Why does power go out during storms?
Wind, falling branches, lightning, ice, and flooding can damage power lines, poles, transformers, and other electrical equipment. Protective devices may also shut off a circuit when they detect a fault, helping prevent further damage.
Why does the power flicker before going out?
A breaker or recloser may interrupt power briefly after detecting a fault, then try to restore the connection. If the problem remains, the device can shut the circuit off again. That's why you may notice a flicker before a longer outage.
How long do storm power outages last?
It depends on the damage and access to the equipment. EIA's nearly nine hours per customer from major events in 2024 is a cumulative annual average. Look up your address on your utility's outage map for a restoration estimate.
Who do I call about a downed power line?
Stay away and keep others clear. Call 911 from a safe place, then report the line to your utility. Treat the line as energized even if you see no sparks.
How long will food stay safe during a power outage?
With the doors closed, a refrigerator keeps food cold for about four hours and a full freezer for about 48 hours. Follow FoodSafety.gov's outage guidance to decide what to keep and what to discard.
