Tornado Delaware Guide: The November 2026 Newark Tornado, Alerts, and Where to Shelter
Delaware doesn't experience tornadoes every day, but they can happen with little warning. November 12, 2026, was a reminder when an EF-1 tornado touched down near Newark in New Castle County. The National Weather Service (NWS) recorded 100 mph peak winds along a 4.4-mile path. This guide explains what happened, how to receive tornado warnings in Delaware, what past Dover tornado reports mean, and where to shelter when severe weather threatens. You'll also learn how to prepare lighting and communication devices before a storm causes a power outage.
The November 12, 2026 Newark, Delaware Tornado
The NWS Mount Holly office rated the Newark tornado EF-1 on the Enhanced Fujita scale. It occurred between approximately 1:05 and 1:15 p.m. EST, and officials reported no injuries or fatalities. Although the tornado lasted around 10 minutes, its damage extended across several neighborhoods.
What did the NWS damage survey find?
According to the NWS survey update issued November 13, 2026, the tornado began in the southern part of the Salem Woods neighborhood and moved generally northeast. It damaged roofs and siding, uprooted trees, and snapped large branches along its path. Here are the confirmed details:
Survey detail | NWS finding |
Date | November 12, 2026 |
Rating | EF-1 |
Estimated peak winds | 100 mph |
Path length | 4.4 miles |
Maximum width | 175 yards |
Approximate duration | 10 minutes |
Injuries and fatalities | None reported |
The tornado moved through several neighborhoods before reaching its strongest estimated intensity near Chapman Woods, where it damaged homes and snapped trees. As it continued along its path, it overturned a semitrailer while crossing I-95 and later damaged two hospital helicopters at Christiana Hospital. These impacts demonstrate how tornadoes can damage buildings, vehicles, trees, and infrastructure across multiple locations. Since flying debris and damaged structures can remain dangerous after the storm passes, choosing a safe shelter and preparing emergency supplies ahead of time is essential.
Prepare Ahead: Power for Alerts and Light in Your Shelter
A tornado warning can leave very little time to react. The safest approach is to prepare your shelter and emergency supplies before severe weather develops. If your designated shelter has limited access to electricity, arrange backup lighting and device charging in advance. A power outage may also follow a tornado if high winds damage utility poles, transformers, or power lines. Having a way to operate a weather radio, charge a phone, and power a small LED lamp can make the hours after a storm easier to manage.
What Should You Keep in Your Emergency Shelter?
Keeping essential supplies in your designated shelter can help you stay safe and manage basic needs during a tornado. Prepare a small emergency kit in advance and store it somewhere you can reach quickly. Include the following items to support communication, lighting, first aid, and personal protection.
Weather Radio: Keep a battery-powered or hand-crank NOAA Weather Radio nearby to receive official weather updates during power or internet outages.
Mobile Phone and Charging Cables: Keep your phone fully charged with its charging cable so you can receive emergency alerts and contact family members.
Flashlight or LED Lantern: Store a reliable flashlight or LED lantern with spare batteries to maintain visibility if the electricity goes out.
Drinking Water and Nonperishable Food: Keep bottled water and ready-to-eat food available to meet basic needs while sheltering.
First-Aid Kit and Medications: Include basic medical supplies and any necessary medications that household members may need.
Sturdy Shoes and Protective Headgear: Keep closed-toe shoes and helmets or other suitable head protection nearby to reduce the risk of injury from debris.
Emergency Contact Numbers: Write important phone numbers on paper so you can contact family members and emergency services if your phone becomes unavailable.
How Can Backup Power Help After a Tornado?
A fully charged portable power station can provide backup electricity after a tornado, helping you recharge compatible phones, operate a small weather radio, and power an LED lamp. Understanding how to keep essential devices powered during a tornado-related outage can help you prioritize important equipment. For Delaware households, the EcoFlow DELTA 3 Classic offers 1,024Wh of capacity for essential low-power devices when household electricity is unavailable. Keep it charged in a dry, safe location and always follow official emergency instructions.
Estimated Runtime for Basic Shelter Devices
The following example shows how long the EcoFlow DELTA 3 Classic might support a small emergency setup.
Emergency load (example) | Estimated power use | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Weather radio, LED lamps, and phones | about 30W | about 29 hours |
Runtime estimate: 870Wh ÷ 30W = 29 hours. The 870Wh figure assumes approximately 85% usable capacity from the 1,024Wh battery. This is an illustrative estimate; actual runtime depends on device ratings, charging losses, and usage patterns. The most important point is to prepare your equipment ahead of time. Do not retrieve, move, or connect to a power station when a tornado warning requires you to take cover.
How to Get Tornado Warnings in Delaware
If you live in Delaware, sign up for the Delaware Emergency Notification System (DENS) to receive important local emergency updates. Keep Wireless Emergency Alerts enabled on your mobile phone and have a battery-powered NOAA Weather Radio available as a backup. Using multiple alert sources helps you stay informed if one communication channel becomes unavailable.
1. Sign Up for Delaware Emergency Notifications
The Delaware Emergency Notification System (DENS), managed by the Delaware Emergency Management Agency (DEMA), is the state's primary public warning system. It allows local 911 centers and emergency managers to send alerts to specific neighborhoods or larger affected areas.
Register your mobile phone: Sign up through DENS using Smart911. Mobile phones are not automatically enrolled.
Choose notification methods: Receive emergency messages through phone calls, text messages, email, or social media, depending on your notification preferences.
Keep your information updated: Review your registered phone number and address so local officials can send alerts to the correct area.
2. Check National Weather Service Warnings
The National Weather Service (NWS) Philadelphia/Mount Holly office issues weather forecasts, watches, and warnings for all three Delaware counties: New Castle, Kent, and Sussex. You can visit the NWS Mount Holly website to check current weather conditions and active alerts. For residents in Dover and Kent County, distinguish historical tornado reports from active warnings. Past storm records can help you understand previous weather events, but they do not indicate that a tornado threat is currently active. Always check the latest NWS alerts for your location and note the update time when reviewing the information.
3. Recognize Tornado Warning Signs
Official alerts are essential, but recognizing changing weather conditions can also help you respond sooner. Learn how to tell a tornado is coming so you can recognize potential warning signs, such as a rotating cloud formation, a dark or greenish sky, or a loud roar. If a tornado warning is issued, take shelter immediately rather than waiting to see the tornado.
Where to Shelter During a Tornado Warning in Delaware
When a tornado warning is issued in Delaware, move to the lowest floor of a sturdy building and choose a small interior room away from windows. A basement or storm shelter offers better protection when available. Mobile homes are not safe during tornadoes, so residents should identify a nearby sturdy building before severe weather arrives. If you are driving, seek the closest suitable shelter rather than trying to outrun the tornado.
4. Choose an Interior Room at Home
The National Weather Service recommends going to a basement, safe room, or small interior room on the lowest floor when a tornado warning is issued.
Basement: Move to the basement and stay away from windows, exterior doors, and areas where heavy objects could fall.
Interior bathroom or closet: If your home has no basement, choose a windowless bathroom, closet, or interior hallway on the lowest floor.
Protect your head: Get under a sturdy table or workbench if possible, and cover your head and neck with a helmet, mattress, or thick blanket.
5. Avoid Mobile Homes and Temporary Structures
Mobile homes, tents, sheds, and storage facilities do not provide reliable protection from tornado winds. If you live in a mobile home, identify the closest sturdy building or designated storm shelter and plan how to reach it before severe weather develops. Some homeowners also consider building a DIY tornado shelter as part of their long-term preparedness plans. Do not wait until a warning is issued to arrange a safe location.
6. Find Shelter If You Are Driving or Outdoors
If you are in a vehicle when a tornado warning is issued, head toward the closest sturdy building if you can reach it safely. Do not try to outrun a tornado in congested traffic or take shelter under a highway overpass. If no sturdy shelter is reachable, follow official NWS last-resort guidance for your situation. This may involve staying low in a vehicle and protecting your head or moving to a low-lying area such as a ditch or ravine when it is safe to do so.
7. Follow Instructions in Public Buildings
If you are at a school, hospital, workplace, or shopping center, follow the building's emergency procedures and instructions from staff. Move to the designated shelter area, preferably on the lowest floor in an enclosed interior space. Avoid windows, glass entrances, gymnasiums, auditoriums, and other large open areas with wide-span roofs.
When checking for tornado activity in Delaware, stay informed through the National Weather Service Mount Holly office and the Delaware Emergency Notification System (DENS). The latest reported event was an EF-1 tornado near Newark on November 12, 2026, with estimated winds of 100 mph. Sign up for DENS, identify a safe shelter, and prepare emergency supplies in advance. Keep an EcoFlow DELTA 3 Classic charged nearby to power essential lights and communication devices during an outage.
Was there a tornado in Delaware in November 2026?
Yes. The NWS confirmed an EF-1 tornado near Newark, Delaware, on November 12, 2026. It had estimated peak winds of 100 mph and traveled 4.4 miles through parts of New Castle County.
How do I get tornado alerts in Delaware?
Register for the Delaware Emergency Notification System (DENS) through DEMA. You should also keep Wireless Emergency Alerts enabled on your phone and use a NOAA Weather Radio for additional weather updates.
Has a tornado hit Dover, Delaware?
Yes. On August 4, 2020, during Tropical Storm Isaias, an EF-2 tornado began near Dover and traveled approximately 35.5 miles toward the Glasgow area. The NWS confirmed estimated peak winds of 115 mph along its path.
Is there a tornado warning in Delaware now?
For current tornado warnings, visit NWS Mount Holly and check your DENS notifications. This article covers historical events and preparedness information rather than live alerts.
Where do I shelter in a mobile home?
Leave your mobile home and move to a sturdy nearby building or designated storm shelter. Mobile homes do not provide adequate protection from tornadoes. Plan your shelter location and transportation before severe weather develops.
