Missouri Tornado Guide: Check Alerts, Take Shelter, and Keep Power for the Basics
A Missouri tornado can hit in any season, not just spring. In a preliminary damage survey, the National Weather Service (NWS) rated a tornado that struck near Clark in Randolph County on November 3, 2026, as EF1. Missouri recorded its deadliest tornado year since the 2011 Joplin disaster in 2025, according to the State Emergency Management Agency (SEMA). This guide explains how to check alerts for your location, understand watches and warnings, and prepare to shelter. It also covers how to keep a weather radio, phones, and lights powered during an outage.
How to Check Missouri Tornado Alerts Right Now
Check live alerts for your actual location. A county tells you which NWS office serves the area, but a tornado warning's mapped area can cover only part of a county. Check the boundary and the issue and expiration times.
During active weather, use weather.gov rather than old clips or social media graphics. Enter your city or ZIP code and open the active alert to check whether it covers your location. Your regional NWS office also provides radar and local weather discussions.
Person checking a weather radar map on a phone next to a weather radioPerson checking a weather radar map on a phone next to a weather radio
Which NWS Office Covers Your Missouri County?
Missouri is served by six NWS offices. Use the official Missouri county warning area map to find the office for your county.
In the northeast, NWS Quad Cities covers parts of the state. In the southern Bootheel, NWS Memphis covers Dunklin and Pemiscot counties. The following four offices serve much of the rest of Missouri.
  • NWS Kansas City/Pleasant Hill (EAX): Covers parts of western and northern Missouri, including the Kansas City metro, St. Joseph, and Randolph County. Check the NWS Kansas City page for updates.
  • NWS St. Louis (LSX): Covers parts of eastern and central Missouri, including St. Louis, Jefferson City, Hannibal, and Columbia in Boone County. Check the NWS St. Louis page for local warnings.
  • NWS Springfield (SGF): Covers southwest, south-central, and central Missouri, including Springfield, Joplin, Branson, and Rolla. Check the NWS Springfield page for county-level alerts.
  • NWS Paducah (PAH): Covers parts of southeast Missouri, including Cape Girardeau, Sikeston, and Poplar Bluff. Check the NWS Paducah page for severe weather bulletins.
Tornado Watch vs. Tornado Warning
Understanding these alerts helps you decide when to prepare and when to take shelter. A watch means conditions favor tornado development. A warning means a tornado has been spotted or indicated by radar. Know the difference between a tornado watch vs a warning before storms start.
Alert
Meaning
What to do
Tornado Watch
Conditions favor tornadoes in and around the watch area.
Charge devices, review your shelter plan, and monitor local weather.
Tornado Warning
A tornado has been reported or indicated by radar.
Go to your designated shelter immediately.
Set Up Multiple Ways to Get Alerts
Tornadoes can happen after dark and outside the usual spring peak. An outdoor siren may not be audible inside. Set up several ways to receive an alert before storms reach your area.
  1. NOAA Weather Radio: Keep a battery-backed weather radio with Specific Area Message Encoding (SAME) programmed to your county FIPS code.
  2. Wireless Emergency Alerts (WEA): Enable emergency alerts and check whether your phone can sound them in Silent mode. For example, supported iPhones have an Always Play Sound setting for Emergency Alerts. Keep an independent alert source such as NOAA Weather Radio.
  3. Local Broadcast Media: Keep a local TV or radio stream handy during a watch so you can track storm paths street by street.
A watch is the time to get power ready, because a warning leaves none.
Keeping a Radio, Phones, and Lights Powered
Set up backup power and pack essentials in advance. Store them at your shelter in a dry, ventilated spot clear of walking routes and potential water entry. Prioritize the weather radio, phones, and lights.
When severe weather knocks out the grid, a charged radio and lights help you stay informed and see where you're going. A 1kWh-class battery power station can cover compatible small loads for a limited time, depending on actual draw. It produces no combustion exhaust.
The EcoFlow DELTA 3 Classic is a 1,024Wh power station. If your planned shelter is indoors, choose a stable, dry, ventilated spot where the unit won't be exposed to water or block the way in. Follow the owner's manual for safe placement and keep the power station ready before warnings are issued.
Top it off before severe weather if you can do so safely. Actual runtime depends on the power your radio, phones, and lights draw.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
How Long Can a 1,024Wh Power Station Run Essential Devices?
Actual runtime depends on the connected devices and their power consumption. Conversion losses also reduce the usable battery capacity.
For planning purposes, assume approximately 870Wh of usable energy. This estimate applies an 85% efficiency factor to the rated capacity.
Use this formula:
Estimated Runtime (hours) = Usable Battery Capacity (Wh) ÷ Total Load (W)
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
Weather radio and two phones charging
About 15W
About 58 hours
Radio, phones, and an LED lantern
About 30W
About 29 hours
The 15W and 30W combined loads are illustrative estimates. Runtime varies with actual power draw, charging patterns, and operating conditions. Use your devices' measured or documented average power when making your own plan.
Pre-Storm Power Checklist
Keep your shelter kit simple and ready to grab when a tornado watch is issued for your county:
  • Charge early, while it is safe to do so. EcoFlow lists roughly 45 minutes from 0% to 80% under its AC test conditions. Set up your shelter supplies before a warning rather than relying on that amount of time.
  • Stage your cords in one bag: Pack charging cables for every family member's phone, plus the power cord for your NOAA weather radio.
  • The 10ms auto-switch can help power equipment that tolerates the transfer. Internet service also depends on power to your modem or optical network terminal and the provider's network staying available. Keep a battery-backed weather radio as another way to receive warnings.
  • Use low-draw LED lighting: Skip candles, which create a fire hazard if debris shifts. Use plug-in LED lanterns or USB string lights instead.
Plan for surviving a tornado with power on for hours after the storm, when downed lines can leave neighborhoods dark for days.
Next, what recent reports show.
Recent Missouri Tornado Reports
NWS damage surveys confirm tornado ratings after the fact. They're history, not current warnings. Always note the date when reading storm summaries online so you do not mistake a past event for an active threat.
When tornadoes hit Missouri, local NWS offices send survey teams to examine tree damage, structural impacts, and debris paths. They use the Enhanced Fujita (EF) scale to estimate wind speeds and assign an official rating.
November 2026 Damage Survey and 2025 Statewide Figures
Looking at verified reports shows why year-round readiness matters across the state:
  • November 3, 2026 (Clark, MO): The November 4 preliminary NWS damage survey reported an EF1 tornado west of Clark in southern Randolph County. It started around 10:42 a.m. CST. The survey estimated peak winds of 90 mph, a path of 1.05 miles, and a maximum width of 50 yards. It reported no injuries or fatalities. The figures were subject to final review.
  • 2025 statewide toll: In a February 23, 2026 release, SEMA cited NWS data showing 16 tornado deaths in Missouri in 2025, the highest toll in the state since the 2011 Joplin tornado. SEMA also reported five federal major disaster declarations in 2025 across hazards.
Separating Storm News from Official NWS Surveys
A news story about utility work can refer to a storm from years earlier. For example, the NWS event summary documents the EF3 tornado that damaged Fredericktown on October 24, 2021. The survey records what happened during the tornado. For later repair schedules or planned outages, check a current notice from the city or utility.
While local news alerts tell you about planned repair outages or recovery town halls, they are not official meteorological surveys. Always check the NWS Public Information Statement (PNS) or Storm Events Database for verified tornado ratings, wind speeds, and paths.
For current restoration information in the Ameren service area, use the official Ameren outage map.
Finally, what to do when a warning hits.
What to Do During a Missouri Tornado Warning
Go to the lowest floor, in an interior room away from windows. Cover your head. Never ride it out in a vehicle if shelter is reachable.
If a tornado warning covers your location, go to shelter immediately. Keep a charged power station, radio, lights, and phone cables there ahead of time. Don't delay sheltering to fetch equipment.
Family sheltering in a basement with blankets and emergency kit during a tornado warningFamily sheltering in a basement with blankets and emergency kit during a tornado warning
Best Shelter Spots by Location
Your safest option depends on where you are when the warning is issued:
  • In a house with a basement: Go underground immediately. Get under a sturdy workbench, heavy table, or staircase, and stay away from heavy appliances on the floor above you.
  • In a home without a basement: Move to a small interior room on the lowest floor, such as a bathroom, closet, or central hallway. Put as many walls between you and the outside as possible.
  • In a mobile or manufactured home: Get out right away. Mobile homes do not offer safe protection against tornado winds. Head to a sturdy nearby building or designated community storm shelter before the storm arrives.
  • In a vehicle: According to the National Weather Service, you are not safe in a vehicle during a tornado. Drive to the closest sturdy shelter if you can safely reach it. If flying debris starts or no shelter is nearby, pull over, get down in your vehicle with your seatbelt on, and cover your head. You can also abandon the vehicle for a low ditch away from trees and power lines, never under a highway overpass.
Protecting Yourself From Flying Debris
Most tornado injuries happen from flying glass and falling debris. Keep these items in your shelter space ahead of time:
  • Bike helmets, batting helmets, or hard hats for everyone in the household.
  • Thick blankets, couch cushions, or a mattress to pull over your body.
  • Sturdy closed-toe shoes so you do not walk across broken glass or nails after the storm passes.
What to Do Right After the Storm Passes
Stay sheltered while the threat remains. Keep monitoring local alerts in case more storms follow. When it is safe to leave, watch for downed power lines, gas leaks, and unstable structures.
  • Call 911 immediately if anyone is injured, trapped, or if you see downed power lines sparking or blocking a road.
  • Stay clear of all downed wires and anything touching them, including puddles, metal fences, and tree branches.
  • Report power outages directly through your electric utility's outage page or automated phone line, such as Ameren Missouri, Evergy, or your local rural electric cooperative, rather than calling 911 just to ask when power will return.
Missouri sees storms beyond spring, as tornado season by region shows, making year-round shelter prep essential.
A Missouri tornado can strike outside the usual spring peak. The preliminary NWS survey near Clark in November 2026 and SEMA's 2025 toll underline the need for a plan. Check alerts for your actual location, go immediately to shelter when warned, and keep your radio, lighting, and backup power ready before the storm.
Is there a tornado warning in Missouri right now?
Use weather.gov to look up your city or ZIP code. Open any active alert and check its mapped area and expiration time. Updates can change quickly. For immediate decisions, rely on live alerts and local instructions.
When is tornado season in Missouri?
Tornado activity generally peaks in spring and early summer. Tornadoes can still occur at other times of year. The preliminary NWS survey near Clark, Missouri, reported an EF1 tornado on November 3, 2026.
What is the difference between a tornado watch and a warning?
A tornado watch means weather conditions are favorable for tornadoes to develop in and around the watch area, so you should review your plan and charge your gear. A tornado warning means a tornado has been reported by spotters or indicated by radar, and you must take shelter immediately.
Where should I shelter in a Missouri tornado?
Go to a basement, storm shelter, or small interior room on the lowest floor. Stay away from windows and exterior walls. Cover your head and neck with suitable protection against flying debris.
Who do I call about outages after a tornado?
Report outages through your electric utility's outage line or website (such as Ameren Missouri, Evergy, or your local electric co-op). Always call 911 immediately for medical emergencies, gas leaks, or downed power lines.
Power Outages
