Washington State Winter Storm Guide: Alerts, Outages, and Keeping Your Heat On
A Washington state winter storm can look very different by county. Western Washington often gets wind and heavy rain in the lowlands with feet of snow on the passes, while eastern Washington sees colder snow and ice. Outages follow wind and heavy snow on trees. And when the power goes out, most furnaces stop too, because the blower and controls need electricity. This guide covers where to check NWS alerts by region, how to prepare, how to plan heating backup with an electrician, and safety during and after the storm.
Washington winter storm alerts by region
Four National Weather Service offices cover Washington. Seattle handles western Washington, while Spokane, Portland, and Pendleton cover the rest. Check your office, plus WSDOT for mountain passes.
Start with the office that matches your county: NWS Seattle, NWS Spokane, NWS Portland, or NWS Pendleton. Each posts watches, warnings, and forecast discussions. For example, the NWS Seattle discussion on Nov. 15, 2026 said a "cold front has moved east of the Cascades," with the next system arriving Tuesday and a dry spell from Wednesday night through Friday. Forecasts shift fast, so always note the time you checked and the office that issued it.
Before any drive over the Cascades, open the WSDOT pass reports. Then bookmark your utility's outage map, such as Seattle City Light, Puget Sound Energy, or Avista, so you can see restoration updates without calling.
The terms matter, too. The NWS explains how it defines winter storm watches, warnings, and advisories. In short, a watch means conditions are possible, a warning means serious conditions are expected, and an advisory means travel and daily life may be disrupted. Lowland storms also raise Washington flash flood risks.
Many Washington homes heat with a furnace or heat pump that stops in an outage. Planning backup for those circuits takes time, so it belongs before storm season.
Keeping heating circuits running in a winter outage
A gas furnace needs power for its blower and controls, and a heat pump needs much more. An electrician can check which heating circuits a home battery can carry and for how long. Gas supply and electric backup heat are counted separately.
This guide covers outages, roads, and heating prep by county first. For homes that rely on fixed heating circuits, a few pre-checks come next. A licensed electrician should check startup load, circuit switching, and expected runtime in advance. Electric auxiliary heat and whole-house electric heat are counted separately, and gas equipment is checked on its own for fuel supply.
When a Washington winter storm cuts power, a gas furnace stops because its blower and controls lose electricity. EcoFlow TITAN 5000, installed with a Smart Home Panel 10 by a licensed electrician, can back up selected heating, lighting, and essential circuits. Grid connection with the Smart Home Panel 10 is No Export, and the electrician confirms which circuits fit.
For a furnace blower, controls, and lights, a 5kWh base covers many hours, and extra batteries extend it.
EcoFlow TITAN 5000
Here are example runtimes, labeled as estimates. They use usable capacity (Wh x 0.85) divided by load (W). Replace the placeholder loads with label figures before relying on them.
Load (example) | Watts used | EcoFlow TITAN 5000 (4,265Wh usable est.) |
Gas furnace blower + controls (example 600W, 50% duty = 300W avg) | about 300W | about 14 hours |
Furnace average + lights + router (example) | about 400W | about 11 hours |
Gas furnaces need electricity, so read up on running a gas furnace without electricity.
Next, the storm-week checklist.
How to prepare for a Washington winter storm
Stock supplies, charge your devices, and refuel before the storm arrives. Bring pets inside. Plan not to drive the passes unless you have to.
The NWS advises refueling heating fuel before the tank runs low. Pack extra medicine, and keep a car survival kit with a phone charger and blankets. If you own a generator, the CDC says never run it inside a home or garage, and keep it more than 20 feet from windows, doors, and vents.
Storm prep beats panic buying. Try preparing for snowstorms without panic buying.
Finally, during and after the storm.
During and after the storm
Stay off roads and away from downed lines. Keep fridge doors shut. Check vents after heavy snow.
The CDC says to keep refrigerator and freezer doors closed during an outage, which helps food stay cold longer. Clear snow from furnace intake and exhaust vents so the equipment can breathe once power returns. If you see a downed line, stay back and call 911.
Home batteries can replace generators for some needs. Compare home batteries for winter storms.
A Washington state winter storm brings different hazards by region, so check your NWS office and WSDOT before and during the storm. Refuel heating fuel, stock supplies, and keep any generator outside, well away from windows, doors, and vents, as the CDC advises. If your furnace or heat pump matters to your plan, think about backup early. An EcoFlow TITAN 5000, installed with a Smart Home Panel 10 by a licensed electrician, can carry verified circuits.
Where do I check Washington winter storm warnings?
Check NWS Seattle for western Washington and NWS Spokane for the east. NWS Portland and Pendleton cover southern areas. Open your region's office page for watches, warnings, and advisories.
Does a gas furnace work in a power outage?
The usual answer is no. A gas furnace needs electricity for its blower and controls, so it stops when the power goes out even if gas is still flowing. Check your model's manual.
How do I check Snoqualmie Pass conditions?
Use the WSDOT pass reports before you drive. They list current conditions, closures, and traction requirements for Snoqualmie Pass and other routes. Check again before leaving, because conditions change.
Can a home battery run my heat pump?
It can back up a verified circuit for a limited time. Heat pumps draw much more than furnace blowers, so an electrician should size the load, including electric backup heat.
What should I do about downed lines?
Stay far away and treat every downed line as live. Call 911, and keep children and pets back. Do not touch anything the line is touching, including vehicles or fences.
