Regular vs. LED Christmas Lights: Which Uses Less Electricity?
It’s that time of year where you see many households with Christmas light displays on for several hours a night for weeks. The type of light bulbs used, incandescent or LED, makes a big difference in how much power is used. LEDs typically use about 75% to 90% less electricity. In this guide, you’ll get exact wattage comparisons and real-world cost breakdowns based on typical electricity rates. This guide also gives you practical ways to lower your holiday energy use, including running your display off of solar-charged battery storage.
How Much Electricity Do Regular and LED Christmas Lights Use?
The wattage of one light strand may be small, but connecting multiple strands increases the total load. When comparing incandescent Christmas lights vs. LED, use the wattage printed on each set’s label.
Wattage Comparison: Incandescent vs. LED Christmas Lights
Standard incandescent mini lights draw roughly 40 to 50 watts per 100-bulb strand. The larger C7 and C9 glass bulbs can pull anywhere from 5 to 7 watts per individual bulb. An equivalent 100-bulb strand of LED mini lights typically uses only 4.8 to 7 watts total. If you power the display with a solar generator, lower-wattage LED strings reduce the load it needs to supply.
Light Type and Configuration
Typical Wattage
Energy Used Over 5 Hours
Equivalent LED Savings
Incandescent Mini Lights
40W – 50W
0.20 – 0.25 kWh
Baseline
LED Mini Lights
4.8W – 7W
0.024 – 0.035 kWh
~85% – 88% less power
Incandescent C9 Bulbs (25 count)
175W
0.875 kWh
Baseline
LED C9 Bulbs (25 count)
20W – 24W
0.10 – 0.12 kWh
~86% – 88% less power
LEDs draw very little current and most brands allow you to safely connect 20 to 30 LED strands, end-to-end on a single outlet. Commercial-grade LED sets may allow 40 or more strands to be connected end to end. Traditional incandescent bulb strands typically have a strict limit of 3 strands connected together before blowing the plug’s built-in fuse.
Why LED Christmas Lights Use Less Electricity
Traditional incandescent bulbs produce light by heating a tiny wire filament until it glows. This technology wastes nearly 90% of the electricity as heat. That is why incandescent glass bulbs feel warm to the touch after just a few minutes. LEDs (light-emitting diodes), on the other hand, pass an electrical current through a semiconductor microchip to create light directly. This method generates almost zero heat and converts far more electricity directly into light.
What Factors Affect Christmas Light Electricity Usage?
The type of bulb you use matters greatly, but it isn’t the only thing that affects your bill. Other factors are how many lights you use and how long the display is on each night.
Total Number of Bulbs and Light Strings
A modest display might include three strands on an indoor tree and two around the front porch. For LED vs. regular Christmas tree lights, compare sets with similar bulb counts and brightness. The cost depends on their total wattage, operating hours, and your electricity rate. Larger displays may also include roofline lights, illuminated trees, and inflatable decorations. As an illustrative load, an 800- to 1,200-watt display uses 0.8 to 1.2 kWh for each hour it runs.
Daily Operating Hours and Seasonal Display Duration
Assuming a 40-day holiday season, running the lights from 5:00 PM to 11:00 PM adds up to 240 operating hours. If the same display is on all day, 24/7, it quadruples your runtime to nearly 960 hours. In this case, the added electricity use is more than a minor seasonal bump; it could cause a noticeable increase in your January utility bill.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
How Much Does It Cost to Run Christmas Lights?
Once you know the total wattage and how long they’re on, you can estimate the cost. The examples below use a U.S. average residential rate of about $0.17 per kilowatt-hour (kWh). Of course, your bill will vary with your local rate and the number of lights.
Average Daily Cost of Running LED vs. Incandescent Christmas Lights
Suppose you decorate your home with 10 strands of lights (1,000 bulbs total) and leave them on for 6 hours every evening:
  • 10 Incandescent Mini Strands (400W total): Running for 6 hours consumes 2.4 kWh per day, costing about $0.41 per day.
  • 10 LED Mini Strands (60W total): Running for 6 hours consumes just 0.36 kWh per day, costing roughly $0.06 per day.
For outdoor LED Christmas lights, use the set’s rated wattage to estimate running costs. In this example, 100 C9 bulbs draw 700W for incandescent lights or 80W–96W for LEDs. At $0.17/kWh over six hours, that costs about $0.71 per evening for incandescent lights and $0.08–$0.10 for LEDs.
Total Christmas Season Electricity Costs
Over a 40-day holiday season at six hours per evening and $0.17/kWh, the 1,000-bulb example costs $16.32 with 400W of incandescent strands and $2.45 with 60W of LEDs. The cost to run Christmas lights changes with display size, operating hours, and the equipment used.
How Local Electricity Rates Affect Christmas Light Costs
What you pay per kilowatt-hour depends on where you live. Homeowners in states with lower utility rates like Washington, North Dakota, or Louisiana (around $0.11–$0.13/kWh) pay less than the average per kWh. Families in California, Hawaii, or New England have higher residential electricity rates that often range from $0.28 to over $0.40/kWh.
EcoFlow DELTA 3 Max Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Portable Power Station (2048Wh)
Can Solar Power Reduce the Cost of Running Christmas Lights?
A solar generator combines compatible solar panels with battery storage for use after sunset. This can reduce grid electricity use when solar charging supplies enough energy, but equipment costs and available sunlight determine whether it saves money overall.
Estimate Solar Power Needs for Christmas Lights
To calculate power needs for a device setup, multiply each light set’s wattage by its planned operating hours, then add the results. Five LED strands drawing 30 watts total over five hours need 150 watt-hours (Wh) per evening. Allow for inverter losses, the power station’s own consumption, and the battery’s actual remaining charge. Cloudy weather can reduce solar replenishment, so a fixed percentage buffer cannot guarantee overnight operation.
Power Christmas Lights with Solar-Charged Battery Storage
A small LED display may need only a modest amount of stored energy each evening. Compatible solar panels can charge a portable power station during the day for use with lights at night. The EcoFlow DELTA 3 Classic Portable Power Station has a 1,024Wh battery for low-wattage loads. Actual runtime depends on total load, remaining charge, and system losses. After the decorations are put away, it can also supply compatible devices during utility outages.
1. 4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 2. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and air conditioners. 3. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly.
Run More Christmas Lights with Higher-Capacity Battery Storage
A larger display may need more stored energy, especially if you’re lighting several areas. A higher-capacity battery means you may also be able to run lights longer between charges.
The EcoFlow DELTA 3 Max Portable Power Station has a 2,048Wh battery, double the nominal capacity of the DELTA 3 Classic. It can supply compatible lighting loads and a small speaker within its output limits. Before adding a hot cocoa station or other heating equipment, check its wattage, the combined simultaneous load, and the required runtime. Compatible solar panels can replenish energy during the day when sunlight permits.
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product.
How Can You Manage Christmas Light Electricity Use?
Even energy-efficient LEDs waste money if they stay on while everyone is asleep. Use timers to automatically turn lights on and off. They’re quick to set up, save you money, and simplify your holidays. When Christmas lights run from a portable power station, scheduled shutoff also helps conserve stored energy.
Use Timers to Limit Christmas Light Operating Hours
Mechanical or photocell countdown timers are an inexpensive, plug-and-play solution which you can find at any hardware store. Dusk-to-dawn countdown timers automatically sense when the sun goes down and turn on your lights. After a preset number of hours, such as 4, 6, or 8 hours, they turn the lights off. A standard mechanical timer lets you dial in exact on/off hours so your lights are on only when you want them.
Use Smart Plugs to Schedule and Control Christmas Lights
Outdoor-rated Wi-Fi smart plugs give you full control right from your phone or smart home system. Smart plugs let you set custom weekday and weekend lighting schedules. Many smart plugs also include built-in energy monitoring that tracks exact kWh usage in real time, letting you see precisely how much your holiday display costs.
LED Christmas lights use far less electricity than incandescent strands, and the savings grow with larger displays and longer run times. Timers and smart plugs let you turn on and off lights automatically so you don’t waste energy. You can use solar-charged battery storage to power smaller displays and avoid adding to your winter’s utility bill. Together, these choices make it easier to enjoy the holiday lights while keeping energy use in check.
What Is the Main Disadvantage of LED Lights?
The biggest drawback of LED Christmas lights is their higher upfront purchase price, which typically runs $3 to $8 more per strand than basic incandescent lights. Early LED models also produced a harsh, bluish-white glare, though modern “warm white” LEDs now closely mimic the cozy glow of traditional glass bulbs.
Is There a Difference Between Cheap and Expensive LED Lights?
Yes—higher-end commercial-grade LEDs use full-wave rectifiers to eliminate noticeable flickering, feature sealed one-piece bulb construction that keeps moisture out, and last 5 to 10+ seasons. Bargain-bin LED strands often use half-wave circuitry that creates a subtle strobe effect and allows water to corrode internal wiring after just one wet winter.
How Common Are Christmas Light Fires?
Christmas light fires are relatively rare, though U.S. fire departments respond to an average of roughly 160 to 200 home fires per year started by Christmas trees and holiday lighting, according to the National Fire Protection Association (NFPA). Most incidents happen when homeowners overload extension cords, use indoor-rated incandescent strands outdoors, or leave high-heat bulbs resting against dry pine needles.
Should You Leave Christmas Lights on All Night Outside?
No, you shouldn’t leave outdoor Christmas lights running all night. Turning them off before bed saves unnecessary electricity, prevents neighborhood light pollution, reduces wear on wiring and transformers, and lowers the risk of electrical shorts during overnight rain, frost, or snow.
Save Bills
