Compare Electric Rates in PA: How to Evaluate Plans and Lower Your Bill
A January cold snap in Pittsburgh or a humid July in Philadelphia can push up your electricity use and your bill. Pennsylvania’s deregulated market lets you choose who supplies your power, so you can compare competing rates with your utility’s Price to Compare (PTC). A little attention to the plan terms, plus a few changes at home, can help keep costs manageable.
How Is the Pennsylvania Electricity Market Structured?
Pennsylvania separates electricity supply from delivery. You can pick your supplier, while your local utility still maintains the lines and delivers power to your home.
Electricity Generation and Supply
Power comes from natural gas and nuclear plants, wind farms, solar installations, and other sources feeding the regional electricity grid. Retail suppliers buy it on the wholesale market and resell it to homes and businesses. The supply charge on your bill, listed in cents per kilowatt-hour (kWh), is the part you can compare across suppliers. Understanding your electricity cost per kWh starts with separating the supply rate from delivery charges and other fees.
Electricity Transmission and Distribution
Your Electric Distribution Company (EDC) handles delivery and maintains the poles, wires, transformers, and meters. Depending on where you live in Pennsylvania, that means PECO, PPL Electric Utilities, Duquesne Light, Met-Ed, Penelec, Penn Power, or West Penn Power. Those delivery charges are regulated, so switching suppliers doesn’t affect them.
Retail Electricity Competition and Consumer Choice
Under Pennsylvania’s Electricity Generation Customer Choice and Competition Act, residential customers can choose their electricity supplier. If you do not choose a supplier, your utility supplies the power at its Price to Compare (PTC). PAPowerSwitch, the state’s official comparison portal, lets you weigh that rate against offers from licensed suppliers.
How Do You Compare Electricity Plans in Pennsylvania?
The lowest advertised rate doesn’t always mean the lowest bill. Along with the rate type and contract length, look closely at any fees and what happens when the introductory offer ends. Finding the best electric supplier rates in PA means comparing the full plan cost at your expected usage, not just the advertised cents per kWh.
Fixed-Rate vs. Variable-Rate Electricity Plans
The choice often comes down to steady pricing or flexibility.
Plan Feature | Fixed-Rate Plan | Variable-Rate Plan |
Price per kWh | No per-kWh price change during the contract | Monthly price can move with market conditions |
Budget Predictability | More predictable; usage still affects the bill | Less predictable; high demand can push rates up |
Contract Length | Often 6, 12, 24, or 36 months | Usually month-to-month |
Early Termination Fee | Possible, but not charged by every plan | Usually no long-term commitment |
Best For | People who want predictable pricing | People who may move or want flexibility |
Note: A fixed supply rate does not fix your total bill; usage, delivery charges, and disclosed fees still matter.
Compare Contract Lengths and Post-Promotion Rates
To answer “what are the best electric rates in PA,” compare each offer over the full contract term rather than only the promotional period. Some low advertised rates expire after only a few billing cycles, after which the supplier’s ongoing fixed or variable rate applies as described in the disclosure statement. Check the contract term and disclosure statement to see when the introductory rate ends and what you’ll pay next. Suppliers must send written renewal notices before the contract expires, so weigh those terms against other offers before the new rate kicks in.
Check for Hidden Fees and Early Termination Charges
Pull up the supplier’s Electric Generation Supplier (EGS) Disclosure Statement before you sign up and check for three common add-ons:
Monthly service charge: Expect a flat fee on every bill with some plans, often running $4.95 to $14.95.
Early cancellation charge: If you move or switch out before your term is up, the supplier can hit you with a penalty.
Monthly usage minimum: Use less than a set amount in a given month—say, 500 kWh—and certain plans tack on an extra fee.
Compare Renewable Energy Plans and Additional Benefits
With a green energy plan, your usage is typically matched with Renewable Energy Certificates (RECs) from wind or solar farms. Suppliers may also include perks such as smart thermostats or free weekend hours. Compare the full cost, though, because a perk won’t always make up for a higher per-kWh rate.
How Can You Switch Electricity Suppliers in PA?
Most switches happen online, with no home visit and no changes to your equipment. Check your current rate, compare what’s available, and enroll with the supplier you want.
Check Your Current Electricity Rate and Utility Provider
Review a recent bill and find the “Generation Supply Charges” section, which lists your current rate and the utility’s Price to Compare (PTC). For homes with a solar battery, use metered grid purchases rather than total household consumption when estimating supplier charges.
Utilities typically update their PTC periodically, often once or twice a year. Common adjustment dates include June 1 and December 1, while some utilities may also make changes around March 1 or September 1. Check when your utility last updated its rate and review your monthly electricity usage in kWh to estimate how the rate difference could affect your bill. The best electric rate in PA for your household depends on your service area, usage, and total plan costs.
Choose a Licensed Electricity Supplier
Go to PAPowerSwitch.com, enter your ZIP code and select your utility. Compare the offers by rate type, monthly fees, and cancellation terms, then check that the supplier is licensed by the PA PUC and read the plan disclosure before enrolling.
Complete the Enrollment and Switching Process
When you enroll online, have your utility account number ready and enter it along with your name and service address. The supplier coordinates the switch with your utility, and the new rate usually appears on your regular bill within one or two billing periods.
How Can You Lower Your Electricity Bills in Pennsylvania?
Once you have compared supply rates, focus on how your household uses electricity. A portable power station changes when electricity is purchased or used; efficiency measures reduce the amount your appliances need.
Start with routine adjustments to heating, cooling, and appliance use. These help you assess your remaining electricity needs before deciding whether storage equipment offers enough value for your household.
Adjust Your Thermostat to Reduce Seasonal Energy Costs
Your heating and cooling system is responsible for much of your home’s energy use. For suitable heating systems, lowering thermostat settings by 7°F to 10°F for eight hours while you sleep or are away can reduce energy use. If you have a heat pump, use a thermostat and control strategy designed for that system rather than applying this setback automatically. In summer, raise the setting within a comfortable range while accounting for indoor humidity, and turn it up when you leave as conditions allow.
Shift Electricity Use Away from Peak-Pricing Periods
Utilities see peak demand and the highest wholesale costs roughly between 5:00 PM and 9:00 PM on weekdays, as people get home from work to cook dinner and run appliances into the evening. On a time-of-use plan, you can lower your bill by running the dishwasher, drying clothes, or charging your EV late at night or early in the morning.
For Pennsylvania households looking to cut peak-hour grid purchases even further, portable energy storage offers a flexible way to manage daily power use alongside off-peak appliance scheduling. The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) supports both wall-outlet and solar charging: families can top up the battery when electricity rates are lower, or use compatible portable solar panels in a suitable location that meets sunlight, site, and equipment requirements. During the higher-priced periods specified in your contract, stored power can run directly connected compatible everyday appliances instead of drawing from the grid. Because this plug-and-play use requires no modifications to the home’s electrical panel, the unit is a portable option renters in apartments or townhouses can consider. Any bill savings depend on the rate difference, charging and discharging losses, and equipment costs.
Consider Energy-Efficient Upgrades to Reduce Long-Term Costs
When deciding how to minimize your electricity bill, start with everyday sources of wasted energy: incandescent bulbs, window drafts, and an uninsulated electric water heater. ENERGY STAR LED replacements, draft sealing, and water-heater insulation address those losses; an ENERGY STAR certified appliance can also reduce daily consumption when an older model needs replacing.
Use Solar Energy to Reduce Long-Term Electricity Costs
Rooftop solar lets your household meet part of its electricity demand directly instead of purchasing that power from the utility. Pennsylvania homeowners who qualify for net metering may earn bill credits when their solar panels send surplus electricity back to the grid. Credit values and installation details vary by utility and the rules that apply, so check current terms before you estimate savings.
A home battery lets you use more of what your panels produce during the day. Instead of sending all excess electricity to the grid, you can store some for evening or overnight use. For homeowners with a compatible rooftop solar system, the EcoFlow TITAN 5000 Plus can be added to a residential storage setup. It lets you store surplus daytime power without removing or rebuilding your existing rooftop array.
Start with your bill: compare your current supply rate with the latest offers on PAPowerSwitch, and check fees and renewal terms before committing to a plan. Then look at how your household uses electricity. The right rate, a few changes to your routine, and, where it makes sense, solar or battery storage can make your monthly bill easier to manage.
Does Switching Electricity Suppliers in Pennsylvania Interrupt My Service?
No. Your local utility keeps delivering electricity and handling outages, so you can switch suppliers without a technician visit or a service interruption.
How Much Can a Pennsylvania Household Save by Switching Suppliers?
Look at the offers in your utility’s service area and estimate potential savings based on your monthly usage, then check each plan’s fees and contract terms. Households using around 1,000 kWh or more per month may see meaningful savings if they find a rate that’s roughly 1¢ to 2¢ lower per kWh, depending on any additional fees.
Should I Wait for Electricity Rates to Drop Before Switching?
If you find a fixed-rate plan below your utility’s PTC, check its fees and cancellation terms first. A plan with no early termination fee leaves you free to switch again if a better offer comes along.
Are Solar Batteries Worth It for PA Homes?
As a PA homeowner, you might consider a solar battery for two reasons: backup power during an outage or the chance to use more of your own solar electricity after sunset. The battery price has to be weighed against your electricity rates, solar output, and how often you would use the stored energy.
What Is the Average Monthly Electricity Bill in Pennsylvania?
One recent estimate puts the average total bill at around $183 per month, based on a combined supply-and-delivery rate near 21.77¢ per kWh and monthly use around 839 kWh. That figure reflects the all-in retail rate, not the supply-only Price to Compare, and your own bill will vary with your utility, household usage, and the season.
