Radiant Floor Heating Installation: How Electric and Hydronic Systems Go In
Radiant floor heating installation looks different depending on the system. Electric radiant floors use heating cables or mats under tile or other approved flooring and can suit individual-room projects. Hydronic systems run warm water through tubing from a compatible boiler or other heat source and can serve a whole home when appropriately designed. This guide covers both types, manufacturer installation guidance, floor coverings, professional electrical and plumbing work, and the loads a hydronic system needs during an outage.
Electric vs hydronic radiant floor heating
Electric systems use cables or mats. Hydronic systems pump warm water through tubing. The installation methods are similar, but the equipment differs.
Warmup's electric-floor installation guide shows heating cable secured over a prepared subfloor and embedded in thinset or self-leveling material before the approved floor finish. Uponor's radiant floor heating handbook describes hydronic tubing installed in slabs, thin pours, or underfloor assemblies, with a heat source, manifolds, pumps, and controls. The appropriate system depends on the building's heat load, construction, floor covering, and installation design.
Electric (mats or cables)
Hydronic (tubing)
Best for
Single rooms, remodels
Whole-house heat
Heat source
Electric resistance
Boiler, water heater, or heat pump
Needs
Dedicated circuit, thermostat
Heat source, pumps, manifold, controls
Who installs
Electrician (and flooring pro)
HVAC/plumbing pro plus electrician
Radiant floors use electricity differently depending on the type, so it helps to estimate radiant floor heating electricity use before you pick a system.
Hydronic floors also depend on circulating pumps and controls. In an outage, those stop, and so does the heat.
Keeping a hydronic system running in an outage
A hydronic system’s circulator pumps and controls need power, and so may its heat source. An installer can check which of those circuits a home battery can carry. Running the pumps alone doesn’t make heat if the boiler or heat pump is also down.
For a hydronic radiant system, EcoFlow TITAN 5000 can back up selected circulator pump and control circuits through a Smart Home Panel 10 installed by a licensed electrician. The heat source’s own power needs are checked separately, whether that’s boiler controls, a heat pump, or electric heat. With the panel, grid connection is No Export.
Circulator pumps and controls draw modest power, so a 5kWh base can cover many hours, as long as the heat source also has what it needs. Use the estimates below as a starting point, then swap in the label figures from your own equipment.
EcoFlow TITAN 5000
EcoFlow TITAN 5000
Runtime estimates (estimates only)
Load (example)
Watts used
EcoFlow TITAN 5000 (4,265Wh usable est.)
Two circulator pumps + controls (example 150W)
about 150W
about 28 hours
Pumps + gas boiler controls and inducer (example 300W)
about 300W
about 14 hours
Method: the examples assume a full 5,017.6Wh battery, an 85% usable-energy allowance (about 4,265Wh), and continuous loads of 150W or 300W. Dividing assumed usable watt-hours by watts gives about 28 or 14 hours, rounded down. These are illustrative calculations, not measured runtimes or equipment ratings. Actual efficiency, standby use, cycling, and other loads change the result. Include the heat source's required electrical loads before relying on a backup plan.
Domestic hot-water efficiency is a separate question from hydronic space-heating compatibility. A standard heat pump water heater is not automatically suitable as a floor-heating heat source. Have the installer verify the manufacturer-approved application, system connections, and electrical loads. For background on domestic hot-water energy costs, see heat pump water heater savings.
Back to installation: the steps.
How to install radiant floor heating: the steps
Plan zones and heat load first. Prepare the subfloor. Then install, test, and cover.
Both approaches need planning, a suitable floor assembly, and testing before the work is covered. Their electrical connections, tubing, and controls differ, so follow the instructions for the specific system.
Electric
  1. Check the circuit and thermostat.
  2. Lay the mat or cable per the layout.
  3. Test resistance before and after installation.
  4. Embed it in thinset or self-leveler.
  5. Finish with tile or approved flooring.
Hydronic
  1. Run a heat-load calculation.
  2. Insulate below the floor.
  3. Place tubing in a slab, thin pour, or plates under the subfloor.
  4. Connect the manifold, pumps, and controls.
  5. Pressure test before covering.
Electric heat is costly to run in some areas, so compare electric garage heater costs for context.
Finally, flooring choices.
How to install radiant floor heating: the stepsHow to install radiant floor heating: the steps
Best floor coverings for radiant heat
Tile and stone work best. Some wood and vinyl products are rated for radiant heat. Check the flooring maker’s limits.
Follow the flooring maker’s maximum surface temperature. Thick carpet and pads reduce output. Permits and inspections may be required for new circuits or boilers.
Winter efficiency starts at home. Pair heating upgrades with winterizing your home for safety.
Radiant floor heating installation depends on the system and the building. Electric mats or cables can suit single-room projects, while hydronic tubing distributes heat from a compatible heat source through a system of pumps and controls. Plan the heat load and zones, test before covering the work, and use flooring approved for the chosen system.
If staying warm during an outage matters, plan for it early. An EcoFlow TITAN 5000 can back up verified hydronic circulator pump and control circuits through a Smart Home Panel 10, installed by a licensed electrician. Your installer should also check what the boiler, heat pump, or electric heat needs, since pumps alone don’t make heat. Start with a circuit list, add up the watts, and decide how many hours of backup you want.
How is radiant floor heating installed?
Electric mats or cables are set in thinset under tile, while hydronic tubing goes into a concrete slab, a thin pour, or plates under the subfloor, then gets pressure tested.
Is electric or hydronic radiant heat better?
Neither is the best choice for every home. Electric mats or cables can suit individual-room projects such as a bathroom remodel. A hydronic design can distribute heat through multiple zones but also needs a compatible heat source, pumps, and controls. Compare the building's heat load, local energy costs, floor assembly, and installation requirements.
Can I install radiant floor heat myself?
Electric mats can be partly DIY-friendly, such as laying the mat, but new circuits need a licensed electrician. Hydronic systems involve boilers, tubing, and pressure testing, so hire a professional.
Does radiant floor heat work in a power outage?
Not without power. Hydronic floors need electricity for circulator pumps, controls, and often the heat source, while electric floors stop heating entirely. Backup must be sized for those loads.
What flooring works with radiant heat?
Tile and stone conduct heat best. Some engineered wood and vinyl products are rated for radiant heat, so check the flooring maker’s maximum surface temperature and installation rules first.
Home Solutions
