Mobile Home Heat Tape: How to Install It Safely and Keep Pipes From Freezing
Water lines under a mobile home are exposed to cold air, making them more vulnerable to freezing during winter. That's why many homeowners use mobile home heat tape to protect their plumbing when temperatures drop. When installed correctly, it helps keep water moving through exposed pipes. However, improper installation, damaged wiring, or outdated equipment can create a serious fire hazard. The U.S. Consumer Product Safety Commission (CPSC) has repeatedly warned about these risks. This guide explains how heat tape works, how to install it safely, when to replace it, and how to prepare for winter power outages.
How Mobile Home Heat Tape Works
Heat tape is an electrical heating cable that runs along a water pipe. On thermostatically controlled models, the thermostat switches the cable on as temperatures fall. A self-regulating cable changes its heat output with temperature and may operate without a separate thermostat. It plugs into a grounded, GFCI-protected outlet to provide additional electrical protection. Heat tape is particularly useful beneath mobile homes because plumbing often runs through exposed spaces where cold air can reach the pipes. However, not every heating cable is suitable for every pipe or installation.
Understanding Different Types of Heat Tape
Heat tape comes in different types, each designed to protect pipes from freezing in cold weather. The two most common options are self-regulating and constant-wattage heat tape, which differ in how they produce and control heat. Understanding how each type works can help you choose the right option for your mobile home's plumbing system.
  • Self-regulating heat tape: Adjusts its heat output according to the surrounding temperature. It generally produces more heat in colder conditions and less as temperatures rise.
  • Constant-wattage heat tape: Produces a relatively consistent amount of heat along its length when powered. It relies on its thermostat and correct installation to control operation.
Why Heat Tape Safety Matters
Heat tape can help protect plumbing from freezing, but it must be installed and used carefully rather than treated like an ordinary extension cord or heating wire. Along with taking steps to prevent frozen pipes during winter, homeowners should understand the potential fire and electrical risks. According to an October 18, 1990, CPSC release, heat tape was involved in an estimated 3,300 residential fires annually, with more than half involving mobile homes and trailers. The CPSC reissued its safety guidelines in January 1996, emphasizing several precautions:
  • Use a three-prong plug and connect the heat tape to a properly grounded electrical outlet.
  • Plug heat tape into a GFCI-protected outlet to reduce the risk of electric shock.
  • Never overlap heat tape unless the manufacturer explicitly allows it, as overlapping can cause excessive heat buildup.
  • Keep the end cap securely sealed and positioned away from the ground to prevent moisture from entering.
If the Power Goes Out: Keeping Heat Tape On
A portable power station can run a short, low-wattage, listed heat tape for a limited period. However, runtime depends on the tape's length, rated wattage, thermostat cycling, battery capacity, and conversion losses. Before considering a backup battery, check that your heat tape is compatible with the power station and that its grounding and GFCI protection requirements can be maintained. Never bypass electrical safety features to make a connection work.
Choosing a Portable Power Station for Heat Tape
For existing compliant heat tape, a portable power station can provide temporary electricity during an outage. Keep the power station indoors in a dry, well-ventilated location, away from moisture and the exposed plumbing underneath the home. Plan ahead for surviving a winter storm power outage, particularly if freezing temperatures are expected to continue after the battery runs out.
In a winter outage, heat tape stops when the power does. An EcoFlow portable power station kept dry indoors can run a compatible, listed plug-in heat tape through an appropriate GFCI-protected connection for a limited time. On the DELTA 3 Classic or DELTA 3 Max, check the AC timeout: a thermostat can disconnect the load long enough for AC output to shut down. If continuous AC availability is required, follow the model’s manual to set AC timeout to Never, verify GFCI protection, and monitor remaining charge. The actual runtime depends on the tape's wattage, length, thermostat activity, and usable battery capacity.
EcoFlow DELTA 3 Classic (1024Wh)
For a short run of low-wattage heat tape, a 1kWh-class power station can provide temporary backup. The EcoFlow DELTA 3 Classic offers 1,024Wh of capacity and 1,800W of AC output, making it an option to consider after checking the tape's electrical requirements.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Max (2048Wh)
If your measured heat tape consumption requires more energy overnight, a larger battery may be worth considering. The EcoFlow DELTA 3 Max offers 2,048Wh of capacity, providing approximately twice the stored energy of the EcoFlow DELTA 3 Classic.
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
Estimated Heat Tape Runtime
The following examples show how battery capacity and average power consumption affect estimated runtime.
Example heat tape load
Average consumption
EcoFlow DELTA 3 Max
15 ft at 6W/ft, 50% duty cycle
45W
19 hours
39 hours
30 ft at 6W/ft, 50% duty cycle
90W
9.7 hours
19 hours
Calculate your expected average load using:
Average watts = Watts per foot × Cable length × Duty cycle
Estimated runtime = Usable battery Wh ÷ Average watts
For these thermostat-controlled examples, assume 6 W per foot, a 50% duty cycle and 85% usable capacity: about 870 Wh for the Classic and 1,741 Wh for the Max. Divide those watt-hours by 45 W or 90 W. For self-regulating cable, use measured energy consumption at the expected temperature. Use the actual heat tape label and measured thermostat behavior when calculating your needs. Real-world results also depend on operating conditions and system losses. The EcoFlow DELTA 3 Classic is better suited to a shorter, lower-wattage backup requirement, while the EcoFlow DELTA 3 Max offers more stored energy when measured consumption indicates a longer overnight need. Neither guarantees continuous freeze protection during severe or extended cold weather.
How to Install Heat Tape Under a Mobile Home
Installing heat tape under a mobile home requires careful attention to pipe material, cable length, electrical connections, and manufacturer instructions. Choosing the right product is just as important as installing it correctly. If you are unsure about the plumbing or electrical setup, ask a qualified professional to inspect it before installation.
How to Install Heat Tape Under a Mobile HomeHow to Install Heat Tape Under a Mobile Home
Step 1: Check Your Pipes and Installation Requirements
Start by identifying the water pipe material, diameter, and total length that needs protection. Check the mobile home's HUD data plate, manufacturer's documentation, and community or park rules. Choose heat tape specifically listed for the pipe material and approved for use with manufactured homes. Do not assume that a cable designed for ordinary household plumbing is suitable for mobile home installation.
Step 2: Select the Correct Heat Tape
Purchase a certified product that matches the pipe length and diameter. Check whether it includes a thermostat, what temperature range it supports, and whether it can be installed on your particular plumbing material. Look for recognized certification markings, such as UL or CSA, and read the complete installation instructions.
Step 3: Apply Heat Tape Directly to the Pipe
Clean and dry the pipe surface before installation. Position the heating cable directly against the pipe according to the manufacturer's recommended spacing and attachment method. The CPSC specifically advises against wrapping heat tape over itself unless the instructions permit it. Never install it on top of existing pipe insulation.
Step 4: Add Insulation Only When Permitted
After securing the cable, check whether the manufacturer allows additional insulation. If permitted, use a nonflammable material such as fiberglass and follow the recommended thickness. Avoid foam or vinyl insulation over heat tape unless the product's instructions explicitly establish that the material is suitable. Incorrect insulation can trap excessive heat and increase fire risk.
Step 5: Check the Electrical Connection
Use a properly grounded three-prong outlet and maintain GFCI protection as recommended by the CPSC. Keep the plug and end cap protected from moisture, and make sure the electrical connection is not resting on the ground. If a suitable outlet is unavailable, have a qualified electrician assess the installation. Do not use an improvised extension cord or modify the plug. Pair heat tape with winterizing your home for safety to protect other vulnerable areas before temperatures fall.
How Long Does Heat Tape Last? Inspection and Replacement
There isn't one guaranteed lifespan for every mobile home heat tape product. Its service life depends on product quality, installation, operating conditions, and maintenance. The CPSC recommends replacing uncertified heat tapes more than three years old with products certified to recognized voluntary safety standards, such as UL or CSA. Damaged or deteriorated cables should be replaced immediately, regardless of age.
Inspecting heat tape and plumbing before winterInspecting heat tape and plumbing before winter
What to Check During Your Annual Inspection
Inspect your mobile home's pipe heat tape every fall before temperatures begin to drop. Always disconnect the power before examining the cable and its connections. If you are unsure how to do this safely, ask a qualified electrician to help.
  • Cable insulation: Look for cracks, cuts, breaks, or exposed wires that could indicate damage or create an electrical hazard.
  • Plug and connections: Check for discoloration, burn marks, loose connections, or other visible signs of damage.
  • End cap: Make sure the end cap is securely sealed and positioned correctly to prevent moisture from entering.
  • Thermostat: Check its placement and physical condition, and confirm that it follows the manufacturer's installation instructions.
  • Pipe insulation: Look for dampness, tears, gaps, or incorrectly installed insulation that could reduce its effectiveness.
  • GFCI protection: Test the GFCI using its test and reset buttons according to the device manufacturer's instructions.
When Should You Replace Heat Tape?
Replace heat tape immediately if you notice cracked insulation, exposed wires, burn marks, discoloration, a burning smell, or damaged plugs and connections. A missing end cap or an uncertified product that is more than three years old also calls for replacement. Since electrical protection is essential when using heat tape, understanding how GFCI outlets help protect outdoor electrical connections is also important. Never repair damaged heat tape with ordinary electrical tape; replace the entire cable with a suitable certified product.
Heat tape can help prevent mobile home pipes from freezing when it is properly listed, grounded, GFCI-protected, and installed according to the manufacturer's instructions. However, electrical safety is essential, especially since CPSC data shows that more than half of the reported heat tape fires involved mobile homes and trailers. Inspect your system every fall and replace damaged or outdated tape. For short outages, the EcoFlow DELTA 3 Classic or EcoFlow DELTA 3 Max may provide temporary power for compatible heat tape within their output limits.
How long does heat tape last on a mobile home?
Heat tape lifespan varies by product and operating conditions. The CPSC recommends replacing uncertified heat tape more than three years old and replacing any damaged cable immediately.
Should heat tape be plugged into a GFCI?
Yes. The CPSC recommends GFCI protection wherever heat tape is plugged in. Use a properly grounded three-prong outlet and have an electrician verify the installation's compliance with applicable manufactured-home requirements.
Can I put insulation over heat tape?
Only when the manufacturer's instructions allow it. Use nonflammable insulation, such as fiberglass, and follow the specified installation requirements. Avoid unsuitable foam or vinyl insulation.
Can heat tape overlap?
Not unless the manufacturer's instructions specifically permit it. Overlapping or wrapping heat tape over itself can cause excessive heat buildup and increase fire risk.
Can a power station run heat tape?
Yes, a compatible power station can operate short, low-wattage, listed heat tape for a limited period. Runtime depends on battery capacity, cable wattage, thermostat cycling, and power losses. It cannot guarantee freeze protection during prolonged freezing conditions.
Home Solutions
