What Do Generators Run On? Fuel Types and What Gas to Use
What do generators run on? Most home and portable units use gasoline, propane, natural gas, or diesel, and dual-fuel models switch between two. The nameplate and manual list the exact fuel for each engine. Fuel choice affects runtime, storage, cost, and what a household can keep on hand before a storm. This article covers which gasoline to buy (and which to avoid, per EPA), how each fuel stores, safe refueling rules, and how to keep a router and lights on while the engine is off.
What Do Generators Run On? The Main Fuel Types
The nameplate and manual show which fuels an engine accepts. Many portable units run on gasoline. Dual-fuel models add propane, and standby units often use natural gas or propane.
The main generator fuel types differ in where they show up and how well they keep in storage.
Fuel | Common in | Storage notes |
Gasoline | Portable, inverter | Degrades in storage; use approved cans and stabilizer per the manual |
Propane | Dual-fuel, standby | Stores long in tanks; less energy per gallon than gasoline |
Natural gas | Standby | Piped supply, no storage at home |
Diesel | Larger standby, commercial | Stores better than gasoline; needs care in cold |
How Each Fuel Fits
Gasoline: It is easy to find and common in portable and inverter models. It breaks down in storage, so manuals often call for approved cans and a stabilizer.
Propane: It shows up in dual-fuel and standby units. Propane keeps well in tanks, though it holds less energy per gallon than gasoline.
Natural gas: Many standby models use it through a piped supply. Nothing is stored at home, but service depends on the gas line staying in operation.
Diesel: Larger standby and commercial units tend to use it. It stores better than gasoline but needs extra care in cold weather.
One Rule for Every Engine
Use the fuel and octane the manual lists. The nameplate is usually a sticker or plate on the frame or near the fuel tank, and the manual repeats those details with added limits. Never mix fuels unless the engine is designed for it. The wrong fuel can damage an engine and may affect the warranty.
Some owners like the flexibility of dual fuel generators, which can switch between gasoline and propane depending on what is on hand. That choice still comes down to the manual and the model.
Plan for disruptions to the fuel your generator actually uses. A portable gasoline generator must stop and cool for refueling. A standby unit connected to an operating natural gas line needs no manual refueling.
When the Generator Is Off: Bridging the Gaps
Shut off a portable gasoline generator and let it cool before adding fuel. Fuel can also run short in a long outage. A charged power station can keep a router, phones, and lights going during those gaps.
Why Short Gaps Matter
Gaps are small, but they add up over a multi-day outage. Each one is a stretch with no lights, no internet, and no way to charge a phone.
Manually refueled units: The engine must be off before anyone adds fuel. Even a short stop cuts power to everything on the generator.
Cool-down time: Manuals list how long to wait. Hot engine parts and fresh fuel are a poor mix.
Fuel shortages: Long outages can strain local supplies. A full can today may not be easy to refill tomorrow.
A portable gasoline generator must stop and cool before refueling. A piped natural gas standby unit can run without manual refueling while service is available, subject to its maintenance schedule. An EcoFlow portable power station charged ahead of time can keep the router, phones, and a lamp running indoors while the engine is off.
A 1kWh-class station suits small loads and fits near the router. It can cover many hours of communication and lighting between generator runs, which is often the real need during a gap.
Runtime Estimate for Small Loads
The figures below are estimates, not test results. Usable capacity is set at 85% of the rated 1,024Wh, about 870Wh, since some energy is lost during conversion.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Router + LED lamp + phones | about 40W | about 22 hours |
Method: usable capacity (Wh × 0.85) ÷ load (W). The 40W load is an example.
Now consider one shutdown. A one-hour refueling and cool-down stop at 40W needs about 40Wh. That is under 5% of the estimated 870Wh.
Real runtime changes with the devices connected, battery age, and temperature. Larger appliances, including refrigerators, need their own planning and fall outside this example.
Households weighing other backup choices can look at home batteries versus propane generators, since the two handle fuel, noise, and upkeep differently.
Back to fuel. The next question is which gasoline to buy.
What Type of Gas Does a Generator Use?
Most gasoline generators use regular unleaded at the octane listed in the manual. Ethanol blends matter. E15, a blend with up to 15% ethanol, is not for small engines.
What Kind of Gas Does a Generator Use? Start With the Manual
The question "what gas does a generator use" has a short answer. Fresh regular unleaded gasoline at the manual's octane works for most small gas engines. The manual is the final word, and some models call for something different.
Other searches, like "what type of gas do generators use" or "what kind of gas does a generator take," lead to the same place. Check the manual, then check the pump.
Why E15 Is Not an Option
EPA allowed E15 to be sold for model year 2001 and newer light-duty vehicles. Small engines are not part of that waiver. EPA rules prohibit gasoline above 10% ethanol in engines and equipment the waiver does not cover, as the EPA fact sheet explains.
The orange E15 pump label also warns against using it in gasoline-powered equipment. A generator falls into that group. Pumps with a blue or black handle marked E10 or lower are a safer match for most small engines, though the manual decides.
Gas Choices at a Glance
Octane: Use the rating the manual lists. Higher octane does not add power to an engine built for regular.
Ethanol: For a small gasoline generator, use fuel with no more than 10% ethanol and observe any stricter limit in the engine manual. Some manufacturers recommend ethanol-free fuel for storage.
Freshness: Old gasoline can gum up the carburetor and fuel lines. A fuel stabilizer helps when the manual allows it. Buying smaller amounts more often also keeps the supply fresh.
Gas choice affects engines in the long run, and the best gasoline for generators varies by model.
Finally, a look at refueling and storage safety.
Generator Fuel Safety: Refueling and Storage
Hot engines and fuel do not mix. Fuel belongs away from the house. And a generator never belongs inside.
Refueling Steps
Turn the generator off: Shut down the load first if the manual says so, then stop the engine.
Let it cool: Follow the cool-down time in the manual. Fuel spilled on hot parts can ignite.
Fill from an approved container: Pour slowly and keep the tank below the fill line. Wipe up spills before restarting.
Restart after the area is clear: Move the fuel container away from the generator first.
Safe Fuel Storage
Store fuel in approved containers outside living spaces. Keep them away from heat, sparks, and pilot lights. Local fire codes may limit how much fuel a household can store, so check them before stocking up. Label each can with the fuel type and fill date so older gasoline gets used first.
Propane cylinders and tanks follow the same idea. Store them upright and outdoors, as the manual and the supplier advise.
Carbon Monoxide Rules
Exhaust from a fuel-burning engine carries carbon monoxide, a gas that cannot be seen or smelled. The CDC says to never use a generator inside a home or garage, even with doors and windows open.
Its other advice is plain:
Distance: Operate portable fuel-burning generators outdoors more than 20 feet from windows, doors, and vents. For permanently installed standby units, follow the model’s installation manual and local siting requirements.
Detectors: Use battery-operated or battery backup CO detectors in the home, since a power outage can disable plug-in models.
Winter outages add pressure to move equipment closer to shelter, which is why carbon monoxide safety with gas generators deserves extra attention in cold weather.
So, what do generators run on? Gasoline, propane, natural gas, or diesel, as the nameplate says. EPA rules keep E15 out of small engines, and the CDC says every generator runs outdoors.
The takeaway is simple. Use the manual's fuel, store it safely, and cool the engine before refueling.
A fuel plan covers the engine, but gaps still happen during refueling, cooldown, and shortages. For those hours, an EcoFlow DELTA 3 Classic can keep a router, phones, and a lamp powered without fuel or exhaust. The 1,024Wh unit recharges from 0 to 80% in about 45 minutes on AC, per EcoFlow, so it can top up while the generator runs. It works alongside the generator, not instead of it.
What fuel do most portable generators use?
Most portable generators use gasoline. Many dual-fuel models also run on propane, which gives owners a second option when gas is hard to find. The nameplate and manual list the exact fuels the engine accepts, so check them before buying fuel.
Can I use E15 in a generator?
No. EPA rules do not allow E15 in engines and equipment that its waiver does not cover, and that includes small engines. The E15 pump label warns against gasoline-powered equipment. Use the ethanol level and octane the manual lists.
Can a generator run on natural gas?
Many standby models do, through a piped supply. That setup avoids storing fuel at home, though it depends on the gas line staying in service. Portable units need a manufacturer-approved setup, so follow the manual closely.
Which generator fuel lasts longest in storage?
Propane in tanks generally stores longer than gasoline, which degrades in storage. Diesel also stores better than gasoline but needs care in cold weather. Natural gas needs no home storage at all, since it arrives through a pipe.
Can I refuel a running generator?
No. Turn it off and let it cool first. Fuel spilled on a hot engine or exhaust can ignite. Follow the manual's cool-down time, fill from an approved container, wipe up spills, and only then restart the generator safely again.
