Amp Circuit for Microwave Ovens: Breaker Size and Dedicated Circuit Rules
Most microwaves need a grounded 120V outlet on a 15 or 20 amp circuit. GE specifies an individual circuit for its countertop and over-the-range models. The Whirlpool hood-combination manual cited below recommends a separate circuit. The model's installation instructions always have the final word. Microwaves pull a lot of current for a small appliance, so sharing a circuit with a toaster or coffee maker can trip the breaker. This guide covers the amp circuit a microwave needs, why nameplate input watts matter more than cooking watts, when a microwave should have its own circuit, and how a countertop model can run on a portable power station during an outage.
What Amp Circuit Does a Microwave Need?
The right amp circuit for microwave ovens depends on the model, so the installation instructions come first. Most units need a 120V, grounded outlet on a 15 or 20 amp breaker. Check whether the installation manual requires or recommends a separate circuit.
What the Makers Say
Two major brands spell out the rules in their installation material.
  • GE Appliances: GE's support page says a microwave needs an individual, properly grounded 120V branch circuit with a three-prong receptacle. The circuit should carry a 15 or 20 amp breaker or time-delay fuse. GE adds that over-the-range models "should always be on a dedicated circuit."
  • Whirlpool: Whirlpool's installation instructions for a microwave hood combination call for a 120V supply rated at 15 or 20 amps. The brand recommends "a separate circuit serving only this microwave oven."
Circuit Requirements at a Glance
Microwave type
Supply
Own circuit?
GE countertop microwave
120V, grounded, 15 or 20 amp breaker
Individual branch circuit required by GE
GE over-the-range microwave
Dedicated circuit required by GE
Whirlpool microwave hood combination (manual W10724870A)
120V, 15 or 20 amp supply
Separate circuit recommended by Whirlpool
What Size Breaker for a Microwave Is Typical?
Most manuals list 15 or 20 amps. The number in the manual beats any rule of thumb.
The breaker must also match the wire. A 15 amp breaker pairs with 14 gauge copper wire. A 20 amp breaker pairs with 12 gauge copper wire. That pairing is why a breaker is never swapped on a whim.
The nameplate also shows the amps a microwave uses. That figure shows how much room is left on the circuit.
Outlet and Circuit Basics
A grounded microwave outlet has two flat slots and a round ground hole. It matches the three-prong cord on the appliance. Cutting off the ground prong removes a key safety feature.
A microwave dedicated circuit serves that one appliance. Nothing else shares its wire, so a toaster or kettle cannot steal capacity.
The same input-watt number also shows whether a microwave can run from battery power when the grid is down.
Running a Microwave During a Power Outage
A countertop microwave can run from a power station if its input watts fit the station's output. The nameplate input watts count, not the cooking watts. Built-in and over-the-range units stay on their home circuits.
Read the Nameplate First
The label sits on the back or inside the door. It lists the rated input in watts or amps. That number is the draw from the wall.
A microwave sold as 1,000 watts of cooking power can pull 1,500 watts or more from the outlet. Only 120V models should plug in directly. Any other setup needs a manual check and, in some cases, an electrician.
During an outage, a countertop microwave can warm food from an EcoFlow portable power station, as long as its nameplate input watts fit the station's output. The microwave plug goes straight into the station's outlet, so nothing connects to the kitchen circuit.
Heating a bowl of soup takes only a few minutes. A small countertop microwave with input under 1,800W can run short cycles from a 1kWh station, as long as startup draw stays within the unit's ratings.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Some households run a higher-input microwave. Others want several meals between recharges. A 3kWh station gives more output and more storage for both cases.
EcoFlow DELTA 3000 Gen4
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The EcoFlow US page lists shipping for early January 2027. Delivery timing should be confirmed for the address in question. A unit that ships later is a planning choice, not a fix for an outage or storm already underway.
How the Products Divide the Job
  • EcoFlow DELTA 3 Classic: This model suits a small countertop microwave whose input and startup draw stay within its ratings.
  • EcoFlow DELTA 3000 Gen4: This model suits higher input or more uses between recharges.
Estimated Microwave Uses Per Charge
These figures are estimates, not test results. They use example input watts and 5-minute uses.
Example load
DELTA 3 Classic (about 870Wh usable)
DELTA 3000 Gen4 (about 2,611Wh usable)
1,200W input microwave, 5 minutes (100Wh)
about 8 uses
about 26 uses
1,500W input microwave, 5 minutes (125Wh)
about 7 uses
about 20 uses
Method: uses = usable Wh ÷ (input W × minutes ÷ 60). The input watts above are placeholders. The nameplate number should replace them.
Outage cooking takes planning, and the right backup power for a microwave depends on input watts, run time, and the number of meals.
Back at home, the wiring matters just as much. Some kitchens need a separate circuit for the microwave.
Does a Microwave Need a Dedicated Circuit?
Check the installation instructions for the exact microwave. GE calls for an individual circuit for the models discussed here. Whirlpool recommends a separate circuit for its cited microwave hood combination. Repeated trips warrant a professional diagnosis.
Should a Microwave Be on Its Own Circuit?
Check the manual before considering a shared circuit. When sharing is permitted, compare the rated input current of all loads that run together with the branch circuit’s capacity.
A separate line keeps the microwave load apart from everything else. Breakers then have less reason to trip mid-meal.
Overload hazard to avoid: a microwave, toaster and kettle share one power strip. A strip does not increase the branch circuit’s capacity.Overload hazard to avoid: a microwave, toaster and kettle share one power strip. A strip does not increase the branch circuit’s capacity.
Do the Amp Math
Start with rated input amps on the nameplate. On single-phase AC, input current equals real input watts divided by voltage times power factor: I = P / (V × PF).
  1. Read the rated input amps, or find the input watts and power factor in the manufacturer’s specifications.
  2. Use the stated current directly. If only watts are given and the power factor is unknown, ask the manufacturer for input current.
  3. Add the amps of every other appliance on the same circuit.
  4. Compare the total with the breaker rating.
For example, 1,500 W at 120 V and a power factor of 1 corresponds to 12.5 A. At a lower power factor the same real power draws more current. A 1,500 W resistive toaster adds about 12.5 A, so these two appliances together would exceed a 20 A circuit.
Labels can confuse, since the gap between microwave wattage and input draw catches many buyers off guard. The door sticker often shows cooking power. The nameplate shows the real load.
When a Dedicated Setup Makes Sense
  • Over-the-range installs: GE says these units should always have their own circuit. The hood fan and light add to the load as well.
  • Repeated trips: Stop resetting the breaker and have an electrician investigate. If the cause is simultaneous loads and the wiring is sound, the electrician can advise on redistributing them or installing a dedicated circuit.
  • Heavy kitchen use: A dedicated microwave circuit helps when a family cooks with several appliances at once.
  • Remodels: A dedicated outlet for microwave use is easier to add while walls are open. Licensed electricians handle this work.
Finally, a few signs show when a circuit needs professional attention.
Signs Your Microwave Circuit Needs an Electrician
Repeated trips, warm outlets, or flickering lights are warnings. A bigger breaker is not the answer. An electrician checks the wire size and the load.
Electrician inspecting a kitchen wall outletElectrician inspecting a kitchen wall outlet
Warning Signs to Watch
The Electrical Safety Foundation International lists overload signs such as flickering lights, frequent breaker trips, and warm or discolored wall plates. For a microwave circuit, these signs matter most:
  • Frequent trips: A breaker can operate because of an overload or a fault. Stop repeated resets and have the appliance and circuit checked.
  • Warm or discolored outlet: Heat at the wall plate can point to a loose connection or an overloaded line. The microwave should stay unplugged until an electrician checks it.
  • Burning smell or buzzing: These are urgent signs. Power to that circuit should be shut off at the panel.
  • Extension cord use: Microwave makers advise against extension cords. The U.S. Consumer Product Safety Commission says cords can overheat when they carry more watts than they can handle.
Why a Bigger Breaker Is Not the Fix
The breaker size for microwave circuits must match the wire behind it. Breakers are not interchangeable, since 15 amp vs 20 amp circuits use different wire. A larger breaker on thin wire lets the wire overheat before the breaker trips.
What an Electrician Will Check
  1. Wire gauge and breaker rating.
  2. Total load on the circuit.
  3. Outlet condition and grounding.
  4. Whether a new circuit is the better answer.
Adding a circuit usually needs a permit. Local building offices set the rules, so the electrician typically pulls the permit.
For the models discussed here, both manufacturers specify a grounded 120V supply on a 15 or 20 amp circuit. GE calls for an individual circuit. Whirlpool recommends a separate circuit for the cited hood combination.
The takeaway is simple. Check the nameplate input watts and the installation manual. Call an electrician for any new circuit or repeated trips.
Outages are a separate problem. The EcoFlow DELTA 3 Classic or the EcoFlow DELTA 3000 Gen4 can run a compatible countertop microwave, as long as its input watts fit the station's output. Delivery timing for the DELTA 3000 Gen4 should be confirmed first. Both options are worth a look for readers who want a plan before the next storm.
What size breaker does a microwave need?
Most US models use a grounded 120V, 15 or 20 amp circuit. Check the specific installation manual for the breaker size and any separate-circuit requirement.
Is a dedicated circuit required for a microwave?
GE specifies an individual branch circuit for the countertop and over-the-range models discussed here. Whirlpool recommends a separate circuit for its cited microwave hood combination. If a breaker repeatedly trips, stop resetting it and have the cause diagnosed.
Can a microwave share a circuit?
Only share when the model’s instructions and local rules allow it. Use the nameplate input current to add up appliances that run together. A 1,500 W microwave at 120 V draws 12.5 A only at a power factor of 1.
How many amps does a 1,000W microwave use?
A 1,000 W cooking rating does not tell you input current. Check rated input amps on the nameplate. If the manual gives real input watts and power factor, divide input watts by voltage times power factor.
Can a power station run a microwave?
A compatible countertop model can run, if its input watts fit the station's output. The microwave connects straight to the station. Built-in and over-the-range units stay on their home circuits and need no power station.
Tips
