Generator Interlock Installation: What the Job Involves and What It Costs
When a storm knocks out your power, a portable generator in the driveway only helps if you can get that power to your circuits safely. That's the job of a generator interlock, a small sliding plate that keeps your main breaker and your generator breaker from being on at the same time. It's one of the more affordable ways to feed selected circuits, but only when the kit matches your exact panel and the work meets code. Here's how generator interlock installation works, what an electrician does, and what drives the price.
What Is a Generator Interlock and How Does It Work?
Maybe you've seen a neighbor run a cord from a generator to a small box on the side of the house and wondered how it all works. The part doing the safety work sits on the cover of the breaker panel.
An interlock kit is a metal plate that mounts on your panel cover. It slides between the main breaker and a generator breaker, so one has to be off before the other can turn on. That simple block keeps generator power from flowing back onto the utility lines.
Why Backfeeding Is So Dangerous
That backward flow is called backfeeding, and it's the reason the rules are so strict. The CPSC portable generator safety alert warns against ever trying to power house wiring by plugging a generator into a wall outlet. The agency calls the practice "extremely dangerous" because it can electrocute utility workers and neighbors served by the same transformer.
Some people try it anyway with a cord that has a plug on both ends. In March 2026, the agency put out a CPSC male-to-male cord warning that tells people to stop using those cords and get rid of them.
What a Complete Interlock Setup Includes
If you're pricing a generator interlock kit installation, it helps to know the plate is only one piece. A working setup needs four parts, and each one has to match the others.
An interlock kit listed for your panel's brand and model
A 2-pole generator breaker that fits the panel
A power inlet box mounted outside the house
A generator cord rated for the load
The word "listed" matters here. A kit made for a different panel may not line up with the breakers, and it may not pass inspection.
Check Local Rules Before You Buy
Local rules can decide whether an interlock is allowed at all. Tri-County Electric Cooperative in Azle, Texas, for example, requires a UL 1008 transfer switch, and it states that interlock kits are not acceptable. Check with your own utility and permitting office before you buy any equipment, since rules vary from one service area to the next. Compare interlock kits versus transfer switches first, since the two handle the same job in different ways.
You may wait for a permit, or for an open slot on an electrician's calendar. Short-term power for lights and phones doesn't have to wait that long.
Before the Install: Power for Lights and Phones Without Panel Work
What do you do if an outage hits before the electrician shows up? For most homes, the first needs are small: a lamp, the Wi-Fi router, and charged phones. None of those need panel work at all.
A portable power station runs those devices straight from its own outlets. It doesn't tie into your home wiring, so it's not a substitute for an interlock.
What to Ask For in Your Quote
This is also a good time to clean up your quote. Ask the electrician to list the panel model, the approved interlock, the inlet box, and the inspection as separate lines. If you only need temporary lighting and communication, budget that no-panel option on its own, apart from the electrical work.
A Plug-In Option While You Wait
While you wait for an electrician or a permit, an EcoFlow portable power station can keep a lamp, the router, and your phones going from its own outlets. One unit is enough for this job, because a second power station does nothing to solve panel and interlock fit.
For a typical evening outage, a station around 1kWh is a reasonable size for lights and communication. The EcoFlow DELTA 3 Classic fits that role, and the details below come from EcoFlow's own product page.
How Long the Basics Can Run
Runtime depends on what you plug in, so treat the numbers below as estimates. The math is simple: take the usable capacity, about 85% of the rated watt-hours, and divide it by the watts your devices draw.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable, estimated) |
Router + LED lamp + phone charging | About 40W | About 22 hours (estimate) |
Check the label on each device and swap in your own numbers. The backup lasts for a limited period, depending on battery capacity and the actual load.
It also helps to plan ahead for what to do in a power outage, from water and food to staying in touch. Here's what the interlock job itself involves.
How a Generator Interlock Is Installed
Searching for how to install a generator interlock kit turns up plenty of DIY videos. What a video can't do is confirm the kit fits your panel, pull your permit, or pass your inspection. If you're wondering how to install a generator interlock the right way, hire a qualified electrician and confirm local licensing and permit requirements.
The electrician confirms the kit fits the panel, then installs the breaker, the inlet, and the plate. Your utility and the local inspector may be involved along the way, and testing comes last.
The Steps an Electrician Follows
The job usually runs in this order. Knowing the steps makes it easier to read the quote and ask good questions.
Confirm the panel's brand and model.
Buy an interlock kit listed for that exact panel.
Pull the permit, where one is required.
Have a qualified electrician turn off all power supplying the panel and confirm it's off with a properly rated voltage sensing device.
Install the 2-pole generator breaker in the slot the kit requires, and fit the retaining bracket the kit's instructions call for.
Mount the interlock plate on the panel cover.
Install the outdoor inlet box and wire it to the breaker.
Label the panel and the inlet.
Schedule the inspection.
Test the setup with the generator running outdoors.
Step five is also where the wrong slot or the wrong breaker defeats the whole kit. Step seven's outdoor inlet suits a portable generator on a manual transfer switch or extension cord. Standby generators are permanently connected to the home's electrical system, and an authorized dealer typically handles that work. For the manual portable setup, the process mirrors how to install a transfer switch.
Staying Safe on Test Day
What about the first test run? The generator has to stay outside, and distance matters. The CDC's carbon monoxide safety page says to run a generator outdoors, more than 20 feet from windows, doors, and vents. The CDC also says to use a battery-powered or battery backup CO detector in your home when a generator is running.
Weather counts too. OSHA's portable generator fact sheet advises against running a generator in rain or wet conditions, and against handling it while you're wet.
Once you know what the job involves, the price makes more sense. Here's what drives it.
Generator Interlock Installation Cost Factors
If you've typed "cost to install interlock kit for generator" into a search bar, you've likely seen numbers all over the map. No federal agency publishes a price list for this work, so this guide won't quote one.
What Goes Into the Bill
The kit itself is usually the small part. Labor, the inlet box, the length of the wire run, and the permit add up from there. A panel that needs repairs or an upgrade can raise the total.
Quote line item | What changes the price |
Interlock kit | Panel brand and model |
Generator breaker | Breaker size and panel type |
Power inlet box | Size and where it mounts |
Wire and conduit | Distance from the panel to the inlet |
Labor | Local rates and how easy the panel is to reach |
Permit and inspection | Local fees and rules |
Panel repairs | Age and condition of the panel |
Your generator interlock kit installation cost depends on how those lines add up at your house. A panel on a garage wall with a short wire run is a different job from a basement panel on the far side of the home.
How to Compare Quotes
Ask at least two licensed electricians for itemized quotes. Line-by-line pricing shows you whether one bid left out the permit or the inlet box. You can also read more on wiring a generator to a breaker box, since generators can connect in more than one way.
Generator interlock installation comes down to a kit listed for your panel, a generator breaker, and an inlet box, all installed by a licensed electrician. The CPSC's warning is the rule to remember: never backfeed through an outlet. Start by confirming your panel model, then get itemized quotes and make sure the permit is pulled. While you wait, an EcoFlow DELTA 3 Classic can keep lights and phones on for a limited time.
Can I install a generator interlock myself?
It's better to hire a licensed electrician. The job means working inside the main panel, and many areas require a permit and an inspection.
Is an interlock kit legal?
An interlock may be permitted if it is listed for the exact panel and accepted by the local authority and utility. For example, Tri-County Electric Cooperative requires a transfer switch in its service area. Confirm local rules before purchasing.
How much does interlock installation cost?
There's no single number. The total depends on the kit, the inlet box, the wire run, labor, and the permit. Itemized quotes from two electricians will give you a real figure for your home.
Interlock or transfer switch: which is better?
Both prevent backfeed, so the choice comes down to budget and ease of use. A transfer switch is often simpler to operate, but it usually costs more. An interlock costs less, as long as you're comfortable managing breakers and loads yourself.
Can I plug a generator into a wall outlet?
No. The CPSC calls backfeeding extremely dangerous because it can electrocute utility workers and neighbors. Use a listed interlock or a transfer switch installed by an electrician instead.
