Winterize Your Apartment: Draft Fixes, Heat Rules, and Outage Prep for Renters
When you rent, winter prep looks different. You can’t replace windows or add insulation, but you can block drafts, use heat safely, and know when cold is your landlord’s problem to fix. Many cities set minimum indoor temperatures, and New York City’s rules are a good example of how specific they get. This guide shows how to winterize your apartment with removable, renter-friendly steps, what to do if your apartment is too cold, how to use space heaters safely, as per the U.S. Fire Administration, and how to prepare for a winter power outage.
How to winterize your apartment without renovating?
Winterizing a rental comes down to drafts, windows, and how you use heat. Stick with removable products, and check your lease before you attach anything to walls, frames, or floors.
Weatherstripping or rope caulk: removable versions seal gaps around doors and window sashes without leaving residue.
Door draft stoppers: a simple fix for the gap under an entry door.
Window insulation film kits: these add a thin air barrier across single-pane glass.
Thermal curtains: close them at night to hold in warmth.
Vents: close vents in unused rooms only if your heating system allows it.
Rugs: they take the bite out of cold floors.
Report broken windows, failing heat, or leaks to your landlord in writing. Small changes cut costs, so pair these with no-renovation apartment electricity hacks to keep your bills in check.
Winter storms can also knock out power, and renters can prep for that without touching the building’s wiring.
Prepare for winter power outages as a renter
Renters can’t install generators or panels, but they can keep a small, movable emergency kit. A portable power station runs lights, phones, and the router during short outages, and it moves with you. It’s not a way to heat the apartment.
Start with your lease. Check who handles drafts, window gaps, and heating maintenance. If your apartment doesn’t stay warm enough, take it to your property manager as your lease directs. If winter outages worry you, build a small kit of supplies you can take with you when you move. A power station like the DELTA 3 Classic powers emergency lights, phones, and network devices directly, so you stay in touch during repair waits or short outages.
Renters can’t install a generator, but an EcoFlow portable power station needs no installation and moves with you. It keeps a lamp, phones, and the Wi-Fi router going through a short winter outage. It isn’t a heating solution.
A 1kWh station covers lights and communication through a typical outage and fits in a closet.
EcoFlow DELTA 3 Classic (1024Wh)
Lights and Wi-Fi: 1,024Wh for a lamp, router, and phones (see estimate).
No installation: Moves with you.
Fast recharge: 0 to 80% in about 45 minutes on AC.
Runtime estimate (estimate only)
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Router + LED lamp + phones | about 40W | about 22 hours |
Method: usable capacity (1,024Wh × 0.85) ÷ load (W). Real runtime varies with the devices you connect.
Blackouts hit apartments differently, so it helps to build an apartment blackout preparedness plan before the next storm.
Back to heat: here’s what to do when the apartment is too cold.
What to do if your apartment is too cold?
First, check vents, filters, and thermostat settings. Then contact your landlord in writing and keep a copy. If heat isn’t restored, look up your city’s rules.
New York City is a useful example of a local rule. Under New York City’s residential heating requirements, heat season runs October 1 to May 31. From 6 a.m. to 10 p.m., the indoor temperature must be at least 68°F when it’s below 55°F outside. From 10 p.m. to 6 a.m., it must be at least 62°F regardless of the outside temperature.
Other cities and states set their own rules, so check your local housing code or tenant agency.
Don’t turn to your oven as a backup. The U.S. Fire Administration says, “Never use an oven to heat your home.” Renters have other emergency options, so read more on portable power for renters in emergencies.
Finally, space heater safety.
Space heater safety in an apartment
Space heaters cause fires when misused. Give them room, and turn them off when you leave. The U.S. Fire Administration offers three rules worth following:
“Keep anything that can burn at least 3 feet from all heat sources.”
“Turn space heaters off when leaving the room or going to bed.”
Plug a portable electric heater directly into a wall outlet. Avoid extension cords and power strips, as the USFA heater safety card advises.
Heaters also draw a lot of power. Check whether space heaters use a lot of electricity before you plug one in.
To winterize your apartment, block drafts with removable fixes, report heat problems to your landlord in writing, and follow the U.S. Fire Administration’s space heater rules. Local rules, like New York City’s, set minimum indoor temperatures. Start by checking your lease and your city code. If winter outages worry you, an EcoFlow DELTA 3 Classic keeps lights, phones, and Wi-Fi running without installation, and it moves with you when you do. It is backup power, not a heater.
How can I winterize my apartment as a renter?
Use removable weatherstripping, window insulation film, door draft stoppers, and thermal curtains. Check your lease first, and report broken windows or failing heat to your landlord in writing.
What should I do if my apartment is too cold?
First check your vents, filters, and thermostat settings. Then contact your landlord in writing, and if heat isn’t restored, check your local housing code or tenant agency for heat rules.
What temperature must a landlord provide in NYC?
NYC HPD requires at least 68°F from 6 a.m. to 10 p.m. when it’s below 55°F outside, and at least 62°F from 10 p.m. to 6 a.m., during the heat season.
Can I use my oven for heating?
No. The U.S. Fire Administration says never use an oven to heat your home. Report the heat problem to your landlord in writing instead, and follow space heater safety rules.
Can a power station heat my apartment?
No. A power station is for lights, phones, and Wi-Fi during outages. Don’t use it for all-day space heating, and report heat problems to your property manager.
