Jackery Explorer 3000 Pro: Specs, Price, and How It Compares
Choosing a portable power station in the 3,000Wh class comes down to stored energy, output, battery lifespan, expandability, and how easily you can move it. The Jackery Explorer 3000 Pro remains relevant to existing owners and shoppers checking remaining stock, although Jackery no longer sells it through its US website. This guide reviews its published specifications, independent test findings, and how it compares with the EcoFlow DELTA Pro and EcoFlow DELTA Pro 3.
Jackery Explorer 3000 Pro Specs and Price
Before you spend this kind of money on any Jackery Explorer 3000 Pro portable power station, you should know exactly what the spec sheet says. No guessing.
Spec
3,024Wh
3,000W continuous
NCM lithium-ion
2,000 cycles to ~70%
Solar Input
Up to 6 compatible panels; solar input 17.5–60V, up to 1,400W total
AC Charging
0-100% in 2.4 hours
Weight
63.9 lbs
3 years (2-year extension available direct from Jackery)
Price
Not currently sold by Jackery US; third-party pricing varies
A few things stand out from those numbers:
  • At 63.9 lbs, this is one of the lighter units in the 3,000Wh class. If you move the station between a garage, a campsite, or a vehicle regularly, that weight savings adds up.
  • The NCM lithium-ion battery is rated for 2,000 cycles to at least 70% remaining capacity. Compare both cycle count and the remaining-capacity threshold when assessing long-term use.
  • Support for up to six solar panels gives you flexibility for faster solar recharging, which matters in locations where grid power isn't available.
  • No expansion battery support means total capacity is locked at 3,024 Wh. If your power needs grow, you can't scale this unit up.
  • The 2.4-hour AC charge time is competitive, so you can top off the battery quickly before a trip or a storm.
If you are considering a Jackery Explorer 3000 Pro solar generator for off-grid use, Jackery supports up to six compatible solar panels with the appropriate adapters. Its 2,000-cycle rating to at least 70% capacity is also worth considering if you plan to use it frequently.
Jackery states that the Explorer 3000 Pro is no longer available for purchase through its US website. Any remaining retailer or refurbished stock should be checked separately for price, condition, and warranty coverage. The comparison below therefore focuses on specifications rather than assuming both models are currently offered at the same price.
Jackery Explorer 3000 Pro vs EcoFlow DELTA Pro
When you're narrowing down your final choice, comparing two units side by side is one of the most practical steps you can take. The Jackery Explorer 3000 Pro vs EcoFlow DELTA Pro comparison is one of the most common matchups in this category, and for good reason: both target the same buyer, but they make different tradeoffs.
Spec
EcoFlow DELTA Pro
3,024Wh
3,600Wh
3,000W
3,600W
Surge Output
~6,000W
7,200W
2,000 to ~70%
3,500 to 80%
Solar Input
1,400W
1,600W
Weight
63.9 lbs
99.2 lbs
Expansion Batteries
Not supported
Supported
Price
$1,799 sale; $2,399 reference price (October 19, 2026)
The EcoFlow DELTA Pro offers more stored energy (3,600Wh vs. 3,024Wh), higher continuous output (3,600W vs. 3,000W), and a higher manufacturer-rated surge output (7,200W vs. 6,000W). Its battery is rated for 3,500 cycles to 80% remaining capacity, compared with 2,000 cycles to at least 70% for the Explorer 3000 Pro. These ratings use different capacity-retention thresholds, so the cycle counts should not be read as identical test endpoints.
Expansion capability is the most structural difference. The EcoFlow DELTA Pro can scale into a larger home backup system with additional batteries, while the Explorer 3000 Pro's capacity is fixed at purchase. If you're thinking about starting with portable backup now and growing into whole-home backup power later, expandability is worth considering early.
EcoFlow DELTA Pro beside a campervan, illustrating the EcoFlow alternative discussed in this comparison. Illustration based on official EcoFlow product imagery.EcoFlow DELTA Pro beside a campervan, illustrating the EcoFlow alternative discussed in this comparison. Illustration based on official EcoFlow product imagery.
The Explorer 3000 Pro's main advantage is weight. At roughly 35% lighter, it's the more practical choice if you carry the unit regularly, especially for camping or road trips.
EcoFlow DELTA Pro
• 3.6-25kWh expandable capacity with DELTA Pro Smart Extra Battery • 3600W-7200W AC output for 99% appliances • Plug & Play home backup solution • Incredible 6500W MultiCharge, 2.7 hours AC charging • Industry first: recharge at thousands of EV stations worldwide • Long-lasting LFP battery supports up to 10 years
EcoFlow DELTA Pro 3
•High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. •Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. • Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. • Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
If you need more capacity and native single-unit 120V/240V output, the EcoFlow DELTA Pro 3 is a step-up option. It provides 4,096Wh of capacity and 4,000W rated output, making it worth considering for compatible well pumps or central air-conditioning loads. Check the appliance's starting requirements; connecting either model to home circuits requires appropriate transfer equipment and professional installation.
What an Independent Review Says About the Jackery Explorer 3000 Pro
The Solar Lab's Explorer 3000 Pro review offers one independent assessment of its portability, output, and battery limitations. Its findings describe the unit tested rather than a survey of all owners.
The review highlights the wheels and telescoping handle as useful portability features. The official weight of about 63.9 lb also makes the Explorer 3000 Pro lighter than the 99.2-lb EcoFlow DELTA Pro. That difference can matter when moving a station between storage, a vehicle, and a campsite.
In its load testing, The Solar Lab reports that the unit sustained its rated 3,000W continuous output, but reliably handled surge loads of about 4,500W rather than the advertised 6,000W. This is one test result, so check the starting requirements of your own appliances.
The same review identifies the older battery chemistry and lack of expansion-battery support as limitations. Those points matter most for frequent cycling or plans to increase storage capacity later. They do not mean an existing unit cannot still serve occasional backup needs.
For solar charging, use Jackery's published input limits and connection guidance: up to 1,400W total, with compatible panels and the required adapters. Panel wattage, sunlight, shading, and setup determine the energy actually collected, so the maximum input rating is not a guaranteed charging rate.
Have you thought about how often you'd actually need to move your power station? If it stays in one spot most of the time, battery longevity and expandability may matter more than shaving off 35 lbs.
The Jackery Explorer 3000 Pro combines 3,024Wh of capacity with 3,000W continuous output and a lighter frame than the EcoFlow DELTA Pro. However, Jackery no longer sells it through its US website, so check any remaining stock carefully. The EcoFlow DELTA Pro offers more capacity, higher output, and expansion options. For 4,096Wh and native single-unit 240V output, consider the EcoFlow DELTA Pro 3. Choose around your actual loads, portability needs, and expansion plans.
What are the full specs of the Jackery Explorer 3000 Pro?
According to Jackery's US specifications, the Explorer 3000 Pro has 3,024Wh capacity, 3,000W continuous AC output, an NCM lithium-ion battery, and a 2,000-cycle rating to at least 70% remaining capacity. It supports up to six compatible solar panels, with solar input of 17.5–60V and up to 1,400W total. It weighs about 63.9 lb and has a 3-year standard warranty, extendable by 2 years under Jackery's terms. Jackery's charging guide lists about 2.4 hours for AC charging; actual time depends on conditions.
How much does the Jackery Explorer 3000 Pro cost?
Jackery says the Explorer 3000 Pro is no longer available through its US website, so there is no current direct-sale price to quote. Remaining retailer or refurbished listings may differ in condition, included panels, warranty, and price. Compare a specific listing with currently available alternatives before buying.
How does the Jackery Explorer 3000 Pro compare to the EcoFlow DELTA Pro?
The Explorer 3000 Pro is about 35% lighter (63.9 lb vs. 99.2 lb), while the EcoFlow DELTA Pro offers more capacity (3,600Wh vs. 3,024Wh), higher continuous output (3,600W vs. 3,000W), and expansion-battery support. Its cycle-life rating is 3,500 cycles to 80% capacity, compared with 2,000 cycles to at least 70% for the Jackery. Compare current availability and the full system configuration as well as the published ratings.
Can the Jackery Explorer 3000 Pro be expanded with additional batteries?
No. The Jackery Explorer 3000 Pro portable power station does not support expansion batteries. Total capacity stays at 3,024Wh no matter what. If you think you'll need more power down the road, that's worth factoring into your decision now.
Is the Jackery Explorer 3000 Pro good for solar charging?
Yes. Jackery specifies support for up to six compatible panels, with a maximum solar input of 1,400W and a solar-input voltage range of 17.5–60V. Four- or six-panel configurations require the appropriate adapters. Charging speed depends on available sunlight, panel specifications, and the connection setup.
Portable Power Stations
