Backup Power for House: Options, Costs, and How to Choose
Power outages are frequent and hard to predict across the U.S., whether from winter ice storms in the Midwest or summer grid strain in Texas and California. Choosing a home backup power system comes down to your essential loads, required runtime, budget, and how much installation and upkeep you’re willing to handle.
What Are the Main Backup Power Options for a House?
Some homes need only a way to keep a refrigerator and a few devices running; others need automatic power for every circuit. The four main backup power categories cover that range, with different costs, outage capabilities, and installation requirements.
Portable Generators
Built on a wheeled frame, a portable generator uses a gasoline, propane, or dual-fuel engine and can be rolled into position during an outage. Most units provide 3,000 to 10,000 running watts, with appliances connected through heavy-duty extension cords or a manual transfer switch. Their exhaust contains carbon monoxide, so they must stay outdoors and at least 20 feet from windows, doors, and vents.
Standby Generators
Standby generators run on natural gas or liquid propane. Each unit sits permanently outdoors on a concrete or composite pad, and an automatic transfer switch (ATS) connects it to your main electrical panel. Once the ATS senses a utility outage, power returns within seconds; you do not have to start or connect the generator. Common ratings of 10 kW to 26 kW can support central air conditioning, electric water heaters, and circuits throughout the house.
Portable Power Stations
Instead of burning fuel, portable power stations store electricity in rechargeable batteries, including lithium iron phosphate (LiFePO4) batteries. They produce no exhaust while running and can be used indoors when placed and ventilated as directed by the manufacturer. Recharging options may include a standard wall outlet, car charger, or compatible portable solar panels. A portable power station can cover a few plug-in essentials if its continuous output and battery capacity match the load. This makes them practical for backing up selected appliances in apartments and townhomes.
Home Battery Backup Systems
Home battery backup systems use high-capacity battery banks, mounted on a wall or standing on the floor and wired into the home’s electrical system. Often paired with rooftop solar panels, they can store grid electricity or surplus solar generation, then automatically feed critical circuits or the entire home during an outage. A properly configured system can provide battery backup power for house circuits without burning fuel on site.
Backup Option | Power Source | Typical Output | Setup Type | Indoor Safe? |
Portable Generator | Gasoline / Propane | 3,000 W – 10,000 W | Manual (cords or transfer switch) | No (outdoors only) |
Standby Generator | Natural Gas / Propane | 10,000 W – 26,000 W | Permanent with automatic transfer | No (outdoors only) |
Portable Power Station | Rechargeable Battery | 500 W – 4,000 W+ | Plug-and-play or inlet box | Yes |
Home Battery System | Rechargeable Battery / Solar | 5,000 W – 20,000 W+ | Hardwired with smart panel/gateway | Yes (garage or utility room) |
Note: The output ranges shown are approximate and based on representative product specifications from different manufacturers, not fixed industry standards. Actual rated output, setup requirements, and indoor installation suitability vary by model and system configuration. Always check the manufacturer’s specifications and installation guidelines before choosing a backup power solution.
How Much Backup Power Does Your House Need?
When sizing a backup power supply for house loads, check both the watts you need at one time and the watt-hours you need over the outage. For a fuel generator, plan for enough fuel to cover the same runtime.
Identify the Essential Appliances and Devices to Power
Begin with the loads your household cannot do without during a blackout. Add conveniences only after you know there is enough capacity for the essentials. Common starting points include:
Kitchen: Refrigerator or freezer
Connectivity and work: Wi-Fi router, modem, laptop and phone chargers
Comfort and safety: Furnace blower, space heater, window AC, sump pump or well pump
Lighting: LED lamps
Calculate Starting and Running Wattage Requirements
Motor- and compressor-driven appliances can briefly draw more power at startup than they do while running. Check each appliance’s running and starting specifications. Add the running watts for loads you expect to use together, then allow for the additional power needed by devices that may start at the same time. Choose a system with sufficient continuous output and startup capacity. If refrigeration is your main priority, size a generator for your fridge around its compressor’s startup demand and any other loads that may run at the same time.
Estimate How Long Your Home Needs Backup Power
Output in watts describes the load a system can support at one time; watt-hours and kilowatt-hours describe the energy available over time. For a daily estimate, multiply each appliance’s running wattage by the hours you expect to use it. A 150 W refrigerator running for about eight hours a day would use roughly 1.2 kWh. Next, choose the outage duration you want to cover, from a few hours to several days, and multiply your daily energy use by that number of days. Leave additional capacity for inverter losses
Consider Seasonal and Weather-Related Power Needs
Your essential loads may not be the same in every season. During a Houston or Phoenix heat wave, a portable AC unit drawing 1,000–1,200 W may belong on the essentials list. In cold weather, even a gas furnace needs electricity for its blower, which may use 500–800 W. Base the list on the weather your area is most likely to experience.
How Much Does Backup Power for a House Cost?
A useful budget covers more than the purchase price. Installation, fuel or recharging, and ongoing maintenance add up differently for portable equipment and permanently installed systems.
Equipment Purchase Costs
Expect to pay about $ 500–$ 1,500 for a portable generator or around $ 1,000– $ 3,500 for a mid-sized or large portable power station, depending on capacity. A whole-home standby generator typically costs about $ 3,000–$ 7,000 for the unit alone. Modular home battery systems may start at around $ 5,000, while adding batteries and other components can push the total cost above $ 15,000.
Installation and Setup Costs
Portable power stations can be used straight out of the box. If you want to connect one to specific circuits, however, adding a manual transfer switch or inlet box can cost roughly a few hundred to over $ 1,000, depending on the equipment and whether you hire an electrician. A transfer switch that connects a portable generator to selected circuits typically costs around $ 500–$ 1,500 to install. Permanent standby generators and hardwired home battery systems may require permits, concrete pads, gas-line connections, or electrical panel upgrades, with additional installation costs potentially reaching several thousand dollars or more.
Fuel and Electricity Costs
Generator operating costs vary with the machine, load, and runtime. A mid-sized portable generator burns roughly 0.5–0.75 gallons of gasoline per hour, which works out to about $ 25–$ 60 per day. Under moderate loads, a natural-gas or propane standby generator typically costs $ 30–$ 75 per day. Recharging a battery costs much less: at $ 0.17/kWh, a full 5 kWh charge is under $ 1. Once solar panels are installed, solar charging removes that grid electricity cost.
If you’re pricing a solar generator, include the compatible panels and any accessories needed to recharge during an outage.
Maintenance and Long-Term Ownership Costs
Generators require routine maintenance, such as oil and filter changes, fuel system checks, and periodic test runs. Gasoline models may also need fuel stabilizer when stored for extended periods. Professional servicing for a standby generator can cost a few hundred dollars per year, depending on the model and service provider. Battery systems require virtually no routine maintenance, although battery chemistry, usage patterns, and operating conditions can affect their lifespan and performance.
Cost Category | Portable Generator | Standby Generator | Portable Power Station | Home Battery System |
Equipment | $ 500 – $ 1,500 | $ 3,000 – $ 7,000 | $ 1,000 – $ 3,500 | $ 5,000 – $ 15,000+ |
Installation | $ 0 – $ 1,500 | $ 2,000 – $ 6,000+ | $ 0 – $ 1,200 | $ 2,000 – $ 6,000+ |
Daily Operating Cost | $ 25 – $ 60 (gas) | $ 30 – $ 75 (gas/propane) | ~$ 0.50 – $ 1.50 (grid) / $ 0 (solar) | ~$ 1.00 – $ 3.00 (grid) / $ 0 (solar) |
Annual Maintenance | $ 50 – $ 150 (DIY oil/filters) | $ 200 – $ 400 (service plan) | ~$ 0 | ~$ 0 |
How Do You Choose the Right Backup Power System for Your House?
After estimating your loads and setting a budget, decide how much of the house you want to cover. Then weigh that coverage against the installation and maintenance you are willing to handle.
Choose a System Based on Your Backup Priorities
For automatic whole-home coverage, a permanently installed generator or battery system may be the better fit. If your priority is a smaller set of essentials, a portable power station can power compatible plug-in appliances without permanent installation or stored fuel. The EcoFlow DELTA 3800 Gen4 Portable Power Station, for example, has a 3,763 Wh battery and UPS transfer in under 10 ms. Check device compatibility before relying on the transfer function, and size runtime for the loads you plan to connect. The portable unit can also serve on RV trips or for backyard projects.
Decide Between Fuel-Based and Battery-Powered Systems
Extended outages are easier to cover with a standby generator when a reliable natural gas supply is available. A battery system removes the need to store fuel and produces no exhaust while it runs. If an outage lasts several days, however, you will need a way to recharge the battery.
Evaluate Solar Compatibility and Expansion Options
Already have rooftop solar? Check that the backup system works with your existing photovoltaic array, and decide whether you may want more storage later. For a larger array, high solar input limits and scalable storage let you keep surplus daytime generation for your own use instead of sending it to the grid for minimal credit. Take the EcoFlow TITAN 5000 Plus: its dual-MPPT setup handles up to 8 kW of solar input, enough for a sizable rooftop PV array. Because the battery is modular, you can start at 5 kWh and build up to 30 kWh to hold onto daytime solar power for the night or a longer blackout.
Evaluate Installation Requirements and Maintenance Needs
Renters and homeowners who expect to move may prefer a portable system that does not require hardwiring. When weighing a portable power station vs. home battery backup, start by deciding whether you need to power plug-in devices or hardwired circuits. Permanent generators still need test runs and regular servicing. With a portable fuel generator, factor in safe fuel storage and routine upkeep along with the purchase price.
Before choosing a system, list the appliances you must keep running, the runtime you need, and what you can spend. A fuel generator can handle heavy demand through an extended outage, as long as you can place it outdoors and keep up with routine engine maintenance. For quiet indoor operation with little routine maintenance, look at portable power stations and home battery systems instead; both can pair with solar. Account for seasonal heating or cooling needs and the installation your home allows before deciding how much convenience to pay for.
Can You Use a Portable Power Station Indoors?
Yes, you can safely use a portable power station indoors because it runs on rechargeable batteries and produces zero carbon monoxide or exhaust fumes. Unlike gas-powered generators—which can cause fatal carbon monoxide poisoning if operated inside a garage, basement, or enclosed porch—battery stations operate silently and emit no harmful gases, making them safe for kitchens, bedrooms, and home offices.
Do Solar Panels Work During a Power Outage?
Standard grid-tied solar panels automatically shut off during a power outage unless they are paired with a battery storage system and an automatic transfer switch or islanding inverter. Utility regulations require grid-tied inverters to disconnect during blackouts—a safety feature called anti-islanding—so your panels do not send live electricity back into utility lines while lineworkers are making repairs. Adding a compatible home battery allows your system to safely isolate from the grid and keep generating solar power for your house.
Can You Combine a Generator and a Battery Backup System?
Yes, combining a gas or propane generator with a battery backup system creates a highly resilient hybrid setup for extended outages. In this arrangement, the battery handles quiet, low-draw overnight loads like your refrigerator, lights, and Wi-Fi without wasting fuel, while the generator runs for just a few hours during the day to recharge the battery at peak efficiency and handle heavy surge appliances.
How Should You Store a Portable Power Station When Not in Use?
Store your portable power station in a cool, dry, and well-ventilated indoor space, away from direct sunlight and extreme temperatures. For long-term storage, follow the manufacturer’s recommended battery charge level, as guidance varies by model. Some manufacturers recommend keeping the battery around 40%–60%, while others suggest a higher charge level. Check the battery periodically, typically every three to six months, and recharge it as needed to prevent deep discharge. Avoid storing the unit in locations exposed to excessive heat, moisture, or freezing temperatures.
