How Many Watts Does a Space Heater Use?
Most full-size plug-in space heaters use 1,500 watts on their highest setting. If the heating element remains on continuously, that equals 1.5 kilowatt-hours (kWh) of electricity for every hour of operation. At a residential rate of 18.2 cents per kWh, the cost is about $0.27 an hour.
Actual use is rarely that tidy. A thermostat may cycle the element off after the room warms, while a drafty basement can keep the same heater running almost nonstop. Wattage tells you the maximum electrical draw; room conditions and runtime determine what appears on the bill.
Whether you are heating a home office in Chicago or taking the chill out of a basement room in Ohio, the calculation starts in the same place. Check the label, estimate the hours the heating element will operate, and multiply the resulting kWh by your utility rate. The sections below compare common heater wattages, explain the math, and cover practical ways to reduce unnecessary use.
What Is the Average Wattage of a Space Heater?
Personal heaters may draw only 200 to 500 watts, but a typical room-size model uses up to 1,500 watts. That upper figure is common because a 1,500W heater draws about 12.5 amps on a 120-volt circuit. A standard 15-amp circuit is rated for 1,800 watts in total, which leaves little capacity for anything else on the same circuit.
When sizing a portable power station for a heater, compare its continuous AC output with the heater’s nameplate wattage.
The 1,800W figure is a circuit rating, not a target for combined use. A heater should be plugged directly into a firm wall outlet, and other high-draw appliances should not share that circuit. Stop using the outlet if the plug fits loosely, the faceplate becomes hot, the cord is damaged, or the breaker repeatedly trips.
Common Space Heater Wattage Options
If you are wondering how many watts does a small space heater use, start with its nameplate rather than its physical size. Portable heaters generally fall into three practical power groups:
  • Low-wattage personal heaters (200W – 500W): These small desktop and under-desk units warm the person nearby rather than the entire room. They suit a workstation where localized heat is more useful than raising the temperature everywhere.
  • Mid-range portable heaters (750W – 1,000W): A mid-range setting can be enough for a small, insulated bedroom or home office. Bathroom use requires a model specifically approved for that environment and an electrical setup that follows the manufacturer’s instructions.
  • Full-size room heaters (1,500W): This is the common maximum for portable room heaters sold for U.S. household outlets. Many models also offer a lower setting, often 750W or 900W, but an “Eco” label does not guarantee a fixed wattage; the controls differ by model.
The lower setting is useful when the room is already warm or when full output is unnecessary. It does not make the heater inherently more efficient at turning electricity into heat. It simply reduces the rate at which the unit consumes electricity and adds warmth.
How Does Wattage Vary by Space Heater Type?
Heating technology changes how warmth reaches the room, but it does not override the wattage on the label. A 1,500W infrared heater and a 1,500W ceramic heater draw the same amount of power while both elements are operating at full output. The difference is how quickly the heat feels noticeable and where it goes.
Space Heater Type
Typical Wattage Range
How It Heats
Best U.S. Home Use Case
Ceramic
200–1,500W
Heats ceramic plates; a fan circulates warm air.
Personal units for a desk or quick supplemental heat in bedrooms and offices.
Infrared (Radiant)
500–1,500W
Directly warms people and objects in its path.
Spot heating in sunrooms, garages, or a seating area where direct warmth matters.
Oil-Filled Radiator
600–1,500W
Heats sealed oil inside metal fins for quiet, steady warmth.
Bedrooms and other rooms where fan noise is unwelcome and slower heat is acceptable.
Fan-Forced (Coil)
750–1,500W
Blows air over a heated metal element.
Small rooms that need quick heat; bathroom use only when the model is approved for it.
Micathermic
750–1,500W
Combines radiant heat with air circulation through mica panels.
Apartments or rooms where a slim floor or approved wall-mounted design is useful.
Ceramic and fan-forced heaters usually make a cold room feel warmer sooner because they move heated air. Oil-filled radiators respond more slowly but continue releasing heat from their warm metal surfaces after the element cycles off. Infrared heaters work best when a person remains within the radiant path. None of these effects changes the basic kWh calculation.
EcoFlow DELTA 3800 Gen4 Portable Power StationEcoFlow DELTA 3800 Gen4 Portable Power Station
How Much Electricity Does a Space Heater Use?
To answer the question “how much energy does a space heater use,” combine its wattage with the time its heating element actually runs. Wattage is the rate at which the heater uses power. A utility bill records energy in kilowatt-hours, which combines that rate with time. If two heaters are both drawing 1,500W, they use the same electricity during each minute of active heating even if one is ceramic and the other is oil-filled.
The thermostat is what often separates rated use from actual use. A heater set to 1,500W may draw full power while the element is on, then very little when the thermostat switches the element off. A four-hour session therefore does not necessarily mean four continuous hours at maximum wattage.
How to Calculate Space Heater Energy Usage
Use the heater’s label rather than a wattage estimate whenever possible. Then apply this formula:
Energy used (kWh) = wattage × hours of use ÷ 1,000
For example, a 1,500W heater operating continuously for four hours uses 6 kWh:
1,500 × 4 ÷ 1,000 = 6 kWh
If the element operates for only half of that four-hour period because the thermostat cycles, the heater uses roughly half as much energy. The fan and controls may still draw a small amount, but the heating element accounts for most of the load.
For a more accurate home estimate, use a plug-in electricity monitor that is rated for the heater’s load and permitted by the heater manufacturer. Otherwise, check the utility’s hourly or daily usage information before and after a typical heating session while accounting for other appliances running at the same time.
Electricity Consumption Per Hour, Day, and Month
The table below shows continuous use at four common power settings. It assumes eight hours each day for 30 days, with no thermostat cycling. Real consumption will be lower whenever the heating element turns off.
Heater Power Setting
Energy Use Per Hour
Daily Usage (8 Hours)
Monthly Usage (30 Days)
400W (Personal Desk Unit)
0.4 kWh
3.2 kWh
96 kWh
750W (Low / Eco Mode)
0.75 kWh
6.0 kWh
180 kWh
1,000W (Medium Setting)
1.0 kWh
8.0 kWh
240 kWh
1,500W (Full High Setting)
1.5 kWh
12.0 kWh
360 kWh
If you are asking “do space heaters use a lot of electricity,” the monthly totals show why runtime matters. The monthly column illustrates why a portable heater can have a visible effect on a winter bill. At full output, one heater used on this schedule consumes 360 kWh. Running a second unit for the same hours doubles that energy use, even if the rest of the home remains at the same thermostat setting.
How Much Does It Cost to Run a Space Heater?
The U.S. Energy Information Administration’s November 2026 forecast places the 2026 annual average residential electricity price at about 18.2 cents per kWh. Rates vary substantially among states, utilities, and rate plans, so your own bill is the better source for a household calculation.
Find the line showing the energy charge in dollars or cents per kWh. Some bills also include delivery charges, riders, taxes, or tiered pricing that change with consumption. For a quick estimate, multiply the heater’s kWh by the rate that most closely reflects the additional electricity you will buy.
Hourly and Monthly Operating Costs
Using $0.182 per kWh, a 1,500W heater operating continuously costs approximately:
  • Per hour: $0.27
  • Per 8-hour workday or night: $2.18
  • Per month (8 hours daily for 30 days): $65.52
The calculation is straightforward: 1.5 kWh per hour multiplied by $0.182 equals $0.273. Over 240 hours in a 30-day month, the same heater uses 360 kWh.
Local rates can change the result dramatically. At $0.32 per kWh, 360 kWh costs $115.20. A household on a tiered or time-varying plan should use the rate that applies during the heater’s normal operating hours rather than a statewide average.
Thermostat cycling reduces space heater energy use, so actual costs may be lower than these continuous-use estimates.
What Affects the Cost of Running a Space Heater?
Two 1,500W heaters have the same maximum electrical draw, but their monthly use can differ because the rooms and operating habits are different:
  • Built-in thermostats and Eco modes: A thermostat can switch the heating element off after the room reaches the set temperature. Some Eco modes alternate wattage settings; others mainly adjust cycling. The savings depend on the controls, setpoint, room, and weather rather than a guaranteed percentage.
  • Room insulation and draftiness: Heat escapes faster through leaky windows, exterior doors, uninsulated walls, and open stairways. In a drafty room, the element stays on longer even though its wattage never changes.
  • Time-of-Use (TOU) utility rates: Some utilities charge more during designated peak periods, often in the afternoon or evening. The hours vary by provider and season. Moving discretionary heating outside those windows may reduce cost, but only when the applicable tariff rewards the shift.
Room size, ceiling height, outdoor temperature, sunlight, and heat from people or electronics also affect cycling. A small heater may be adequate at a desk yet run continuously when asked to heat an open basement.
EcoFlow TITAN 5000 PlusEcoFlow TITAN 5000 Plus
How Can You Reduce Space Heater Electricity Costs?
A space heater saves money only in the right use case. It can make sense when it warms one occupied room and allows the central heating setpoint to be lowered elsewhere. If the furnace continues heating the entire house at the same setting, the portable unit becomes an additional load rather than a replacement for other heating.
A home battery can shift when grid electricity is purchased, but it does not reduce the heater’s energy use for the same output and runtime.
The most effective changes are practical: heat less space, limit drafts, choose a reasonable setpoint, and turn the unit off when the room is empty. Safety should not be traded for a lower bill. Keep the heater at least three feet from bedding, curtains, furniture, papers, and other combustible material, and plug it directly into a wall outlet rather than an extension cord or power strip.
Choose the Right Space Heater Wattage
The familiar rule of 10 watts per square foot is a rough starting point, not a sizing standard. It assumes an ordinary ceiling height and reasonably typical insulation. Climate, window area, air leakage, exterior walls, and whether the room is open to adjacent spaces can change the result substantially.
Under that rule, a 150-square-foot bedroom points toward a 1,500W heater. A 400W personal model is intended for a much smaller comfort zone, such as the area beneath a desk. Switching from 1,500W to 400W reduces maximum draw by about 73%, but it works only when localized warmth meets the need.
Do not buy a higher-wattage portable heater for a standard household outlet in an attempt to warm a larger room. If 1,500W cannot keep up, the better answer may be air sealing, central heating, a permanently installed system, or professional evaluation of the room’s heat loss.
Comparing electric heating options can help when one portable heater cannot meet the room’s heating needs.
Reduce Heat Loss and Heating Runtime
Small changes around the room can shorten the time the heating element remains on:
  • Close the door and seal drafts: Keep conditioned air in the occupied room. Weatherstripping, a door sweep, or properly installed window film can reduce obvious leakage without blocking required ventilation.
  • Use a programmable timer or smart thermostat: Use only controls allowed by the heater manufacturer. Use permitted controls only while someone is present and awake; do not schedule unattended preheating. Portable heaters should not run unattended or while people are sleeping.
  • Dress for the season indoors: Warm socks and another light layer may make a lower room setpoint comfortable. The savings from each degree vary with the building, weather, and heating system, so a fixed percentage should not be promised.
Open curtains when direct sun is warming the room and close them after sunset if they reduce heat loss. Keep furniture and drapes away from the heater so warm air can circulate and the required clearance remains open.
Use Portable Power Stations for Flexible Heating
A space heater can be useful in a detached shed or during an outage, but it needs a power source that can handle its high wattage. A portable power station offers stored electricity for these situations, though runtime depends on the heater’s draw and the station’s capacity.
For example, the EcoFlow DELTA 3800 Gen4 Portable Power Station starts with 4 kWh of base storage capacity. It can be expanded up to 12 kWh, letting households scale their backup reserves to match real winter demand. Its 3,600W rated output easily handles demanding household appliances. Check the space heater’s wattage label beforehand to confirm compatibility and estimate runtime.
1. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery.
Because resistance heat consumes stored energy quickly, prioritize the loads that matter most during an outage. Lighting, communications, refrigeration, and heating-system controls may need to share the same reserve.
Integrate Home Batteries with Smart Energy Management
For households that regularly use high-draw appliances, a home battery can store rooftop solar production or shift some grid consumption away from high-price periods. The financial value depends on the utility plan. Charging a battery from the grid and using that energy later also involves conversion losses, so rate differences must be large enough to make the shift worthwhile.
The EcoFlow TITAN 5000 Plus delivers 7,200W of rated output, enough to run space heaters alongside other household loads, and works with EcoFlow OASIS 3.0. OASIS 3.0 uses household usage patterns, solar forecasts, and utility rates to schedule charging and discharging. Actual savings depend on your tariff, solar generation, and energy use.
1. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. 2. 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use.
Energy management can also help preserve reserve power for an outage or prevent several large loads from operating together. The battery’s output rating and stored capacity answer different questions: output determines what can run at once, while capacity influences how long those loads can continue.
A standard full-size space heater uses 1,500 watts on high. At the 2026 U.S. residential benchmark of about 18.2 cents per kWh, continuous operation costs roughly $0.27 per hour. Eight hours a day for 30 days would use 360 kWh and cost about $65.52 before any additional bill adjustments.
The most economical use is usually targeted heating in one occupied room while reducing heat elsewhere. Match the wattage to the task, limit drafts, use the thermostat thoughtfully, and keep the heater on a suitable wall outlet with clear space around it. If backup power or a home battery is part of the plan, compare both output and stored capacity so the high draw of resistance heat does not crowd out more important household loads.
Do Space Heaters Run Up Your Electric Bill?
Yes, running a 1,500W space heater for several hours every day can add $50 to $115 a month to your electric bill, depending on how long you use it and your local utility rate. However, using a space heater to warm an occupied room while lowering your whole-home heating system’s thermostat by 7°F to 10°F for 8 hours a day may help reduce energy costs. According to the U.S. Department of Energy (DOE), this thermostat adjustment can save up to 10% annually on heating and cooling costs. Actual savings depend on how much energy your central heating system saves compared with the space heater’s added electricity use.
Is It Cheaper to Turn the Heat up or Use a Space Heater?
Using a space heater is cheaper when you only need to warm one or two occupied rooms, whereas central heating is more economical if you are trying to heat the entire house. If your home uses a natural gas furnace or a high-efficiency heat pump, central heating delivers more heat per dollar overall—so a plug-in electric heater only saves money when it allows you to keep the rest of the house noticeably cooler.
Why Does My Space Heater Use So Much Electricity?
Space heaters rely on electric resistance heating, which requires a continuous 1,500-watt flow of electricity to generate steady heat—nearly 15 times more power than a 55-inch LED TV and comparable to running a hair dryer or microwave nonstop. Because electrical resistance cannot multiply heat energy the way a heat pump does, every unit of warmth requires an equal unit of electricity.
Can I Sleep with My Space Heater All Night?
Safety experts and the National Fire Protection Association (NFPA) strongly recommend turning portable space heaters off before you go to sleep. If you need overnight warmth in a cold bedroom, choose a UL- or ETL-listed oil-filled radiator with a built-in digital thermostat, tip-over shutoff, and overheat protection, plug it directly into the wall outlet, and place it at least three feet away from blankets, curtains, and furniture.
Home Backup
